查看: 646|回复: 8
电阻电容电感测量仪源码
发表于 2017-3-5 15:22:49 | 显示全部楼层 |阅读模式
#include"stc15.h"
#include "math.h"
typedef unsigned char  uchar;
typedef unsigned short ushort;
typedef unsigned int   uint;
//定义变量
//sbit frequence_flag= P3^5  ;          // 脉冲接收信号T
//#define DataPort P2  //LCD1602数据端口
sbit    LcdRs=P4^5;        //LCD1602命令端口
sbit    LcdRw=P4^4;        //LCD1602命令端口
sbit    LcdEn=P4^2;        //LCD1602命令端口
uchar dis_tab1[]={"Welcome         "};        //第一行显示数组
uchar dis_tab2[]={"                "};        //第二行显示数组
sbit R1_KEY=P1^0;
sbit R2_KEY=P1^1;
sbit C1_KEY=P1^2;
sbit C2_KEY=P1^3;
sbit L_KEY=P1^4;
sbit auto_R_KEY=P3^6;
sbit auto_C_KEY=P3^3;
sbit AD_KEY=P3^7;
sbit A0=P5^4;
sbit A1=P5^5;
sbit EN1=P4^1;
sbit EN2=P3^4 ;
sbit R_relay=P3^0;
sbit C_relay=P3^1;
sbit L_relay=P3^2;
uint frequence=0,n,ad_conv;
float meaturement, meaturement_1=0.0,R_up_limit=19000,C_up_limit=90,R_low_limit=19,C_low_limit=0.09;
uint i,j,R_flag=0,C_flag=0;
uchar adc_dat_hi,adc_dat_low,status;
float sum=0,addata=0;
//函数声明
void delay(uint z);
void write_date(uchar date);
void write_com(uchar date);
void init_1602(void);
void LCD1602_CleanScans(void);
void LCD1602_SetPos(uchar x,uchar y);
void LCD1602_DisplayString(uchar *s);
void decimal_process(float date);
void integer_process(uint date);
void timer_init(void);
uchar key_scan(void);
void R1_CD4052(void);
void R2_CD4052(void);
void C1_CD4052(void);
void C2_CD4052(void);
void L_CD4052(void);
//延时
void delay(uint z)
    uint a,b;
    for(a=0; a<z; a++)
           for(b=0; b<120; b++);
//发送单个字符
{   LcdEn=0;
    LcdRs=1;
    LcdRw=0;
    P2=date;
    LcdEn=1;
    delay(5);
    LcdEn=0;
//发送命令
{   LcdEn=0;
    LcdRs=0;
    LcdRw=0;
    P2=date;
    LcdEn=1;
    delay(5);
    LcdEn=0;
//初始化:dis_tab1和dis_tab2是初始化的内容
void init_1602()
   unsigned char i=0;
   write_com(0x38);
   write_com(0x0c);
   write_com(0x06);
   write_com(0x01);               //清屏
   write_com(0x80);               //第一行坐标
   for (i=0;i<16;i++)
      write_date(dis_tab1);
   write_com(0x80+0x40);        //第二行坐标
   for (i=0;i<16;i++)
      write_date(dis_tab2);
//清屏
void LCD1602_CleanScans()
    write_com(0x01);
//void key_scan()
//        write_com(0x80+0x40);
//        write_date(' ');
//        write_date('r');
//        write_date('u');
//        write_date('n');
//设定显示位置
    uchar pos;
    if(x == 0)
            x = 0x80;
    else if(x == 1)
            x = 0x80+0x40;
    pos = x + y;
    write_com(pos);
//显示字符串   LCD1602_DisplayString("1234")
    uchar  i = 0;
    while(*s != 0)
        write_date(*s);
        s++;
        delay(5);
//5位整数3位小数十进制转字符
   if((date/10000>1)||(date/10000==1))
     dis_tab2[2]=((int)date)%100000/10000+0x30;
   else
     dis_tab2[2]=' ';
   if((date/1000>1)||(date/1000==1))
     dis_tab2[3]=((int)date)%10000/1000+0x30;
   else
     dis_tab2[3]=' ';
   if((date/100>1)||(date/100==1))
     dis_tab2[4]=((int)date)%1000/100+0x30;
   else
     dis_tab2[4]=' ';
   if((date/10>1)||(date/10==1))
     dis_tab2[5]=((int)date)%100/10+0x30;
   else
     dis_tab2[5]=' ';
   if((date>1)||(date==1))
     dis_tab2[6]=((int)date)%10+0x30;
   else
     dis_tab2[6]=0x30;
    dis_tab2[7]='.';
   if((date>0.1)||(date==0.1))
     dis_tab2[8]=((long int)(date*10))%10+0x30;
   else
     dis_tab2[8]=0x30;
   if((date>0.01)||(date==0.01))
     dis_tab2[9]=((long int)(date*100))%10+0x30;
   else
     dis_tab2[9]=0x30;
   if((date>0.001)||(date==0.001))
     dis_tab2[10]=((long int)(date*1000))%10+0x30;
   else
     dis_tab2[10]=0x30;
//5位整数10进制转字符
//   if(data1/1000000>0)
//     dis_tab2[0]=data1/1000000+0x30;
//   else
//     dis_tab2[0]=' ';
//   if(data1/100000>0)
//     dis_tab2[1]=data1%1000000/100000+0x30;
//   else
//     dis_tab2[1]=' ';
   if(date/10000>0)
     dis_tab1[2]=date%100000/10000+0x30;
   else
     dis_tab1[2]=' ';
   if(date/1000>0)
     dis_tab1[3]=date%10000/1000+0x30;
   else
     dis_tab1[3]=' ';
   if(date/100>0)
     dis_tab1[4]=date%1000/100+0x30;
   else
     dis_tab1[4]=' ';
   if(date/10>0)
     dis_tab1[5]=date%100/10+0x30;
   else
     dis_tab1[5]=' ';
     dis_tab1[6]=date%10+0x30;
//定时器1和定时器0初始化
void timer_init()
    TMOD=0x51;           //定时器1工作在计数器方式1,定时器0工作在定时器方式1
    TL0=0x00;
    TH0=0x4C;           //50ms
    TL1=0X00;
    TH1=0X00;           //从0开始记数
    i=20;              //计数变量附初值
    ET0=1;              //允许T0中端
    EA=1;
    TR0=1;               //启动T0
    TR1=1;              //启动T1计数
//AD采样
void ADC_init()
    ADC_CONTR |= 0X80;
    for(j = 0;j<10000;j++);
    P1ASF = 0X20;
    ADC_CONTR = 0XE5;
void get_adcDat()
    for(n=0;n<6;n++)
       ADC_CONTR |= 0X08;
       for(j = 0;j<2000;j++);
       status = 0;
       while(status == 0)
        status = ADC_CONTR&0X10;
       ADC_CONTR &= 0XE7;
          adc_dat_hi = ADC_RES;
       adc_dat_low=ADC_RESL&0X03;
       ad_conv=adc_dat_hi;
       ad_conv=(ad_conv<<2)+adc_dat_low;
       addata=(float)ad_conv;
       addata=addata/256.0;
       addata=addata*1.25;
       sum+=addata;
    n=0;
    addata=sum/6.0;
    sum=0;
//按键选择
    if(!R1_KEY||!R2_KEY||!C1_KEY||!C2_KEY||!L_KEY||!auto_R_KEY||!auto_C_KEY||!AD_KEY)
        delay(10);
        if(!R1_KEY)            return 1;
        if(!R2_KEY)         return 2;
        if(!C1_KEY)         return 3;
        if(!C2_KEY)         return 4;
        if(!L_KEY)          return 5;
        if(!auto_R_KEY)     return 6;
        if(!auto_C_KEY)     return 7;
        if(!AD_KEY)            return 8;
    return 0;
//继电器和CD4052模拟开关的选择
     A0=0;
     A1=1;
     EN1=0;
    EN2=1;
     R_relay=1;
     C_relay=0;
     L_relay=0;
     A0=0;
     A1=0;
     EN1=0;
    EN2=1;
     R_relay=1;
     C_relay=0;
     L_relay=0;
     A0=1;
     A1=1;
     EN1=0;
    EN2=1;
     R_relay=0;
     C_relay=1;
     L_relay=0;
     A0=1;
     A1=0;
     EN1=0;
    EN2=1;
     R_relay=0;
     C_relay=1;
     L_relay=0;
void L_CD4052(void)
     A0=0;
     A1=0;
     EN1=1;
    EN2=0;
     R_relay=0;
     C_relay=0;
     L_relay=1;
void VD_CD4052(void)
     A0=0;
     A1=0;
     EN1=1;
    EN2=1;
     R_relay=0;
     C_relay=0;
     L_relay=0;
void main()
    init_1602();
    timer_init();
    ADC_init();
    while(1)
        switch(key_scan())
            case 1:
               LCD1602_SetPos(0,0);
               LCD1602_DisplayString("R:     ");
               R1_CD4052();
               if(frequence==0)
                    meaturement=0;
               else
               meaturement=((float)frequence)+1.0;               //补偿
               meaturement=10.0/(meaturement*0.693147*0.000001);
               meaturement=meaturement/21.0-420.476;               //频率转电阻值
               meaturement=meaturement-756;
//               if(meaturement<1800)
//               meaturement=meaturement-790;
//               else
//                meaturement=meaturement-840;
               dis_tab2[11]=0xF4;
               dis_tab2[12]=' ';
               break;
            case 2:
               R2_CD4052();
               if(frequence==0)
                    meaturement=0;
               else
               meaturement=((float)frequence);
               meaturement=1.0/(meaturement*0.7*0.00001)-20.0;
               meaturement=meaturement/2.0;
               if(meaturement>=380.0)
                  meaturement=0.7856*meaturement;
               else
               if(meaturement<380.0&meaturement>=35.0)
                  meaturement=0.812*meaturement;
               else
                meaturement=0.79*meaturement;
               if(meaturement<=310)
                meaturement=(meaturement-1.2436)/1.0196;
               else
               meaturement=(meaturement+92.642)/1.213;                  // y = 1.213x - 92.642
               meaturement=0.98*meaturement;
               dis_tab2[11]='K';
               dis_tab2[12]=0xF4;                                       //kΩ
               break;
            case 3:
               LCD1602_DisplayString("C:     ");
               C1_CD4052();
               if(frequence==0)
                    meaturement=0;
               else
                meaturement=(float)frequence*0.965;
                 meaturement=1.0/(meaturement*0.7*0.0003);
                if(meaturement<7)
                meaturement=meaturement*0.95-0.04;
               dis_tab2[11]='n';
               dis_tab2[12]='F';                                       //nf
               break;
            case 4:
               C2_CD4052();
               if(frequence==0)
                    meaturement=0;
               else
                    if(meaturement>=23)
                    meaturement=((float)frequence)*0.948;
                    else
                    meaturement=((float)frequence)*0.943;
                    meaturement=1.0/(meaturement*0.7*0.03);
               dis_tab2[11]=0xE4;
               dis_tab2[12]='F';                           // uF
               break;
            case 5:
               LCD1602_DisplayString("L:     ");
               L_CD4052();
               if(frequence==0)
                    meaturement=0;
               else
                    if(meaturement>2200)
                         meaturement=2*meaturement/3;
                    else
                    if(meaturement>1700)
                         meaturement=0.585*meaturement;
                    else
                         meaturement=meaturement*6.5/12;
                    meaturement=1000.0/(meaturement*0.001*meaturement*0.2*0.001*3.14159*3.14159);
//               if(meaturement>160)
//               meaturement_1=meaturement;
//               meaturement=meaturement/100-0.95;
//               meaturement=pow(20,meaturement)+meaturement_1;
//               else
//               meaturement=meaturement-8;
               dis_tab2[11]='m';
               dis_tab2[12]='H';                                       //mH
               break;
            case 6:
               if(R_flag==0)                   //Ω档
                   R1_CD4052();
                   if(frequence==0)
                     meaturement=0;
                   else
                   if(meaturement>R_up_limit)
                       R_flag=1;
                   dis_tab2[11]=0xF4;
                   dis_tab2[12]=' ';
                 if(R_flag==1)                   //KΩ档
                   R2_CD4052();
                   if(frequence==0)
                    meaturement=0;
                   else
                       else
                       else
                       else
                   if(meaturement<R_low_limit)
                       R_flag=0;
                   dis_tab2[11]='K';
                   dis_tab2[12]=0xF4;
               break;
            case 7:
               if(C_flag==0)                   //nf档
                   C1_CD4052();
                   if(frequence==0)
                    meaturement=0;
                   else
                    if(meaturement<7)
                   if(meaturement>C_up_limit)
                       C_flag=1;
                   dis_tab2[11]='n';
                   dis_tab2[12]='F';
                 if(C_flag==1)                   //uf档
                   C2_CD4052();
                   if(frequence==0)
                    meaturement=0;
                   else
                    if(meaturement>=23)
                    else
                   if(meaturement<C_low_limit)
                       C_flag=0;
                   dis_tab2[11]=0xE4;
                   dis_tab2[12]='F';
               break;
           case 8:
               LCD1602_DisplayString("V:     ");
               VD_CD4052();
               get_adcDat();
               meaturement=addata;
               dis_tab2[11]='V';
//        integer_process(frequence);
//        LCD1602_SetPos(0,0);
//        LCD1602_DisplayString(dis_tab1);
        decimal_process(meaturement);
        LCD1602_SetPos(1,0);
        LCD1602_DisplayString(dis_tab2);
void T0_ISR(void) interrupt 1
   i--;
   if(i==0)
      TR1=0;      //关T1计数
      frequence=TH1;
      frequence=(frequence<<8)+TL1;
      i=20;
      TH1=0;
      TL1=0;
      TR1=1;       //开T1计数
   TL0=0x00;
   TH0=0x4C;
发表于 2017-3-5 19:09:23 | 显示全部楼层
社区居民忠实会员社区劳模最爱沙发终身成就奖优秀斑竹奖
发表于 2017-3-5 20:27:44 | 显示全部楼层
终身成就奖特殊贡献奖优秀斑竹奖
发表于 2017-3-5 21:19:30 | 显示全部楼层
社区居民忠实会员社区劳模最爱沙发优秀斑竹奖终身成就奖
发表于 2017-3-6 08:34:30 | 显示全部楼层
谢谢楼主分享,虽然没看懂
广告位出租,价格可以商量。
发表于 2017-3-6 08:38:20 | 显示全部楼层
社区居民终身成就奖原创先锋奖
发表于 2017-3-6 08:52:42 | 显示全部楼层
PADS高级班留级2期
发表于 2017-3-6 08:56:42 | 显示全部楼层
发表于 2017-3-6 09:47:01 | 显示全部楼层
请问有木有原理图哦,这个显示用的1602吗,看程序里面有类似的,谢谢
