查看: 940|回复: 2
[技术文章] mstar安卓电视方案kernel控制GPIO的方法
发表于 2017-3-20 00:16:28 | 显示全部楼层 |阅读模式
关于kernel控制GPIO的方法往往比较复杂,这里介绍一种在mstar平台实际写过的一种简单方法。
Kernel是往往没有现成的GPIO控制接口,所以得自己造。
这里以在kernel控制PAD_GPIO_PM1,PAD_GPIO_PM5这两个IO口为例。例子中出现的寄存器要在你所用平台的CHIP资料上找。
#if defined(CONFIG_ARM) || defined(CONFIG_MIPS)
#define REG_MIPS_BASE               0xFD000000      //Use 8 bit addressing
#elif defined(CONFIG_ARM64)
extern ptrdiff_t mstar_pm_base;
#define REG_MIPS_BASE           (mstar_pm_base)
#endif
#define MHal_GPIO_REG(addr)         (*(volatile U8*)(REG_MIPS_BASE + (((addr) & ~1) << 1) + (addr & 1)))
#define PAD_GPIO_PM1 11
#define PAD_GPIO_PM1_ADDR  0x0f02UL
#define PAD_GPIO_PM1_OEN BIT0
#define PAD_GPIO_PM1_OUT BIT1
#define PAD_GPIO_PM1_IN BIT2
#define PAD_GPIO_PM5 15
#define PAD_GPIO_PM5_ADDR  0x0f0AUL
#define PAD_GPIO_PM5_OEN BIT0
#define PAD_GPIO_PM5_OUT BIT1
#define PAD_GPIO_PM5_IN BIT2
void GPIO_PM1_Set_High()
        MHal_GPIO_REG(PAD_GPIO_PM1_ADDR) &= ~PAD_GPIO_PM1_OEN;
        MHal_GPIO_REG(PAD_GPIO_PM1_ADDR) |= PAD_GPIO_PM1_OUT;
void GPIO_PM1_Set_Low()
        MHal_GPIO_REG(PAD_GPIO_PM1_ADDR) &= ~PAD_GPIO_PM1_OUT;
void GPIO_PM5_Set_High()
        MHal_GPIO_REG(PAD_GPIO_PM5_ADDR) &= ~PAD_GPIO_PM1_OEN;
        MHal_GPIO_REG(PAD_GPIO_PM5_ADDR) |= PAD_GPIO_PM1_OUT;
void GPIO_PM5_Set_Low()
        MHal_GPIO_REG(PAD_GPIO_PM5_ADDR) &= ~PAD_GPIO_PM1_OUT;
社区居民忠实会员社区劳模特殊贡献奖最爱沙发终身成就奖优秀斑竹奖原创先锋奖
发表于 2017-3-20 08:49:32 | 显示全部楼层
发表于 2017-3-20 09:20:48 | 显示全部楼层
