查看: 12900|回复: 41
[PADS9.5以下] amlogic S812 +AP62X2/6354/6356+RN5T618M+GL852G+RTL8211F-CG PCB和原理图
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2017-3-29 22:54:23 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    NamePart TypePCB DecalValue
    1J1DC-05-06DC-0501DC-0501
    1J2P6_6CN-2P00-9PA2001WV-11P
    1L4INDUCTORS_POWER(SMD)L50504.7uH_2A_DCR?ü70mohm
    1L5INDUCTOR_POWERL-50501uH_3A_DCR25mohm
    1L9INDUCTOR_POWERL-50501uH_3A_DCR25mohm
    1L10INDUCTOR_POWERL-50501uH_3A_DCR25mohm
    1Q4MOSFETP_21SOT-23WPM2015
    1Q5T_NPNSOT-23PMBT3904
    1R4RES-VR0805NC/0R
    3U2DDR3_96P_16B_2CEBGA96-0P8MMH5TQ4G63AFR-PBC
    3U3DDR3_96P_16B_2CEBGA96-0P8MMH5TQ4G63AFR-PBC
    3U4DDR3_96P_16B_2CEBGA96-0P8MMH5TQ4G63AFR-PBC
    3U5DDR3_96P_16B_2CEBGA96-0P8MMH5TQ4G63AFR-PBC
    4TP4T_POINT_R_1TP30DATA_STROBE
    4U1MX25L3206ESOIC-8-150MILNC/MX25L1606EZNI-12G
    4U5NAND-FLASH-TSOP48TSOP-48NC/29F32G08CBACA
    4U7EMMC_V50BGA169-INANDSDIN7DP2-8G
    6J1J-TF-CARD-PUSHTF-CARD-PUSHTFWF1-EBF1-1X0X
    6SW1BUTTON_4PIN_BSW-KFC-55Update_switch
    7C8CAP_NP_6C04020.1uF/nc
    7C21CAPNPC060310uF_6.3V/nc
    7Q1MOSFETP_21SOT-23WPM2015/nc
    7Q2T_NPNSOT-23PMBT3904/nc
    7R14RESISTOR_2R0402470K/nc
    7R17RESISTOR_2R040247K/nc
    7R20RESISTOR_2R04020R/nc
    7R21RESISTOR_2R0402100K/nc
    7U3UM02BSUM02BSRTL8188EUS/nc
    8D1TVS_DIODEESD0402AZ5325-01F
    8D2TVS_DIODEESD0402AZ5325-01F
    8D3TVS_DIODEESD0402AZ5325-01F
    8D4TVS_DIODEESD0402AZ5325-01F
    8D5TVS_DIODEESD0402AZ5325-01F
    8D6TVS_DIODEESD0402AZ5325-01F
    8D9TVS_DIODEESD0402AZ5325-01F
    8D10TVS_DIODEESD0402AZ5325-01F
    8F1PPTC_FUSEFUSE-0805FUSE-500mA
    8F3PPTC_FUSEFUSE-0805FUSE-500mA
    8F4PPTC_FUSEFUSE-0805FUSE-500mA
    8F5PPTC_FUSEFUSE-0805FUSE-500mA
    8F6PPTC_FUSEFUSE-0805FUSE-1000mA
    8FB1FERRITE_BEAD_2FB0603100MHz220ohm
    8FB4FERRITE_BEAD_2FB0603100MHz220ohm
    8L1L-CM-IND_0ACM2012-2PNC
    8L2L-CM-IND_0ACM2012-2PNC
    8L3L-CM-IND_0ACM2012-2PNC
    8L5L-CM-IND_0ACM2012-2PNC
    8R1RES-V_1R04020R
    8R2RES-V_1R04020R
    8R3RES-V_2R0402680R_1%
    8R4RES-V_2R040210K
    8R5RES-V_2R040210K
    8R7RES-V_1R04020R
    8R15RES-V_2R040210K
    8R16RES-V_2R040210K
    8R18RES-V_2R0402100K
    8R19RES-V_1R04020R
    8R20RES-V_1R04020R
    8R21RES-V_1R04020R
    8R22RES-V_1R04020R
    8R23RES-V_1R04020R
    8R24RES-V_1R04020R
    8R25RES-V_2R040210K
    8R26RES-V_2R040210K
    8R27RES-V_2R040210K
    8R28RES-V_2R0402680R_1%
    8R29RES-V_2R040210K
    8R30RES-V_2R0402100K
    8U1GL850G_0SOP65P780X200-28NGL852G
    8U4GL850G_0SOP65P780X200-28NGL852G
    8Y1CRYSTAL-4PY-SMD4P322512MHz_20ppm
    8Y4CRYSTAL-4PY-SMD4P322512MHz_20ppm
    9C1CAPNPC04020.1uF
    9C2CAPNPC04020.1uF
    9C3CAPNPC04021uF_6.3V
    9C4CAPNPC04020.1uF
    9C5CAPNPC04021uF_6.3V
    9C7CAPNPC04020.1uF
    9C8CAPNPC04021nF
    9C9CAPNPC04020.1uF
    9C10CAP_NP_6C04021uF_6.3V
    9C11CAPNPC060310uF_6.3V
    9D3TVS_DIODEESD0402AZ5725-01F
    9D4TVS_DIODEESD0402AZ5725-01F
    9D5TVS_DIODEESD0402AZ5725-01F
    9FB1FERRITE_BEADFB0402100MHz220ohm
    9J1J-HDMI-TYPE-A-19P_0HDMI-19P-SMDZX-HDMI-07A
    9Q1MOSFETP_21SOT-23WPM2015
    9Q2MOSFETP_4SOT-23WNM6001
    9Q3MOSFETP_4SOT-23WNM6001
    9Q5MOSFETP_4SOT-23WNM6001
    9R1RESISTOR_2R0402100K
    9R2RESISTOR_2R040247K
    9R3RESISTOR_2R040247K
    9R4RESISTOR_2R04023K_1%
    9R5RESISTOR_2R0402562R_1%
    9R6RESISTOR_2R04022.2K
    9R7RESISTOR_2R040247K
    9R10RESISTOR_2R04024.7K
    9R11RR040247K
    9R13RESISTOR_2R04022.2K
    AC9CAPNPC060310uF_6.3V
    AC11CAPNPC04021uF_6.3V
    AC17CAPNPC04021uF_6.3V
    AC28CAP_NP_6C0402NC/33pF
    AC29CAP_NP_6C0402NC/0.1uF
    AC32CAP_NP_6C04020.1uF
    AJ3GQ-08_0SPDIFSPDIF-JYT
    AJ4AV1-8_0.4-50JAV1-84-3BNC/AV1-8.4-3B
    AR28RES-V_2R0402NC/100R
    AR29RES-V_2R0402NC/75R
    AR30RES-V_2R0402150R_1%
    C121CAPNPC060310uF_6.3V
    C122CAPNPC04020.1uF
    C123CAPNP_DUP1_1C0402NP
    C124CAPNP_DUP1_1C0402NP
    C125CAPNP_DUP1_1C040210pF
    C126CAPNP_DUP1_1C040210pF
    C127CAPNPC040210pF_NPO
    C128CAPNP_DUP1_1C040227pF
    C129CAPNP_DUP1_1C040227pF
    C130CAPNP_DUP1_1C06034.7uF
    C131CAPNPC04020.1uF
    C132CAPNP_DUP1_1C06034.7uF
    C133CAPNP_DUP1_1C06034.7uF
    CN1USB-2A-03USB-2A-03USB-2A-03
    CN2USB-2A-03USB-2A-03USB-2A-03
    J2ANT-WIFIJ-MS-156ACA-5036-A3-CC-S
    J6ANT-WIFIJ-MS-156ACA-5036-A3-CC-S
    L1INDUCTORL30304.7uH
    PU2RTL8211F_FD_FI_FDIQFN40-PT04-5X5MMRTL8211F-CG
    PY1SMD_CRYSTAL_10XT-SMD4P322525MHz_20ppm_CL20pF
    RJ1RJ45_1000M_MAGNETICS_LEDRJ45_1000M_FACE-UPRJ45_1000M_FACE-UP
    RN1RESISTOR_2R040210K
    RN2RESISTOR_2R040210K
    RN4RESISTOR_2R040210K
    RN5RESISTOR_2R040210K
    U1AML-S802BGA531_0P65S812
    U2UM02BSUM02BSRTL8812
    U8EUP3412_1TDFN-10EP3415 1%
    U3024C02A_1IC_SOIC_8PINAT24C02
    U38ALPU-MPSOT23-6ALPU-MP
    U39AP6493_V10_5AP62X2AP62X2/6354/6356
    U814STMEF214P101MFRSTMEF214P101MFRSTMEF214P101MFR
    U815STMEF214P101MFRSTMEF214P101MFRSTMEF214P101MFR
    Y1CRYSTAL_0Y-SMD4P322537.4MHz
    重要提示:PCB作品文件展下载说明
    17万
    管理员
     楼主| 发表于 2017-3-29 22:57:56 | 显示全部楼层
    S812_DSN.7z (406 KB, 下载次数: 113)
    S812_PCB.7z (979 KB, 下载次数: 85)
    已经量产的文件。
    配套按键板,生产资料等.7z (5.38 MB, 下载次数: 41)
    发表于 2017-3-29 23:17:13 | 显示全部楼层
    沙发,第一时间顶你来了
    前天 11:17
  • 签到天数: 54 天
    1元学习Allegro(1期)
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模优秀斑竹奖最爱沙发社区明星宣传大使奖
    发表于 2017-3-30 00:18:09 | 显示全部楼层
    不错的量产作品,S812。好像高一级的是S912
    社区居民忠实会员终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2017-3-30 01:31:57 | 显示全部楼层
    终身成就奖社区居民忠实会员灌水天才奖新人进步奖幽默大师奖贴图大师奖优秀斑竹奖宣传大使奖金点子奖社区明星
    发表于 2017-3-30 07:59:54 | 显示全部楼层
    发表于 2017-3-30 08:05:53 | 显示全部楼层
    发表于 2017-3-30 08:14:33 | 显示全部楼层
    2 小时前
    1元学习Allegro(230718)
    网络监控器IPCAMERA,视
    终身成就奖社区居民特殊贡献奖
    发表于 2017-3-30 08:29:33 | 显示全部楼层
    发表于 2017-3-30 08:30:35 | 显示全部楼层
