Name | PCB Decal | Value | Part Type |
ANT7200 | HMT-TX001-018 | | CON-SPRING-T105-11F2R |
ANT7201 | HMT-TX001-018 | | CON-SPRING-T105-11F2R |
D4100 | SOD_FL_2412_H070 | | DIODE-SCHOTTKY-WSB5543W-2/TR |
D5100 | DBL-3020WEDT-08H | YELLOW | DIODE-LED-YELLOW-LTW-M670ZVS-BT |
D6100 | SOD-323-PRISEMI | PTVSHC3D4V5B | ESD-PRISEMI-PTVSHC3D4V5B |
J10 | FH26-25S-0.3SHW | | CON-ZIF-FH26-25S-0.3SHW |
J0402 | 818000500 | | CON-RF-818000500 |
J0600 | ECT818000291_SPEC_X2 | | ECT818000291_SPEC_X2 |
J3100 | CON-PH19-3B05F35A | | CON-EAR-PH19-3B05F35A |
J4107 | FH34S-6S-0.5SH | | CON-FPC-196243-06041-3 |
J5100 | OK-03NF024-04 | | CON-BTB-OK-03NF024-04 |
J5101 | OK-03NF024-04 | | CON-BTB-OK-03NF024-04 |
J6100 | B55-AB03F15A | | B55-AB03F15A |
J6200 | OK-03NF024-04 | | CON-BTB-OK-03NF024-04 |
J6300 | FH34S-6S-0.5SH | | CON-FPC-196243-06041-3 |
J6401 | S83-0B16F14A | | SOCKET-S83-0B16F14A |
J6402 | CAF99-06133-0102-CUS-A | | SIM-SOCKET-SIM-UAF95-05164-S107-A |
L0300 | IND-POWER-WPN2016 | 2.2uH | IND-POWER-2.2UH-WPN201610H2R2MT |
L0301 | IND_POWER_WPN252010 | 0.47uH | IND-POWER-0.47UH-WPN2520 |
L0302 | IND-POWER-WPN2016 | 2.2uH | IND-POWER-2.2UH-WPN201610H2R2MT |
L0303 | IND-POWER-WPN2016 | 0.68uH | IND-POWER-0.68UH-WPN201610HR68MT |
L0304 | IND-POWER-WPN2016 | 2.2uH(NF) | IND-POWER-2.2UH-WPN201610H2R2MT |
L0305 | IND-POWER-WPN2016 | 2.2uH(NF) | IND-POWER-2.2UH-WPN201610H2R2MT |
L0400 | SL0201 | 22nH | IND-CER-22NH-5%-0201-LQP03TN-02 |
L0401 | SL0201 | 10nH | IND-CER-10NH-0.3-0201-SDCL0603Q-02 |
L0402 | SR0201 | 0 | RES-0-0201 |
L0403 | SL0201 | 2.4nH(NF) | IND-CER-2.4NH-0.3-0201-SDCL0603Q-02B01 |
L0404 | SL0201 | 2.2nH | IND-CER-2.2NH-0.3-0201-SDCL0603Q-02B01 |
L0405 | SL0201 | 5.1nH | IND-CER-5.1NH-0.3-0201-SDCL0603Q-02 |
L0409 | SL0201 | 18nH | IND-CER-18NH-3%-0201-LQP03TN-00 |
L0410 | IND-NF-0201 | NF | IND-NF-0201 |
L0411 | SL0201 | 5.1nH | IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01 |
L0412 | SC0201 | 1.0pF | CAP-1PF-0201 |
L0417 | SL0201 | 5.6nH(NF) | IND-CER-5.6NH-3%-0201-LQP03TN-00 |
L0418 | IND-NF-0201 | NF | IND-NF-0201 |
L0419 | IND-NF-0201 | NF | IND-NF-0201 |
L0421 | SL0201 | 10nH | IND-CER-10NH-0.3-0201-SDCL0603Q-02 |
L0423 | IND-NF-0201 | NF | IND-NF-0201 |
L0424 | IND-NF-0201 | NF | IND-NF-0201 |
L0425 | SL0201 | 5.1nH(NF) | IND-CER-5.1NH-0.3-0201-SDCL0603Q-02 |
L0468 | SL0201 | 3.3nH | IND-CER-3.3NH-0.1-0201-LQP03TN-00 |
L4100 | IND-POWER-SPH2520 | 10uH | IND-POWER-10UH-SPH252012H100MT |
L7201 | SL0201 | 2.4nH(NF) | IND-CER-2.4NH-0.3-0201-SDCL0603Q-02B01 |
L7208 | SL0402 | 120nH | IND-CER-120NH-0402 |
L7216 | SC0201 | 3.3pF | CAP-3.3PF-0201 |
L7225 | IND-NF-0201 | NF | IND-NF-0201 |
L7226 | IND-NF-0201 | NF | IND-NF-0201 |
L7228 | SL0201 | 8.2nH | IND-CER-8.2NH-3%-0201-LQP03TN-00 |
L7239 | SL0201 | 1.5nH | IND-CER-1.5NH-0.3-0201-SDCL0603Q-02 |
Q6100 | SOT-23-6L | WPT2F30 | PNP-WILLSEMI-WPT2F30 |
Q6101 | SOT-523 | | FET-N-WNM4153-3/TR |
REC1 | AUDIO-REC-1506 | | AUDIO-REC-1506 |
TVS3125 | SOD_FL_1006_H040 | | TVS-ESD9L5.0ST5G |
TVS4102 | SMLV0402 | (NF) | MLV-AVLC5S02050 |
U0100 | BGA_600_P040_1330X1210_H090 | | ASIC-SC7731C-600-0.4 |
U0400 | PQFN_28_P073X075_600X600_T387_H095 | | RF-SW+PA-SC2663H |
U0402 | FILTER_8_180X140_H060 | TxRx:1950/2140MHz | RF-SAW-DUPLEX-SAYEY1G95HA0F0A |
U0404 | FILTER_CAF_10_P050_200X125_H105 | | RF-BALUN-LFB21914MDZ2D326 |
U0405 | BGAS_49_P040_330X330_H079_SR3533G | | RF-TRANSCEIVER-SR3533G |
U0406 | RF-PA-SPRD-3X3-10PIN | | RF-PA-SC2671H |
U0409 | RF-PA-SPRD-3X3-10PIN | | RF-PA-SC2675H |
U0410 | FILTER_8_180X140_H060 | TxRx:897.5/942.5MHz | RF-SAW-DUPLEX-SAYEY897MHA0F0A |
U0501 | BGA_221_P050_1150X1300_H100 | | MEM-LPDDR3+EMMC-KMQN1000SM-B316 |
U4105 | DFN2X2 | | DC2DC-WD3138D-6/TR |
U5200 | MXC400 | MXC400xXC | MXC400XXC |
U7200 | BT+WIFI+FM+GPS-SR2351 | | BT+WIFI+FM+GPS-SR2351C |
U7201 | RF-SAW-DPX-1.6X0.8-YAGEO | 1.5/2.4GHz | RF-SAW-DPX-RFDIP1608060TM7T62 |
U7202 | RF-SAW-LFB212G45CL1D172 | | RF-SAW-LFB212G45CL1D172 |
U7203 | SAFFB1G57KE0F0A | 1575.42MHz | RF-SAW-SAFFB1G57KE0F0A |
U7204 | RF-LNA-GPS-BGU8009 | | RF-LNA-GPS-BGU8009 |
U7206 | RF-SW+PA-2.4G-SR2319A | | RF-SW+PA-2.4G-SR2319A |
X0200 | XTAL_CC_320X150_H085 | 32.768KHz | XTAL-CRYSTAL-32.768K-Q-SC32S0322070AAAF |
X0401 | XTAL-CRYSTAL-2520 | 26MHz(NF) | XTAL-DCXO-26M-DSX221G |
Y7200 | OSC_CC_250X200_H090_KDS | 26MHz | XTAL-TCXO-26MHZ-1XXB26000MAB |
