重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | ANT1 | ANT-A | | ANT1 | ANT3 | GPS_ANT_4PA | | ANT_GPS | ANT4 | ANT | GPS_ANT | ANT_2P | B2 | L-0805 | FB0R | INDUCTOR_1 | CN2 | CON-22P_SUOHANG | CON-22_SUOHANG | CON-22P_SUOHANG | CN3 | 60P_2.0MMA | CON60P-2.0 | SIP60P_2.0 | CON2 | CON-2P | MIC | CON-2P | CON4 | CON2.0-6 | NC | CON2.0-6 | CON10 | FPC6P_0.5 | ???ó | CON6_GH_0.5MM | D1 | SOD523 | ESD/3.3V/5pF | DIODE_BREAKDOWN_0 | D2 | SOD-323 | IN4148 | DIODE_4148 | D3 | DO_D5M5_13 | 1N5404 | DIODE/INH | D4 | SOD-214 | B540C-13F 5A SMC | DIODE | D5 | SOD-323 | IN4148 | DIODE_4148 | D6 | SOD323 | 1N4001 | DIODE_3 | D7 | SOD-323 | IN4148 | DIODE_4148 | D9 | SOD-323 | IN4148 | DIODE_4148 | D10 | SMA | 1N4001 | 1N4001_SMD | D11 | 1SS16 | 1N4007 | SS14 | D12 | SOD-323 | IN4148 | DIODE_4148 | D13 | SOD523 | ESD/3.3V/5pF | DIODE_BREAKDOWN_0 | D14 | DO_214AC | 1N4001 | DIODE_3 | D15 | SOD-323 | IN4148 | DIODE_4148 | D16 | SOD-323 | IN4148 | DIODE_4148 | D17 | SOD-323 | IN4148 | DIODE_4148 | D18 | SMA | SS14 | 1N4001_SMD | D19 | SOD-106 | 1N4004 | DIODE | D20 | SOD323 | 1N4001 | DIODE_3 | D29 | SOD523 | ESD/3.3V/5pF | DIODE_BREAKDOWN_0 | EC1 | ECSMD_5 | 47uF/6.3V | CAP/E2 | EC2 | EC_D8_3M5 | 470uF/6.3V | CAPACITOR_1 | EC3 | ECSMD_5 | 47uF/16V | CAP/E2 | EC4 | ECSMD_5 | 47uF/16V | CAP/E2 | EC5 | ECSMD_5 | 100uF/16V | CAP/E2 | EC17 | ECSMD_6M6 | 220uF/25V | CAP/E/SMD | EC182 | EC_D12M5_5 | 3300uF/25V | CAP/E1 | F4 | F1206 | 0R | F1206 | FB1 | L1206 | FB0R/1206 | L0805 | FB2 | 603 | 600R | IND | FB3 | L0603 | 600R/100MHZ | INDUCTOR | FB4 | L0603 | 600R/100MHZ | INDUCTOR | FB5 | 603 | 600R | IND | FB7 | L0603 | 600R/100MHZ | INDUCTOR | FB8 | L0603 | FB 0R | INDUCTOR_3 | FB10 | L0603 | FB 0R | INDUCTOR_3 | FB11 | L-0805 | FB0R | INDUCTOR_1 | FB12 | L0603 | FB 0R | INDUCTOR_3 | FB13 | L0603 | FB 0R | INDUCTOR_3 | FB16 | L0603 | FB0R | L0805 | FB19 | 603 | 600R | IND | IC2 | SOP8_1M27 | 24C04 | MP1580_13 | IC4 | SOP8_1M27_PAD | AS1015 | MP1580_18 | IC6 | TO252 | LM78M09/T0252 | LM7805CT_15 | IC7 | TSSOP28_0M65 | BD3702FV | BD3702FV | IC9 | HZIP25 | TDA7388 | TDA7384 | IC12 | TSSOP24_0M65 | FMS6502 | FMS6502 | J1 | CON2.0-6 | | CON6 | J2 | RA10P_2.0 | TDQ-30FMV-001 | TDQ-230V-16 | J3 | 30P0.5MMA | | 30PTFT | J7 | FPC_0M5_10PIN | FPC_10PIN_0.5 | CON12 | J8 | 30P0.5MM | | 30PTFT-A | J9 | CON6PIN/1.25 | CON6P_1.25SMD | CON6PIN/125 | JP1 | JUMP2.0 | | JUMP | JP2 | JUMP2.0 | | JUMP | L1 | IND0805 | 10UH | IND_0805 | L2 | IND_10MM | 22UH/5A | IND_12UH/2A | L3 | INDCD43 | 3.3uH/2.15A | L | L5 | IND0805 | 10uH0805 | IND-MOLDED | L6 | INDCD54 | 100UH | IND-MOLDED | L9 | IND-SMT-CD43 | 1mH/500mA | CHIPIND_10X10 | L20 | L1206 | FB 0R 1206 | IND-1206_0R | L23 | IND0805 | 27NH0805 | IND-MOLDED | L24 | R0603 | 600R/100MHZ | INDUCTOR_3 | L26 | SC75470SMD | 22uH/CDH127/5A | IND-MOLDED | L33 | L0805 | FB0R | L_0805 | LCD_VDD3V3 | TP\1 | | TP | Q1 | SOT23 | 2N3904 | 2N3904_23 | Q2 | SOT23 | 2N3904 | 2N3904_23 | Q3 | SOT-23AA | DTC144 | DTC144D | Q5 | SOT-23AA | DTC144 | DTC144D | Q6 | SOT23 | 2N3904 | 2N3904_23 | Q7 | SOT23 | DTC144 | TRANSISTOR_NPN_2 | Q8 | SOT-23 | DTC144 | DTC144 | Q9 | SOT_23 | DTC343 | KRC231_S | Q10 | SOT_23 | DTC343 | KRC231_S | Q11 | SOT-23-M | APM2307 | APM2307 | Q12 | SOT-23 | DTC144 | DTC144 | Q13 | SOT23 | 2N3904 | NPN_15 | Q15 | SOT23 | 2N3904 | 2N3904_23 | Q16 | SOT23 | 2N3906 | 2N3906_23 | Q17 | SOT23 | 2N3904 | NPN_15 | Q18 | SOT23 | 2N3906 | 2N3906_23 | Q19 | SOT_23 | DTC343 | KRC231_S | Q20 | SOT23 | 2N3904 | 2N3904_23 | Q22 | SOT-23-M | APM2307 | APM2307 | Q23 | SOT-23 | DTC144 | DTC144 | Q24 | SOT-23-M | APM2307 | APM2307 | Q25 | SOT-23 | DTC144 | DTC144 | Q26 | SOT23 | 2N3904 | 2N3904_23 | Q27 | SOT-23-M | APM2307 | APM2307 | Q28 | SOT-23-M | APM2307 | APM2307 | Q30 | SOT-23 | APM2307 | 2N3906 | Q31 | SOT-23 | DTC144 | DTC144 | Q32 | SOT-23-M | APM2307 | APM2307 | Q33 | SOT-23-M | APM2307 | APM2307 | Q34 | SOT-23-M | APM2307 | APM2307 | Q35 | SOT23 | 2N3904 | 2N3904_23 | Q37 | SOT-23 | DTC144 | DTC144 | Q38 | SOT-23 | DTC144 | DTC144 | Q39 | SOT-23 | DTC144 | DTC144 | Q40 | SOT-23 | DTC144 | DTC144 | Q41 | SOT_23 | DTC343 | KRC231_S | Q43 | SOT-23AA | DTC144 | DTC144D | Q45 | SOT-23-M | APM2307 | APM2307 | Q46 | SOT-23 | DTC144 | DTC144 | TC85 | SMTC6.5 | 220uF/25V | ECAP | TP1 | TP\1 | | TP | TP_RX | TP\1 | | TP | TP_RX1 | TP\1 | | TP | U1 | CON-100P-1.5MM-VER1.5 | RK3188 o?D?°? | CON100P-1.5MM_RK3188-2DDR-V1.5 | U2 | SOT-25 | AP2204K-3.3V | AP2204K-ADJ | U3 | SOT-25 | AP2204K-5V | AP2204K-ADJ | U4 | GPS-1612 | | GPS-1612 | U5 | SO14 | TJA1041 | TJA1041 | U7 | MP3202DJ | FSP3307 | MP3202 | U8 | QFP64-1010-0.5 | STM32F103B | STM32F103B | U10 | SOT-23-5 | XC6219B332MR | XC6221B332MR | U11 | SOT89-5 | LN6210B332PR | XC6210B332MR_89 | U15 | SN74CBT16233 | ZL8643eup | ZL8643EUP | U17 | SOT-23-5 | LN6210B182MR | XC6210B332MR_25 | U21 | SOT-23-5 | XC6219B332MR | XC6221B332MR | U39 | QFN64-9X9 | ADV7181D | ADV7181CB_0 | VDD_3V3 | TP\1 | | TP | X2 | OSC | 16.0MHZ | CRYSTAL_0 | Y6 | OSC | 28.63636M | Y_DIP-2 | ZD1 | SOD-323-A | 16V | DIODE_BREAKDOWN_8 | ZD6 | SOD-323-A | 6.8V | DIODE_BREAKDOWN_8 |
RK3188_MB.7z
(661 KB, 下载次数: 22)
重要提示:PCB作品文件展下载说明
