TA的每日心情 | 开心 2024-6-20 15:58 |
签到天数: 1 天 [LV.1]初来乍到
长期免费代管18-28岁小
- 8256
早期的机子,,机子改版还没画完,方案搁浅了。 有需要的下载练习或者提取封装。
Name | Part Type | PCB Decal | Value | BAT1 | BATTERY_2 | BATTERY1 | Socket_bat | CM1 | USB_COMMON_CHOKE_0 | DLW21S | USB comon choke | CM2 | USB_COMMON_CHOKE_0 | DLW21S | USB comon choke | J1 | IR_TSOP4838 | TSOP4838 | TSOP4838 | J4 | HDR1X2 | HDR1X2 | HDR1x2 | J5 | CON6 | HDR1X6W | CONN6 | J6 | USB_0 | USB_C | USB | J7 | USB_0 | USB_C | USB | J11 | HDR1X4 | HDR1X4W | HDR1x4 | J12 | HDMI_CONNECTOR_-_SMT_1 | HDMI | HDMI CON-SMT | J13 | OPTICAL_TX_2 | DLT11R2-D2B | DLT11R5-D2 | J14 | AV6_2 | AV6-8.4-16D | AV6-8.4-16D | J15 | RJ-45-8-LED | RJ45-8-LED | RJ-45+LED | J16 | AV6_2 | AV6-8.4-16D | AV6-8.4-16D | J17 | HDR1X4_0 | HDR1X5W | HDR1x5 | J19 | 2MMHDR2X11_17 | HDR1X12/2MM | 2MMHDR12 | J22 | PHONEJACK_0 | DC_IN | DC-JACK | J24 | USB_2 | USB_B | USB B | J28 | CON2 | HDR1X2W | CON2 | J29 | HDR1X9_1 | HDR1X12/2MM | HDR1X12 | JK1 | SCART-DOUBLE-SC201 | SCART-DOUBLE-SC201 | SCART-DOUBLE-SC201 | L2 | BEAD | 805 | BEAD | L3 | BEAD | 805 | BEAD | L4 | BEAD | L0805 | BEAD | L6 | BEAD_2 | L0805 | BEAD | L7 | IND | L1206 | 0.47uH | L8 | BEAD | L0805 | NC/BEAD | L9 | BEAD | L0805 | BEAD | L10 | BEAD | L0805 | NC/BEAD | L11 | BEAD_2 | L0805 | BEAD | L12 | BEAD_2 | L0805 | BEAD | L13 | BEAD_2 | L0805 | BEAD | L14 | INDUCTOR_IRON_0 | TC5026-101K | 33uH/3A | L15 | BEAD_2 | L0805 | BEAD | L16 | INDUCTOR_IRON_0 | TC5026-101K | 33uH/3A | L42 | INDUCTOR_IRON | TC5026-101K | 15uH/3A | L43 | BEAD_2 | L0805 | BEAD | L44 | BEAD_2 | L0805 | BEAD | L45 | BEAD_2 | L0805 | BEAD | L46 | BEAD_2 | L0805 | BEAD | L47 | BEAD_2 | L0805 | BEAD | L48 | INDUCTOR_IRON | TC5026-101K | 15uH/3A | L49 | BEAD_2 | L0805 | BEAD | LED2 | LED_0 | LED3 | GREEN LED | LED3 | LED_0 | LED3 | RED LED | Q1 | PNP-SO23 | SOT23 | 2N3906 | Q3 | 2N3904 | SOT23 | 2N3904 | Q5 | BSS138 | SOT23 | BSS138 | Q6 | BSS138 | SOT23 | BSS138 | Q7 | BSS138 | SOT23 | BSS138 | Q11 | MOSFET_P_0 | SOT23 | IRLML6401 | Q12 | 2N3904 | SOT23 | 2N3904 | Q13 | 2N3904 | SOT23 | 2N3904 | Q14 | BSS138 | SOT23 | BSS138 | Q15 | BSS138 | SOT23 | BSS138 | Q16 | BSS138 | SOT23 | BSS138 | Q17 | BSS138 | SOT23 | BSS138 | Q18 | 2N3904 | SOT23 | 2N3904 | Q19 | PNP-SO23 | SOT23 | 2N3906 | Q20 | PNP-SO23 | SOT23 | 2N3906 | Q21 | PNP-SO23 | SOT23 | 2N3906 | Q22 | PNP-SO23 | SOT23 | 2N3906 | Q23 | MOSFET_P_0 | SOT23 | IRLML6401 | Q25 | PNP-SO23 | SOT23 | 2N3906 | SATA1 | SATA_HOST_CON | SATA_HOST_CON | SATA_HOST_CON | SW10 | SW_PUSHBUTTON | BUTTON4.5MM | ESWITCH_TL1105SF250Q | TR1 | YCL_PH163112 | YCL_SMT16 | YCL PH163112 | U2 | X24C44_1 | SOT23-5 | HM888 | U3 | SMP8634_05-20 | BGA820L_1MM | SMP8634 | U4 | 24C01_0 | SOIC8 | 24C02 | U5 | SDRAM_DDR_32MX16 | TSOP66 | 32Mx16 DDR 200MHz | U6 | SDRAM_DDR_32MX16 | TSOP66 | 32Mx16 DDR 200MHz | U7 | SDRAM_DDR_32MX16 | TSOP66 | 32Mx16 DDR 200MHz | U8 | SDRAM_DDR_32MX16 | TSOP66 | 32Mx16 DDR 200MHz | U9 | LP2995 | SOIC8 | LP2995M | U10 | FLASH_512MBIT_S29GL512N | TSOP56 | S29GL512N | U11 | MIC4576_3 | SOIC8_P | MP1410 | U12 | MIC4576_3 | SOIC8_P | MP1410 | U14 | CS4344 | TSSOP10 | CS4344 | U15 | RTL8201_1 | QFP48_0.5MM | IP101A LQFP48 | U17 | CS4344 | TSSOP10 | CS4344 | U20 | MP1411_0 | MSOP10_P | MP1411DH | U21 | PT7M7809RT | SOT23 | IMP809T | U22 | PCF8593_0 | SOIC8 | DS1337 | U23 | LDO_0 | SOT-223 | 1117-1.8 | U24 | MP1593 | SOIC8_P | MP1430 | U25 | LDO_0 | SOT-223 | 1117-3.3 | U26 | AAT4626-1 | SOIC8 | AAT4626IAS-1-T1 | U27 | RCLAMP0514M | MSOP10 | RClamp0524P | U28 | RCLAMP0514M | MSOP10 | RClamp0524P | U29 | CAT6613 | PQFP100 | CAT6613 | U30 | LDO_0 | SOT-223 | 1117-1.8 | U31 | CS4344 | TSSOP10 | CS4344 | U32 | CS4344 | TSSOP10 | CS4344 | U33 | LDO_1 | SOT23-5 | XC6210A182MR | U34 | LDO_2 | SOT23-5 | XC6210A252MR | U35 | SKS-LQFP128-GLI8196-0_2 | LQFP128A | GL830 LQFP 128 PIN | U36 | SN74AVC1T45_3 | SOIC8 | PIC12F609 | U37 | LDO_0 | SOT-223 | 1117-ADJ | U38 | 24C01_2 | DMB-TH | 24C01_0 | VC22 | CAP_CERAMIC_1 | C0603 | 100nF | VQ2 | 2N2222_3 | SOT23 | 2N3904 | VQ3 | 2N2222_3 | SOT23 | 2N3904 | VR5 | RESISTOR_2 | R0402 | 3K | VR6 | R_2 | R0402 | 2K | VR11 | RESISTOR_9 | R0402 | 120R | VR12 | RESISTOR_9 | R0402 | 10K | VR15 | RESISTOR_9 | R0402 | 1.2K | VR16 | RESISTOR_9 | R0402 | 10K | VR17 | RESISTOR_9 | R0402 | 1.2K | X1 | XTAL_HC49LP_27MHZ_/_MK2743 | XTAL-SMD | 27MHz | X3 | XTAL_HC49LP_27MHZ_/_MK2743 | XTAL-SMD | 24MHz | X5 | XTAL_HC49LP_27MHZ_/_MK2743 | XTAL-SMD | 25MHz | X6 | XTAL | XTAL2V | 32.768kHz | X7 | CRYSTAL | XTAL | 25MHz |
A1.7z
(1.2 MB, 下载次数: 7)
