[PADS9.5以下] MT6595 12层手机板PCB Sil8348+SKY13488+LSM6DS0+MT6332+SKY77621+MT6650N+MT6
查看12063 | 回复64 | 2017-4-12 11:30:57 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePCB DecalValuePart Type
B404RLC0603HPZ1608D221-1R2TFC0603
BATCONBAT_140508BAT_140508
BEAD6001RLC0402BLM15BD182SN1BEAD0402
CON801AXE540127Panasonic AYF332535BPAXE540127
CON1102ZIF_FH26-25S-0.3SHWSensorZIF_FH26-25S-0.3SHW
CON1201ZIF_FP243AH-0XXG1XM-6S-0.5SH_BFH34S-6S-05SHZIF_FP243AH-0XXG1XM-6S-0.5SH_B
CON16016-0.8PAD-PIN5-1-0.4PINTCH6-0.8
CON16026-0.8PAD-PIN5-1-0.4PINTCH6-0.8
CON3401C90P103-00004-HCar_Kit / MM8130-2600C90P103-00004-H
CON3603C90P103-00004-HC90P103-00004-H
CON3604ECT818000157MM9329-2700B
CON6001JACK-JAF00-05184-0161CON / 5 / EJ-36952-10-GPJACK-JAF00-05184-0161
CON6501BAT_140508BAT_140508
D1SOD323RB521CS-30RB551V-40
D2001SOD323RB551V-30RB551V-30
D2101SOD523RB521CS-30RB520S-30
D2102SOD323PZ5D4V2HRB551V-40
D2103SOD323AARB160M-30-EVBRB551V-40
D2106SOD323RB521CS-30RB551V-40
D2109SOD323PZ5D4V2HRB551V-40
D2121SOD523RB521CS-30RB520S-30
D2301SOD323LRB500V40T1GRB551V-40
D2302SOD323/SMD/MM3Z2V4T1D / RB551V-30SOD323/SMD/MM3Z2V4T1
D6402SOD523D / MM5Z6V2RB520S-30
EMI916ACFT4A2G900EACFT4A2G900EACFT4A2G900E
GB2001RLC0603BAT / CPH3225AC0603
HOL2DH1_6MMNDH1_6MMN
JFLASHCON_3PIN_08PITCHCON_3PIN_08PITCH
L6002RLC0402BLM15BD182SN1BEAD0402
L6401RLC0201L / 5.6 / nH / 0201C0201
L6402RLC0201L / 3.5 / nH / 0201C0201
LED3LED_2016ELCH03-5070E6E9284001-T0(YY)LED_2016
MIC6002MIC_SM0401L_423_M02_MMIC_SM0401L_423_M02_M
NTC1RLC0402NTC / NTCG103JF103FT / 0402R0402
PL2105L/IND/SMD/2520PL / PMSB25201T-2R2MSL/IND/SMD/2520
PL2106L/IND/SMD/VLS201610EPL / PMSB20161T-2R2MSL/IND/SMD/VLS201610E
PL2108L3030L/10uH/4040L3010
PL2109L3030L/1uH/MDMK3030T1R0MML3010
PL2305RLC0805PL / PMSB20161T-4R7MSL0805
PL6251L/IND/SMD/VLS201610EPL / PMSB20161T-R47MSL/IND/SMD/VLS201610E
Q6601WNM41532N7002_SOT23-3WNM4153
U401AW8110CSRYDA168B20YDA145
U502SAWFILTER/SMD/SAWFD1G90BH0F0ASAWFD1G90BH0F0A
U503IC_SAW_B8505IC_SAW_B8505
U1001MT6595/MWFPOP823/MT6595/MWFPOP823/
U1002IC_SN74LVC2T45-YZPSN74LVC2T45IC_SN74LVC2T45-YZP
U1003SOT23-6SGM6605-ADJYN6G/TRSGM6605
U1030MAX2659MAX2659MAX2659
U1101IC_CE6200IC_CE6200
U1102IC_CE6200IC_CE6200
U1103B2B_AXE5_10P_PITCH04_AAPDS-9900B2B_AXE5_10P_PITCH04_A
U1108IC_LSM6DS0LSM330IC_LSM6DS0
U1202IC_LDO_SGM2031IC_LDO_SGM2031
U1639IC_SAW_B8505DPX / SAYFH710MCA0F0AIC_SAW_B8505
U1644IC_BL1005-10G2500_SBL1005-10G2500IC_BL1005-10G2500_S
U1652SAW-B9081SAW-B9081
U1653IC_BL1005-10G2500_SBL1005-10G2500IC_BL1005-10G2500_S
U1666SAWFILTER/SMD/SAFEA2G59MB0F00SAW / F5QG740M0P2KHSAFEA2G59MB0F00
U1702KXTJ2-1009KXTJ2-1009
U1703MMC3416XPJMMC34160PJMMC3416XPJ
U2001MT6331/WLCSP208/U / MT6331MT6331/WLCSP208
U2101MT6332/WLCSP151/U / MT6332MT6332/WLCSP151
U2102TPS61282U / TPS61280TPS61282
U2103BGA_FPF2405BGA_FPF2405
U2104IC_FT8010_10PINIC_FT8010_10PIN
U2301TPS61165TPS61165DRVTPS61165
U2306TPS65132_0128U / TPS65132AYFFRTPS65132_0128
U2307USP/6P/SMD/XC6227USP/6P/SMD/XC6227
U2401WLCSP48/DA9210/DIALOGU / DA9210WLCSP48/DA9210
U3102TCXO/SMD/2.5X2.0/KT2520FKT2520F26000DCW28QAKTCXO/SMD/2.5X2.0/KT2520F
U3203IC_PA_SKY77621PA / SKY77621IC_PA_SKY77621
U3208IC_4GPA_SKY77778-51SKY77701IC_4GPA_SKY77778-51
U3210SAW-B9081SAW / SAFEA2G59MB0F00SAW-B9081
U3301B8553DPX / SAYFH1G74CA0B0AB8553
U3302IC_SWITCH_SKY13421_486LF_201655CSKY13421IC_ANT_SWITCH_SKY13421
U3304IC_SWITCH_SKY13488ASM / SKY13488IC_SWITCH_SKY13488
U3306IC_SAW_B8505DPX / SAYRF1G95HN0F0AIC_SAW_B8505
U3307IC_SWITCH_SKY13421_486LF_201655CSKY13421IC_ANT_SWITCH_SKY13421
U3308B8553DPX / D6HN2G655BN56B8553
U3309B8553DPX / D6PE1G960P3BYB8553
U3313IC_SAW_B8505DPX / SAYFH836MCC0F0AIC_SAW_B8505
U3314IC_SWITCH_SKY13421_486LF_201655CSKY13421IC_ANT_SWITCH_SKY13421
U3316BALUN/SMD/HHM22112A2CPL / LDJ18829M24AE003BALUN/SMD/HHM22112A2
U3317SF18-0942GASBA1B9837SF18-0942GASBA1
U3321SAWFILTER/SMD/SAFEA2G59MB0F00SAW / 885049SAWFILTER/SMD/SAFEA2G59MB0F00
U3323IC_BL1005-10G2500_SBL1005-10G2500IC_BL1005-10G2500_S
U3335IC_SWITCH_SKY13418-485LFSKY13418IC_SWITCH_SKY13418-485LF
U3401IC_SWITCH_SKY13421_486LF_201655CSKY13421IC_ANT_SWITCH_SKY13421
U3404SAWFILTER/SMD/SAFEA2G59MB0F00SAWFILTER/SMD/SAFEA2G59MB0F00
U3405IC_ANT_SWITCH_SKY13418-485LFSKY13418IC_ANT_SWITCH_SKY13418
U3406SAW_SAFFB1G81FA0F0ASAW / SAFFB1G84FL0F0ASAW_SAFFB1G81FA0F0A
U3407SAWFILTER/SMD/SAFEA2G59MB0F00SAW / SAFFB1G90FB0F0ASAWFILTER/SMD/SAFEA2G59MB0F00
U3408SAW_SAFFB1G81FA0F0ASAW / B9898SAW_SAFFB1G81FA0F0A
U3411SAW_SAFFB1G81FA0F0ASAW / SAFFB1G96FN0F0ASAW_SAFFB1G81FA0F0A
U3412SAW_SAFFB1G81FA0F0ASAW / F5QG881M592KGSAW_SAFFB1G81FA0F0A
U3422IC_SWITCH_SKY13477SKY13477IC_SWITCH_SKY13477
U5001MT6630/WLCSP113/U / MT6630-WLCSPMT6630/WLCSP113/
U5005BALUN/SMD/BL1608/ACXBALUN/SMD/BL1608/ACX
U5006SAWFILTER/SMD/SAFEA2G59MB0F00SAWFILTER/SMD/SAFEA2G59MB0F00
U5008FILTER/SMD/LFD211G57ME3FILTER/SMD/LFD211G57ME3
U5010SAWFILTER/SMD/SAFEA2G59MB0F00SAWFILTER/SMD/SAFEA2G59MB0F00
U5101MT6650N_4X4U / MT6605MT6605_4X4
U6201NX3P190NX3P190
U6211IC_CE6200IC_CE6200
U6241IC_SWITCH_KTD267-04IC_SWITCH_KTD267-04
U6302IC_HALL_HCO165_ORIENT-CHIPHCO165IC_HALL_HCO165_ORIENT-CHIP
U6401WNM415322WNM4153WNM4153
U6411TFBGA64U / Sil 8348TFBGA64
U6438IC_CE6200IC_CE6200
U6601BGA_ICE40LMBGA_ICE40LM
U6631IC_CE6200IC_CE6200
U6661IC_VSOP98260IC_VSOP98260
U6662IC_CE6200IC_CE6200
X200132K_DST31OS32KCRYSTAL-32K-3215
X5001IC_TCXO_2520IT2205AEIC_TCXO_2520
X5101IC_TCXO_2520IC_TCXO_2520
重要提示:PCB作品文件展下载说明
老吴 | 2017-4-12 11:36:46 | 显示全部楼层
游客,如果您要查看本帖隐藏内容请回复
yfchen1003 | 2017-4-12 11:54:03 | 显示全部楼层
zebin | 2017-4-12 11:54:09 | 显示全部楼层
miaomiao | 2017-4-12 12:33:35 | 显示全部楼层
yerik | 2017-4-12 13:06:58 | 显示全部楼层
caiden | 2017-4-12 14:00:17 | 显示全部楼层
hl646398140 | 2017-4-12 14:08:35 | 显示全部楼层
老大发的东西 总是这么NB
xnima_irumei | 2017-4-12 14:15:57 | 显示全部楼层
ky175 | 2017-4-12 16:38:41 | 显示全部楼层
真好看,看到很多线。
