查看: 4905|回复: 26
[Allegro16.6以下] DM6437+TVP5158IPNP+XC9572+TPS65251RHAR+KSZ8001LI  PCB共享
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2017-4-14 09:07:48 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    D1DIODE_DUAL_CA_JKK_2_SOD323_SED3SED323-3R30D0R4-A-11-LF/NCSOD323
    D2DIODE_DUAL_CA_JKK_2_SOD323_SED3SED323-3R30D0R4-A-11-LF/NCSOD323
    D10LED_SLED0603_LED_GREEN_NORMAL_0LED_GREEN_NORMAL_0603SLED0603
    D12BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    D13BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    D14BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    D15BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    D18BTSS-2P_SOD323_TESD05FB/NCTESD05FB/NCSOD323
    D19DIODE_SCHOTTKY_DO-214AC_SMA_B36B360A-13/3A/40VDO-214AC_SMA
    D21BTSS-2P_SOD323_TESD03FBTESD03FBSOD323
    D22DIODE BI-DIRTRIG_R603-35X45_SFSFI0603-EA240-HSPR603-35X45
    D23DIODE BI-DIRTRIG_R603-35X45_SFSFI0603-EA240-HSPR603-35X45
    D27BAS21_SOT23_3_BAS21BAS21SOT23_3
    D29BAS21_SOT23_3_BAS21BAS21SOT23_3
    D30BAS21_SOT23_3_BAS21/NCBAS21/NCSOT23_3
    D31DIODE BI-DIRTRIG_SR2220_SFI222SFI2220SA240-500JSR2220
    D32BAS21_TO-277A_SS10PH10/10A/100VSS10PH10/10A/100VTO-277A
    D33BAS21_TO-277A_SS10PH10/10A/100VSS10PH10/10A/100VTO-277A
    D34BAS21_SOT23_3_BAS21BAS21SOT23_3
    D35DIODE BI-DIRTRIG_SR2220_SFI222SFI2220SA240-500JSR2220
    D39BAS21_SOT23_3_BAS21/NCBAS21/NCSOT23_3
    D40LED_SLED0603_LED_GREEN_NORMAL_0LED_GREEN_NORMAL_0603SLED0603
    D41LED_SLED0603_LED_GREEN_NORMAL_0LED_GREEN_NORMAL_0603SLED0603
    D42LED_SLED0603_LED_GREEN_NORMAL_0LED_GREEN_NORMAL_0603SLED0603
    D43BTSS-2P_SOD323_TESD05FB/NCTESD05FB/NCSOD323
    D44BTSS-2P_SOD323_TESD05FB/NCTESD05FB/NCSOD323
    D45BTSS-2P_SOD323_TESD05FB/NCTESD05FB/NCSOD323
    D46BTSS-2P_SOD323_TESD05FB/NCTESD05FB/NCSOD323
    D47BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    D48BTSS-2P_SOD323_TESD05FB/NCTESD05FB/NCSOD323
    D49BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    D50BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    D51BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    D52BTSS-2P_SOD323_TESD36FBTESD36FBSOD323
    D53BTSS-2P_SOD323_TESD36FBTESD36FBSOD323
    D54BTSS-2P_SOD323_TESD05FB_1TESD05FBSOD323
    D55BTSS-2P_SOD323_TESD24FB/NCTESD24FB/NCSOD323
    D56BTSS-2P_SOD323_TESD24FB/NCTESD24FB/NCSOD323
    D57BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    D58BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    D59BTSS-2P_SOD323_TESD05FBTESD05FBSOD323
    DN1ESDA14V2L_SOT23_3_TESD05G2U/NCTESD05G2U/NCSOT23_3
    DN2ESDA14V2L_SOT23_3_TESD05G2U/NCTESD05G2U/NCSOT23_3
    FL3FILTER_TCE1210_SMD4_CHOKE4-59X3ACT45B-510-2P/NCCHOKE4-59X34-ACM4528H
    HOLE1TP_0_HOLE_3_8_MM_3MMHOLE/NC3mmHOLE/NCHOLE_3_8_MM
    HOLE2TP_0_HOLE_3_8_MM_3MMHOLE/NC3mmHOLE/NCHOLE_3_8_MM
    HOLE3TP_0_HOLE_3_8_MM_3MMHOLE/NC3mmHOLE/NCHOLE_3_8_MM
    HOLE4TP_0_HOLE_3_8_MM_3MMHOLE/NC3mmHOLE/NCHOLE_3_8_MM
    J2DJ7406_CON_DJ7406_DJ7406SDJ7406SCON_DJ7406
    J4JUMP_0_CONN2X7-40X100-TSM_2X7PI2X7PIN/2.54mm/TSM-107-01-S-DVCONN2X7-40X100-TSM
    J13CON3X2_CONN2X3-SMD-2D54_2X3PIN/2X3PIN/2.54mmCONN2X3-SMD-2D54
    J20CON6_CON_SIP6_2D54MM_CON_1X6P_2CON_1x6P_2.54MMCON_SIP6_2D54MM
    L1IND_PWR_SPL0707MM_3.3UH/2.8A3.3uH/2.8ASPL0707MM
    L2IND_PWR_SPL1212MMB_100UH/1.7A100uH/1.7ASPL1212MMB
    L3IND_PWR_SPL1212MMB_100UH/1.7A100uH/1.7ASPL1212MMB
    L5IND_PWR_SPL0707MM_3.3UH/2.8A3.3uH/2.8ASPL0707MM
    L6IND_PWR_SPL0707MM_3.3UH/2.8A3.3uH/2.8ASPL0707MM
    L7IND_PWR_SPL_8_8_4P5_10UH/3.2A10uH/3.2ASPL_8_8_4P5
    L8IND_PWR_SPL0303MM_2.7UH-30%/1A2.7uH-30%/1ASPL0303MM
    L14INDUCTOR_L805-35X60_220/3A220/3AL805-35X60
    L15INDUCTOR_L805-35X60_220/3A220/3AL805-35X60
    L16INDUCTOR_L805-35X60_220/3A220/3AL805-35X60
    L17INDUCTOR_L805-35X60_220/3A220/3AL805-35X60
    L18INDUCTOR_L805-35X60_220/3A220/3AL805-35X60
    L19INDUCTOR_L805-35X60_220/3A220/3AL805-35X60
    L20INDUCTOR_L805-35X60_220/3A220/3AL805-35X60
    L22INDUCTOR_SL0603_1000/0.4A1000/0.4ASL0603
    L23INDUCTOR_SL0603_1000/0.4A1000/0.4ASL0603
    L24INDUCTOR_SL0603_1000/0.4A1000/0.4ASL0603
    L25INDUCTOR_SL0603_1000/0.4A1000/0.4ASL0603
    L26INDUCTOR_SL0603_1000/0.4A1000/0.4ASL0603
    L28INDUCTOR_L805-35X60_220/3A220/3AL805-35X60
    L29INDUCTOR_L805-35X60_220/3A220/3AL805-35X60
    L30INDUCTOR_L805-35X60_220/3A220/3AL805-35X60
    L31INDUCTOR_SL0603_1000/0.4A/NC1000/0.4A/NCSL0603
    L32INDUCTOR_SL0603_1000/0.4A/NC1000/0.4A/NCSL0603
    L33INDUCTOR_SL0603_1000/0.4A1000/0.4ASL0603
    Q5NPN_SOT23_3_S9014S9014SOT23_3
    Q6PNP_SOT23_3_S9012S9012SOT23_3
    Q8NDS8434_0_SOT23_3A_IRLML5203TRIRLML5203TRSOT23_3A
    Q13NPN_SOT23_3_S9014S9014SOT23_3
    Q14NPN_SOT23_3_S9014S9014SOT23_3
    Q15PNP_SOT23_3_S9012S9012SOT23_3
    Q16NPN_SOT23_3_S9014S9014SOT23_3
    Q17NPN_SOT23_3_S9014S9014SOT23_3
    Q18PNP_SOT23_3_S9012S9012SOT23_3
    Q19NPN_SOT23_3_S9014S9014SOT23_3
    Q20PNP_SOT23_3_S9012/NCS9012/NCSOT23_3
    Q21NPN_SOT23_3_S9014S9014SOT23_3
    Q22NDS8434_0_SOT23_3A_IRLML5203TRIRLML5203TRSOT23_3A
    Q23NPN_SOT23_3_S9014S9014SOT23_3
    Q24NDS8434_0_SOT23_3A_IRLML5203TRIRLML5203TRSOT23_3A
    Q25NPN_SOT23_3_S9014S9014SOT23_3
    Q26NDS8434_0_SOT23_3A_IRLML5203TRIRLML5203TRSOT23_3A
    TP12TP_TP_SMT_TP_SMTTP_SMTTP_SMT
    U2TMS320DM6437ZDUQ6_BGA100P22X22_TMS320DM6437ZDUQ6BGA100P22X22_23X23X248-376
    U3TPS65251_QFN40_05MM_0606MMLTS_ATPS65251RHARQFN40_05MM_0606MMLTS_A
    U10XM5081-ADJ_2_SOT23_5C_TPS62260TTPS62260TDDCRQ1SOT23_5C
    U12XM5081-ADJ_3_SOT23_5C_TPS79318DTPS79318DBVRQ1SOT23_5C
    U28TPS54260_MSOP-10_TPS54260TPS54260MSOP-10
    U30KS8001_0_QFP48_05MM_0707MML_KSZKSZ8001LIQFP48_05MM_0707MML
    U561G08_SOT23_5C_SN74LVC1G08DBVTSN74LVC1G08DBVTSOT23_5C
    U65MAX3221_0_PW16-14X70_MAX3221IPWMAX3221IPW/NCPW16-14X70
    U96TVP5158_QFN40P16X16X120-128_(S1TVP5158IPNPQFN40P16X16X120-128
    U98DS2411R_0_SOT23-3_DS2411RDS2411RSOT23-3
    U109K9F1G08_SOP48_20_720A_K9F1G08U0K9F1G08U0A-PCB0SOP48_20_720A
    U110OPA361A_0_SC70-6_OPA361-Q1OPA361-Q1SC70-6
    U111TJA1051_SOP8_50_150_TJA1042T/3TJA1042T/3SOP8_50_150
    U112MT47H32M16_FBGA84_K4T1G164QF-BIK4T1G164QF-BIE6FBGA84
    U113MT47H32M16_FBGA84_K4T1G164QF-BIK4T1G164QF-BIE6FBGA84
    U115TLV431AIDBVR_0_SOT23_5C_TLV431ATLV431AIDBVRSOT23_5C
    U119TMP75AIDR_SO-8_TMP75AIDR/NCTMP75AIDR/NCSO-8
    U123XC9572XL-7VQG64I_3_VQG64_XC9572XC9572XL-7VQG64IVQG64
    U126H1102_STFM16_50_280_11FB_05NL11FB_05NLSTFM16_50_280
    U127SRV05-4_SOT23_6_TLSD05H4UTLSD05H4USOT23_6
    U128MAX811_SOT143_MIC811TUMIC811TUSOT143
    U129XM5081-ADJ_3_SOT23_5C_TPS7931_1TPS79318DBVRQ1/NCSOT23_5C
    Y4CRYSTAL_22.5792MHZ_SX4_3225MM_225MHzSX4_3225MM
    Y8XO75NACU_SX4_3225MM_27.000000MH27.000000MHzSX4_3225MM
    Y9XO75NACU_SX4_3225MM_27.000000MH27.000000MHzSX4_3225MM
    重要提示:PCB作品文件展下载说明
     楼主| 发表于 2017-4-14 09:08:11 | 显示全部楼层
    DM6437.7z (1.29 MB, 下载次数: 38)
    发表于 2017-4-14 09:26:00 | 显示全部楼层
    社区居民忠实会员社区劳模最爱沙发终身成就奖优秀斑竹奖
    发表于 2017-4-14 14:44:35 | 显示全部楼层
    困……
    发表于 2017-4-14 21:21:13 | 显示全部楼层
    昨天 19:56
  • 签到天数: 90 天
    发表于 2017-4-16 18:17:08 | 显示全部楼层
    好资料,谢谢分享!!!!
    发表于 2017-4-16 21:01:57 | 显示全部楼层
    好资料,谢谢分享!!!!
    社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
    发表于 2017-6-26 09:16:40 | 显示全部楼层
    昨天 10:07
  • 签到天数: 217 天
    社区居民社区劳模终身成就奖特殊贡献奖
    发表于 2017-6-26 09:19:51 | 显示全部楼层
    昨天 08:36
  • 签到天数: 182 天
    终身成就奖社区居民特殊贡献奖优秀斑竹奖
    发表于 2017-7-25 10:11:44 | 显示全部楼层
