重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | 3V3 | TEST | | TEST | ANT2 | CON2/2.0 | 2PIN 2.0mm | CN2 | BACK | TP_1.5MM | | TP_1.2MM | BRAKE | TP_1.5MM | | TP_1.2MM | CN1 | FFC50/0.5B | FFC50P 0.5mm | AT070TN92 | D1 | SOD-323 | IN4148 | IN4001(DIP) | D2 | DO-214ABAAAAA | 1N4001 | IN4001(DIP) | D3 | D_1206 | IN4148 | IN4001(DIP) | D4 | DIO/DO-214AA | IN5822 | IN4001(DIP) | D5 | DIO/DO-214AA | IN4001 | IN4001(DIP) | D6 | DO-214AB | RB050LA-40 | 1N4003G_1 | D7 | D_1206 | IN4148 | IN4001(DIP) | D8 | DIO/DO-214AA | IN4001 | IN4001(DIP) | D9 | DIO/DO-214AA | IN4001 | IN4001(DIP) | D10 | SMD_4007 | 0603ESDA-LP | IN4001(DIP) | D12 | SOD-323 | IN4148 | IN4001(DIP) | D13 | SOD-323 | IN4148 | IN4001(DIP) | D14 | FY/D-MI06-CA- | 1N5401 | D-101 | D16 | SOT-23 | BAV99 | BA99 | D19 | SOT-23 | BAV99 | BA99 | D20 | SOD-323 | IN4148 | IN4001(DIP) | D21 | SMD_4007 | IN4001 | IN4001(DIP) | D23 | SOT-23 | BAV99 | BA99 | D24 | SOD-323 | IN4148 | IN4001(DIP) | D25 | SOT-23 | BAV70 | BA70 | D27 | SMD_4007 | 0R | IN4001(DIP) | D28 | SOD-323 | IN4148 | IN4001(DIP) | D29 | SOD-323 | IN4148 | IN4001(DIP) | D31 | SOD-323 | IN4148 | IN4001(DIP) | D32 | SOD-323 | IN4148 | IN4001(DIP) | D33 | SOD-323 | IN4148 | IN4001(DIP) | D34 | SOD-323 | IN4148 | IN4001(DIP) | D35 | SOD-323 | IN4148 | IN4001(DIP) | D37 | SOD-323 | IN4148 | IN4001(DIP) | D38 | SOD-323 | IN4148 | IN4001(DIP) | D39 | SOD-323 | IN4148 | IN4001(DIP) | EC1 | EC_8X5 | 470UF/16V | EC | EC24 | EC_8X5 | 470UF/16V | EC | EC25 | EC_8X5 | 470UF/16V | EC | ESD1 | 0603L | ESD | PGB1010603 | ESD2 | 0603L | ESD | PGB1010603 | ESD3 | 0603L | ESD | PGB1010603 | ESD4 | 0603L | ESD | PGB1010603 | ESD5 | 0603L | ESD | PGB1010603 | ESD6 | 0603L | ESD | PGB1010603 | ESD7 | 0603L | ESD | PGB1010603 | ESD8 | 0603L | ESD | PGB1010603 | ESD12 | 0603L | ESD | PGB1010603 | ESD13 | 0603L | ESD | PGB1010603 | ESD14 | 0603L | ESD | PGB1010603 | ESD15 | 0603L | ESD | PGB1010603 | ESD16 | 0603L | ESD | PGB1010603 | F3 | 1812_FUSE | 0.35A | FUSE/0.035A | GND | TEST | | TEST | IC1 | SOT252 | BL1117-3.3V | LD1117 | IC3 | PT2348 | PT2348 | ZZF-PT2348 | IC4 | SO8-OPT | 24C02 | AT24C02 | J1 | LINE_OUT16P | | LINE_OUT_16PIN | J2 | TFT6765-TUN_AA | | J_18PIN | J3 | RAC3X4 | | RCA24P | J4 | NEW-ISO-16P | | JACK18PIN | J5 | TV-S77-1A | | TV_13PIN | J6 | FFC60/0.5B | 60P | CON_60P_0.5MM | J7 | OUTPUT | 2P | HVP | J8 | CN40(0.5)-B | | 40PIN_0.5MM | J9 | CN2(3.0) | | CON2 | J13 | CN4(1.0) | 4PIN 1.0mm | CON4_TOUCH | L1 | L0603 | 600R@100M | L | L2 | L1206B | 600R@100M | L | L3 | L/TC-28H | 200uH | (LGJ)IND-CDRH74 | L4 | L12X12 | 22UH | IND | L5 | SDSL0603F | 1.5uH | IND | L6 | L1206B | 600R@100M | L | L7 | 0603L | 600R@100M | L | L8 | 0603L | 600R@100M | L | L9 | IND-CDH2B18-HP | 2.2uH | IND-2.2UH/1.65AN-CDH2B18-XA | L10 | L0805 | 2.7uH | L | L11 | IND/10MM | 50R/100M | L4 | L12 | 0603R | 10UH | L-1 | L13 | IND-SMT-CD43 | 10UH | IND | L14 | 0805R | 270nH | L-1 | L15 | IND-CDH2B18-HP | 2.2uH | IND-2.2UH/1.65AN-CDH2B18-XA | L16 | 0603R | 600R@100M | L | L17 | L0603 | 600R@100M | L | L18 | IND-0805-BA | FB | L2 | L19 | 0805R | 220nH | L-1 | L20 | 0603L | 600R@100M | L | L21 | IND-SMT-CD43 | 22uH | IND | L22 | 0603L | 600R@100M | L | L23 | 0603L | 600R@100M | L | L24 | 0603L | 600R@100M | L | L25 | 0603R | 600R@100M | L | L26 | L0603 | 600R@100M | L | L27 | L0603 | NC | L | L28 | 0603L | 600R@100M | L | L29 | 0805R | 2.7UH | L2 | L32 | L0805 | 2.7uH | L | L36 | L1206B | NC | L | L44 | 0603R | 1K@100M | L2 | L45 | 0603R | 1K@100M | L2 | M1 | MARK | | MARK | M2 | MARK | | MARK | M3 | MARK | | MARK | M4 | MARK | | MARK | Q1 | SOT-23 | S8550 | PNP | Q2 | SOT-23 | S8550 | PNP | Q3 | SOT-23 | S8050 | NPN | Q4 | SOT-23 | S8050 | NPN | Q5 | SOT-23 | S8050 | NPN | Q6 | SOT-23 | S8050 | NPN | Q7 | SOT-23 | S8050 | NPN | Q8 | SOT-23 | S8550 | PNP | Q9 | SOT-23 | S8050 | NPN | Q10 | SOT-23 | S8050 | NPN | Q11 | SOT-23 | S8050 | NPN | Q12 | SOT-23 | S8550 | PNP | Q13 | SOT-23 | S8050 | NPN | Q14 | SOT-23 | 9018 | NPN | Q15 | SOT-23 | S8050 | NPN | Q16 | SOT-23 | S8050 | NPN | Q17 | SOT-23 | S8550 | PNP | Q18 | TO-89 | KTC4375 | NPN | Q19 | Q/SOT-23/SMD-ZR | KRC103 | C103 | Q20 | SOT-23 | M3407 | SI2323 | Q21 | SOT-23 | S8550 | PNP | Q22 | SOT-23 | S8550 | PNP | Q23 | SOT-23 | S8050 | NPN | Q24 | SOT-23 | KRC103S | NPN/ECB | Q25 | SOT-23 | KRC103 | C103 | Q26 | SOT-23 | P6403 | MOS_P | Q27 | SOT-23 | KRC103 | C103 | Q28 | SOT-23 | S8550 | PNP | Q29 | SOT-23 | 9018 | NPN | Q32 | SOT-23 | S8550 | PNP | Q38 | SOT-23 | KRC103S | NPN/ECB | Q39 | SOT-23 | KRC103 | C103 | RST | TEST | | TEST | TEST | TEST | | TEST | TP01 | TP_1.5MM | | TP_1.2MM | TP1 | TP-D2.0-AA | | POINTER | TP2 | TP-D2.0-AA | | POINTER | TP3 | TP-D2.0-AA | | POINTER | TP4 | TP-D2.0-AA | | POINTER | U1 | SOT252 | 78M09 | IC-VOLREG7809_A | U2 | SOP16-3.9-1.27 | CD4052 | CD4052 | U3 | SOIC8E | MP1584 | PQ1CZ21_0_3 | U4 | TA8266H | TDA7388 | TDA7384 | U5 | SO8-OPT | NJM4558 | NJM4558 | U6 | SOT23-6 | MP3202 | ZZF-FSP3305 | U7 | LQFP48 | HK-48P | STM8A_48 | U8 | SI4731-TUN_A | TDA7786 | TDA7786/SI4731 | U9 | SOT-23-5 | EML3406-ADJ | BL3406B-ADJ | U10 | TO-89 | HT7533-1 | IC-HT7533-1-SOT-89-AA | U11 | SOT-23 | SGM809_2.93V | IMP809 | U12 | MSOP-10 | SGM3005 | SGM3005XMS | U13 | TO-89 | HT7550-1 | IC-HT7533-1-SOT-89-AA | U14 | QFN16-0.5MM | TPS2546 | TPS2546 | U15 | SOT-23-5 | EML3406-ADJ | BL3406B-ADJ | U18 | SOT-23 | XC6206P302M | XC6206P152M | U19 | NJM2107 | MP1540 | SOT23-5 | U21 | SOIC8_208MIL | MX25L6406E | GD5F4GQ4UAYIG_3 | U26 | BC3 | IVT I159 | BC3 | U28 | SOT252 | BL1117-3.3V | LD1117 | U29 | QFP128P0_40B14_00X14_00H1_60 | FC500 | APPX-ELQFP128-1118_6 | U33 | SOP66PO_65B10 | K4H511638J-LCCC | DDR_SDRAM66P | U37 | SOT-23 | SGM809_2.93V | IMP809 | U38 | SSOP24_0.635MM | SI4730 | SI4730_SSOP24 | X+ | TP_1.5MM | | TP_1.2MM | X- | TP_1.5MM | | TP_1.2MM | XT1 | CRY/HC-49USM | 24MHZ | CRYSTAL | XT2 | CRY/HC-49USM | 8MHZ | CRYSTAL | Y+ | TP_1.5MM | | TP_1.2MM | Y- | TP_1.5MM | | TP_1.2MM | Y1 | XTAL3 | 32.768khz | XTAL | Z2 | ZD_1206 | 10V | ZD_1206 | Z3 | ZD_1206 | 7.5V | ZD_1206 | Z6 | ZD_1206 | 16V | ZD_1206 | Z7 | ZD_1206 | 6.8V | ZD_1206 | ZD1 | 0603R | 24V2R5S | ESD | ZD2 | 0603R | 24V2R5S | ESD | ZD3 | 0603R | 24V2R5S | ESD | ZD4 | ZD_1206 | 5.1V | ZD_1206 | ZD10 | 0603R | 24V2R5S | ESD |
重要提示:PCB作品文件展下载说明
