之前发过一个跟这个板子,基本上一样的。只改动了小位置的走线。http://bbs.ntpcb.com/read.php?tid=77819
REFDES | COMP_DEVICE_TYPE | SYM_NAME | ACODEC1 | LQFP48 | LQFP48 | ATX_12V | ATX_PWR_4P | ATX_PWR_4P | ATX_POWER | ATX_PWR_24P | ATX_PWR_24P | AUDIO1 | AUDIO_JACK_13P_3 | AUDIO_JACK_13P_3 | BAT1 | BATTERY_1 | BATTERY_1 | COM1 | COM_D-SUB_9P_M | COM_D-SUB_9P_M | COM2 | J5X2_COM | J5X2_COM | CPU1 | LGA1155 | LGA1155 | CPU_FAN | FAN4X1 | FAN4X1 | C_INTRUSION | J2X1 | J2X1 | D1 | BAT54_132_2 | BAT54_132_2 | D2 | BAT54_132_2 | BAT54_132_2 | D3 | FPC_4P10_R_1 | FPC_4P10_R_1 | D4 | FPC_4P10_R_1 | FPC_4P10_R_1 | D5 | SOD_523 | SOD_523 | D6 | BAT54_132_2 | BAT54_132_2 | D7 | SOD_123_2 | SOD_123_2 | D8 | BAT54_132_2 | BAT54_132_2 | D9 | BAT54_132_2 | BAT54_132_2 | D10 | 1N4148 | 1N4148 | D11 | FPC_4P10_R_1 | FPC_4P10_R_1 | D12 | FPC_4P10_R_1 | FPC_4P10_R_1 | D13 | 1N4148 | 1N4148 | D14 | BAT54_132_2 | BAT54_132_2 | D15 | 1N4148 | 1N4148 | D16 | BAV99_132_2 | BAV99_132_2 | D17 | BAV99_132_2 | BAV99_132_2 | D18 | SOD_123_2 | SOD_123_2 | DD1 | BAT54_132_2 | BAT54_132_2 | DD2 | BAT54_132_2 | BAT54_132_2 | DIMM1 | DDR3_240P_2 | DDR3_240P_2 | DIMM2 | DDR3_240P_2 | DDR3_240P_2 | DIMM3 | DDR3_240P_2 | DDR3_240P_2 | DIMM4 | DDR3_240P_2 | DDR3_240P_2 | DP1 | DISPLAY_20P_1 | DISPLAY_20P_1 | DP2 | DISPLAY_20P_1 | DISPLAY_20P_1 | DVI1 | DVI_29P_MB_1 | DVI_29P_MB_1 | EC1 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC2 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC3 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC4 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC5 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC6 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC7 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC8 | EC3D5_8_H11MM_1P | EC3D5_8_H11MM_1P | EC9 | EC3D5_8_H11D5MM_1P | EC3D5_8_H11D5MM_1P | EC10 | EC3D5_8_H11D5MM_1P | EC3D5_8_H11D5MM_1P | EC11 | EC3D5_8_H11D5MM_1P | EC3D5_8_H11D5MM_1P | EC12 | EC3D5_8_H11D5MM_1P | EC3D5_8_H11D5MM_1P | EC13 | EC3D5_8_H11D5MM_1P | EC3D5_8_H11D5MM_1P | EC14 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC15 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC16 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC17 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC18 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC19 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC20 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC21 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC22 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC23 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC24 | EC3D5_8_H11D5MM_1P | EC3D5_8_H11D5MM_1P | EC25 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC26 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC27 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC28 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC29 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC30 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC31 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC32 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC33 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC34 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC35 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC36 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | EC37 | EC3D5_8_H9MM_1P | EC3D5_8_H9MM_1P | EC38 | EC3D5_8_H9MM_1P | EC3D5_8_H9MM_1P | EC39 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC40 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC41 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC42 | EC2D5_6D3_H11MM | EC2D5_6D3_H11MM | EC43 | OSCON2D5_6D3_H9MM | OSCON2D5_6D3_H9MM | F1 | FUSE_SMD_1 | FUSE_SMD_1 | F2 | F1812 | F1812 | FB1 | FB0603-SHORT_1 | FB0603-SHORT_1 | FB2 | FB0603-SHORT_1 | FB0603-SHORT_1 | FB3 | FB0603-SHORT_1 | FB0603-SHORT_1 | FB4 | FB0603-SHORT_1 | FB0603-SHORT_1 | FB5 | FB0603-SHORT_1 | FB0603-SHORT_1 | FB6 | FB0603-SHORT_1 | FB0603-SHORT_1 | F_AUDIO | J5X2_AUDIO_1 | J5X2_AUDIO_1 | F_PANEL | J7X2_PANEL_10P | J7X2_PANEL_10P | F_USB1 | J5X2_USB_1394 | J5X2_USB_1394 | F_USB2 | J5X2_USB_1394 | J5X2_USB_1394 | F_USB3 | J5X2_USB_1394 | J5X2_USB_1394 | L5 | CHOKE_NLC252018_SMD_2P | CHOKE_NLC252018_SMD_2P | L7 | CHOKE_1R0M-R_1 | CHOKE_1R0M-R_1 | L8 | CHOKE-R56M_PT6D6X4D2MM_2 | CHOKE-R56M_PT6D6X4D2MM_2 | L9 | CHOKE-R56M_PT6D6X4D2MM_2 | CHOKE-R56M_PT6D6X4D2MM_2 | L10 | CHOKE-R56M_PT6D6X4D2MM_2 | CHOKE-R56M_PT6D6X4D2MM_2 | L11 | CHOKE-R56M_PT6D6X4D2MM_2 | CHOKE-R56M_PT6D6X4D2MM_2 | L12 | CHOKE_R30M_1 | CHOKE_R30M_1 | L13 | CHOKE_4R7_PT2D65MM_SMD | CHOKE_4R7_PT2D65MM_SMD | L14 | FB0805 | FB0805 | L15 | CHOKE_9D5X11_PT7MM_H_2 | CHOKE_9D5X11_PT7MM_H_2 | L16 | CHOKE_1R0M-R_1 | CHOKE_1R0M-R_1 | L17 | FB0603 | FB0603 | LAN1 | QFN48_PT04-4D4X4D4MM_1 | QFN48_PT04-4D4X4D4MM_1 | LAN2 | FBGA121_BCM5761 | FBGA121_BCM5761 | MC1 | C0805 | C0805 | ME_DISABLE | J3X1 | J3X1 | OBR1 | J2X1 | J2X1 | OD1 | BAT54_132_2 | BAT54_132_2 | OD2 | BAT54_132_2 | BAT54_132_2 | P1 | SHORT2-NMNP | SHORT2-NMNP | P2 | SHORT2-NMNP | SHORT2-NMNP | P3 | SHORT2-NMNP | SHORT2-NMNP | P4 | SHORT2-NMNP | SHORT2-NMNP | P5 | FB0603-SHORT_1 | FB0603-SHORT_1 | PCH1 | BGA942_CPT | BGA942_CPT | PCIE16X | PCIE_X16_164P_3 | PCIE_X16_164P_3 | PCIE1X_1 | PCIE_X1_36P_2 | PCIE_X1_36P_2 | PFB1 | FB0603 | FB0603 | PFB2 | FB0603 | FB0603 | PFB3 | FB0603 | FB0603 | PFB4 | FB0603 | FB0603 | PFB5 | L0805 | L0805 | PFB6 | FB0603 | FB0603 | PFB7 | L0805 | L0805 | PFB8 | L0805 | L0805 | PFB9 | FB0805 | FB0805 | PFB10 | FB0805 | FB0805 | PRINTER | J13X2_LPT_1 | J13X2_LPT_1 | PSKM | KB_MS | KB_MS | SD1 | SOD_123_2 | SOD_123_2 | SD2 | SOD_123_2 | SOD_123_2 | SD3 | SOD_123_2 | SOD_123_2 | SD4 | SOD_123_2 | SOD_123_2 | SJ1 | 2X30_XDP_CONN-NMNP | 2X30_XDP_CONN-NMNP | SP1 | SHORT2-NMNP | SHORT2-NMNP | SP2 | SHORT2-NMNP | SHORT2-NMNP | SP3 | SHORT2-NMNP | SHORT2-NMNP | SPDIF_OUT | J4X1_SPDIFO_2P | J4X1_SPDIFO_2P | SPI_DEBUG | J6X2_PT1D27MM_SMD_2P | J6X2_PT1D27MM_SMD_2P | SQ1 | SOT23_BCE_2 | SOT23_BCE_2 | SQ2 | SOT223_BCE_3P_1 | SOT223_BCE_3P_1 | SU1 | TQFN48_5D55X5D55_1 | TQFN48_5D55X5D55_1 | SYS_FAN | FAN4X1 | FAN4X1 | TPM | J10X2_TPM_4P-FOXTEQ | J10X2_TPM_4P-FOXTEQ | U1 | SOT23_6P_2 | SOT23_6P_2 | U2 | SOT23_6P_2 | SOT23_6P_2 | U3 | MSOP10_W120_PT05 | MSOP10_W120_PT05 | U4 | MSOP10_W120_PT05 | MSOP10_W120_PT05 | U5 | MSOP10_W120_PT05 | MSOP10_W120_PT05 | U6 | MSOP10_W120_PT05 | MSOP10_W120_PT05 | U7 | SOT23_6P_2 | SOT23_6P_2 | U8 | SOT23_6P_2 | SOT23_6P_2 | U9 | SOT23_6P_2 | SOT23_6P_2 | U10 | SOP8_W210_PT50 | SOP8_W210_PT50 | U11 | PSOP8_W150_PT50_PAD-UP7719B_1 | PSOP8_W150_PT50_PAD-UP7719B_1 | U12 | SOT23_6P_2 | SOT23_6P_2 | U13 | SOT23_6P_2 | SOT23_6P_2 | U14 | SOT23_6P_2 | SOT23_6P_2 | U15 | SOT23_8P_1 | SOT23_8P_1 | U16 | TSSOP20_W170_PT065 | TSSOP20_W170_PT065 | U17 | TSSOP20_W170_PT065 | TSSOP20_W170_PT065 | U18 | SOP8_W150_PT50 | SOP8_W150_PT50 | U19 | SOP8_W150_PT50 | SOP8_W150_PT50 | U20 | QFN20_ISL95870B_1 | QFN20_ISL95870B_1 | U21 | QFN48_PT04-4D4X4D4MM_1 | QFN48_PT04-4D4X4D4MM_1 | U22 | SOP8_W150_PT50 | SOP8_W150_PT50 | U23 | DFN10_RT8106A_1 | DFN10_RT8106A_1 | U24 | SOT23_6P_2 | SOT23_6P_2 | U25 | SOT23_8P_1 | SOT23_8P_1 | U26 | SOP8_W150_PT50-92X110 | SOP8_W150_PT50-92X110 | U27 | SOT23_6P_2 | SOT23_6P_2 | U28 | SOT23_8P_1 | SOT23_8P_1 | U29 | SOP8_W150_PT50 | SOP8_W150_PT50 | U30 | SOT23_6P_2 | SOT23_6P_2 | U31 | SOT23_6P_2 | SOT23_6P_2 | U32 | TSSOP28_W170_PT065 | TSSOP28_W170_PT065 | U33 | SOT23_8P_1 | SOT23_8P_1 | U34 | PSOP8_W150_PT50_PAD-UP7719B_1 | PSOP8_W150_PT50_PAD-UP7719B_1 | U35 | SOP8_W150_PT50 | SOP8_W150_PT50 | U36 | SOP8_W150_PT50 | SOP8_W150_PT50 | U37 | QFP128 | QFP128 | U38 | SOP8_W150_PT50-86X86_1 | SOP8_W150_PT50-86X86_1 | USB3F1 | CON10X2_2MM_20P_USB3_1 | CON10X2_2MM_20P_USB3_1 | USB3_1 | USB3_18P4R-LOTES-SHORTBODY_1 | USB3_18P4R-LOTES-SHORTBODY_1 | USBLAN1 | USBLAN_LED_A | USBLAN_LED_A | X1 | CRYSTAL | CRYSTAL | X2 | CRYSTAL | CRYSTAL | X3 | CRYSTAL | CRYSTAL | Y1 | ETXTALS-SPAD | ETXTALS-SPAD |
