[Allegro16.6以下] 精英电脑代工设计的  宏基Q77_B75H2-AM2 V10 电脑主板PC
查看10387 | 回复47 | 2017-5-19 22:26:07 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
REFDESCOMP_DEVICE_TYPESYM_NAME
ACODEC1LQFP48LQFP48
ATX_12V1ATX_PWR_4PATX_PWR_4P
ATX_POWERATX_PWR_24PATX_PWR_24P
AUDIO1AUDIO_JACK_13P_3AUDIO_JACK_13P_3
BAT1BATTERY_1BATTERY_1
COM1COM_D-SUB_9P_MCOM_D-SUB_9P_M
COM2J5X2_COMJ5X2_COM
CPU1LGA1155LGA1155
CPU_FANFAN4X1FAN4X1
C_INTRUSIONJ2X1J2X1
D2BAT54_132_2BAT54_132_2
D31N41481N4148
D41N41481N4148
D51N41481N4148
D61N41481N4148
D71N41481N4148
D8SOD_523SOD_523
D9BAT54_132_2BAT54_132_2
D10BAT54_132_2BAT54_132_2
D111N41481N4148
D121N41481N4148
D13BAV99_132_2BAV99_132_2
D14BAV99_132_2BAV99_132_2
D15BAT54_132_2BAT54_132_2
D161N41481N4148
D19FPC_4P10_R_1FPC_4P10_R_1
D20FPC_4P10_R_1FPC_4P10_R_1
D21FPC_4P10_R_1FPC_4P10_R_1
D22FPC_4P10_R_1FPC_4P10_R_1
D100BAT54_132_2BAT54_132_2
DD1BAT54_132_2BAT54_132_2
DD2BAT54_132_2BAT54_132_2
DIMM1DDR3_240P_2DDR3_240P_2
DIMM2DDR3_240P_2DDR3_240P_2
DIMM3DDR3_240P_2DDR3_240P_2
DIMM4DDR3_240P_2DDR3_240P_2
DP1DISPLAY_20P_1DISPLAY_20P_1
DP2DISPLAY_20P_1DISPLAY_20P_1
F_AUDIOJ5X2_AUDIO_1J5X2_AUDIO_1
F_PANELJ7X2_PANEL_10PJ7X2_PANEL_10P
F_USB1J5X2_USB_1394J5X2_USB_1394
F_USB2J5X2_USB_1394J5X2_USB_1394
F_USB3J5X2_USB_1394J5X2_USB_1394
GPIO1J2X1J2X1
GPIO2J2X1J2X1
H1HOLE8_5HOLE8_5
H2HOLE8_5HOLE8_5
H3HOLE8_5HOLE8_5
H4HOLE8_5HOLE8_5
H5HOLE8_5HOLE8_5
H6HOLE8_5HOLE8_5
H7HOLE8_5HOLE8_5
H8HOLE8_5HOLE8_5
INT_SPKJ4X2_4PJ4X2_4P
J12X30_XDP_CONN-NMNP2X30_XDP_CONN-NMNP
L1CHOKE_NLC252018_SMD_2PCHOKE_NLC252018_SMD_2P
L2CHOKE_1R0M-R_1CHOKE_1R0M-R_1
L3FB0805_1FB0805_1
L4CHOKE_4R7_PT2D65MM_SMDCHOKE_4R7_PT2D65MM_SMD
L5L0805_1L0805_1
L6FB0603_1FB0603_1
L7L0805_1L0805_1
L8L0805_1L0805_1
L9FB0805_1FB0805_1
L10FB0805_1FB0805_1
L11FB0805_1FB0805_1
L12FB0603_1FB0603_1
L13CHOKE_4R7K_PT3D35MM_SMDCHOKE_4R7K_PT3D35MM_SMD
L24CMM21_1CMM21_1
L25CMM21_1CMM21_1
L26CMM21_1CMM21_1
L27CMM21_1CMM21_1
L28CMM21_1CMM21_1
L29CMM21_1CMM21_1
L30CMM21_1CMM21_1
L31CHOKE_9D5X11_PT7MM_H_3CHOKE_9D5X11_PT7MM_H_3
L32CHOKE_1R0M-R_1CHOKE_1R0M-R_1
L33CHOKE-R56M_PT6D6X4D2MM_2CHOKE-R56M_PT6D6X4D2MM_2
L34CHOKE-R56M_PT6D6X4D2MM_2CHOKE-R56M_PT6D6X4D2MM_2
L35CHOKE-R56M_PT6D6X4D2MM_2CHOKE-R56M_PT6D6X4D2MM_2
L36CHOKE_R30M_1CHOKE_R30M_1
L37CHOKE_9D5X11_PT7MM_H_3CHOKE_9D5X11_PT7MM_H_3
L38CHOKE-R56M_PT6D6X4D2MM_2CHOKE-R56M_PT6D6X4D2MM_2
L39CMM21_1CMM21_1
LAN1QFN48_PT04-4D4X4D4MM_1QFN48_PT04-4D4X4D4MM_1
LAN2QFN48_PT04-4D4X4D4MM_1QFN48_PT04-4D4X4D4MM_1
MC1C0805_1C0805_1
ME_DISABLEJ3X1J3X1
ME_TESTJ3X2J3X2
MN31SOT23_GDS_2SOT23_GDS_2
OBRJ2X1J2X1
OD2BAT54_132_2BAT54_132_2
OD3BAT54_132_2BAT54_132_2
P1SHORT2-NMNPSHORT2-NMNP
P2R0805-SHORTR0805-SHORT
P3R0805-SHORTR0805-SHORT
P5R0805-SHORTR0805-SHORT
P100SHORT2-NMNPSHORT2-NMNP
P101SHORT2-NMNPSHORT2-NMNP
PCH1BGA942_CPTBGA942_CPT
PCI1PCI_120P-ABPCI_120P-AB
PCI2PCI_120P-ABPCI_120P-AB
PCIE16XPCIE_X16_164P_3PCIE_X16_164P_3
PCIE1X_1PCIE_X1_36P_2PCIE_X1_36P_2
PRINTERJ13X2_LPT_1J13X2_LPT_1
PSKM1KB_MSKB_MS
SATA1SATA7P-M-HUANXUN_1SATA7P-M-HUANXUN_1
SATA2SATA7P-M-HUANXUN_1SATA7P-M-HUANXUN_1
SATA3SATA7P-M-HUANXUN_1SATA7P-M-HUANXUN_1
SATA4SATA7P-M-HUANXUN_1SATA7P-M-HUANXUN_1
SATA5SATA7P-M-HUANXUN_1SATA7P-M-HUANXUN_1
SATA6SATA7P-M-HUANXUN_1SATA7P-M-HUANXUN_1
SBT1BAT54_132_2BAT54_132_2
SFB6FB0603_1FB0603_1
SFB7FB0805_1FB0805_1
SJ12X30_XDP_CONN-NMNP2X30_XDP_CONN-NMNP
SL1CMM21_1CMM21_1
SL2CMM21_1CMM21_1
SPI_DEBUG1J6X2_PT1D27MM_SMD_2PJ6X2_PT1D27MM_SMD_2P
SQ2SOT23_GDS_2SOT23_GDS_2
STP25SHORT2-NMNPSHORT2-NMNP
SU1SOT23_6P_2SOT23_6P_2
SYS_FANFAN4X1FAN4X1
TP2TP30_SMDTP30_SMD
TP3TP30_SMDTP30_SMD
TP6TP30_SMDTP30_SMD
TP7TP30_SMDTP30_SMD
TP28SHORT2-NMNPSHORT2-NMNP
TP29SHORT2-NMNPSHORT2-NMNP
TP30SHORT2-NMNPSHORT2-NMNP
TP31SHORT2-NMNPSHORT2-NMNP
TP32SHORT2-NMNPSHORT2-NMNP
TP33SHORT2-NMNPSHORT2-NMNP
TP34SHORT2-NMNPSHORT2-NMNP
TP35SHORT2-NMNPSHORT2-NMNP
TP36SHORT2-NMNPSHORT2-NMNP
TP37SHORT2-NMNPSHORT2-NMNP
TP99TP30_SMDTP30_SMD
TP199SHORT2-NMNPSHORT2-NMNP
TP200SHORT2-NMNPSHORT2-NMNP
TPMJ10X2_TPM_4P-ACERJ10X2_TPM_4P-ACER
TP_VGATP30_SMDTP30_SMD
U2SOT23_6P_2SOT23_6P_2
U3MSOP10_W120_PT05MSOP10_W120_PT05
U4MSOP10_W120_PT05MSOP10_W120_PT05
U5SOT23_6P_2SOT23_6P_2
U6SOT23_6P_2SOT23_6P_2
U7SOT23_6P_2SOT23_6P_2
U8MSOP10_W120_PT05MSOP10_W120_PT05
U9TSSOP20_W170_PT065TSSOP20_W170_PT065
U10PSOP8_W150_PT50_PAD-UP7719B_1PSOP8_W150_PT50_PAD-UP7719B_1
U11SOT23_6P_2SOT23_6P_2
U12MSOP10_W120_PT05MSOP10_W120_PT05
U13TSSOP20_W170_PT065TSSOP20_W170_PT065
U14SOT23_8P_1SOT23_8P_1
U15QFN20_ISL95870B_1QFN20_ISL95870B_1
U16QFP128QFP128
U17SOT23_6P_2SOT23_6P_2
U18TO92_OGI_78L05_2TO92_OGI_78L05_2
U19DFN10_RT8106A_1DFN10_RT8106A_1
U20SOT23_6P_2SOT23_6P_2
U21SOP14_W150_PT50SOP14_W150_PT50
U22SOT23_8P_1SOT23_8P_1
U23SOT23_8P_1SOT23_8P_1
U24SOP8_W150_PT50-86X86SOP8_W150_PT50-86X86
U25SOP8_W150_PT50-92X110SOP8_W150_PT50-92X110
U27SOT23_6P_2SOT23_6P_2
U28SOP8_W150_PT50SOP8_W150_PT50
U29PSOP8_W150_PT50_P6NMNPPSOP8_W150_PT50_P6NMNP
U30SOT23_5P_1SOT23_5P_1
U31SOT23_5P_1SOT23_5P_1
U32SOP8_W150_PT50SOP8_W150_PT50
U35SOT23_6P_2SOT23_6P_2
U48QFN48_PT04-4D4X4D4MM_1QFN48_PT04-4D4X4D4MM_1
U49SOP8_W150_PT50SOP8_W150_PT50
U50SOP8_W150_PT50SOP8_W150_PT50
U52SOT23_8P_1SOT23_8P_1
U60SOT23_6P_2SOT23_6P_2
U61SOT23_6P_2SOT23_6P_2
USBUSBX4_2USBX4_2
USB3FCON10X2_2MM_20P_USB3_1CON10X2_2MM_20P_USB3_1
USB3LAN1RJ45_USB3_32PRJ45_USB3_32P
VGA1VGA-THIEF_1VGA-THIEF_1
X1CRYSTALCRYSTAL
X2CRYSTALCRYSTAL
X4CRYSTALCRYSTAL
Y1ETXTALS-SPADETXTALS-SPAD
重要提示:PCB作品文件展下载说明
老吴 | 2017-5-19 22:29:19 | 显示全部楼层
PCB文件和原理图。原理图是PDF格式。PCB是 ALLEGRO16.6格式
Q77_B75H2-AM2-V1.0.7z (9.09 MB, 下载次数: 75)
bidezhi7777 | 2017-5-19 22:48:42 | 显示全部楼层
是不是有点过时了,但封装还要提取一下
老吴 | 2017-5-19 23:02:48 | 显示全部楼层
riverhill | 2017-5-20 08:15:47 | 显示全部楼层
单枪舞九州 | 2017-5-20 08:18:42 | 显示全部楼层
gyj82117 | 2017-5-20 08:36:22 | 显示全部楼层
miaomiao | 2017-5-20 08:46:32 | 显示全部楼层
cdl511 | 2017-5-20 08:49:38 | 显示全部楼层
bidinghong | 2017-5-20 08:53:06 | 显示全部楼层
谢谢老师分享电脑主板系列PCB
