用户在使用STM32时,可以利用其内部的PVD对VDD的电压进行监控,通过电源控制寄存器(PWR_CR)中的PLS[2:0]位来设定监控的电压值。
PLS[2:0]位用于选择PVD监控电源的电压阀值:
000:2.2V
001:2.3V
010:2.4V
011:2.5V
100:2.6V
101:2.7V
110:2.8V
111:2.9V
在电源控制/状态寄存器(PWR_CSR)中的PVDO标志用来表明VDD是高于还是低于PVD设定的电压阀值。该事件连接到外部中断的第16线,如果该中断在外部中断寄存器中被使能的,该事件就会产生中断。当VDD下降到PVD阀值以下和(或)当VDD上升到PVD阀值之上时,根据外部中断第16 线的上升/下降边沿触发设置,就会产生PVD中断。这一特性可用于发现电压出现异常时,执行紧急关闭任务。
下面是用于测试PVD的代码:
主程序的代码:
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void EXTI_Configuration(void);
void NVIC_Configuration(void);
/* Private functions ---------------------------------------------------------*/
STM32 中文应用文档
* Function Name : main
* Description : Main program
* Input : None
* Output : None
* Return : None
int main(void)
RCC_Configuration(); /* System Clocks Configuration */
GPIO_Configuration(); /* Configure the GPIO ports */
NVIC_Configuration(); /* NVIC configuration */
EXTI_Configuration();
PWR_PVDLevelConfig(PWR_PVDLevel_2V8);
PWR_PVDCmd(ENABLE);
while(1) {}
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
RCC_DeInit(); // RCC system reset(for debug purpose)
RCC_HSEConfig(RCC_HSE_ON); // Enable HSE
HSEStartUpStatus = RCC_WaitForHSEStartUp(); // Wait till HSE is ready
if(HSEStartUpStatus == SUCCESS) {
RCC_HCLKConfig(RCC_SYSCLK_Div1); // HCLK = SYSCLK
RCC_PCLK2Config(RCC_HCLK_Div1); // PCLK2 = HCLK
RCC_PCLK1Config(RCC_HCLK_Div1); // PCLK1 = HCLK/2
FLASH_SetLatency(FLASH_Latency_2); // Flash 2 wait state
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); // Enable Prefetch Buffer
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); // PLLCLK = 8MHz * 9 = 72 MHz
RCC_PLLCmd(ENABLE); // Enable PLL
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) {} // Wait till PLL is ready
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); // Select PLL as system clock source
while(RCC_GetSYSCLKSource() != 0x08) {} // Wait till PLL is used as system clock source
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
STM32 中文应用文档
* Function Name : GPIO_Configuration
* Description : Configures the different GPIO ports.
* Input : None
* Output : None
* Return : None
GPIO_InitTypeDef GPIO_InitStructure;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure); //GPIO B
* Function Name : EXTI_Configuration
* Description : Configures .
* Input : None
* Output : None
* Return : None
EXTI_InitTypeDef EXTI_InitStructure;
EXTI_DeInit();
EXTI_StructInit(&EXTI_InitStructure);
EXTI_InitStructure.EXTI_Line = EXTI_Line16;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure); // Configure EXTI Line16 to generate an interrupt
* Function Name : NVIC_Configuration
* Description : Configures Vector Table base location.
* Input : None
* Output : None
* Return : None
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
STM32 中文应用文档
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); // Configure one bit for preemption priority
NVIC_InitStructure.NVIC_IRQChannel = PVD_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure); // Enable the PVD Interrupt
中断程序:
* Function Name : PVD_IRQHandler
* Description : This function handles PVD interrupt request.
* Input : None
* Output : None
* Return : None
void PVD_IRQHandler(void)
if (PWR_GetFlagStatus(PWR_FLAG_PVDO))
GPIO_WriteBit(GPIOB, 1 << 5, Bit_SET);
else
GPIO_WriteBit(GPIOB, 1 << 5, Bit_RESET);
注:在void EXTI_Configuration(void)中,对于EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling; 中的初始化值,根据你的需要进行修改,具体细节如下:
EXTI_Trigger_Rising --- 表示电压从高电压下降到低于设定的电压阀值产生中断;
EXTI_Trigger_Falling --- 表示电压从低电压上升到高于设定的电压阀值产生中断;
EXTI_Trigger_Rising_Falling --- 表示电压从高电压下降到低于设定的电压阀值、或从低电压上升到高于设定的电压阀值产生中断。
本文PDF格式:
1.pdf
<em class="xg1">(66.5 KB, 下载次数: 5)
</em>
2009-11-25 17:28:46 上传
下载次数: 5
下载积分: 积分 -1
最初发表日期:2008-7-16 |
