查看: 10583|回复: 50
[Pads_VX.2x] 802.11 a/b/g/n Dual band  AR9342 RGMII/RMII / PCIe  REFER
    昨天 08:02
  • 签到天数: 159 天
    1元学习Allegro(230718)
    网络监控器IPCAMERA,视
    终身成就奖社区居民特殊贡献奖
    发表于 2017-6-11 00:10:10 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    AR9342 RGMII/RMII / PCIe REFERENCE DESIGN ,802.11 a/b/g/n Dual band
    MI124-245-01988-025-SCH.rar (194 KB, 下载次数: 42) MI124-250-01988-020-PCB.rar (510 KB, 下载次数: 46)
    AR9342_Autelan_0111.pdf (3.93 MB, 下载次数: 31)
    板子含有一下元件:
    CAP,0201,COG,0.2pF,+/-0.1pF,50VL571
    CAP,0201,COG,0.3pF,+/-0.1pF,50VC410,C4132
    CAP,0201,COG,0.5pF,+/-0.1pF,25VC427,C430,C431,C437,C439,C441,C564,C567,C674,L68,L69,L71,L7213
    CAP,0201,COG,0.6pF,+/-0.1pF,50VC374,C3752
    CAP,0201,COG,10pF,+/-5%,50VC672,C701,C702,C707,C708,C709,C710,C711,C713,C715,C722,C72912
    CAP,0201,X7R,100pF,+/-10%,25VC2301
    CAP,0201,X7R,1000pF,+/-10%,25VC57,C112,C147,C183,C719,C721,C726,C7288
    CAP,0201,X7R,0.01uF,+/-10%,10VC446,C4472
    CAP,0201,X5R,0.1UF,+/-10%,6.3VC3,C53,C54,C55,C56,C60,C61,C62,C67,C68,C69,C70,C71,C72,C73,C74,C75,C76,C78,C111,C125,C134,C135,C136,C138,C146,C155,C156,C157,C161,C174,C176,C177,C178,C180,C187,C193,C194,C195,C196,C203,C204,C205,C206,C215,C216,C217,C218,C219,C220,C228,C718,C720,C725,C727,C737,C738,C739,C740,C741,C742,C744,C745,C74664
    CAP,0201,COG,1.0pF,+/-0.25pF,50VC378,C408,C409,C414,C6135
    CAP,0201,COG(HIGH-Q),1.3pF,+/-0.1pF,25VC4121
    CAP,0201,COG,2.2pF,+/-0.25pF,50VC383,C422,C432,C433,C436,C442,C443,C723,C730,R612,R61811
    CAP,0201,COG,3.3pF,+/-0.25pF,50VC423,C424,C428,C4384
    CAP,0201,COG,6.8pF,+/-0.25pF,50VC703,C704,C712,C714,C716,C7176
    CAP,0201,COG,8.2pF,+/-0.5pF,25VC381,C388,C406,C407,C411,C415,C416,C4178
    CAP,0402,NPO,10pF,+/-5%,50VC207,C291,C3773
    CAP,0402,X7R,0.01uF,+/-10%,25VC1141
    CAP,0402,X5R,0.1uF,+/-10%,10VC1,C8,C10,C12,C64,C65,C66,C77,C79,C81,C86,C91,C96,C97,C98,C100,C101,C104,C105,C109,C116,C118,C120,C123,C128,C129,C130,C133,C141,C143,C149,C150,C151,C152,C154,C159,C160,C163,C171,C172,C173,C181,C185,C213,C214,C233,C73447
    CAP,0402,X5R,1uF,+/-10%,6.3VC2,C5,C108,C122,C124,C140,C142,C145,C153,C162,C170,C73512
    CAP,0402,NPO,8.2pF,+/-0.25pF,50VC27,C282
    CAP,0603,X5R,1uF,+/-10%,6.3VC1841
    CAP,0603,X5R,10uF,+/-20%,6.3VC164,C165,C166,C1674
    CAP,0603,X5R,4.7uF,10%,6.3VC7321
    CAP,0805,X5R,10uF,10%,6.3VC4,C9,C11,C99,C106,C107,C115,C127,C158,C175,C182,C199,C200,C222,C223,C379,C384,C393,C394,C736,C74321
    CAP,0805,X5R,22uF,+/-20%,6.3VC6,C7,C119,C137,C148,C7336
    CAP,ELECT,100uF,+/-20%,25V,RADIAL,THC901
    RES,0201,0OHMS,+/-5%,1/20WC724,C731,R2,R5,R606,R607,R629,R630,R631,R632,R63311
    RES,0201,1KOHMS,+/-5%,1/20WR74,R79,R554,R5584
    RES,0201,10KOHMS,+/-5%,1/20WR140,R142,R1733
    RES,0201,22OHMS,+/-5%,1/20WR18,R19,R20,R21,R22,R23,R24,R25,R26,R27,R28,R29,R38,R39,R40,R41,R42,R71,R72,R73,R75,R611,R61723
    RES,0201,27OHMS,+/-5%,1/20WR553,R5572
    RES,0201,49.9OHMS,+/-1%,1/20WR43,R44,R45,R46,R47,R48,R49,R51,R52,R53,R54,R55,R57,R61,R67,R68,R69,R7018
    RES,0201,56KOHMS,+/-5%,1/20WR555,R5562
    RES,0201,68OHMS,+/-5%,1/20WR171
    RES,0402,0OHMS,+/-5%,1/16WR3,R4,R13,R56,R83,R84,R85,R90,R93,R95,R96,R102,R111,R127,R131,R149,R152,R155,R157,R158,R183,R184,R185,R186,R187,R188,R189,R190,R194,R609,R610,R615,R616,R621,R624,R63736
    RES,0402,1KOHMS,+/-0.1%,1/16WR1791
    RES,0402,10KOHMS,+/-5%,1/16WR1,R92,R98,R100,R103,R124,R139,R144,R145,R146,R156,R175,R63613
    RES,0402,100KOHMS,+/-1%,1/16WR196,R1992
    RES,0402,1.5KOHMS,+/-5%,1/16WR501
    RES,0402,22OHMS,+/-5%,1/16WR30,R32,R33,R34,R355
    RES,0402,220OHMS,+/-5%,1/16WR133,R134,R136,R138,R1475
    RES,0402,2.37KOHMS,+/-1%,1/16WR121
    RES,0402,49.9OHMS,+/-1%,1/16WR311
    RES,0402,560OHMS,+/-1%,1/16WR631
    RES,0402,56KOHMS,+/-1%,1/16WR1971
    RES,0402,6.19KOHMS,+/-1%,1/16WR141
    RES,0402,68OHMS,+/-5%,1/16WR15,R162
    RES,0603,0OHMS,+/-5%,1/10WR193,R198,R201,R202,R203,R205,R206,R207,R208,R210,R211,R23312
    RES,0603,1OHM,+/-5%,1/10WR212,R2132
    RES,0805,0OHMS,+/-5%,1/8WR195,R204,R2093
    IND,0201,FILM,1.2nH,+/-0.2nHL512,L5152
    IND,0201,FILM,1.5nH,+/-0.1nHC425,C426,C434,C4454
    IND,0201,FILM,1.8nH,+/-0.1nHL70,L73,L75,L774
    IND,0201,FILM,2.0nH,+/-0.1nHC380,C3822
    IND,0201,FILM,3.3nH,+/-0.1nHC3911
    IND,0201,FILM,3.9nH,+/-0.1nHC387,L54,L55,L62,L635
    IND,0201,FILM,3.9nH,+/-0.2nHL513,L5162
    IND,0201,FILM,4.7nH,+/-0.2nHL517,L5182
    IND,0402,5.6nH+/-0.1nHR121,R1232
    IND,0402,6.8nH+/-0.1nHR112,R1192
    IND,FERRITE,2.2uH,20%L11
    IND,SMT,3.3uH,+/-20%L211
    AR9342,WASPSINGLE CHIP,2X2, 2.4/5 GHz,802.11N,WLANs,QFNU11
    XTAL,SMD,40MHz,4pin,21ppm,3.2X2.5MMY21
    DIO,SBR3A40SA,3A,SUPERBARRIER RECTIFIER,SMAD21
    LED,GREENCLEAR,0603,SMDDS1,DS2,DS3,DS4,DS55
    TRA,SOT-23,PNPGeneral Purpose AmplifierQ1,Q22
    ***Use135-00167-000***U31
    IC,Memory,MX25L3205D,32M-bitSPI FLASH, SO8U51
    SWITCH,LTSWITCH RT ANGLE_Thru_HoleSW1,SW22
    CON,Thru_Hole,6X2,.1X.1,GoldPlated,12 PinJP11
    CON,Thru_Hole,7X2,.1X.1,ST,Gold,14PJ41
    CON,Thru_Hole,9X2,.1X.1,GoldPlated,18 PinJP21
    CON,TESTPIN,Thru_Hole,BLACK,HAND SOLDERED ONLYTPC11
    CON,Ultra-MiniatureCoaxJ11,J192
    CON,SM,52pin,PCIEXPRESS MINI CARDJ71
    RF_SPEC,TRANS,SiGe,HF,TSLP-3-9Q505,Q5062
    RF_SPEC,PASE5005L,5GHz,QFN16U8,U92
    RF_SWI,PHEMT GAAS SP3T 0.1-6.0 GHz,8PS502,S5032
    REG,RT8258,1.2A,24V,700kHz,SOT23-6U71
    MI124-020PCB
    NO LOADCOMPONENTs
    NO_LOAD,RES,0201R58,R59,R60,R62,R77,R78,R167,R178,R180,R181,R182,R613,R614,R619,R620,R622,R623,R625,R62619
    NO_LOAD,RES,0402R36,R37,R81,R91,R94,R97,R99,R101,R104,R105,R106,R107,R108,R110,R113,R114,R115,R117,R118,R125,R126,R129,R135,R137,R141,R150,R151,R153,R154,R159,R161,R162,R174,R191,R192,R627,R628,R634,R63539
    NO_LOAD,RES,0603R200,R2292
    NO_LOAD,IND,0201L56,L59,L60,L74,L765
    评分
    参与人数 1威望 +20 收起 理由
    老吴 + 20 这样把BOM 列出来,大奖励。
    查看全部评分
    重要提示:PCB作品文件展下载说明
    昨天 08:13
  • 签到天数: 129 天
    你必须非常努力才能显
    发表于 2017-6-11 06:53:53 | 显示全部楼层
    社区居民忠实会员终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2017-6-11 08:36:22 | 显示全部楼层
    昨天 08:42
  • 签到天数: 183 天
    终身成就奖社区居民特殊贡献奖优秀斑竹奖
    发表于 2017-6-11 08:45:00 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2017-6-11 08:51:43 | 显示全部楼层
    发表于 2017-6-11 08:52:14 | 显示全部楼层
    1元学习PADS(1期)
    发表于 2017-6-11 08:53:19 | 显示全部楼层
  • 签到天数: 19 天
    终身成就奖优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2017-6-11 08:55:31 | 显示全部楼层
    订好的资源呀。。。。
    社区居民忠实会员终身成就奖
    发表于 2017-6-11 08:57:50 | 显示全部楼层
    前天 13:27
  • 签到天数: 89 天
    1元学习Allegro(1期)
    发表于 2017-6-11 09:02:44 | 显示全部楼层
