李现路:在DSP6000中怎样编写您的第一个程序(二) Post By:2009-11-23 23:46:16
三、完整的中断向量表程序如下:
.global _vectors ;定义一个能被外部(C语言程序)引用的变量
.global _c_int00
.global _vector1
.global _vector2
.global _vector3
.global _vector1
.global _vector5
.global _vector6
.global _vector7
.global _vector8
.global _vector9
.global _vector10
.global _vector11 ; Hookup the c_int08 ISR(连接这个中断设置寄存器) in main()
.global _vector12 ; Hookup the c_int08 ISR in main()
.global _vector13
.global _vector14
.global _vector15
完整版本请见http://www.51qianru.cn/bbs/
* Global symbols referenced in this file but defined somewhere else.
* Remember that your interrupt service routines need to be referenced here.
.ref _c_int00 ;reset ISR(复位中断设置寄存), .ref表明一个或多个在另一个模块中定义而在前模块中要用到的符号
* This is a macro that instantiates one entry in the interrupt service table.
VEC_ENTRY .macro addr ;中断返回函数
STW B0,*--B15
MVKLaddr,B0
MVKHaddr,B0
B B0
LDW *B15++,B0
NOP 2
NOP
NOP
.endm
* This is a dummy interrupt service routine used to initialize the IST.
_vec_dummy:;初始化IST寄存器(中断向量表起始地址寄存器,用于设置中断服务程序存放的地址)
B B3
NOP5
* This is the actual interrupt service table (IST). It is properly aligned and
* is located in the subsection .text:vecs. This means if you don't explicitly
* specify this section in your linker command file, it will default and link
* into the .text section. Remember to set the ISTP(中断向量表起始地址寄存器) register to point to this
* table.
.sect ".vecs";定义初始化带名称的段
.align 1024;分配程序页
_vectors:
_vector0: VEC_ENTRY _c_int00 ;RESET(应用程序的入口)
_vector1: VEC_ENTRY _vec_dummy;NMI(非屏蔽中断,用于处理极为关键的任务)
_vector2: VEC_ENTRY _vec_dummy;RSVD
_vector3: VEC_ENTRY _vec_dummy
_vector4: VEC_ENTRY _vec_dummy
_vector5: VEC_ENTRY _vec_dummy
_vector6: VEC_ENTRY _vec_dummy
_vector7: VEC_ENTRY _vec_dummy
_vector8: VEC_ENTRY _vec_dummy
_vector9: VEC_ENTRY _vec_dummy
_vector10:VEC_ENTRY _vec_dummy
_vector11:VEC_ENTRY _vec_dummy ; Hookup the c_int08 ISR in main()
_vector12:VEC_ENTRY _vec_dummy ; Hookup the c_int08 ISR in main()
_vector13:VEC_ENTRY _vec_dummy
_vector14:VEC_ENTRY _vec_dummy
_vector15:VEC_ENTRY _vec_dummy
曙海教育
曙海嵌入式学院3G通信培训中心
(MTK培训,Android培训,iPhone培训)
电话:021-51875830
网址:http://www.51qianru.cn
讲师:李现路
版权所有-曙海教育 转摘请注明作者和出处课程有:
三、完整的中断向量表程序如下:
.global _c_int00
.global _vector1
.global _vector2
.global _vector3
.global _vector1
.global _vector5
.global _vector6
.global _vector7
.global _vector8
.global _vector9
.global _vector10
.global _vector13
.global _vector14
.global _vector15
STW B0,*--B15
MVKLaddr,B0
MVKHaddr,B0
B B0
LDW *B15++,B0
NOP 2
NOP
NOP
.endm
B B3
NOP5
* table.
.align 1024;分配程序页
_vectors:
曙海教育
曙海嵌入式学院3G通信培训中心
电话:021-51875830
讲师:李现路
版权所有-曙海教育 转摘请注明作者和出处课程有: |
