TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 24548
重要提示:PCB作品文件展下载说明
全网独家首发。。
Name | Part Type | PCB Decal | Value | CN601 | USB-B_1 | USB_MINI_4P | USB-A | CN602 | USB-B_1 | USB_MINI_4P | USB-A | CON2 | INVERTER_1 | CN6-20A | CON6_2.0 | CON101 | CH2-3056S_2 | PHONEJACK_SW_SA | PHONEJACK | CON102 | CON2 | CN2-20A | CON2_2.0 | CON103 | CON2 | CN2-20A | CON2_2.0 | CON500 | CONNECTOR_COAX-J_0_2 | RCV3-14MM-1 | AV3 | CON501 | CONNECTOR_COAX-J_0 | RCV2-14MM-1 | AV2 | CON502 | CONNECTOR_COAX-J_1 | AVB-1 | AV1 | CON601 | DB15_HD_0 | VGAS | VGA | CON700 | HDMI_J_2_VERTER_2 | HDMI_TYPE_A | HDMI/90D | CON701 | HDMI_J_2_VERTER_2 | HDMI_TYPE_A | HDMI/90D | CON702 | HDMI_J_2_VERTER_2 | HDMI_TYPE_A | HDMI/90D | CON703 | HDMI_J_2_VERTER_2 | HDMI_TYPE_A | HDMI/90D | CON1100 | DEMOD_SOCKET_1 | DEMOD-S | SOCKET | D7 | BAV99_SMD | SOT-23 | BAV99 | D609 | DIODE_SCHOTTKY | DO-214 | 0R | F1200 | FUSE | AXIAL0.4 | 5A/12V | F1201 | FUSE | R1206 | NC/5A/12V | H2 | HOLE-V8 | HOLE4-7 | NC | H3 | HOLE-V8 | HOLE4-7 | NC | H4 | HOLE-V8 | HOLE4-7 | NC | H5 | CON3_3 | TPAD | NC | H6 | CON3_3 | TPAD | NC | H7 | CON3_3 | TPAD | NC | J104 | CON9_1 | CN8-20A | CON8-2.0 | J113 | HEADER_1X4-2MM_180D | CN4-20A | CON4-2.0 | J114 | HEADER_1X4-2MM_180D | CN4-20A | NC/CON4-2.0 | J452 | DIP-36(2_18)_0 | CON20X2-2.0-LVDS | DIP\40\2X20 | J455 | FI-RE51S-HF_2 | CON-FI-RE51S-HF | FI-RE51S-HF | J501 | HEADER_1X4-2MM_180D | CN4-20A | CON4-2.0 | J503 | HEADER_1X4-2MM_180D | CN4-20A | CON4-2.0 | J504 | CON6_2_0.0MM | CN7-20A | CN7-2.0 | J1201 | CON12_0 | CN12-20A | NC/CON12_2.0 | J1202 | DC_JACK_0 | DC-JACK3P | DCJACK | L42 | INDUCTOR_2 | L0402 | FB | L1204 | INDUCTOR_IRON_2 | SMD03X03 | SWPA3015S2R2NT/1.5A | L1205 | INDUCTOR_IRON_2 | SMD04X04 | SWPA4030S2R2NT/2.95A | LED1202 | 7012X/SM_2 | LED | LED/GREEN | LED1203 | 7012X/SM_2 | LED | LED/GREEN | LP3 | INDUCTOR_IRON_2 | SMD08X08 | SWPA8040S4R7NT/4A | NC/Q700 | NPN(BEC)_0 | SOT-23 | 3904 | NC/Q702 | NPN(BEC)_0 | SOT-23 | 3904 | NC/Q704 | NPN(BEC)_0 | SOT-23 | 3904 | Q1 | P_DGS_0 | SOT23-100 | AO3401A | Q2 | NPN(BEC)_0 | SOT-23 | 3904 | Q450 | P_DGS_0 | SOT23-100 | AO3401A | Q451 | NPN(BEC)_0 | SOT-23 | 3904 | Q453 | P_DGS_0 | SOT23-100 | NC/AO3401A | Q580 | _N_DSG_0 | SOT-23 | NC/2N7002 | Q703 | NPN(BEC)_0 | SOT-23 | 3904 | Q1002 | NPN_BEC_3 | SOT-23 | 3904 | Q1003 | PNP(BEC)_0 | SOT-23 | 3906 | Q1004 | NPN_BEC_3 | SOT-23 | 3904 | Q1200 | NPN(BEC)_0 | SOT-23 | 3904 | Q1201 | P_DGS_0 | SOT23-100 | AO3401A | Q1202 | NPN(BEC)_0 | SOT-23 | 3904 | RP452 | RP47X4 | RP0402 | NC/0RX4 | RP453 | RP47X4 | RP0402 | NC/0RX4 | RP454 | RP47X4 | RP0402 | NC/0RX4 | RP455 | RP47X4 | RP0402 | NC/0RX4 | SW1200 | ROCKER_SWITCHES | SW-2P-MRA1KKAT0B | PWR-SWITCH | T901 | TRF_ATB2012_75011_NTP | TRANS_ATB2012 | BW21S7511A01TF | TP1 | TEST_POINT_1 | TP-0.5MM | NC | TP2 | TEST_POINT_1 | TP-0.5MM | NC | TP3 | TEST_POINT_1 | TP-0.5MM | NC | TP4 | TEST_POINT_1 | TP-0.5MM | NC | TP5 | TEST_POINT_1 | TP-0.5MM | NC | TP6 | TEST_POINT_1 | TP-0.5MM | NC | TU1 | FK1602_CAN_TUNER | FK1602 | NC/FK1602 | TU2 | CON3_2 | TUNER-C2 | J | U2 | SOT-223 | SOT-223 | AMS1117-3.3 | U4 | PAM2301 | SOT-23-5 | SY8089 | U5 | PAM2301 | SOT-23-5 | SY8032/SY8032E | U48 | CHINA_3 | IC-156P-EPLQFP | MSD3458/MSD6190 | U103 | M24CXX_0 | SOP8-255-50 | MX25L3205 | U104 | IR | IR-1 | IR | U702 | RT9711A_1 | SOT-23-5 | SGM2588E | U901 | SOT-223 | SOT-223 | NC/AMS1117L-3.3 | U905 | MXL601RF_0 | QFN24_MXL601 | MxL661 | U1001 | SP490_1 | IC-24P-TSSOP-6_4MM-G | MSH9010 | U1201 | AOZ1036_41 | DFN3X3-12 | SY8368A | Y001 | CRYSTAL-2PIN_0 | XTAL\HC49\F | 16.000MHz | Y100 | CRYSTAL-2PIN_0 | XTAL\HC49\F | 24.000MHz |
资料在二楼,全部都有。 |
重要提示:PCB作品文件展下载说明
