TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 21119
PCB和原理图都是PADS9.5格式
Name | Part Type | PCB Decal | Value | ANT96 | ANT2 | ANT-C | ANT | CN1 | CON-SMD22P-0.5MM | CON-SMD22PIN-0.5MM | 20P 0.5mm | CN2 | CON4_5 | 4P/1.25MM | CON4 | CN3 | CON-SMD22P-0.5MM | CON-SMD22PIN-0.5MM | 20P 0.5mm | CN4 | CON4_5 | 4P/1.25MM | CON4 | CN5 | CON4_5 | 4P/1.25MM | CON4 | CN6 | CON4_6 | FPC-4P-1.0MM | FPC4-1.0D | CN9 | CON2_0 | CCFL-LAMP | LED-PANEL | CON1 | CON-SMT-60PIN-HANNSTAR | FPC-60PIN-0.5MM | | CON2 | C200_LVDS_CON_4P | C200_LVD_CON_4P | | CON3 | CON94 | CON94 | | CON4 | CON74 | CON74 | | D1 | DIODE | DIODE_DO201AD_7MM | IN5401 | D2 | TVS | STVS0603 | ESD | D3 | TVS | STVS0603 | NC | D4 | DS | SD2010 | SS14 | D5 | DIODE | SD0805 | IN4148W | D6 | DIODE | SD0805 | IN4148W | D7 | TVS | STVS0603 | ESD | D8 | DS | SD2010 | SS14 | D9 | BAT54C | SOT23-BAT54 | BAT54C | D10 | TVS | STVS0603 | 0603ESDA-LP | D11 | TVS | STVS0603 | 0603ESDA-LC | D12 | DIODE | SD0805 | IN4148W | D13 | TVS | STVS0603 | 0603ESDA-LP | D14 | TVS | STVS0603 | ESD | D15 | BAT54C | SOT23-BAT54 | BAT54C | D21 | TVS | STVS0603 | 0603ESDA-LC | D23 | TVS | STVS0603 | 0603ESDA-LC | D24 | TVS | STVS0603 | 0603ESDA-LC | D26 | DIODE_DIAC | ESD0603 | ESD | D27 | TVS | STVS0603 | ESD | D28 | DIODE_DIAC | ESD0603 | ESD | D30 | DIODE | SD0805 | 1N4148 | D31 | DIODE | SD0805 | 1N4148 | F1 | FUSE | SF1308 | 500MA | F3 | FUSE | SF1308 | 500MA | F4 | FUSE | SF1308 | 200MA | FB1 | INDUCTOR_0_2 | RES0805 | 600R | FB2 | INDUCTOR_0 | L0603 | 600R | FB3 | FB | L0805 | SZ2012K421TF | FB4 | FB | SLB0805 | SZ2012K601TF | FB5 | FB | L0805 | FB310 | FB8 | FB | SLB0805 | SZ2012K601TF | FB9 | INDUCTOR_0 | L0603 | 600R | FB11 | INDUCTOR_0_2 | RES0805 | 600R | FB12 | INDUCTOR_0 | L0603 | 600R | FB13 | FB | L0805 | SZ2012K421TF | J1 | SIP32AM | CON32P-A1.0MM | 32P-1.0MM下接 | J2 | DD | TAP | | J3 | DD | TAP | | J4 | DD | TAP | | J5 | RCA_54PIN | RCA-54PIN | | J6 | CON-4PIN-IPOD | SIP4-78D74-32D | USB_JK CON | J7 | DD | TAP | | J8 | DD | TAP | | J9 | DD | TAP | | J10 | 32PIN | 32PINAAAAAAAAAAA | | J11 | DD | TAP | | J12 | DD | TAP | | J13 | DD | TAP | | J14 | IS0-54PIN | HD54 | | J15 | GPSANT | GPSANTA | CON5 | J16 | GPSANT | GPSANTA | CON5 | J17 | FM-4750 | DIP-10PIN-FM | TDQ-30FMV-001 | J18 | FCC-10P-1.25MM | CON-10P-1.25MM | FCC-10P-1.25MM | L1 | FB | SL0805 | 1.8uH | L2 | IND | L-5X5 | 10uH/1.6A | L3 | FB | SL0805 | 1.8uH | L4 | IND_18X25MM | L-13/25 | 35mH非晶呃流线圈 | L5 | IND | L-5X5 | 10uH/1.6A | L6 | FB | SL0805 | 1.8uH | L7 | INDUCTOR/CHIP | CF2522 | 3.3UH | L15 | CD74 | IND-SMT-CD75 | 22UH | L21 | INDUCTOR/CHIP | IND-SMD-CDH8B28/38/43/58 | 2.2MH | L51 | FB | SL0805 | 1.8uH | Q1 | NPN | SOT23 | 9014 | Q2 | NPN | SOT23 | 9014 | Q3 | NPN | SOT23 | 9014 | Q4 | PNP | SOT23 | 8550 | Q5 | NPN | SOT23 | 9014 | Q6 | PNP | SOT23 | 8550 | Q7 | PMOS | SOT23-MOS | DMP3098L | Q8 | NPN | SOT89 | 8050 | Q9 | NPN | SOT23 | 9014 | Q10 | PMOS | SOT23-MOS | DMP3098L | Q11 | PMOS | SOT23-MOS | DMP3098L | Q12 | NPN | SOT23 | 9014 | Q13 | NPN | SOT23 | 9014 | Q14 | NPN | SOT23 | 3904 | Q15 | PNP | SOT23 | MMBT3906 | Q16 | PNP | SOT23 | 8550 | Q17 | NPN | SOT23 | 9014 | Q18 | NPN | SOT23 | 9014 | Q19 | NPN | SOT23 | 9014 | Q20 | NPN | SOT23 | MMBT3904 | Q21 | NPN | SOT23 | 3904 | Q23 | PMOS | SOT23-MOS | DMP3098L | Q24 | NPN | SOT23 | 3904 | Q25 | PNP | SOT23 | 8550 | Q26 | PNP | SOT23 | 8550 | Q27 | PMOS | SOT23-MOS | DMP3098L | Q28 | NPN | SOT23 | 9014 | SC1 | SCREW-2.6-3.0MM | SCREW-2.6MM-4 | | SC2 | SCREW-2.6-3.0MM | SCREW-2.6MM-4 | | SC3 | SCREW-2.6-3.0MM | SCREW-2.6MM-4 | | SC4 | SCREW-2.6-3.0MM | SCREW-2.6MM-4 | | SC5 | SCREW-2.6-3.0MM | SCREW-2.6MM-4 | | SC6 | SCREW-2.6-3.0MM | SCREW-2.6MM-4 | | U1 | MN101EF51A_1 | QFP44-31D5-472 | MN101EF51A | U2 | RT9164-33CG//AIC1117-33CY_0 | SOT223 | 1117/3.3V | U3 | MTK_CON126_1.27MM | MTK_CON126_1.27MM | | U4 | SGM9119 | SOP8-25D59-197 | SGM9119 | U6 | MP3302 | SOT23-5 | MP3302 | U7 | MP1541 | SOT23-5 | MP1541 | U11 | TDA7381_0 | TDA7386A | TDA7388 | U16 | HT7133 | SOT89-1 | HT7533 | Z1 | DZ | SD0805-1 | 5.6V | Z2 | DZ | SD0805-1 | 5.6V | Z3 | DZ | SD0805-1 | 5.6V | Z4 | DZ | SD0805-1 | BZT52C9V1 | Z5 | DIODE | SD0805 | IN4148W | Z6 | DZ | SD0805-1 | BZT52C15V | Z7 | DZ | SD0805-1 | BZT52C6V8 | Z10 | DZ | SD0805-1 | 3V9 | ZD4 | BAV99 | SOT23-BAV99 | BAT54S | ZD5 | BAV99 | SOT23-BAV99 | BAT54S |
