TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20878
Name | PCB Decal | Value | Part Type | ANT | ANT-C | ANT | ANT2 | CN1 | CN-SMD4P-H-1.25-A | 4Px1.25mm | CN4P | CN5 | CN-SMD4P-H-1.25-A | 4Px1.25mm | CN4P | CON1 | JACK_60PIN_2.0MM | | JACK60PIN_2.0MM | D1 | STVS0603 | 0603ESDA-LC | TVS | D2 | STVS0603 | 0603ESDA-LC | TVS | D3 | STVS0603 | 0603ESDA-LP | TVS | D4 | SOT23-BAT54 | BAT54C | BAT54C | D5 | SD0805 | IN4148W | DIODE | D6 | SD0805 | IN4148W | DIODE | D7 | STVS0603 | 0603ESDA-LP | TVS | D8 | SOT23-BAT54 | BAT54C | BAT54C | D9 | SOT23-BAT54 | BAT54C | BAT54C | D10 | SOT23-BAT54 | BAT54C | BAT54C | D11 | SD0805 | IN4148W | DIODE | D12 | DIODE2-235A | 1N5401 | DIODE | D13 | SOT23-BAT54 | BAT54C | BAT54C | D14 | STVS0603 | 0603ESDA-05 | TVS | D15 | STVS0603 | 0603ESDA-05 | TVS | D16 | STVS0603 | 0603ESDA-LC | TVS | D17 | STVS0603 | 0603ESDA-LC | TVS | D18 | STVS0603 | 0603ESDA-LC | TVS | D19 | STVS0603 | 0603ESDA-LC | TVS | D20 | STVS0603 | 0603ESDA-LP | TVS | D25 | SOT23-BAT54 | BAT54C | BAT54C | D26 | STVS0603 | 0603ESDA-LC | TVS | D27 | STVS0603 | 0603ESDA-LC | TVS | D28 | SOT23-BAT54 | BAT54C | BAT54C | D29 | STVS0603 | 0603ESDA-LC | TVS | F1 | SF1308B | 500MA | FUSE | F2 | SF1308A | 200MA | FUSE | F3 | SF1308A | 500MA | FUSE | F4 | SF1308A | 200MA | FUSE | FB1 | SLB0805 | SZ2012K601TF | FB | FB2 | SLB0805 | SZ2012K601TF | FB | FB3 | SLB0805 | SZ2012K601TF | FB | FB5 | SLB0805 | SZ2012K601TF | FB | FB7 | SLB0805 | SZ2012K601TF | FB | FB8 | SLB0805 | SZ2012K601TF | FB | FB11 | SLB0805 | SZ2012K601TF(600R) | FB | FB12 | SLB0805 | SZ2012K601TF(600R) | FB | J1 | JACK-26PINAAA | | JACK-26PIN | J2 | FPC10-19D69 | FFC12P-1.0MM-BOT | FFC10-0.5MM | J3 | TAP | | DD | J5 | CON-SMT-32PIN | FFC32P-1.0MM-DIP | SIP34A | J6 | SIP4-78D74-32D | CON4-2.0mm | SIP4-1 | J7 | FPC10-19D69 | FFC12P-1.0MM-BOT | FFC10-0.5MM | J8 | DIP-10PIN-FM | TDQ-30FMV-001 | FM-4750 | J10 | CON36P-1.0MM | FFC36P-1.0MM-BOT | SIP36 | J12 | CON-SMT-4PIN-1.25MM | ?? | SIP6 | JP1 | TEST-1.0 | TP-2 | TEST_1_1 | JP2 | TEST-1.0 | TP-2 | TEST_1_1 | L1 | SLB0805 | 1.8uH | FB | L2 | SLB0805 | 1.8uH | FB | L3 | SLB0805 | 1.8uH | FB | L4 | CHIPINDX7.5 | 22UH | IND22UH | L5 | CF25221 | NC | INDUCTOR/CHIP | L6 | SL3040AA | SWRH1005C-150MT | IND | L21 | CF2522 | NC | INDUCTOR/CHIP | L51 | SL0805 | 1.8uH | FB | L161 | SL3040AA | SWRH1005C-150MT | IND | L221 | EI-28A | 850uH | IND | Q1 | SOT23 | 3904 | NPN | Q2 | SOT23 | 3904 | NPN | Q3 | SOT23 | 3904 | NPN | Q4 | SOT23 | MMBT3906 | PNP | Q5 | SOT23 | MMBT3906 | PNP | Q6 | SOT23 | MMBT3906 | PNP | Q7 | SOT23 | 3904 | NPN | Q8 | SOT23 | MMBT3904/nc | NPN9014 | Q9 | SOT23 | 3904 | NPN | Q10 | SOT23 | 3904 | NPN | Q11 | SOT23-MOS | DMP3098L | PMOS | Q12 | SOT23-MOS | DMP3098L | PMOS | Q13 | SOT23 | 3904 | NPN | Q14 | SOT23 | 3904 | NPN | Q15 | SOT23 | 3904 | NPN | Q16 | SOT23-MOS | DMP3098L | PMOS | Q17 | SOT23 | 3904 | NPN | Q18 | SOT23 | 3904 | NPN | Q20 | SOT23 | 3904 | NPN | Q21 | SOT23-MOS | DMP3098L | PMOS | Q22 | SOT23-MOS | DMP3098L | PMOS | Q23 | SOT23 | MMBT3904 | NPN | Q25 | SOT23 | MMBT3906 | PNP | Q26 | SOT23 | MMBT3906 | PNP | U1 | QFP44-31D5-472 | MN101EF51A | MN101EF51A_1 | U2 | SOP8-50-220 | SGM9119 | SGM9119 | U3 | MSOP-10 | | SGM8905 | U4 | MTK3360_CORE_141 | | MTK_CON141_1.27MM | U5 | SOT23-6 | WS3202E | WS3202E | U6 | MSOP-10 | | SGM8905 | U8 | SOP8-50-220A | MP2303A | MP2303A | U11 | HZIP25 | TDA7387EP | TDA7381_0 | U14 | SOP8-50-220A | MP2303A | LSP5503 | U16 | SOT89-1 | HT7533 | HT7133 | U27 | TSSOP20/CS4361 | CS4361-CZZ /NC | CS4361 | Z1 | SD0805-1 | BZT52C5V6 | DZ | Z2 | SD0805-1 | BZT52C3V9 | DZ | Z3 | SD0805-1 | BZT52C3V9 | DZ | Z4 | SD0805 | IN4148W | DIODE | Z5 | PMDS-1AA | M7 | DIODE | Z7 | PMDS-1AA | M7 | DIODE | Z8 | SD0805 | IN4148W/nc | DIODE | Z9 | SD0805 | IN4148W/nc | DIODE | Z10 | SD0805-1 | BZT52C3V9 | DZ | Z11 | SD1406 | BZT52C16v | DZ |
