[PADS9.5以下] 10层手机PCB MT6589+MT6320+NNS701+MT6628
查看9744 | 回复32 | 2017-7-7 12:15:49 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
Image 2.png 、、
10层设计。。
板子有以下主要元件。
NamePCB DecalValuePart Type
ANT5TP2.5X3.5ANTANT
ANT6TP2.5X3.5ANTANT
ANT1101TP2.2POGOPOGO_ANTENNE
ANT1102TP2.2POGOPOGO_ANTENNE
ANT_FEED1ANT_GSMANT_GSM
ANT_FEED2ANT_GSMANT_GSM
ANT_FEED3ANT_GSMANT_GSM
B4100603L100nH(LQW18ANR10G00)PZ1608D221-1R0TF
CN402AJ_JTCONN_WKUBI005_061AJ_JTCONN_WKUBI005AJ_JTCONN_WKUBI005
CN801FH19SC-10S-0.5SHFH19SC-10S-0.5SHFH19C-10S-0.5SH(05)
CN901ST1W008S4MCAH11-08193-SF01CAH11-08193-SF01
CN902SD-47308-001SIMF006G5K15-00R6000000006
CN903SD-47308-001SIMF006G5K15-00R6000000006
CN1601AXK740147AXK840145WGAXK740147
COIN040J_COIN_BAT_XH414HGIV01Ebattery 20uAh 3.3V2800000000
CON1AXK710145B2B_10PIN_CTP_AXK710
CON2USB(MCB03)ZX62D-B-5PA8
CON801DF30FC-24DS-0.4VAB2B_24PIN_CAMERA_S550_SUB
CON802DF30FC-24DS-0.4VAB2B_24PIN_CAMERA_S550_SUB
CON1201AXK710145B2B_10PIN_CAMERA_AXK710
D1SH_VAR_1_0.6_0.5PESD5V0S1BL2400000006
D2SH_VAR_1_0.6_0.5PESD5V0S1BL2400000006
D3SH_VAR_1_0.6_0.5PESD5V0S1BL2400000006
D301RB551V-30RB521CS-30DIODE_DIP_SCHOTTKY
D302UMD2PZ3D4V2HUDZSTE-175.1B
D303RB551V-30RB521CS-30DIODE_DIP_SCHOTTKY
D304RB551V-30RB521CS-30DIODE_DIP_SCHOTTKY
D305RB551V-30RB521CS-30DIODE_DIP_SCHOTTKY
D306SOD-523200000000
D307SOD-523200000000
D411BZX884-B3V9BZX884-B3V9BZX884-B3V9
D412BZX884-B3V9BZX884-B3V9BZX884-B3V9
D413BZX884-B3V9BZX884-B3V9BZX884-B3V9
D414BZX884-B3V9BZX884-C5V1BZX884-B3V9
D415BZX884-B3V9BZX884-C5V1BZX884-B3V9
D416BZX884-B3V9BZX884-C5V1BZX884-B3V9
D417PESD12VL1BPESD12VL1BPESD12VL1B
D418PESD12VL1BPESD12VL1BPESD12VL1B
D419PESD12VL1BPESD12VL1BPESD12VL1B
D420PESD12VL1BPESD12VL1BPESD12VL1B
D421PESD12VL1BPESD12VL1BPESD12VL1B
D422402ESD 12V 0.2pF2400000001
D423402ESD 12V 0.2pF2400000001
D1413SH_VAR_1_0.6_0.5PESD5V0S1BL2400000006
D1688NSR0620PNSR0620P2T5GNSR0620P
D1689BZX84J-B3V3BZX84J-B3V3BZX84J-B3V3
EMI805TCM0806G-350-2PTCM0806G-350-2PEMIX21A390FNPE_1
F1001BL2012-8PADFB2012-05N2R4GTFB2012-05N2R4E
FEX1604RES040275mA1000000049
J3KKS_ANT_TESTPADKKS_ANT_TEST
J305J_BAT-WKBAV002-D31PAN30-03544-SF19J_BAT-WKBAV002-D31
L1IND0402_HQ4.7NHL0402_4.7NH
L2IND0402_HQ4.7NHL0402_4.7NH
L3IND0402_HQ4.7NHL0402_4.7NH
L4IND0402_HQ4.7NHL0402_4.7NH
L5IND0402_HQ4.7NHL0402_4.7NH
L301L/IND/SMD/2520INDUCTOR
L302L/IND/SMD/2520INDUCTOR
L303L/IND/SMD/2520INDUCTOR
L304L/IND/SMD/2520INDUCTOR
L306L/IND/SMD/2520INDUCTOR
L307L/IND/SMD/2520INDUCTOR
L308L/IND/SMD/2520INDUCTOR
L309L/IND/SMD/2520INDUCTOR
L401BEAD0402BK1005HM102-TB0402-BK1005HM102-T
L402BEAD0402BK1005HM102-TB0402-BK1005HM102-T
L403BEAD0402BK1005HM102-TB0402-BK1005HM102-T
L404IND0402_0.551.8KBLM15BD182SN1D
L405IND0402_0.551.8KBLM15BD182SN1D
L406IND0402_0.551.8KBLM15BD182SN1D
L407IND0402_0.551.8KBLM15BD182SN1D
L408IND0603_0.95BLM18PG221SN1DBLM18SG331TN1D
L409IND0603_0.95BLM18PG221SN1DBLM18SG331TN1D
L611IND0402_HQ_NCNCL0402_NC
L614IND0402_HQ_NCNCL0402_NC
L615IND0402_HQ_NCNCL0402_NC
L616IND0402_HQ27NHL0402_22NH
L618IND0402_HQ33NHL0402_33NH
L619IND0402_HQ_NCNCL0402_NC
L621IND0402_HQ_NCNCL0402_NC
L623IND0402_HQ_NCNCL0402_NC
L631IND0402_HQ4.7NHL0402_2.7NH
L633IND0402_HQ0RL0402_1.0NH_300MA
L634IND0402_HQ_NCNCL0402_NC
L636IND0402_HQ4.7NHL0402_4.7NH
L638IND0402_HQ2.2NHL0402_2.7NH
L653IND0402_HQ4.3NHL0402_4.7NH
L1001IND0402_HQ7.5nHL0402_7.5NH
L1002LQM2MP_0806LQM2MPN2R2NG0LLQM2MPN2R2NG0L
L1003IND0402_HQ6.2nHFERRITE_BEAD_SMD_0402
L1006BEAD0402BK1005HM102-TB0402-BK1005HM102-T
L10100402L100NH?à5%0402L-100NH-5%
L10110402L27NH?à5%0402L-27NH-5%
L10120402L120NH?à5%(NC)0402L-120NH-5%
LCR1001402NC0402L
LCR1002402NC0402L
PAD1PAD_VIBPAD_SPK/REC/MOT_1.2X2
PAD2PAD_VIBPAD_SPK/REC/MOT_1.2X2
Q1VMT3_ROHMNPN-DTC143ZM
Q3012-1L1B/SMD/SSM3K35MFVNCMOSFET_N_2
Q401SOT95P280X135-3LSI2333DS-E3SOT95P280X135-3L
Q402SOT95P280X135-3LSI2333DS-E3SOT95P280X135-3L
Q403SOT95P280X135-3LSI2333DS-E3SOT95P280X135-3L
Q0502PNM23T703E0-2PNM23T703E0-2PNM23T703E0-2
Q801SOT65P210X110-6LSI1902DL-T1-E3SOT65P210X110-6L
REC+PAD_RECPAD_REC
REC-PAD_RECPAD_REC
RF701J_RF_MM8430-2600RF_SWITCH_S550
SPK+1PAD_SPK_P200PAD_SPK_P200
SPK-1PAD_SPK_P200PAD_SPK_P200
SW1401KEY_LS10N2LS10N2-T6008000000
SW1402KEY_LS10N2LS10N2-T6008000000
SW1403KEY_LS10N2LS10N2-T6008000000
SW1404KEY_LS10N2LS10N2-T6008000000
SW1405KEY_LS10N2LS10N2-T6008000000
TP1201TP3.8X2.5X3TPTP
TP1202TP2.5X3.8X3TPTP
U1D6PE1G960P3BPSAYFP1G95CA0B00D6PE1G960P3BP
U2ACPM-5402SKY77761SKY77701_3
U20NNS701NNS701
U201MT6589/VFBGA515/P0.4/B0.25/11.8X11.8MT6589E1_LPDDR2
U301SOT-6STT818BFDG6303_2
U302MT6320/TFBGA216/P0.4/B0.25/7.4X7.8MT6320E1MT6320/TFBGA216/P0.4/B0.25/7.4X7.8
U401AW8733TQRAW8733TQRAW8733TQR
U402MAX9063EBS+G45MAX9063EBS+G45MAX9063EBS+G45
U403MLP3X3-10SEMTECH SC613IMLTRTTEA1206T_0
U404MAX9063EBS+G45MAX9063EBS+G45MAX9063EBS+G45
U405MAX9063EBS+G45MAX9063EBS+G45MAX9063EBS+G45
U501FBGA162/P0.5/B0.27/12X13.5/HYNIXLPDDR2+eMMC (162 MCP)FBGA162/P0.5/B0.27/12X13.5/HYNIX
U602SAFEA1G84FA0F00SAFEA1G84FA0F00
U604EFCH881MTDA1QCS5A
U605MT6167/TFBGA100/P0.4/B0.25/4.6X4.6MT6167MT6167
U607D6PE1G960P3BPSAYFP1G95CA0B00D6PE1G960P3BP
U616D6PE1G960P3BPSAYFP1G95CA0B00D6PE1G960P3BP
U702SKY77590PA_/_SKY77590_0
U708ACPM-5402SKY77761SKY77701_3
U713ACPM-5402SKY77761SKY77701_3
U801SOT23_5PIN_1.25SGM2019-1.5YN5G/TR
U802SOT23_5PIN_1.25SGM2019-2.8YN5G/TR
U803SOT95P280X145-6ALXC6401EE49MRNSOT95P280X145-6AL
U804SOT23_5PIN_1.25SGM2019-1.5YN5G/TR
U805SOT95P280X145-6ALXC6401EE49MRNSOT95P280X145-6AL
U10037L26002009RAKON/IT2205BE/26MHzTCXO_RAKON_SMD_4P
U1004SAFEA1G84FA0F00SAFEB1G57KE0F00SAFEB1G57KA0F00
U1010TSLP6/SMD/P0.4/BGA725L6/SBGA725L6NJG1107HB3_0
U1027MT6628/WLCSP88/SMD/B0.25/3.991X4.452MT6628Q_WLCSPMT6628_E1_WLCSP
U1102SOT23-53V3APL5151
U1201BMA250EGSENSOR_BMA250E
U1202BMP180BMP180
U1203AK8963CAK8963CAK8963C
U1204MPU-3050MPU-305074ALVC74PW_0
U1205WSDCGQ_SHT20_V2_C1WSDCGQ_SHT20WSDCGQ_SHT20
U1601ESD_EMI0402X4AVRC14S05Q030100R2400000000
U1602ESD_EMI0402X4AVRC14S05Q030100R2400000000
U1603ESD_EMI0402X4AVRC14S05Q030100R2400000000
U1604ESD_EMI0402X4AVRC14S05Q030100R2400000000
U1605ESD_EMI0402X4AVRC14S05Q030100R2400000000
U1606ESD_EMI0402X4AVRC14S05Q030100R2400000000
U1607N_VQFN016_3X3_AW9356DS_AW9356_CNN_DS_AW9356_CN
X301CRYSTAL_MS3V-T1R_T7_12.5PFSSP-T7-FSSP-T7-F
X601TCXO32258pF-X'tal 26MHzTCVCXO_0
XJ102SWITCH20279-001E-01818000157
重要提示:PCB作品文件展下载说明
老吴 | 2017-7-7 12:17:16 | 显示全部楼层
只有PCB。没原理图。
游客,如果您要查看本帖隐藏内容请回复
为明天努力 | 2017-7-7 13:53:41 | 显示全部楼层
单枪舞九州 | 2017-7-7 14:50:30 | 显示全部楼层
南亭好远 | 2017-7-7 17:25:48 | 显示全部楼层
眼花缭乱了,好高端的作品
佝偻的戒指 | 2017-7-7 21:03:13 | 显示全部楼层
chess2006 | 2017-7-7 21:18:05 | 显示全部楼层
1258897655 | 2017-7-7 21:46:09 | 显示全部楼层
cdl511 | 2017-7-7 22:00:51 | 显示全部楼层
allegro_wh | 2017-7-8 07:48:13 | 显示全部楼层
