查看: 6166|回复: 3
[PADS] 《Power PCB 2005增强第二版 带破解》(PADS 2005sp2)2005 sp2[ISO]
社区居民宣传大使奖终身成就奖社区明星忠实会员
发表于 2012-4-24 10:46:12 | 显示全部楼层 |阅读模式
Power PCB 2005增强第二版(带破解) Mentor Graphics(明导)公司2006新产品,从Power pcb 4.0以后成为最好用的EDA 软件!!
Here is another one from us...........
Mentor Graphics PADS 2005 SPac2 Build 266.2
PADS2005 SPac2 Release Highlights
Introduction
As the third major release for 2005, PADS2005 SPac2 continues to
demonstrate Mentor Graphics ongoing commitment to this product line
with GUI standardization across the PADS tools including a new Project
Explorer for PADS Logic and PADS Layout, and further usability and
intra-tool integration. Other enhancements include functions formerly
known as the Analog Toolkit option, as standard for every PADS Layout
configuration. A newly integrated OrCAD schematic and library import
function has been added to PADS Logic. In addition, this release
introduces the new Mentor Stardard Installer (MSI) which includes all
products found in the PADS Flow.
As with all releases, it also includes a significant number of defect
fixes, see the Release Notes on the web.
1- Use the makelic facility under KeyGen folder to make a working
license for your machine. Save it to a known place.
2- Install the programs by inserting the CD or running Setup.
3- When asked, point to the generated license.txt in item 1.
4- Select what you want to intall.
5-
NB.: PADS2005 SPac2 has been fully tested on Windows XP service
pack 2. When Windows XP service pack 2 is installed on a license
server, PADS end users may not be able to check out floating
licenses from the license server. This happens because the
Windows Firewall (Internet Connection Firewall or ICF) is turned
on by default. You must disable the firewall or setup the
lmgrd.exe and mgcld.exe as exception processes, for floating
licensing to work correctly.
PADS2005 SPac2, the new release from Mentor Graphics is now shipping! Join us in this webinar to see the new enhancements and updates, which include:
An updated GUI for PADS Logic and PADS Layout
PADS Logic enhancements including group rotate and improved control of net name visibility
Differential pair of other routing enhancements
The addition of radial placement, custom teardrops and jumpers as core features to PADS Layout
DxDesigner enhancements
 楼主| 发表于 2012-4-24 10:46:29 | 显示全部楼层
    昨天 09:19
  • 签到天数: 200 天
    发表于 2024-1-2 09:23:42 | 显示全部楼层
    昨天 08:36
  • 签到天数: 81 天
    终身成就奖社区居民优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2024-2-9 11:01:43 | 显示全部楼层
