重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | 6CON1 | JP_USB-0400ASMT | MICRO-USB-TM-MC-02 | Micro USB Port | ANT1 | CON2 | ANT_2P | WI-FI ANT | D1 | DIODE_PIN | TVS0603 | TVS | D14 | DIODE_PIN | TVS0603 | TVS | D15 | DIODE_PIN | TVS0603 | TVS | D5004 | DIODE_0 | D0805 | B5819W | D5005 | DIODE_SCHOTTKY | SOD123 | 3.0V | D5006 | DIODE_0 | D0805 | B5819W | D5007 | DIODE_PIN | TVS0603 | TVS | D5008 | DIODE_PIN | TVS0603 | TVS | D5009 | DIODE_PIN | TVS0603 | TVS | D5010 | DIODE_SCHOTTKY | SOD123 | 3.0V | D5012 | DIODE_PIN | TVS0603 | TVS | D5030 | DIODE_PIN | TVS0603 | TVS | D5031 | DIODE_PIN | TVS0603 | TVS | D5032 | DIODE_PIN | TVS0603 | TVS | D5033 | DIODE_PIN | TVS0603 | TVS | D5034 | DIODE_PIN | TVS0603 | TVS | D5035 | DIODE_PIN | TVS0603 | TVS | D5036 | DIODE_PIN | TVS0603 | TVS | D5037 | DIODE_PIN | TVS0603 | TVS | D5038 | DIODE_PIN | TVS0603 | TVS | D5039 | DIODE_PIN | TVS0603 | TVS | ED2000 | DIODE_BI-DIR_TRIG | E0402 | ESD5451N | FB10 | COM_CHOKE_0 | CHOKE_4P | DLW21HN900SQ2L | FB7105 | INDUCTOR_2 | L0402 | 600R/100MHz | FB7106 | INDUCTOR_2 | L0402 | 600R/100MHz | FB7107 | INDUCTOR_2 | L0402 | 600R/100MHz | FB7108 | INDUCTOR_2 | L0402 | 600R/100MHz | FB7109 | INDUCTOR_2 | L0402 | 600R/100MHz | FB7200 | INDUCTOR | R0603 | 0R | FB7201 | INDUCTOR | L0603 | BLM18EG601SN1 | FB7202 | INDUCTOR | L0603 | BLM18EG601SN1 | FB7203 | INDUCTOR | L0603 | BLM18EG601SN1 | FB7204 | INDUCTOR | L0603 | BLM18EG601SN1 | J4 | HEADER_4_0 | KEY3X5 | H9_VLO | J5 | HEADER_4_1 | FPC6P_0.5MM | H9_VLO | J11 | PHONEJACK_STEREO_SW_3 | PJK-311S-C | PHONEJACK | J19 | TOUCH-10PIN_0 | FPC6P_0.5MM | 8PIN-0.5mm | J20 | TOUCH-10PIN_0 | FPC6P_0.5MM | 8PIN-0.5mm | J22 | LCM0200CE1A0_12 | FH26-39S-0-3 | 39P | J23 | CON2 | CON2A | batter | J24 | LCM0200CE1A0_12 | FH26-39S-0-3 | 39P | J1800 | CON3 | UART-DEBUG | CON3 | J7201 | CON2_0 | WIREL | CON2 | J7202 | CON2_0 | WIREL | CON2 | L1 | INDUCTORS_OF_FERRITE | IND-3X3 | SWPA3015S1R0NT/1.5A | L10 | INDUCTORS_OF_FERRITE | IND-3X3 | SWPA3015S1R0NT/1.5A | L11 | INDUCTORS_OF_FERRITE | IND-3X3 | SWPA3015S1R0NT/1.5A | L12 | INDUCTORS_OF_FERRITE | IND-4X4 | SWPA4020S1R0NT/3A | L13 | INDUCTORS_OF_FERRITE | IND-3X3 | SWPA3015S1R0NT/1.5A | L14 | INDUCTORS_OF_FERRITE | IND-3X3 | SWPA3015S1R0NT/1.5A | L32 | INDUCTOR_3 | IND-4X4 | 4.7uH | L2109 | INDUCTOR_1 | CD43 | 4.7uH/2A | L2110 | INDUCTOR_1 | CD43 | 4.7uH/2A | L2205 | INDUCTORS_OF_FERRITE | INDC2520X220L | 0.22uH/5A | L2207 | INDUCTORS_OF_FERRITE | INDC2520X220L | 0.22uH/5A | LA60 | INDUCTOR_1 | L2520 | 2.2uH | LA61 | INDUCTOR_1 | L2520 | 2.2uH | P2102 | TESTPOINT1 | T-0.7 | TEST | P2104 | TESTPOINT1 | T-0.7 | TEST | Q3600 | FET_N_MOS | SOT23 | WNM2016 | Q3601 | NPN4 | SOT23 | 8050 | TPR | TEST-1_4.0 | TP | TEST-1.0 | TPR1 | TEST-1_4.0 | TP | TEST-1.0 | TPRG | TEST-1_4.0 | TP | TEST-1.0 | TVOL+ | TEST-1_4.0 | TP | TEST-1.0 | TVOL- | TEST-1_4.0 | TP | TEST-1.0 | TVOL-1 | TEST-1_4.0 | TP | TEST-1.0 | TVOL-2 | TEST-1_4.0 | TP | TEST-1.0 | U29 | 5T619_2 | CSP0608-80 | RC5T620-1017 | U37 | MT6628_1 | LGA44_12_12MM | M500 | U1000 | MCU_RK3288 | BGA636_19X19 | MCU_RK3288 | U2000 | ESDX2 | SOT23 | ESD5302F | U2205 | BB27_0 | WLCSP-20 | SYR827 | U2206 | BB27_0 | WLCSP-20 | SYR828 | U3600 | LPDDR3-32BIT-178PIN | FBGA178-13X11.5 | LPDDR3-32_178 | U3601 | LPDDR3-32BIT-178PIN | FBGA178-13X11.5 | LPDDR3-32_178 | U4000 | INAND_0 | INAND_169 | eMMC | U4001 | LDO-PT5108/RT9013 | SOT25 | TG1803-18 | U7100 | CODEC-ALC3224 | QFN48-6X6 | ALC5640 | U7201 | LDO-PT5108/RT9013 | SOT25 | TG1803-18 | U8004 | G5121 | SOT26 | SY7200A | U8005 | G5121 | SOT26 | SY7200A | UA66 | G5121_3 | TQFN-16 | TPS65135 | UA67 | G5121_3 | TQFN-16 | TPS65135 | Y2 | CRYSTAL | CRY-MC146 | 32.768K | Y5 | CRYSTAL-4 | CRY-D3225 | 26M-20ppm | Y1100 | CRYSTAL-4_1 | CRY-D3225 | 24M-30ppm |
重要提示:PCB作品文件展下载说明
