I’m quite confused about these two words. In the following sentences:
1. As you will see, data adapter objects function as a bridge between the client <strong>tier</strong> and a relational database.
2. To showcase the usefulness of the disconnected <strong>layer</strong>, you will be updating the data library with new namespaces that make use of disconnected types.
it seems that they mean the same thing. Are there any differences between them? |
