重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | ANT6 | R1206 | WIFI_ANT | R1206 | ANT7 | R1206 | BT_ANT | R1206 | BT1 | BAT | 3.7V | BAT | D1 | SOD323_1 | 1N4148 | SOD323 | D4 | SOT23 | BAT54C | SOT23 | D5 | SOD123 | 1N5819 | SOD123 | D6 | SOD128 | SS32 | SOD128 | D8 | SOD323_1 | 1N4148 | SOD323 | D9 | SOD123 | NC/1N5819 | SOD123 | D20 | SOD123 | 1N5819 | SOD123 | D21 | D1206 | 18V | D1206 | D22 | D1206 | 6.8V | D1206 | D23 | SOT23_5 | BAT54S | SOT23 | D26 | SOT23_5 | BAT54C | SOT23 | D27 | SOT23_5 | BAT54S | SOT23 | EC3 | C0603 | 47UF/4V | C0603 | EC4 | C0603 | 47UF/4V | C0603 | ED3 | E0402N_6 | ESD9B5VL | E0402N | ED4 | E0402N_6 | NC/ESD9B5V | E0402N | ED5 | E0402N_6 | ESD9B5VL | E0402N | ED6 | E0402N_6 | NC/ESD9B5V | E0402N | ED13 | E0402N_6 | ESD9B5V | E0402N | ED14 | E0402N_6 | ESD9B5V | E0402N | ED27 | E0402N_6 | NC/AZ5725-01F/ESD9B5VL | E0402N | ED28 | E0402N_6 | NC/AZ5725-01F/ESD9B5VL | E0402N | ED31 | E0402N_6 | NC/AZ5725-01F/ESD9B5VL | E0402N | ED33 | E0402N_6 | NC/AZ5725-01F/ESD9B5VL | E0402N | ED37 | E0402N_6 | NC/AZ5725-01F/ESD9B5VL | E0402N | FB4 | L0603 | FB180R | L0603 | J1 | RS7M1609013-A | 30P0.5TOP | RS7M1609013-A | J2 | TF-CARD | TF_SD_SOCKET | TF-CARD | J4 | 757DC-B | DC056 | 757DC-B | J9 | HDMI | HDMI_C | HDMI | J10 | CON_05MM_24P | OV2659 | CON_05MM_24P | J11 | PJ-311A | 2SJ2271 | PJ-311A | J16 | MICRO_USB_NJ2A | USB | MICRO_USB_NJ2 | J18 | UART-DEBUGA | NC | UART-DEBUG | J25 | R0603_1 | SPEAK | R0603 | L13 | IND-4X4 | 4.7UH/1.5A | IND-4X4 | L17 | IND_4X4&3X3 | NC/3.3UH/1A | IND_4X4&3X3 | L18 | IND_4X4&3X3 | 2.2UH/2A | IND_4X4&3X3 | L19 | IND-4X4 | 10UH | IND-4X4 | L20 | IND_4X4&3X3 | 2.2UH/1.5A | IND_4X4&3X3 | L21 | IND-4X4 | 10UH | IND-4X4 | L22 | IND_4X4&3X3 | 2.2UH/1.5A | IND_4X4&3X3 | L29 | L0603 | FB120R | L0603 | L30 | L0603 | BLM18PG181SN1 | L0603 | L34 | L0402 | 0R | L0402 | L35 | L0402 | 0R | L0402 | L36 | L0603 | FB180R | L0603 | L37 | L0603 | BLM18EG601SN1 | L0603 | L38 | L0603 | FB180R | L0603 | MIC1 | MIC_450X250 | MIC | MIC_450X250 | MIC2 | MIC1 | MIC | MIC1 | Q1 | SOT23 | 8050 | SOT23 | Q6 | SOT23 | NC/SI2305 | SOT23 | Q7 | SOT23_5 | 8050 | SOT23 | Q11 | SOT23_5 | SI2305 | SOT23 | Q13 | SOT23_5 | SI2305 | SOT23 | Q16 | SOT23 | 2SK3018 | SOT23 | Q17 | SOT23_5 | 8050 | SOT23 | Q20 | SOT23 | WNM2021/2SK3018 | SOT23 | Q21 | SOT23 | 8050 | SOT23 | SHIELD2 | SHIELD-3P | CON5 | SHIELD-3P | SHIELD5 | SHIELD-3P | CON5 | SHIELD-3P | SHIELD8 | SHIELD-3P | CON5 | SHIELD-3P | SW9 | SW8 | POWER | SW8 | SW11 | SW-PB3 | RESET | SW-PB3 | U1 | RK2928_BGA313 | MCU_RK3028_BGA | RK2928_BGA313 | U2 | FBGA96_9X14/2 | DDR3_256M_16BIT | FBGA96_9X14 | U3 | FBGA96_9X14/2 | DDR3_256M_16BIT | FBGA96_9X14 | U4 | QFN5X5-40PIN | GSL1680/8 | QFN5X5-40PIN | U5 | EMMC_BGA153B | EMMC4G-BGA153 | EMMC_BGA153B | U6 | TSOP1-48 | NAND_FLASH_2 | TSOP1-48 | U7 | SOT26_2 | AP2004H | SOT26 | U8 | MSOP8 | HYM8563 | MSOP8 | U9 | QFN32 | ESP8089 | ESP8080_7 | U11 | MSOP8 | TCS7191 | MSOP8 | U12 | SOT25_1 | AP1610 | SOT25 | U22 | SOT25 | NC/AP2415 | SOT25 | U24 | QFN40L | ACT8931A | QFN40L | U26 | SOT26_2 | TCS3354 | SOT26 | U31 | CON50P_0D5MM | LC070LF02CWXXLA | CON50P_0D5MM | U32 | SOT26_2 | AP3127B | SOT26 | U40 | MMA7660FC | MC3233 | MMA7660FC | U43 | MXC6625 | MXC6225XU | MXC6625 | U80 | WIFI-8723 | WIFI-8723 | WIFI-8723 | X1 | M49S-SMD | 24MHZ | M49S-SMD | Y5 | CRY_MC146 | 32.768KHZ-20PPM | CRY_MC146 | Y6 | M49S-SMD | 26MHZ | M49S-SMD | Y7 | CRY_2X6 | NC/32.768KHZ-20PPM | CRY_2X6 | ZD1 | SOD123 | 3V | SOD123 |
重要提示:PCB作品文件展下载说明
