重要提示:PCB作品文件展下载说明
板子量产型号:YK102Q-MCP186-8931A-V1.1
Name | PCB Decal | Value | Part Type | D2 | D1206 | 1N4148 | DIODE_3 | D3 | D1206 | 1N5819 | DIODE_3 | D5 | D1206 | 21V | DIODE_ZENER13_0 | D6 | D1206 | 1N5819 | DIODE_3 | D7 | D1206 | 1N5819 | DIODE_3 | D8 | D1206 | NC/1N5819 | DIODE_3 | D9 | SOT23 | BAT54S | DIODE_1 | D10 | D1206 | 7V | DIODE_ZENER13_0 | D11 | D1206 | 1N5819 | DIODE_3 | D12 | D1206 | 1N5819 | DIODE_3 | D13 | DO-214AA | SS32 | DIODE | D16 | D1206 | 1N5819 | DIODE_3 | D17 | SOT23 | BAT54C | BAT54C | D18 | D1206 | 1N4148 | DIODE_3 | D25 | SOT23 | BAT54S | DIODE_1 | ED1 | E0402N | ESD9B5VL | TVS_M | FB3 | 603 | 600R/100MHz | IND0603 | FB4 | 603 | 600R/100MHz | IND0603 | FL1 | 603 | 330nH | IND0603 | FL2 | 603 | 330nH | IND0603 | GL4 | 402 | 4.7nH | IND0402 | J1 | DC_0075 | DC5V/3A | DC_0075 | J2 | TF-CKT01-009D | TF_SD_SOCKET | TF_SD_SOCKET | J3 | CON6P_0.5_BOTTOMA | CON6 | CON6 | J4 | PHONE-3_5L | | ST-315-5PL | J5 | FPC_30_05 | LP097X02 | LP097X02_2 | J6 | SPKPAD | SPKR | CON2_M | J7 | SPKPAD | SPKL | CON2_M | J8 | HDMI-19PF_CA | HDMI_C | HDMI_19C | J9 | FPC24-0.5 | OV2659 | OV2659 | J10 | WIFIANT | ANT1 | WIFI_ANT | J11 | FPC40-0.5 | | LVDS_10_40 | J12 | WIFIANT | ANT1 | WIFI_ANT | J14 | UART-DEBUG | UART-DEBUG | UARTDEBUG | J15 | CON6P_0.5_BOTTOMA | CON6 | CON6 | J16 | MICRO_USB_NJ2 | USB | MICRO_USB_NJ2 | J17 | CON6P_0.5_BOTTOMA | CON6 | CON6 | J18 | WIFIANT | ANT1 | WIFI_ANT | J29 | WIFIANT | ANT1 | WIFI_ANT | L1 | IND-4X4 | 3.3uH/2A | INDUCTOR_1_2 | L2 | IND-4X4 | 3.3uH/2A | INDUCTOR_1_2 | L3 | IND-4X4 | 3.3uH/2A | INDUCTOR_1_2 | L4 | IND-4X4 | 2.2uH/1.5A | INDUCTOR4X4 | L5 | IND-4X4 | 2.2uH/1.5A | INDUCTOR4X4 | L7 | IND-5X5 | 10uH/1A | INDUCTOR5X5 | L8 | IND-5X5 | 22uH/0.5A | INDUCTOR5X5 | L9 | 402 | NC | RES0402 | L10 | 402 | NC | RES0402 | L11 | 402 | NC | RES0402 | L12 | 402 | NC | RES0402 | L13 | 402 | NC | RES0402 | L14 | 402 | NC | RES0402 | L15 | IND-4X4A | 1.5uH/2.5A | INDUCTOR4X4 | L16 | IND-4X4 | 10uH/1.5A | INDUCTOR_1_2 | M1 | R1206 | MOTO | MOTOR_SERVO | MIC1 | MIC45 | MIC | MIC | Q1 | SOT23 | SI2305 | MOSFET_P | Q2 | SOT23 | 8050 | NPN | Q3 | SOT23 | 2SK3018 | MOSFET_N | Q4 | SOT23 | SI2305 | MOSFET_P | Q5 | SOT23 | 2SK3018 | MOSFET_N | Q6 | SOT23 | SI2305 | MOSFET_P | Q7 | SOT23 | NC | MOSFET_N | Q8 | SOT23 | 8050 | NPN | Q9 | SOT23 | 2SK3018 | MOSFET_N | Q10 | SOT23 | SI2305 | MOSFET_P | Q11 | SOT23 | 2SK3018 | MOSFET_N | Q12 | SOT23 | 8050 | 8050 | Q13 | SOT23 | 2SK3018 | MOSFET_N | Q14 | SOT23 | 8050 | NPN | Q15 | SOT23 | 2SK3018 | MOSFET_N | Q16 | SOT23 | SI2305 | MOSFET_P | Q17 | SOT23 | 8050 | NPN | Q18 | SOT23 | 2SK3018 | MOSFET_N | Q19 | SOT23 | 2SK3018 | MOSFET_N | Q20 | SOT23 | SI2305 | MOSFET_P | Q21 | SOT23 | SI2305 | MOSFET_P | Q31 | SOT23 | SI2305 | MOSFET_P | RP1 | RES-ARRAY0402 | NC/0R | RESX4 | RP2 | RES-ARRAY0402B | NC/0R | RESX4 | RP3 | RES-ARRAY0402A | NC/0R | RESX4 | RP4 | RES-ARRAY0402AA | NC/0R | RESX4 | RP12 | RES-ARRAY0402 | 33R | RESX4 | RP45 | RES-ARRAY0402 | NC/10K | RESX4 | RP46 | RES-ARRAY0402 | NC/10K | RESX4 | SHIELD1 | SHIELD-3P | CON5 | CON5_1 | SW6 | IT_1207BSMD | POWER | SW6P-IT | SW11 | TS-030 | RESET | TS30 | U1 | BGA453-19X19 | RK3188 | RK3168 | U2 | MCP186A | | MCP186A | U3 | SOT25 | LP3984-18B5F | LDO23-5 | U4 | QFN6 | NL27WZU04 | UPC8236T6N | U5 | SOT23 | PT5110_2.5V | LDO_SOT23 | U6 | TSOP1-48 | NAND_FLASH | NAND_TSOP48 | U7 | TSOP1-48 | NAND_FLASH | NAND_TSOP48 | U8 | BGA144 | RK616 | RK610_BGA | U9 | INAND_169 | INAND | I_NAND | U10 | SOT26 | TCS3354 | RT9271_0 | U11 | MMA7660FC | STK8312 | MMA7660FC_1 | U12 | SOT25 | TT9107 | LPW5206H | U13 | SLP2510P8 | AR0524P5 | ESD4+1 | U14 | SOT25 | LP3984-33B5F | LDO23-5 | U15 | GB9664-12X12 | APXXXX | RTL8723BS_VD | U17 | MP2625B | MP2625BGL | MP2625BGL | U18 | QFN40L | ATC8931A | ATC8931A | U19 | SOT25 | SY8009B | DS8008_6 | U20 | SOT25 | SY8009B | DS8008_6 | U21 | SOT25 | RT9013_12PB | LDO23-5 | U22 | SOT25 | RT9013_18PB | LDO23-5 | U23 | MSOP8 | HYM8563 | HYM8563 | U24 | SOT26 | AP2004H | G5121_1 | U25 | SOT23 | CE8809C33M | BL8506 | U27 | SLP2510P8 | AR0524P5 | ESD4+1 | U28 | SOT26 | LP3382B6F | U_MP3202 | U31 | CW2013 | CW2013 | CW2013 | U32 | L3G4200D | L3G4200D | L3G4200D | U33 | MMA8452Q | LIS3DH/MMA8452Q | MMA8452Q | U34 | BAG14-1.6X1.6 | AK8975C | AK8975C | U44 | ODFN6-2.35X1.8 | uS5151 | US5151_M | U80 | WIFI_8723AS | WIFI+BT | RLUM02BS_1 | U88 | MSOP8 | NS4150B | TT8642 | U90 | MSOP8 | NS4150B | TT8642 | U171 | NL27WZU04 | NL27WZU04 | N27XXXXX | X1 | M49S-SMD | 24MHz | XTAL_ELLIP | Y1 | CRY-MC146 | 32.768K | CRYSTAL2X6 | Y2 | CRY-D3225 | 26M-20ppm | CRYSTAL-4 | Y3 | CRY-D3225 | 26M-20ppm | CRYSTAL-4 | Y4 | CRY-D3225 | TCXO-26M | CRYSTAL-4 |
重要提示:PCB作品文件展下载说明
