PCB打样,PCB快速加急
- 0
Name | Part Type | PCB Decal | Value | 7Y1 | CRYSTAL-4P_0 | Y-SMD4P3225 | 24MHz_33pF_20PPM | AU5 | CS4354_1 | TSSOP16A | MAX232 | CN1206 | HEADER_1X4-2MM_180D | CN4-20A | CN4-2.0 | CN1207 | HEADER_1X4-2MM_180D | CN4-20A | CN4-2.0 | CON12 | HDMI_J_2_VERTER_1 | HDMI19P-90 | HDMI/180D | CR16 | DIODE_NORMAL | D0402 | SMAJ20A-13-F/NC | D7 | BAV99_SMD | SOT-23 | BAV99 | D62 | BAV99_0 | D0402 | NC | D63 | BAV99_0 | D0402 | NC | D102 | DIODE_SCHOTTKY | DO-214 | NC/SS34 | D103 | DIODE_SCHOTTKY | DO-214 | NC/SS34 | D817 | BAV99_0 | D0402 | NC | D818 | BAV99_0 | D0402 | NC | D828 | DO-214_SS34_4A/60V | DO-214 | 0R | D829 | LED | LED0805 | LED | D830 | LED | LED0805 | LED | D832 | DO-214_SS34_4A/60V | DO-214 | 0R | H1 | CON3_3 | TPAD | NC | H2 | CON3_3 | TPAD | NC | H3 | CON3_3 | TPAD | NC | H4 | CON3_3 | TPAD | NC | H5 | CON3_3 | TPAD | NC | H6 | CON3_3 | TPAD | NC | H7 | CON3_3 | TPAD | NC | H8 | CON3_3 | TPAD | NC | HOLE1 | 3.3-6-HOLE | 3.3-6-HOLE | 3.3-6-hole | HOLE2 | 3.3-6-HOLE | 3.3-6-HOLE | 3.3-6-hole | HOLE3 | 3.3-6-HOLE | 3.3-6-HOLE | 3.3-6-hole | HOLE4 | 3.3-6-HOLE | 3.3-6-HOLE | 3.3-6-hole | HOLE5 | 3.3-6-HOLE | 3.3-6-HOLE | 3.3-6-hole | J1 | CON12_2_0.0MM | CN12-20A | CN12_2.54 | J2 | CON6_1 | CN6-20A | CN6_2.0 | J3 | CON3 | CN3_20A | NC/Header/2.54mm/180D/Male | J4 | CON6 | CN6-20A | NC/CON6-2.0 | J16 | CPT_A_3 | CON-FI-RE41S-HF | NC/FI-RE41S-HF | J17 | FI-RE51S-HF_2 | CON-FI-RE51S-HF | NC/FI-RE51S-HF | J19 | CPT_A_4 | CON-FI-RE41S-HF | NC/FI-RE41S-HF | J20 | FI-RE51S-HF_2 | CON-FI-RE51S-HF | NC/FI-RE51S-HF | J105 | HEADER_1X4-2MM_180D | CN4-20A | CON4-2.0 | J106 | HEADER_1X4-2MM_180D | CN4-20A | CON4-2.0 | J107 | HEADER_1X4-2MM_180D | CN4-20A | CON4-2.0 | J108 | HEADER_1X4-2MM_180D | CN4-20A | CON4-2.0 | J1006 | CON20A | CON2X10_2.0 | CON20A_2X10_2.0 | J2003 | FI-RE51S-HF_2 | CON-FI-RE51S-HF | NC/FI-RE51S-HF | J2008 | CON40A | CON40A_2X20_2.0 | CON40A_2X20_2.0 | J2012 | CON24A_3 | CON20X2_1.27 | CON20X2_1.27 | J2013 | HEADER_1X4-2MM_180D | CN4-2.54A | CON4-2.54 | J2029 | HEADER_1 | CON6X2-2.0 | CON6X2-2.0 | J2030 | HEADER_1X4-2MM_0_2 | CN4-20A | CON4-2.0 | J2032 | HEADER_1X4-2MM_0 | CN3_20A | CON3-2.0 | J2033 | CON2 | CN2-20A | CON2-2.0 | J2034 | HEADER_0 | CON5X2-2.0 | CON5X2-2.0 | J2036 | CON14 | CON14-20A | CON14-20A | J2037 | CON9_0 | CN6-20A | CON6-2.0 | L1 | INDUCTOR_IRON_2 | SMD08X08 | SWPA8040S1R0NT/8A | L2 | INDUCTOR_IRON_2 | SMD05X05 | SWPA3015S2R2NT/1.5A | L33 | INDUCTOR_2 | L0805 | FB | L34 | INDUCTOR_2 | L0805 | FB | L36 | P-INDUCTOR_3 | SMD03X03 | 15uH | L37 | P-INDUCTOR_3 | SMD03X03 | 15uH | L38 | INDUCTOR | L0402 | NC/0R | L39 | P-INDUCTOR_3 | SMD03X03 | 15uH | L41 | P-INDUCTOR_3 | SMD03X03 | 15uH | L102 | INDUCTOR | L0402 | FB/60R | L103 | INDUCTOR | L0402 | FB/60R | L104 | INDUCTOR | L0402 | FB/60R | L105 | INDUCTOR | L0402 | FB/60R | L107 | INDUCTOR | L0402 | FB/60R | L108 | INDUCTOR | L0402 | FB/60R | L111 | INDUCTOR | L0402 | FB/60R | L112 | INDUCTOR | L0402 | FB/60R | L113 | INDUCTOR | L0402 | FB/60R | OPS-80P2 | TX25A_1 | TX24-80R-LT-H1E | TX24-80R-LT-H1E | Q3 | SOT-23_3904 | SOT-23 | 3904 | Q4 | SOT23-100_3401_4 | SOT23-100 | 3401 | Q5 | NPN(BEC)_0 | SOT-23 | 3904 | Q7 | AO3400_SOT23 | SOT-23 | NC/2N7002 | Q8 | SOT23-100_3401_4 | SOT23-100 | 3401 | Q14 | _N_DSG_0 | SOT-23 | 2N7002 | Q452 | NPN(BEC)_0 | SOT-23 | 3904 | Q902 | NPN_BEC_3 | SOT-23 | 3904 | Q903 | PNP(BEC)_0 | SOT-23 | 3906 | Q904 | NPN_BEC_3 | SOT-23 | 3904 | Q922 | SOT-23_3904 | SOT-23 | 3904 | Q929 | SOT-23_3904 | SOT-23 | 3904 | Q930 | SOT-23_3906 | SOT-23 | 3906 | Q931 | SOT-23_3904 | SOT-23 | 3904 | Q932 | SOT-23_3906 | SOT-23 | 3906 | S2 | INDUCTOR_0 | 48X39MM | Heat-sink48X39 | SW1508 | KEY_0 | SW2_TS_037 | PS_ON | SW1509 | KEY_1 | SW2_TS_037 | Android_PWR | U1 | ULTRASONIC_27X27_2L_0917_0 | IC-941P-P08 | ULTRASONIC_27X27_2L_0917_1 | U5 | AT24C21_2 | SOP8-225-50 | NC/24C02 | U6 | AT24C21_2 | SOP8-225-50 | NC/24C02 | U10 | AOZ1036_41 | DFN3X3-12 | SY8368A | U11 | SOT-223 | SOT-223 | AS1117L-3.3 | U12 | PAM2301_2 | SOT-23-5 | SY8089A | U38 | TAS5708_0 | HTQFP48 | TAS5707 | U103 | M24CXX_0 | SOP8-255-50 | MX25L1605 | U1213 | SGM7227 | MSOP10-3_1X3_1H1_1-P0_5 | SGM7227 | U1214 | LDO_TO-252_1117-ADJ | SOT-223 | AMS1117-3.3_1A | USB2501 | USB20_TYPE_A | USB20A4_USB_AF_01_001 | USB-HUB_PORTBA | USB2508 | USB20_TYPE_A | USB20A4_USB_AF | USB-HUB_PORTBA |
