DXP2004 DRC 规则英文对照+ H' ?( ?5 A+ _
Ⅰ:Error Reporting 错误报告. ^# B5 J* V% M' |2 X: @M$ n+ ^
8 t8 E4 A4 C$ X
A:Violations Associated with Buses 有关总线电气错误的各类型(共12项)
◆bus indices out of range 总线分支索引超出范围0 i$ {6 @5 g3 S8 t
◆Bus range syntax errors 总线范围的语法错误
◆Illegal bus range values 非法的总线范围值4 GH2 s' y$ S; ^, W% R$ s( b3 v$ b
◆Illegal bus definitions 定义的总线非法3 v) m, Q4 @! m5 ~; Y
◆Mismatched bus label ordering 总线分支网络标号错误排序5 ?; c; m) Zi7 u- I8 }1 g
◆Mismatched bus/wire object on wire/bus 总线/导线错误的连接导线/总线
◆Mismatched bus widths 总线宽度错误
◆Mismatched bus section index ordering 总线范围值表达错误
◆Mismatched electrical types on bus 总线上错误的电气类型# E: f9 I! e' U$ c6 {# Y
◆Mismatched generics on bus (first index) 总线范围值的首位错误; F* J* n7 J$ Ne( O" g
◆Mismatched generics on bus (second index) 总线范围值末位错误3 QI) Y" U8 }
◆Mixed generics and numeric bus labeling 总线命名规则错误0 N8 q; x( Z+ v! j* L8 q9 J% r- r/ U
B:Violations Associated Components 有关元件符号电气错误(共20项)- _& O/ W, Q5 r5 ~" g
◆Component Implementations with duplicate pins usage 元件管脚在原理图中重复被使用! z5 \7 S3 G7 y, ]s) L4 l$ D# n
◆Component Implementations with invalid pin mappings 元件管脚在应用中和PCB封装中的焊盘不符
◆Component Implementations with missing pins in sequence 元件管脚的序号出现序号丢失
◆Component contaning duplicate sub-parts 元件中出现了重复的子部分( x% z+ y6 Y# m7 ~- ?L
◆Component with duplicate Implementations 元件被重复使用
◆Component with duplicate pins 元件中有重复的管脚 / w& D3 l) s* O% b* K1 vl/ c% Q* n
◆Duplicate component models 一个元件被定义多种重复模型9 V- h, |1 m* i0 a& V# q
◆Duplicate part designators 元件中出现标示号重复的部分
◆Errors in component model parameters 元件模型中出现错误的的参数
◆Extra pin found in component display mode 多余的管脚在元件上显示
◆Mismatched hidden pin component 元件隐藏管脚的连接不匹配
◆Mismatched pin visibility 管脚的可视性不匹配4 l" D; e5 O6 _" S' B1 o
◆Missing component model parameters 元件模型参数丢失 ( ^' T% {y/ z5 B( A
◆Missing component models 元件模型丢失: P2 C% M: I$ }) H. I
◆Missing component models in model files 元件模型不能在模型文件中找到
◆Missing pin found in component display mode 不见的管脚在元件上显示j5 Y! i9 Y! G% h/ u0 T
◆Models found in different model locations 元件模型在未知的路径中找到
◆Sheet symbol with duplicate entries 方框电路图中出现重复的端口 * O4 B. p/ d/ f0 v" ^
◆Un-designated parts requiring annotation 未标记的部分需要自动标号4 R' F/ q. G3 _7 e5 H+ Y
◆Unused sub-part in component 元件中某个部分未使用
& h- L6 e" @H4 v6 k& U! ~
C:violations associated with document 相关的文档电气错误(共10项)
1、conflicting constraints 约束不一致的9 j7 ?0 _6 H& l3 {$ ^& p9 T
2、duplicate sheet symbol name 层次原理图中使用了重复的方框电路图
3、duplicate sheet numbers 重复的原理图图纸序号
4、missing child sheet for sheet symbol 方框图没有对应的子电路图7 W' }' }1 k4 q$ `
5、missing configuration target 缺少配置对象
6、missing sub-project sheet for component 元件丢失子项目" J5 h& U- T* C& @6 L" @
7、multiple configuration targets 无效的配置对象 - l+ J8 `7 t; X
8、multiple top-level document 无效的顶层文件
9、port not linked to parent sheet symbol 子原理图中的端口没有对应到总原理图上的端口
10、sheet enter not linked to child sheet 方框电路图上的端口在对应子原理图中没有对应端口N$ d) VC- n" |8 W6 i
D:violations associated with nets 有关网络电气错误(共19项)
1、adding hidden net to sheet 原理图中出现隐藏网络 0 ]5 c7 j8 K. p( F) I
2、adding items from hidden net to net 在隐藏网络中添加对象到已有网络中
3、auto-assigned ports to device pins 自动分配端口到设备引脚6 u5 p, L_J/ W
4、duplicate nets 原理图中出现重名的网络 j7 S( y( r9 f; b; W! y
5、floating net labels 原理图中有悬空的网络标签
6、global power-objects scope changes 全局的电源符号错误
7、net parameters with no name 网络属性中缺少名称 * ]$ C( c. Pn" w
8、net parameters with no value 网络属性中缺少赋值
9、nets containing floating input pins 网络包括悬空的输入引脚/ c4 Q2 L/ H' _6 F2 `
10、nets with multiple names 同一个网络被附加多个网络名 / I4 ?/ a, M7 w5 r6 ^
11、nets with no driving source 网络中没有驱动 ( D% G8 l# IY1 p; t$ f
12、nets with only one pin 网络只连接一个引脚
13、nets with possible connection problems 网络可能有连接上的错误
14、signals with multiple drivers 重复的驱动信号( e5 A6 Y: ?/ r; X) _/ o; q) B: Yx
15、sheets containing duplicate ports 原理图中包含重复的端口
16、signals with load 信号无负载 M5 Q8 w& y" d4 z) t" Z9 I! b) W
17、signals with drivers 信号无驱动
18、unconnected objects in net 网络中的元件出现未连接对象 1 W6 f( C8 u; b
19、unconnected wires 原理图中有没连接的导线
E:Violations associated with others有关原理图的各种类型的错误(3项)
1、No Error 无错误
2、Object not completely within sheet boundaries 原理图中的对象超出了图纸边框 : E. G: Z$ k" j
3、Off-grid object原理图中的对象不在格点位置+ U0 `; M+ i3 T9 a6 L5 H
! j% d8 N* Y- z( ?' Q; L" ~/ j
F:Violations associated with parameters 有关参数错误的各种类型
1、same parameter containing different types 相同的参数出现在不同的模型中
2、same parameter containing different values 相同的参数出现了不同的取值
, W9 f! I& \2 L9 a" P5 N% o
" e. D' ]! s/ ~. b
Ⅱ、Comparator 规则比较
" V, n( r' |- H- C
A:Differences associated with components 原理图和PCB上有关的不同(共16项)
◆Changed channel class name 通道类名称变化! |: p# y" ~2 U1 }1 W
◆Changed component class name 元件类名称变化( m7 }4 n5 `- h. }' E8 q3 l0 n! k
◆Changed net class name 网络类名称变化
◆Changed room definitions 区域定义的变化% _/ D& z7 `6 r7 Q! Z! X1 o
◆Changed Rule 设计规则的变化5 b: B. ~v. k- }; q
◆Channel classes with extra members 通道类出现了多余的成员
◆Component classes with extra members 元件类出现了多余的成员
◆Difference component 元件出现不同的描述
◆Different designators 元件标示的改变! y$ X- q8 k$ I8 u* q+ w/ u' w
◆Different library references 出现不同的元件参考库1 L3 j) W. a! uQ7 f
◆Different types 出现不同的标准
◆Different footprints 元件封装的改变
◆Extra channel classes 多余的通道类
◆Extra component classes 多余的元件类y# w8 ~! _1 i5 `; `9 H" P
◆Extra component 多余的元件
◆Extra room definitions 多余的区域定义
B:Differences associated with nets 原理图和PCB上有关网络不同(共6项)
◆Changed net name 网络名称出现改变
◆Extra net classes 出现多余的网络类 0 p: e% K3 p+ d& K( Y# Nu
◆Extra nets 出现多余的网络/ w1 f* m1 d1 r" Fi* z
◆Extra pins in nets 网络中出现多余的管脚
◆Extra rules 网络中出现多余的设计规则
◆Net class with Extra members 网络中出现多余的成员
C:Differences associated with parameters 原理图和PCB上有关的参数不同(共3项)
◆Changed parameter types 改变参数类型 , R( ]+ C4 t9 @. H
◆Changed parameter value 改变参数的取值) Q2 w, W) Q' ~9 g6 e# x! YF
◆Object with extra parameter 对象出现多余的参数 |
