查看: 2322|回复: 10
[Allegro16.6以下] JMB321_QFN64+NB638+CM2020+H5007 做的 Hi3531 底板PCB
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2017-12-29 14:31:00 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    BT1BAT_SOCK-2032_CR2032HE_20322032CR2032HE
    BZT1BUZZER_BUZZER_BUZZERBUZZERBUZZER
    CB110UF10%-1206-X5R-25V_1206C_10U210u25V10%1206C
    CB13100NF+80-20%-0603-Y5V-50V_060_3100n50V+80-20%_NC0603C
    CB14100NF+80-20%-0603-Y5V-50V_0603C100n50V+80-20%0603C
    CE1D-CE-1000UF20%-16V-20/40_CE20-41000uF20%16V20/40CE20-40
    CE2D-CE-220UF20%-25V-16/32_CE8-3_5220uF25V16/32CE8-3_5
    CE15D-CE-1000UF20%-16V-20/40_CE20-41000uF20%16V20/40CE20-40
    CN1D-SCON-6-1.25S_SIP6-1_27S_SIP6-SIP6-1.25SSIP6-1_27S
    CNT10D-SATA-DIP7A_0_SATA7-1_27B_SATASATA-DIP7BSATA7-1_27B
    CT110UF10%-1206-X5R-25V_1206C_10U210u25V10%1206C
    D1S-S-DIODE-1N5819-1206_1206D_1N51N5819-12061206D
    D2D_DMMELF_DMMELF_1N41481N4148DMMELF
    D3D_DMMELF_DMMELF_1N41481N4148DMMELF
    D66S-S-DIODE-1N5819-1206_1206D_1N51N5819-12061206D
    DT4S-DIODE-1N4148-1206_DMMELF_1N411N4148DMMELF
    H8HOLE40-8STAR-000_HOLE41-8STAR_HHOLE40-8STAR-000HOLE41-8STAR
    J1CON4_IDEPWR_0_IDEPWR_IDEPWRIDEPWRIDEPWR
    J2D-ATX-2X10-3.5MS_ATX-POWER20A_HHEADER10X2-2_54FSATX-POWER20A
    J3D-SCON-45-2_10.0S_BLOCK_3531T_HHi3531-BLOCK-PINBLOCK_3531T
    J4HEADER8X2_IDC16-2_54AR_IDC16-3HEADER8X2_IDC16-2_54ARIDC16-3_81AR
    J5HEADER8X2_IDC16-2_54AR_IDC16-3HEADER8X2_IDC16-2_54ARIDC16-3_81AR
    J6RJ45A_RJ45A_RJ45RJ45RJ45A
    J7USBS_0_USB-H-A_USBS_NCUSBS_NCUSB-H-A
    J8HDMIDB19S4HDMI_RX_CON_SMD
    J9D-SCON-45-2_9.0S_BLOCK_3531B_HIHi3531-BLOCK-PINBLOCK_3531B
    J15D-BNCX1S_BNC-5_BNCX1SBNCX1SBNC-5
    JK4D-RELAY-HLS6-4100-DC5V_HLS6_410HLS6-4100-5VHLS6_4100H
    JT1D-SCON-2-2.54S_SIP2-2_5A_CON2CON2SIP2-2_5A
    JT2D-SCON-10-2.54S_SIP10-2_5A_CON1CON10SIP10-2_5A
    JT3D-SCON-2-2.54S_SIP2-2_5A_CON2CON2SIP2-2_5A
    JT4D-SCON-4-5.08S_IDEPWR_IDEPWRIDEPWRIDEPWR
    JT5D-DHD-2X20-2.54MS_IDC40-2_54A_HHEADER20X2_IDC40-2_54AIDC40-2_54A
    JT6D-SCON-2-2.54S_SIP2-2_5A_CON2CON2SIP2-2_5A
    JT7D-SCON-4-2.54S_SIP4-2_5A_CON4CON4SIP4-2_5A
    JT9D-SCON-2-7.5S_SIP2-7_5_TERMINALTerminal2SIP2-7_5
    JT10D-SCON-3-2_54S_SIP3-2_5A_CON3_SCON3_SIP3-2_5A_NCSIP3-2_5A
    JT11D-CON-USB_SOCKET-AB_USB-H-A_USBUSBH-AUSB-H-A
    JT12D-CON-DC005_POWERJACK_POWERJACKPOWERJACKPOWERJACK
    L4S-INDUC-0805L-600R_0805L_600R@1600R@100M08050805L
    L5IND_MSS1278_1_LS-SB0560_4UH/20A4uH/20ALS-SB0560
    L6D-INDUC-LH810-10UH_LD8_5-5_LH81LH810-10uHLD8_5-5
    L7S-INDUC-0603L-120R_0603L_120R@1120R@100M06030603L
    L8S-INDUC-0603L-120R_0603L_120R_1120R@100M0603_NC0603L
    L9S-INDUC-SCDH127-12X12-10UH_SCDH10uH/5ASCDH127_6X4
    L11S-INDUC-SCDH127-12X12-10UH_SCDH10uH/5ASCDH127_6X4
    L53IND_MSS1278_1_LS-SB0560_4UH/20A4uH/20ALS-SB0560
    LB8S-INDUC-0603L-120R_0603BL_120_1120R@100M0603_NC0603BL
    LB9S-INDUC-0805L-600R_0805BL_600R@600R@100M08050805BL
    LED10S-LED-NLGREEN-0603_0603LED_GREEGREEN-06030603LED
    LED11S-LED-HLRED-0603_0603LED_RED-06RED-06030603LED
    LEDT1S-LED-HLRED-0603_0603LED_NC_REDNC_RED-06030603LED
    PTC1D-PTC-30V-4A-RAD0.2_PTC-D_10_5_X30UF400PTC-D_10_5
    PTCT1D-PTC-250V-0.12A-RAD0.2_RAD2_JKJK250-120RAD2
    PTCT2D-PTC-250V-0.12A-RAD0.2_RAD2_JKJK250-120RAD2
    Q9S-NPN-MMBT3904-SOT23_SOT23_MMBTMMBT3904-SOT23SOT23
    Q10MOSFET_P_SOT23_SOT23_IRLML6401TIRLML6401TRPBFSOT23
    Q11S-NPN-MMBT3904-SOT23_SOT23_MMBTMMBT3904-SOT23SOT23
    Q12MOSFET_P_SOT23_SOT23_IRLML6402PIRLML6402PBFSOT23
    Q13S-NPN-MMBT3904-SOT23_SOT23_MMBTMMBT3904-SOT23SOT23
    Q14S-NPN-MMBT3904-SOT23_SOT23_MMBTMMBT3904-SOT23SOT23
    QT1S-NPN-MMBT3904-SOT23_SOT23_S805S8050LT1SOT23
    QT6S-NPN-MMBT3904-SOT23_SOT23_MM_1MMBT3904SOT23
    T1PULSEH5007_0_H5007_PULSE H5007Pulse H5007H5007
    TT1S-TRANS-H1102_STFM16-50-285_H11H1102STFM16-50-285
    TVST1D-TVS-P6KE6V8-DO15_DO-15_P6KE6VP6KE6V8DO-15
    TVST2D-TVS-P6KE6V8-DO15_DO-15_P6KE6VP6KE6V8DO-15
    TVST3S-PESD0603-140_0603R_PESDPESD0603R
    TVST4S-PESD0603-140_0603R_PESDPESD0603R
    TVST5S-PESD0603-140_0603R_NC_PESDNC_PESD0603R
    TVST6S-PESD0603-140_0603R_NC_PESDNC_PESD0603R
    TVST7S-PESD0603-140_0603R_PESDPESD0603R
    TVST8S-PESD0603-140_0603R_PESDPESD0603R
    U1JR0325A0_QFN64_4_QFN64-9X9_JMB3JMB321_QFN64QFN64-9X9
    U2JR0325A0_QFN64_4_QFN64-9X9_JMB3JMB321_QFN64QFN64-9X9
    U3SERIALFLASH_25LV512/010_SOP8_0NC_25LV512SOP8-6_2-1_27
    U4SERIALFLASH_25LV512/010_SOP8_0NC_25LV512SOP8-6_2-1_27
    U6S-IC-MP1482DS-SO8_SON8-6_2-1_27MP1482SON8-6_2-1_27
    U7S-IC-MP1484EN-SO8_SON8-6_2-1_27MP1484SON8-6_2-1_27
    U10S-IC-MP1484EN-SO8_SON8-6_2-1_27MP1484SON8-6_2-1_27
    U11SRV05-4_SOT23-6_SRV05-4SRV05-4SOT23-6
    U12SRV05-4_SOT23-6_SRV05-4SRV05-4SOT23-6
    U29CM2020CM2020SOP38-20-173A
    U45NB638NB638QFN20-NB638
    U46NB638NB638QFN20-NB638
    U618S-IC-TPS54425_0_S-PVQFN-N14_TPSTPS54821S-PVQFN-N14
    U619S-IC-TPS54425_0_S-PVQFN-N14_TPSTPS54821S-PVQFN-N14
    UB1S-IC-SRV05-4_SOT23-6_SRV05-4SRV05-4SOT23-6
    UT1S-IC-L78L05ABUTR-SOT89_SOT-89_LL78L05ABUTRSOT-89
    UT2S-IC-AP1117-1.8_SOT223_AMC1117-AMC1117-1.8SKSOT223
    UT3S-IC-DS1307Z_SOP8-6_2-1_27_DS13DS1307ZSOP8-6_2-1_27
    UT4S-IC-485-SN65LBC184DR_SOP8-6_2-MAX485EESASOP8-6_2-1_27
    UT5S-IC-AP1117-1.8_SOT223_AMC1117-AMC1117-1.8SKSOT223
    UT6S-IC-LM358AM-SO8_SOP8-6_2-1_27_LM358SOP8-6_2-1_27
    UT7S-IC-SGM9115_SOP8-6_2-1_27_SGM9SGM9115SOP8-6_2-1_27
    UT8S-IC-SGM9115_SOP8-6_2-1_27_SG_1SGM9116_NCSOP8-6_2-1_27
    UT9S-IC-LM3526_SOP8-6_2-1_27_MIC20MIC2026-2BMSOP8-6_2-1_27
    UT10S-IC-232-MAX232ACSE_SOP16-6_2-1MAX232ACSESOP16-6_2-1_27
    X1S-CRYS-25M-XTAL_49M_XTAL-49M_2525M-XTAL_49MXTAL-49M
    X2S-CRYS-25M-XTAL_49M_XTAL-49M_2525M-XTAL_49MXTAL-49M
    XT1D-CRYS-32.768KHZ_XTAL-08_32.76832.768KXTAL-08
    ZT1S-GDS-BA301N-4532S_TVS-SMB_SEMIsemiconductor_NCTVS-SMB
    ZT2S-GDS-BA301N-4532S_TVS-SMB_SEMIsemiconductor_NCTVS-SMB
    重要提示:PCB作品文件展下载说明
     楼主| 发表于 2017-12-29 14:31:56 | 显示全部楼层
    Hi3531BB.7z (1.54 MB, 下载次数: 21)
    昨天 16:46
  • 签到天数: 235 天
    你必须非常努力才能显
    发表于 2017-12-29 14:39:13 | 显示全部楼层
    终身成就奖原创先锋奖优秀斑竹奖
    发表于 2017-12-29 14:50:44 | 显示全部楼层
    终身成就奖原创先锋奖优秀斑竹奖
    发表于 2017-12-30 00:01:46 | 显示全部楼层
  • 签到天数: 76 天
    社区居民终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2017-12-30 08:43:49 | 显示全部楼层
    终身成就奖社区居民
    发表于 2017-12-30 08:55:16 | 显示全部楼层
    游客
    发表于 2017-12-30 08:59:04 | 显示全部楼层
    发表于 2017-12-30 09:01:47 | 显示全部楼层
    发表于 2020-8-21 16:42:46 | 显示全部楼层
