| 1 | 10AB___A | FBGA96/SMD/P0.8/3-IN-1 | 1 | U6 |
| 2 | 10AB___A | MT8516/TFBGA406/P0.5/B0.27/12.6X13.1 | 1 | U201 |
| 3 | 10AB___A | SOT-23/3P/SMD/RT9169 | 1 | U1 |
| 4 | 10AB___A | SOT-23/5P/SMD/RT9043GB | 2 | U2 U9718 |
| 5 | 10AB___A | TQFN32/SMD/P0.4/4X4/G2156 | 1 | U5 |
| 6 | 10AB___A | TSOP48/SMD | 1 | U22 |
| Resisters | | 74 | |
| 7 | 10AR___A | R0402 | 68 | R3 R4 R5 R7 R8 R9 R11 R12 R13 R14 R15 R16 R24 R25 R26 R30 R31R37 R42 R52 R55 R57 R58 R59 R60 R61 R62 R63 R64 R65 R67 R69 R70 R82 R92 R114R140 R154 R201 R203 R210 R212 R217 R218 R219 R220 R222 R223 R305 R306 R307R309 R339 R364 R365 R409 R413 R415 R426 R433 R526 R1018 R1019 R1020 R1021R1048 R1049 R5009 |
| 8 | 10AR___A | R0603 | 6 | R6 R10 R29 R101 R102 R104 |
| Capacitors | | 109 | |
| 9 | 10AC___A | C0402 | 96 | C1 C2 C3 C4 C5 C10 C15 C17 C19 C41 C42 C43 C49 C51 C52 C54 C55C58 C59 C60 C61 C62 C63 C64 C65 C66 C68 C70 C72 C73 C74 C75 C76 C86 C88 C89C90 C92 C93 C94 C95 C96 C97 C98 C99 C101 C102 C103 C104 C105 C118 C119 C120C124 C125 C127 C128 C130 C131 C138 C139 C140 C143 C145 C147 C148 C149 C150C152 C155 C156 C157 C158 C159 C161 C162 C163 C164 C165 C166 C197 C200 C213C216 C222 C223 C245 C323 C324 C340 C341 C342 C353 C354 C601 C1006 |
| 10 | 10AC___A | C0603 | 13 | C16 C50 C69 C91 C100 C121 C122 C129 C132 C133 C134 C136 C153 |
| Inductors | | 6 | |
| 11 | 10AE___A | L/IND/SMD/2520 | 3 | L2 L4 L5 |
| 12 | 10AE___A | L/IND/SMD/LVS-S3016 | 1 | L1 |
| 13 | 10AE___A | L0402 | 2 | L5007 L5009 |
| Connectors | | 1 | |
| 14 | 10AS___A | MODULE/110P/SMD/P1.4/45X55 | 1 | CON9001 |
| Fuses | | | 3 | |
| 15 | 10AM___A | FD | 3 | FM1 FM2 FM5 |
| Jumpers | | | 5 | |
| 16 | | TP0.3MM | 5 | TP102 TP103 TP104 TP105 TP123 |
| Unkowns | | | 20 | |
| 17 | | CRYSTAL/SMD/D3.2X2.5/M118-103 | 1 | X601 |
| 18 | | NC/MMD/L3/4MIL | 2 | NC19 NC20 |
| 19 | | PAD_3PIN | 1 | WIFI_BT_ANT |
| 20 | | R0402 | 5 | NTC302 RD4 VR407 VR408 VR418 |
| 21 | | SHIELD_CAN_CLIP/3P/SMD/PTV3121N | 11 | PB1 PB2 PB3 PB4 PB5 PB6 PB7 PB8 PB9 PB10 PB11 |
| BottomLayer | | 20 | |
| Jumpers | | | 19 | |
| 22 | | TP/SMD/D0.6 | 15 | TP107 TP108 TP109 TP110 TP111 TP112 TP113 TP114 TP115 TP116TP125 TP126 TP127 TP128 TP129 |
| 23 | | TP0.3MM | 4 | TP100 TP101 TP106 TP124 |
| Unkowns | | | 1 | |
| 24 | | NC/MMD/L1/4MIL | 1 | NC14 |
