查看: 2337|回复: 2
[Allegro16.6以下] S32K116EVB S32K116评估板
发表于 2018-11-27 20:40:56 | 显示全部楼层 |阅读模式
[/free]
S32K116EVB-QSP.zip (7.2 MB, 下载次数: 4)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uF10%DISCRETEC2
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uF10%DISCRETEC3
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC4
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC5
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UF DISCRETEC6
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC7
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uF10%DISCRETEC8
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UF DISCRETEC9
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC10
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uF DISCRETEC11
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_110uF10%DISCRETEC12
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UF DISCRETEC16
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965220PF DISCRETEC17
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uF10%DISCRETEC18
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC19
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC21
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC22
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC24
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC25
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC26
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC27
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UF DISCRETEC28
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.0MM4700 PF DISCRETEC40
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC47
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M0.01UF20%DISCRETEC59
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_112PF DISCRETEC126
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_112PF DISCRETEC127
CCE6P8X6P8CAP_POL_CCE6P8X6P8_DISCRETE_6.147uF DISCRETEC128
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC129
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC140
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UF DISCRETEC143
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UF DISCRETEC144
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM10pF10%DISCRETEC533
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM10pF10%DISCRETEC535
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC536
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UF DISCRETEC542
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC543
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC544
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC545
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC546
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC547
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC548
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF10%DISCRETEC549
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC550
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.0MM4700 PF DISCRETEC551
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC552
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC553
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC554
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC555
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC556
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC557
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uF DISCRETEC558
LED_0603LED_LED_0603_IC_0.9MM_370-75079RED ICD1
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREEN ICD2
LED_0603LED_LED_0603_IC_0.85MM_370-7654GREEN ICD3
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1MM_PMEG3050EP ICD6
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1MM_PMEG3050EP ICD9
LED6_5X6MMLED_TRI_COLOR_LED6_5X6MM_IC_2.6LED RED/GRN/BL ICD11
DSN0603-2DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSF ICD17
DSN0603-2DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSF ICD18
DSN0603-2DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSF ICD19
TP_TH_063TEST_POINT_3_TP_TH_063_IC_5.6MM5006 ICGND1
TP_TH_063TEST_POINT_3_TP_TH_063_IC_5.6MM5006 ICGND2
CON_SKT1X8_THCONN_HDR_8X1_CON_SKT1X8_TH_IO_8SKT_1X8 IOJ1
CON_SKT1X10_THCONN_HDR_10X1_CON_SKT1X10_TH_IOSKT_1X10 IOJ2
SKT2X8_TH_SSQCONN_HDR_8X2_SKT2X8_TH_SSQ_IO_8SKT_2X8 IOJ3
SKT2X8_TH_SSQCONN_HDR_8X2_SKT2X8_TH_SSQ_IO_8SKT_2X8 IOJ4
CON_MICROAB_10F_25_SM_RAMICRO_USB_CONN_10PIN_CON_MICROAUSB_MICRO_AB IOJ7
HDR103CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR TH 1X3 IOJ10
CON_HDR_4M_100_TH_RACONN_HDR_4X1_CON_HDR_4M_100_TH_HDR 1X4 RA IOJ11
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5 IOJ12
CON_HDR_4M_100_TH_RACONN_HDR_4X1_CON_HDR_4M_100_TH_HDR 1X4 RA IOJ13
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5 IOJ14
HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ15
CON3_PWR_JACK_TH_PJ051ADC_POWER_JACK_SHD_CON3_PWR_JACKCON PWR 3 IOJ16
HDR103CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR TH 1X3 IOJ104
HDR103CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR TH 1X3 IOJ107
HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ108
IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1330 OHM DISCRETEL1
IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1330 OHM DISCRETEL2
IND_0402INDUCTOR_FERRITE_IND_0402_DISCR30 OHM DISCRETEL512
LFPAK5_1P27_5X4PMOS_5P_LFPAK5_1P27_5X4_IC_1.2PHPT61003PY ICQ1
SC_75NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1G ICQ6
SC_75NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1G ICQ7
SC_75NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1G ICQ8
SC_75NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1G ICQ9
SOT-563_6P_0P5_SMTBJT_DUAL_PNP_NPN_SOT-563_6P_0P5BC847BVN ICQ10
SOT-563_6P_0P5_SMTBJT_DUAL_PNP_NPN_SOT-563_6P_0P5BC847BVN ICQ11
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER1
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER3
RC0402_25RES_RC0402_25_DISCRETE_0.40MM_180K DISCRETER4
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__1220 DISCRETER12
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32MM5K20%DISCRETER13
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER15
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER16
RC0402_25RES_RC0402_25_DISCRETE_0.45M_105%DISCRETER18
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__333 DISCRETER21
RC0402_25RES_RC0402_25_DISCRETE_0.45M_105%DISCRETER24
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__333 DISCRETER25
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER30
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER31
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER32
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER35
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER39
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER42
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__410.0K1%DISCRETER44
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER47
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER49
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER51
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER52
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_1680 DISCRETER56
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER57
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__510.0K1%DISCRETER60
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__210.0K DISCRETER62
RC0402_25RES_RC0402_25_DISCRETE_0.40M_115K1%DISCRETER68
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__61.0K1%DISCRETER69
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__410.0K1%DISCRETER74
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__210.0K DISCRETER77
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_42K DISCRETER80
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER84
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER88
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__21.0M DISCRETER91
RC1206_OVRES_RC1206_OV_DISCRETE_0.6MM_4760.4 DISCRETER92
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_1680 DISCRETER95
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_1680 DISCRETER96
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_1680 DISCRETER97
RC1206_OVRES_RC1206_OV_DISCRETE_0.6MM_4760.4 DISCRETER98
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER117
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER119
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER120
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER121
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER169
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_42K DISCRETER171
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER172
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER300
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_44.7K DISCRETER525
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER527
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_44.7K DISCRETER528
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER530
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_12.2 DISCRETER535
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_10k DISCRETER537
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER538
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER562
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER571
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER572
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER573
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER574
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER575
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7K1%DISCRETER576
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER577
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER578
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER579
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER580
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER581
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER582
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER583
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER584
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER585
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER587
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER588
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER589
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER590
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER591
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER592
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER593
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_11K DISCRETER595
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_11K DISCRETER596
RC0603_OVRES_RC0603_OV_DISCRETE_0.55M_11K DISCRETER597
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER598
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_433K DISCRETER599
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_433K DISCRETER600
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER601
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_433K DISCRETER602
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER603
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER604
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_433K DISCRETER605
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER607
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER608
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER609
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710K DISCRETER623
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER624
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER625
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER626
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER627
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER632
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER635
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER636
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER637
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER638
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER639
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER640
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER641
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER642
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER643
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER644
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER645
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER649
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER650
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER651
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER652
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER653
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER654
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER655
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER656
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER657
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER658
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER659
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER660
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER662
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER663
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER666
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER667
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER669
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER671
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER673
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER674
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER675
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER676
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER677
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER678
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER679
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER680
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER681
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER685
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER686
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER687
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER693
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER694
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER695
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER696
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER697
RC0402_25RES_RC0402_25_DISCRETE_0.45M_105%DISCRETER701
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER702
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER703
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER712
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER713
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER715
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER718
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER719
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_2560 OHM DISCRETER729
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0K5%DISCRETER730
RC0402_25RES_RC0402_25_DISCRETE_0.40M_2100K DISCRETER731
RC0402_25RES_RC0402_25_DISCRETE_0.40M_318K DISCRETER732
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__74.7K DISCRETER733
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER737
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER739
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER741
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER745
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER750
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER752
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER753
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER754
SH0603RES_SHORT-2_SH0603_DISCRETE_0.10 DISCRETESH1
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402W ICSW2
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402W ICSW3
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402W ICSW5
ELECTRODE_SQ_15MMELECTRODE_ELECTRODE_SQ_15MM_IC_Electrode ICSW7
ELECTRODE_SQ_15MMELECTRODE_ELECTRODE_SQ_15MM_IC_Electrode ICSW8
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402W ICSW9
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP4
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP5
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP6
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP7
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP8
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP9
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP10
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP11
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP12
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP18
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP28
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP29
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP30
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP503
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP504
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP505
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP506
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP507
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP508
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP509
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP510
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP511
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP512
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP513
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP514
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP515
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP516
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP517
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP518
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP519
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP520
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP521
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP522
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP523
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP524
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP525
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP526
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINT ICTP527
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP528
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP529
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP530
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP531
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP532
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP533
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP534
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP535
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP536
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP537
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP538
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP539
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP540
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP541
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP542
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP543
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP544
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP545
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD93
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD94
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD95
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD96
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD97
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD98
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD99
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTPAD100
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS1
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS2
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS3
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS4
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS5
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS6
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS7
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOP ICTS8
XQFN8_1P45X1P25MMNTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8H ICU1
SSOP8_DCU74LVC2T45DC_8P_SSOP8_DCU_IC_1MM74LVC2T45DC ICU2
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45 ICU4
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45 ICU7
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPMK20DX128VFM5 ICU8
SOT891_6P_0P35_1P05X1P05NC7WP14_SOT891_6P_0P35_1P05X1P074LVC2G14GF,132 ICU9
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45 ICU10
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6 ICU11
SOT23_5SSPX3819M5_FIX_0_SOT23_5S_IC_1.4SPX3819M5-L-3-3 ICU15
SON20_0P5_3P6X5P6UJA1169TKF_3_SON20_0P5_3P6X5P6_UJA1169TK/F ICU19
SO8_1P27_4X5TJA1027T_0_SO8_1P27_4X5_IC_1.75TJA1027T/20 ICU21
XQFN8_1P45X1P25MMNTSX2102GU8H_0_XQFN8_1P45X1P25MNTSX2102GU8H ICU26
XQFN8_1P45X1P25MMNTSX2102GU8H_0_XQFN8_1P45X1P25MNTSX2102GU8H ICU32
XQFN8_1P45X1P25MMNTSX2102GU8H_0_XQFN8_1P45X1P25MNTSX2102GU8H ICU33
XQFN8_1P45X1P25MMNTSX2102GU8H_0_XQFN8_1P45X1P25MNTSX2102GU8H ICU34
LQFP48PS32K116_LQFP_0_LQFP48_IC_1.6MMPS32K116LFF0MLCR ICU36
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZ ICY1
XTAL2_3P3X2P6XTAL_XTAL2_3P3X2P6_IC_0.95MM_2340MHz ICY3
[free]
购买主题 本主题需向作者支付 5 枚金币 才能浏览
重要提示:PCB作品文件展下载说明
    5 天前
  • 签到天数: 284 天
    发表于 2018-11-27 21:53:27 | 显示全部楼层
    昨天 11:02
  • 签到天数: 376 天
    [LV.9]以坛为家II
    53
    社区居民终身成就奖特殊贡献奖
    发表于 2019-4-28 16:22:10 | 显示全部楼层
    VERY GOOD!
