重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | CAN_H | TEST | TP-1.0 | | CAN_L | TEST | TP-1.0 | | CN2 | COM4 | COM4 | CON4 | CN3 | USB-4P2.0 | 4PIN-2.0MM | | CN4 | CN60P_HSD | CN60PA05TA | HANNSTAR TFT 60P 0.5MM DN | CN6 | MARK | MARK | | CN7 | MARK | MARK | | CN8 | MARK | MARK | | CN9 | MARK | MARK | | CN15 | CON4 | CON4-1.0 | 4P 1.0MM DN | CON1 | 9PPAD | 9PCONPAD | CARD CON | CON2 | 9PCONPAD | 9PCONPAD | MAP CARD CON | CON4 | 30PINCON | 30PINCHIPCON | 30P 0.5MM DN | CON5 | 30PINCON | 30PINCHIPCON | 30P 0.5MM DN | CON6 | TF-CARD | TFCARD | GPS TF CARD | CON7 | 9PCONPAD | 9PCONPAD | MAP CARD CON | CON8 | TF-CARD | TFCARD | DVD TF CARD | CON9 | 9P | 9PCONPAD | MAP CARD CON | CON10 | CON-SMT-2PIN | CON-SMT-2PIN-1.25MM | 2P PH=1.25MM | CON11 | 4PCON | 4PINDIPCON | NC | D1 | DIODE | D1206 | 1N4148 | D4 | D-SW-1N4148-SOD-323-AA | D-SOD-323-AA | IN4148 | D12 | DIO | CHIPDIO1 | IN4148 | D14 | DIO | CHIPDIO1 | IN4148 | E1 | EC-220UF/6.3V-SMD-6.3X5.5-AA | EC-SMD-6.3X5-AA | 220UF/10V | E19 | EC | NUCAP6X5 | 47UF/10V | EC1 | C | NUCAP6X5 | 47UF/10V | EC2 | C | NUCAP6X5 | 47UF/10V | J1 | CON16 | CON-FPC16P-1.0D | 16pin 1.0 mm UP | L3 | IND | 0805IND | 1UH | L4 | IND | 0805IND | 1UH | L5 | L | CHIPINDX5.6 | 10UH | L6 | IND | 0805IND | 1UH | L7 | IND | 0805IND | 1UH | L8 | IND | 0805IND | 1UH | L9 | IND | 0805IND | 1UH | L10 | L | CHIPIND4X3 | 10UH | L11 | L | CHIPINDX5.6 | 22UH | L12 | L | CHIPINDX5.6 | 100UH | LED26 | LED | CHIPLED | LED | MIC+ | TP | TP-HOLE | TP | MIC- | TP | TP-HOLE-1 | TP | MIC1 | MIC | MICROPHONE | | Q1 | BAT54S | BAT54S | BAT54S | Q2 | NPN | SOT-23 | 8050 | Q9 | PNP | SOT-23 | 8550 | Q10 | NPN | SOT-23 | 8050 | Q11 | BAT54S | BAT54S | BAT54S | REM1 | IR | REMOTE | IR | RP7 | RPACK4 | 4XR0402 | 33R | RX | TEST | TP-1.0 | | SW1 | ENVOL | ENVOL | POWER/MUTE | SW2 | SW | SW-SMD2-3.5H | BND | SW3 | SW | SW-SMD2-3.5H | SRC | SW4 | SW | SW-SMD2-3.5H | GPS | SW5 | ENVOL | ENVOL | ENTER | TX | TEST | TP-1.0 | | U1 | T107_13 | 128 | T107 | U2 | AMS1117 | AMS1117 | RT9164-1V8 | U3 | AMS1117 | AMS1117 | RT9164-3V3 | U4 | AAT4280 | MP3202 | AAT4280 | U5 | TJA1050T | SOP8 | TJA1040 | U6 | AAT4280 | MP3202 | AAT4280 | U7 | STM8_64 | IC-LQFP-64(10X10)-AA | STM8_64p | U12 | MP3202DJ | MP3202DJ | MP3202DJ | U15 | TSC2003 | TSC2003 | TSC2003 | U23 | TPS61041 | SOT23-5L | TPS61040 | USB1 | USB5P | SST-USB-1 | | USB3 | USB-4PA | CON-4PIN-1.25MMA | | X1 | TCXO-C-16M-HC-49S/SMD-AA | TCXO-HC-49S/SMD-H4.2-AA | 16M | Y1 | CRYSTAL | CHIPCRYSTAL1 | 27MHZ | ZD2 | D-ZEN-5.6V/300MW-SOD-323-AA | D-SOD-323-AA | 5.6V | ZD3 | ZD | ZD1206 | MBR0520 | ZD4 | D-ZEN-5.6V/300MW-SOD-323-AA | D-SOD-323-AA | 5.6V | ZD5 | D-ZEN-5.6V/300MW-SOD-323-AA | D-SOD-323-AA | 5.6V | ZD6 | ZENDIO | CHIPZENDIO1 | 7.5V | ZD7 | ZENDIO | CHIPZENDIO1 | 10V | ZD8 | D-ZEN-5.6V/300MW-SOD-323-AA | D-SOD-323-AA | 5.6V |
重要提示:PCB作品文件展下载说明
