查看: 4737|回复: 28
[Allegro16.6以下] 一个开发板底板PCB文件共享
    长期免费代管18-28岁小
    发表于 2019-5-26 15:57:54 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    BAT1BATTERY_0_BAT1_BATTERYBATTERYBAT1
    CON1HIF3F-20PA-2_54DS_HDRMS2MM-2X10HIF3F-20PA-2.54DS(Box,Male,Right Angle)HDRMS2MM-2X10
    CON2CON_DB9_DSUB9-RA-FE_CON_DB9CON_DB9DSUB9-RA-FE
    CON3CON_DB9_DSUB9-RA-FE_CON_DB9CON_DB9DSUB9-RA-FE
    CON4CON_DB9_DSUB9-RA-FE_CON_DB9CON_DB9DSUB9-RA-FE
    CON5CON_DB9_DSUB9-RA-FE_CON_DB9CON_DB9DSUB9-RA-FE
    CON6MD60-19P_6_MD60-19P_HDMI19Phdmi19pMD60-19P
    CON7ZX62RD-AB-5P8_2_MICROUSB-B-H_ZXZX62RD-AB-5P8MICROUSB-B-H
    CON8CON_SIM_CARD6_2_CON6-SIM_CON_SICON_SIM_CARD6CON6-SIM
    CON9MD60-19P_4_HDMI-C_MD60-19PMD60-19PHDMI-C
    CON10CON40X2_0_8MM_CON2X40-0_5MM-BB_CON40X2_0_8MMCON2X40-0_5MM-BB
    CON11CON40X2_0_8MM_CON2X40-0_5MM-BB_CON40X2_0_8MMCON2X40-0_5MM-BB
    CON12CON40X2_0_8MM_CON2X40-0_5MM-BB_CON40X2_0_8MMCON2X40-0_5MM-BB
    CON13CON40X2_0_8MM_CON2X40-0_5MM-BB_CON40X2_0_8MMCON2X40-0_5MM-BB
    CT1C0402_0_C0603_10UF/10V10uF/10VC0603
    D1DIODE_D1206_IN4148IN4148D1206
    E1ANTENNA_2_0X3_0-SMD_M830310M8303102_0X3_0-SMD
    F1FUSE_R0603_YDQYDQR0603
    FB16FB1206_0_FB0603_FB0603FB0603FB0603
    FB17HCB2012KF-300T50_1_L0402_BLM15ABLM15AG221SN1DL0402
    H1TP_P0_0.8_D0_HOLE2_7_TP_P0_0.8_TP_P0_0.8_D0HOLE2_7
    H2TP_P0_0.8_D0_HOLE2_7_TP_P0_0.8_TP_P0_0.8_D0HOLE2_7
    H3TP_P0_0.8_D0_HOLE2_7_TP_P0_0.8_TP_P0_0.8_D0HOLE2_7
    H4TP_P0_0.8_D0_HOLE2_7_TP_P0_0.8_TP_P0_0.8_D0HOLE2_7
    J1MS110-C10B-C16_2_TF-CARD_MS110-MS110-C10B-C16TF-CARD
    J2SDCARDSOCKET_0_SDCARD_SDCARDSDCardSDCARD
    J3CON2_2_54P_A4B-2PA-2_54DSA_CON2CON2_2_54PA4B-2PA-2_54DSA
    J4CON2_2_54P_A4B-2PA-2_54DSA_CON2CON2_2_54PA4B-2PA-2_54DSA
    J5CON2-2_54P_A4B-2PA-2_54DSA_CON2CON2-2_54PA4B-2PA-2_54DSA
    J6JACK_AU_EAR_JACK_JACK_AUJACK_AUEAR_JACK
    J7JACK_AU_EAR_JACK_JACK_AUJACK_AUEAR_JACK
    J8LVDS_QM_2_FPC30-050_LVDS_QMLVDS_QMFPC30-050
    J9LVDS_QM_2_BL115-050-30RL_LVDS_QLVDS_QMBL115-050-30RL
    J12HEADER2_HEADER2-3_8_HEADER 2HEADER 2HEADER2-3_8
    J13SKT_USB-ACONN_4PMINIABUSB
    J14HEADER2_HEADER2-3_8_HEADER 2HEADER 2HEADER2-3_8
    J15SKT_USB-ACONN_4PMINIABUSB
    JACK1POWERJACK_3_JACK-2_5MM_B_POWERPOWER JACK_3JACK-2_5MM_B
    L1LQH32C_0_L6X6-CDRH58D18R_3.3UH(3.3uH(CDRH3D18ENP-3R3NC)L6X6-CDRH58D18R
    L2LQH32C_0_L0402_100NH100nHL0402
    L3LQH32C_0_L0402_100NH100nHL0402
    L6LQH32C_0_L0402_3.3NH3.3NHL0402
    L7LQH32C_0_L3X3MM_2.2UH2.2uHL3X3MM
    L9LQH32C_0_L6X6-CDRH58D18R_3.3UH(3.3uH(CDRH3D18ENP-3R3NC)L6X6-CDRH58D18R
    LED1LED-RED_SMD_1_LED-2012_LED-REDLED-Red (SMD 2012)LED-2012
    PWRON1SW-TACT_SW4-SMD_SW-TACT(RED)_11SW-TACT(RED)_1105SSW4-SMD
    PWRON2SW-TACT_SW4-SMD_SW-TACT(RED)_11SW-TACT(RED)_1105SSW4-SMD
    PWRON3SW-TACT_SW4-SMD_SW-TACT(RED)_11SW-TACT(RED)_1105SSW4-SMD
    PWRON4SW-TACT_SW4-SMD_SW-TACT(RED)_11SW-TACT(RED)_1105SSW4-SMD
    PWRON5SW-TACT_SW4-SMD_SW-TACT(RED)_11SW-TACT(RED)_1105SSW4-SMD
    Q1PDTC114YE_0_SOT-23_PDTC114YEPDTC114YESOT-23
    RF1CON_SMA-V_SMA_CON_SMA-VCON_SMA-VSMA
    RJ1HR911105A_0_RJ8-SRLBY_HR911105AHR911105ARJ8-SRLBY
    SW1SW-4_SW4-SMD_SW-4SW-4SW4-SMD
    SW2SW-3_KHS03_SW-3SW-3KHS03
    TP4TP_P0_0.8_D0_2_0X3_0-SMD_GNDgnd2_0X3_0-SMD
    TP5TP_P0_0.8_D0_TP0_8-SMD_DL_KEYDL_KEYTP0_8-SMD
    TP6TP_P0_0.8_D0_TP0_8-SMD_U0TXDU0TXDTP0_8-SMD
    TP7TP_P0_0.8_D0_TP0_8-SMD_U0RXDU0RXDTP0_8-SMD
    U1U-MP2012DQ_0_SWITCH_DDSZ_MP2012MP2012DQSWITCH_DDSZ
    U2U-MP2012DQ_QFN6-0_95-3X3H_MP201MP2012DQQFN6-0_95-3X3H
    U3U-MP2012DQ_QFN6-0_95-3X3H_MP201MP2012DQQFN6-0_95-3X3H
    U4MAX3232EEAE_SOIC16_MAX3232CSEMAX3232CSESOIC16
    U5MAX3232EEAE_SOIC16_MAX3232CSEMAX3232CSESOIC16
    U6MAX3232EEAE_SOIC16_MAX3232CSEMAX3232CSESOIC16
    U774ALVC164245DGGU-74ALVC164245DGGTSSOP_48
    U8DM9621NP_1_QFN48-050-0707LH_DM9DM9621NPQFN48-050-0707LH
    U974ALVC164245DGGU-74ALVC164245DGGTSSOP_48
    U10WM8960GEFL_0_QFN32-050-5X5LH_WMWM8960GEFLQFN32-050-5X5LH
    U12U-SN75LVDS83BDGG_3_TSSOP56_SN75SN75LVDS83BDGGTSSOP56
    U14TXS0102DCU_1_TSSOP8_TXS0102DCUTXS0102DCUTSSOP8
    U15SWB-A31_SWB-A31-WIFIMODULE_SWB-SWB-A31SWB-A31-WIFIMODULE
    U16DSX321G26MHZ_X4-2_5X3_2_7V260007V26000012X4-2_5X3_2
    U17DSX321G26MHZ_X4-2_5X3_2_DSX321GDSX321G26MHZX4-2_5X3_2
    U18MCP2515_SOIC_18W_MCP2515MCP2515SOIC_18W
    U19MCP2551_SOIC8_MCP2551MCP2551SOIC8
    U20SN65HVD3082_SOIC8_SN65HVD3082SN65HVD3082SOIC8
    U21U-SMF05C_SC70-6_SMF05CSMF05CSC70-6
    U22RT8065_SOIC8-LH_RT8065RT8065SOIC8-LH
    U23UNA-PLUS-MODULE_4_LGA66_27X16-7UNA-PLUS-Module_4LGA66_27X16-7MM_02
    U24UFL-R-SMT-1_RF_UFL-R-SMT-1UFL-R-SMT-1RF
    U27CON20_0_HDRMS2MM-2X10_CON_CAMERCON_CAMERA2MHDRMS2MM-2X10
    U28TXS0102DCU_1_TSSOP8_TXS0102DCUTXS0102DCUTSSOP8
    U29TXS0102DCU_1_TSSOP8_TXS0102DCUTXS0102DCUTSSOP8
    U36MPU30X0_1_QFN24-050-4X4LH_MPU30MPU30X0QFN24-050-4X4LH
    U37SM-05_SM-01_GPSGPSSM-01
    U38CON20_1_HDRMS2MM-2X10_CON_GPIOCON_GPIOHDRMS2MM-2X10
    X1CRYSTAL_CC5V-T1A_32.768KHZ_SMD_8MCC5V-T1A
    Y1Y_24.576MHZ-5032_X4-2_5X3_2_25M25MHZX4-2_5X3_2
    重要提示:PCB作品文件展下载说明
    暑假期间,免费代管18-28岁小孩,限女性。
    长期免费代管18-28岁小
     楼主| 发表于 2019-5-26 15:58:24 | 显示全部楼层
    DEVELOP_V3.4.7z (1 MB, 下载次数: 3)
  • 签到天数: 104 天
    1元学习Allegro(1期)
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模优秀斑竹奖最爱沙发社区明星宣传大使奖
    发表于 2019-5-26 16:03:53 | 显示全部楼层
    什么CPU的,知道的话最好说明一下
    PADS-191021高级班
    发表于 2019-5-26 16:48:54 | 显示全部楼层
    发表于 2019-5-26 17:12:47 | 显示全部楼层
    PADS-190603高级班
    发表于 2019-5-26 17:45:36 | 显示全部楼层
    发表于 2019-5-26 18:47:33 | 显示全部楼层
    发表于 2019-5-26 20:43:35 | 显示全部楼层
    厉害,好想学习下,但可惜没资料。
    发表于 2019-5-26 22:54:36 | 显示全部楼层
    发表于 2019-5-26 23:04:27 | 显示全部楼层
