查看: 3244|回复: 20
[Pads_VX.2x] PI3VDP411LSZBE+ ALC892-CG + ICS9DB403DFLFT +HIN213ECAZ 做的开发板底板P
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2019-9-10 17:44:41 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    MB_PCB.7z (583 KB, 下载次数: 4)
    NamePCB DecalPart Type
    B1L06031212_BEAD_0_L0603_DISCRETE_120_
    B14ACM20121212_FILTER_0_ACM2012_DISCRETE_
    D1DIODE_2P_175_213X155130_SCHOTTKY_SMB-1_0_DIODE_2P_1
    D2SLP2010P8130_TVS_SLP2510P8_0_SLP2010P8_D
    D3SLP2010P8130_TVS_SLP2510P8_0_SLP2010P8_D
    D4SLP2010P8130_TVS_SLP2510P8_0_SLP2010P8_D
    D5SLP2010P8130_TVS_SLP2510P8_0_SLP2010P8_D
    D6SLP2010P8130_TVS_SLP2510P8_0_SLP2010P8_D
    D7SOD-523_ANODE2130_SCHOTTKY_ANODE2_0_SOD-523_A
    D8SOT-23130_SCHOTTKY_SOT-23A_CC_2_SOT-2
    D9SOD-523_ANODE2130_SCHOTTKY_ANODE2_0_SOD-523_A
    FM1FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIAL
    FM2FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIAL
    FM3FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIAL
    FM4FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIAL
    H1H32P64-MTH00_H32P64-MTH_0_H32P64-MTH_H32P
    H2H32P64-MTH00_H32P64-MTH_0_H32P64-MTH_H32P
    H3H32P64-MTH00_H32P64-MTH_0_H32P64-MTH_H32P
    H4H32P64-MTH00_H32P64-MTH_0_H32P64-MTH_H32P
    JACK1HD_5X2P_79_23N685B-10M101653_BH_5X2P_23N685B_0_HD_5X2P_
    JBAT1WF_8P_79_RA_50421-008011655_WF_8P_BOX_SRA_SPH-002T_0_W
    JCOM1DBCOM-VM5MS1654_DBCOM-VM5MS_1_DBCOM-VM5MS_
    JFAN1WHP3VA1655_WHP3VA_0_WHP3VA_IO_W_3V_2.
    JFP1HD_10X2P_100_D1653_JH10X2V_0_HD_10X2P_100_D_I
    JGPIO1HD_5X2P_1001653_JH5X2S_0_HD_5X2P_100_IO_PH
    JHDMI1HDMICONN_19P_QJ11191-WFB3-41654_HDMI_19P_QJ11191_0_HDMICON
    JI2C1WF_4P_79_BOX_R1_D1655_WHL4V-2M_0_WF_4P_79_BOX_R1
    JLAN1RJ45_14P_RB1-JA6B9W1A1652_RJ45_14P_RB1-JA6B9W1A_0_RJ
    JLPC1HD_7X2P_79_F1653_JH7X2S-22P8242_0_HD_7X2P_7
    JLVDS1SPH20X21653_SPH20X2_2_SPH20X2_IO_BB_20
    JLVDS2WHL5V-2M-24W11401655_WHL5V-2M-24W1140_0_WHL5V-2
    JMINI1AMINIPCIE_HALF_PICO_ITX00_MINIPCIE_HALF_PICO_ITX_0_MIN
    JMINI1BFOX_AS0B226-S68K7F1654_AS0B226-S68K7F_0_FOX_AS0B2
    JMINI2AMINIPCIE_HALF_PICO_ITX00_MINIPCIE_HALF_PICO_ITX_0_MIN
    JMINI2BFOX_AS0B226-S68K7F1654_AS0B226-S68K7F_0_FOX_AS0B2
    JPB1WF_2P_79_BOX_R1_D1655_WHL2V-2M_0_WF_2P_79_BOX_R1
    JPS1WF_2X2P_165_BOX_D1655_ATX_2X2P_D_0_WF_2X2P_165_B
    JPS2PJ_2P_2DC-G213B2001652_DCJACK_2P_2DC-G213B200_0_P
    JRTC1HD_3X1P_79_D1653_JH3X1V-2M_0_HD_3X1P_79_D_I
    JRTC2WHL2V-1251655_WHL2V-125_0_WHL2V-125_IO_W
    JSATA1SATA_7P_WATM-07DBN4A3B8UW_D1654_SATA_7P_2HOLD_0_SATA_7P_WA
    JSATA2WF_4P_98_BOX_R1_D1655_WF_4P_98_BOX_D_0_WF_4P_98_
    JSDIO1SDCARD8P_DM3CS-SF1654_SDCARD_8P_DM3CS-SF_0_SDCAR
    JSIM1SIM_6P_5210622-SINR031654_SIMCARD_6P_5210622_0_SIM_6
    JSMB1WF_4P_79_BOX_R1_D1655_WHL4V-2M_0_WF_4P_79_BOX_R1
    JSPI1SOCKET_8P_ACA-SPI-004-K011651_SOCKET_8P_0_SOCKET_8P_ACA-
    JUMP1HD_3X1P_100_D1653_JH3X1V_0_HD_3X1P_100_D_IO_
    JUMP2HD_2X2P_100_D1653_JH2X2V_0_HD_2X2P_100_D_IO_
    JUSB1MINIUSB_5P_UH51543-AS7-7F1654_MINIUSB_5P_6HOLD_MA_0_MINI
    JUSB2USB_8P_UB1112C-8FDE-4F1654_USB_8P_4HOLD_A_0_USB_8P_UB
    JUSB3USB_9X2P_UEA1112C-8HS6-4F1654_USB3-A_9X2P_UEA1112C-8HS_0
    LED1LED_0603130_LED_LED-0603_G_0_LED_0603_K
    LED3LED_0603130_LED_LED-0603_G_0_LED_0603_K
    LED4LED_0603130_LED_LED-0603_G_0_LED_0603_K
    LED5LED_0603130_LED_LED-0603_G_0_LED_0603_K
    LED7LED_0603130_LED_LED-0603_G_0_LED_0603_K
    LED8LED_0603130_LED_2P_O_0_LED_0603_KPT-160
    PC1C1210_H10211_C_0_C1210_H102_DISCRETE_10UF
    PD1DIODE_2P_175_213X155130_SCHOTTKY_SMB-1_0_DIODE_2P_2
    PD2DIODE_2P_175_213X155130_SCHOTTKY_SMB-1_0_DIODE_2P_2
    PD3DIODE_2P_146_106X61130_ZENER_SOD-123_0_DIODE_2P_14
    PD4SOD-523_ANODE2130_SCHOTTKY_ANODE2_0_SOD-523_A
    PD5DIODE_2P_146_106X61130_ZENER_SOD-123_0_DIODE_2P__1
    PD6DIODE_2P_175_213X155130_TVS_SMB-1_0_DIODE_2P_175_21
    PFS1FUSE_2P_121_125X621752_FUSE_2P_0_FUSE_2P_121_125X
    PJUMP1HD_2X2P_100_D1653_JH2X2V_0_HD_2X2P_100_D_IO_
    PL1INDUCTOR_2P_408_453X4061211_CHOKE_0_INDUCTOR_2P_408_45
    PL2INDUCTOR_2P_245_287X26809_L_0_INDUCTOR_2P_245_287X268_
    PL3CHOKE_2P_238_287X2601211_CHOKE_0_CHOKE_2P_238_287X2
    PQ1SON_8P_26_130X130_TP106X71131_NEXFET_CSD87330Q3D_0_SON_8P
    PQ2SON_8P_26_130X130_TP106X71131_NEXFET_CSD87330Q3D_0_SON_8P
    PQ3QFN_8P_26_118X118_TP131_P_MOS_SO8-PWRPAK_0_QFN_8P_2
    PQ4QFN_8P_26_118X118_TP131_P_MOS_SO8-PWRPAK_0_QFN_8P_2
    PQ5QFN_8P_26_118X118_TP131_P_MOS_SO8-PWRPAK_0_QFN_8P_2
    PQ6QFN_8P_26_118X118_TP131_N_MOS_SO8-PWRPAK_0_QFN_8P_2
    PQ7SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_6
    PQ8QFN_8P_26_118X118_TP131_P_MOS_SO8-PWRPAK_0_QFN_8P_2
    PQ9SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_6
    PQ10SOT-23131_SOT-23A_GSDP_0_SOT-23_AO340
    PQ11SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_6
    PQ12SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_6
    PR1R040210_R_0_R0402_DISCRETE_1K
    PR2R2512_POLE3510_R_0_R2512_POLE35_DISCRETE_2M
    PS1FUSE0805129_PS_2P_0_FUSE0805_SMD0805P10
    PS2FUSE1812129_PS_2P_0_FUSE1812_SMD1812P30
    PS3FUSE1812129_PS_2P_0_FUSE1812_SMD1812P30
    PU1QFN_8P_20_79X79_NCP45520IMN141_ON_NCP45520IMNTWG-H_1_QFN_8
    PU2QFN_8P_20_79X79_NCP45520IMN141_ON_NCP45520IMNTWG-H_1_QFN_8
    PU3QFN_24P_20_157X157_TP96141_TI_TPS51125RGET_1_QFN_24P_2
    PU4QFN_16P_20_118X118141_ENPIRION_EP53F8QI-T_0_QFN_1
    PU6SOIC_24P_26_323X307141_LT_LTC4100EG-TRPBF_0_SOIC_2
    PU7SOT-23_5P141_TI_TS321IDBVR_0_SOT-23_5P_N
    Q2SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_6
    Q3SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_6
    Q4SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_1
    Q5SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_1
    Q6SOT-23131_SOT-23A_BEC_0_SOT-23_MMBT39
    Q13SOT-89_2SA1213-Y131_2SA1213-Y_SOT-89_0_SOT-89_2
    Q14SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_6
    Q15SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_6
    Q16SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_6
    Q17SC70_6P131_N_MOS_SOT-363_DUAL_0_SC70_6
    Q18SOT-23_H48131_N_MOS_SOT-23_1_SOT-23_H48_S
    Q19SOT-23_H48131_N_MOS_SOT-23_1_SOT-23_H48_S
    SHIELD10SHIELD_5P_368X40196_SHIELD-CAN-CLIP_PTV0703B_2_
    SOM-AB1BB_110X2P_2433X244_2HOLD_F1654_BB_110X2P_QT002206_0_BB_11
    SOM1NANO_ETXE-BP00_SOM-NANOETX-T10R20_2_NANO_ET
    SPK1BUZZER2D175_BUZZER_2P_0_BUZZER2D_PAC-WT
    STDOFF1H336P6-MTH_MT191_COPPER_2_H336P6-MTH_MT_POST
    STDOFF2H336P6-MTH_MT191_COPPER_2_H336P6-MTH_MT_POST
    STDOFF3H336P6-MTH_MT191_COPPER_2_H336P6-MTH_MT_POST
    STDOFF4H336P6-MTH_MT191_COPPER_2_H336P6-MTH_MT_POST
    STDOFF5H285P5-MTH_MT_H177191_COPPER_2_H285P5-MTH_MT_H1_1
    STDOFF6H285P5-MTH_MT_H177191_COPPER_2_H285P5-MTH_MT_H1_1
    STDOFF7H285P5-MTH_MT_H177191_COPPER_2_H285P5-MTH_MT_H1_1
    STDOFF8H285P5-MTH_MT_H177191_COPPER_2_H285P5-MTH_MT_H1_1
    STDOFF9H285P5-MTH_MT_H177191_COPPER_2_H285P5-MTH_MT_H177
    STDOFF10H285P5-MTH_MT_H177191_COPPER_2_H285P5-MTH_MT_H177
    STDOFF11H285P5-MTH_MT_H177191_COPPER_2_H285P5-MTH_MT_H177
    STDOFF12H285P5-MTH_MT_H177191_COPPER_2_H285P5-MTH_MT_H177
    SW2SW_4P_236X236_H197160_STS-B5_0_SW_4P_236X236_H197
    SW3SW_4P_236X236_H197160_STS-B5_0_SW_4P_236X236_H197
    SW4SW_4P_236X236_H197160_STS-B5_0_SW_4P_236X236_H197
    SW5SW_2P_100_98X378160_SW_2P_ESD101EZ_0_SW_2P_100_
    SW6SW_2X2P_100_198X378160_SW_4P_ESD102EZ_0_SW_2X2P_10
    TP6TP-S20X2-SHORT00_TP-S20X2-SHORT_0_TP-S20X2-SH
    TP7TP-S20X2-SHORT00_TP-S20X2-SHORT_0_TP-S20X2-SH
    TP8TP-S20X2-SHORT00_TP-S20X2-SHORT_0_TP-S20X2-SH
    TP9TP28_NSM00_TP28_0_TP28_NSM_TP28_NSM
    TP10TP28_NSM00_TP28_0_TP28_NSM_TP28_NSM
    TP12TP28_NSM00_TP28_0_TP28_NSM_TP28_NSM
    U1QFN_48P_20_276X276_TP219141_PERICOM_PI3VDP411LSZBE_0_QF
    U3SOIC_28P_26_402X307141_IDT_ICS9DB403DFLFT_0_SOIC_2
    U4QFN_20P_20_177X98_TP118X39141_NXP_CBTL02042ABQ_0_QFN_20P_
    U7SOIC_28P_26_402X30714S_HIN213ECAZ_SSOP28-209MIL_1_
    U8SOIC_8P_50_193X236141_TI_SN65HVD251D_SOIC8_2_SOIC
    U9QFP_48P_20_354X354141_REALTEK_ALC892-CG_0_QFP_48P
    U11SOT-23_5P141_TI_TS321IDBVR_0_SOT-23_5P_T
    重要提示:PCB作品文件展下载说明
    昨天 21:18
  • 签到天数: 47 天
    终身成就奖社区居民优秀斑竹奖
    发表于 2019-9-10 18:51:39 | 显示全部楼层
    谢谢分享CH340G的ISP一键下载原理图及PCB图
    发表于 2019-9-10 19:20:02 | 显示全部楼层
    路过。。。。。。。。
    发表于 2019-9-10 20:33:30 | 显示全部楼层
    5 天前
  • 签到天数: 285 天
    发表于 2019-9-10 22:19:12 | 显示全部楼层
    发表于 2019-9-11 08:07:03 | 显示全部楼层
    发表于 2019-9-11 08:31:47 | 显示全部楼层
    昨天 09:13
  • 签到天数: 277 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2019-9-11 09:51:09 | 显示全部楼层
    PADS-181015高级班
    社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖金点子奖
    发表于 2019-9-11 12:48:34 | 显示全部楼层
    最后成功的人往往不是最有才华的人,而是那些默默付出直到最后一刻也不放弃的那些人!
  • 签到天数: 50 天
    PADS-180606高级班
    终身成就奖社区居民忠实会员社区劳模最爱沙发优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2019-9-11 16:26:03 | 显示全部楼层
