重要提示:PCB作品文件展下载说明
| Comment | Pattern | Quantity | Components | | | | | | 4PIN_2.54MM | 2 | J16, J17 | | 8PIN_2.54MM | 1 | J15 | | 0* | 0603R | 1 | R55 | | 0.2F/NC | SBAT-MS-FL11 | 1 | C55 | | 106 | 0603C | 2 | C156, C248 | | 10K*4 | RN8-0805 | 1 | RZ1 | | 10uH | SCD75 | 1 | L11 | | 120@100MHz/NC | 0805L | 3 | BL5, BL7, BL8 | | 120@100MHz | 0805L | 5 | BL1, BL2, BL3, BL4, BL6 | | 120uH | L8*10 | 1 | T12 | | 12M | S3225A | 1 | X7 | | 12R | 0805R | 1 | R193 | | 12V_IN | TEST_PAD | 1 | 12V_IN | | 12V | TEST_PAD | 1 | 12V | | 14.318M | S3225A | 1 | Y1 | | 1N5819/NC | DMMELF | 2 | D14, D16 | | 1nF | 0603C | 4 | C1, C42, C44, C46 | | 1uF,5% | 0603C | 2 | C285, C295 | | 1V2 | TEST_PAD | 1 | 1V2 | | 1V8 | TEST_PAD | 1 | 1V8 | | 22uH | SCD75 | 1 | L13 | | 24LC1024 | SOIC-8P | 1 | U14 | | 25M | S3225A | 1 | X6 | | 27kΩ | 0603R | 1 | R248 | | 27M | S3225A | 1 | X2 | | 2A | 1812R | 1 | F3 | | 30K%1 | 0603R | 1 | R158 | | 30pF/NC | 0603C | 2 | C49, C51 | | 30R/400mA | 0603L | 7 | L1, L2, L3, L4, L5, L6, L7 | | 32.768KHz/NC | DX2-100C | 1 | X4 | | 32.768KHzNC | SX2-0402 | 1 | X1 | | 37.5R | 0603R | 2 | R71, R72 | | 3V3_SB | TEST_PAD | 1 | 3V3_SB | | 3V3 | TEST_PAD | 1 | 3V3 | | 4148 | 4148 | 1 | D34 | | 470uH | SMT-4*4L | 1 | L9 | | 48M | S3225A | 1 | X5 | | 48MHz | X4-0705 | 1 | X3 | | 5V_MONI | TEST_PAD | 1 | 5V_MONI | | 5V | TEST_PAD | 1 | 5V | | 6.8K | 0603R | 1 | R181 | | 74HC4066 | SOP14-50-250 | 2 | U35, U38 | | 78L05 | SOT-89_4P | 1 | U22 | | 8.2PF/NC | 0603C | 1 | C117 | | 8050 | SOT23 | 2 | Q4, Q6 | | 8550 | SOT23 | 3 | Q1, Q2, Q7 | | 91K%1 | 0603R | 1 | R157 | | ADS7846 | SOP16-25-250 | 1 | U11 | | ADUC0402 | 402 | 9 | | | ASM811SEUS-T | SOT143 | 2 | U9, U12 | | AT88SC0104A/NC | SOP8-50-150 | 1 | U6 | | AU6438-JBS | IC_SSOP_28P_150mil | 1 | U24 | | AVDD | TEST_PAD | 1 | AVDD_LCD1 | | B240 | DO_214AC | 2 | D2, D22 | | B240A | DO_214AC | 4 | D15, D17, D19, D21 | | BAT720/NC | SOT23A | 1 | D1 | | BAV99 | SOT23 | 4 | D3, U29, U30, U31 | | C8M09 | ESD_C8M | 1 | U19 | | CLASS_OUT | SIP2-59-R | 2 | J9, J10 | | COMM_BERD | SCMC4-32-68 | 1 | U25 | | CON10 | 10PIN_2.54MM | 1 | J12 | | CON2_254MM | 2PIN_2.54MM | 1 | J20 | | CON3 | 3PIN_2.54MM | 1 | J13 | | CON3 | SIP3-59-R | 1 | J2 | | CON3 | SIP8-1.27 | 1 | J11 | | CON4 | SSED4-39D37-DOWN | 1 | J5 | | CON5 | 5PIN_2.54MM | 1 | J14 | | CON50 | SSED50 | 1 | J23 | | CON6 | SIP6-59-R | 1 | J3 | | CON7 | SIP7-59-R | 2 | J4, J7 | | CX20707 | QFN-76-0.4MM | 1 | U13 | | DF1117-1.8 | SOT223 | 1 | M1 | | GND_IN | TEST_PAD | 1 | GND_IN1 | | GSM1117S-3.3T | SOT223 | 1 | M2 | | H | HOLE40-8STAR | 4 | H1, H2, H3, H4 | | HI3510 | BGA400-32-2222 | 1 | U1 | | HY57V281620ET-H | SOP54-32-400 | 2 | U2, U3 | | JACK_POWE | DC-013 | 1 | J19 | | JTAG | SIP8 | 1 | J1 | | LED+ | TEST_PAD | 1 | LED+1 | | MAX3232E | SOP16-50-250 | 1 | U15 | | MAX3485E | SOP8-50-250 | 1 | U16 | | MAX4090 | TSOT23-6 | 1 | U34 | | MC4558 | SOP8-50-250 | 3 | U36, U37, U39 | | MIC | SIP2-59-R | 1 | J8 | | mp1530 | TSSOP-16P | 1 | U28 | | mp2467 | SO8-6_2-1_27EPAD | 2 | U21, U23 | | MP3202 | TSOT23-6 | 1 | U32 | | MP3215 | TSOT23-5 | 2 | U8, U40 | | nc | 0603C | 4 | C265, C268, C269, C282 | | NC | 0603R | 4 | R254, R263, R271, R278 | | NJM2235 | SOP8-50-250 | 1 | U33 | | PCF8563/NC | SOP8-26-150 | 1 | U5 | | ps7241-1b | SOIC-4P | 8 | T4, T5, T6, T7, T8, T9, T10, T11 | | RESET/NC | SW2-300 | 1 | SW1 | | RESET | ST042A | 1 | SW2 | | RJ8 | HY951180A | 1 | J18 | | RT8008 | TSOT23-5 | 1 | M3 | | RTL8201CP | LQFP48 | 1 | U20 | | S29GL064A10TAIR10 | SOP56-20-720 | 1 | U4 | | S340A | SMC | 3 | D13, D35, D36 | | SD | MC12-21000-G3R | 1 | J21 | | SD05/NC | SOT-323 | 3 | D23, D24, D25 | | SD05 | SOT-323 | 6 | D26, D28, D30, D31, D37, D38 | | SD12/NC | SOT-323 | 1 | D33 | | SD12 | SOT-323 | 3 | D27, D29, D32 | | SI2301/ZXMP6A13FTA | SOT23 | 2 | Q3, Q5 | | SMJ5.0A | DO_214AC | 8 | D5, D6, D7, D8, D9, D10, D11, D12 | | SN74LVC04A | SOP14-50-250 | 1 | U27 | | SRV05-4 | SOT23-6 | 3 | U17, U18, U26 | | STM8S103F2 | TSSOP-20 | 1 | U10 | | SWIM | SIP4 | 1 | J6 | | TL431 | TO-92A | 1 | D20 | | TRANS4 | TRANS4 | 1 | T13 | | TVP5150AM1PBSR PQFP32 | QFP32-19D69-240 | 1 | U7 | | USB/NC | USB-MINI-5P | 1 | J22 | | VCOM | TEST_PAD | 1 | VCOM1 | | VGH | TEST_PAD | 1 | VGH1 | | VGL | TEST_PAD | 1 | VGL1 | | YELLOW LED | 0805-LED | 1 | D4 | | ZXMP6A13FTA | SOT23 | 1 | D18 |
重要提示:PCB作品文件展下载说明
