重要提示:PCB作品文件展下载说明
| Name | PCB Decal | Value | Part Type | | ANT1 | ANT/DIP/101266-1BAAA | TP | ANTENNA_11 | | D301 | SOD323 | D / UDZS 5.1B | SOD-323 | | D305 | SOD123 | Rohm RB160M-60 | SOD123 | | J101 | MM8430-2600B | MM8430-2610 | MM8430-2600B | | J102 | 818000157 | MHC-310 | 818000157 | | J301 | B32-AB03F15X | BC-4565-M-03-01-LF | B32-AB03F15X | | J402 | A20S01006A68AA | | JA0607360140-14 | | J601 | 6PINAA | | PAD_6PIN | | J602 | T1-CAMERA-24 | DF30FC-24DS-0.4V | T1-CAMERA-24 | | J603 | AXT524130 | DF30FC-24DS-0.4V | CAM_BACK_S9_30PIN | | J604 | SIDE2PIN | | SIDE2PIN | | J605 | PIN3KEYFPCA | | PIN3KEYFPC | | J701 | 25PINAA | | 25PINAA | | J702 | FPC8PIN0.5 | | FPC0.5 | | J703 | SIMMS-00615-TP32 | | SIMMS-00615-TP32_A13 | | J704 | 24PIN5804 | | 24PIN5804 | | J706 | SIMMS-00615-TP32 | | SIMMS-00615-TP32_A13 | | J707 | SD-TFH010-003A | SD-47352-101 | CAH11-08193-1500 | | L252 | L/IND/SMD/LVS252010-2R2 | CMLW252012SR68NST | INDUCTOR_2A | | L255 | L0402 | 10R | L0402 | | L301 | L/IND/SMD/LVS252010-2R2 | CMLW252012SR68NST | INDUCTOR_2A | | L425 | L0402 | 100nH | L0402 | | L450 | L0402 | 0R | L0402 | | L451 | L0402 | 0R | L0402 | | L452 | L0402 | SBJ100505T-182Y-N | L0402 | | LED603 | LQM2HPN2R2MG0 | FLASH MODULE | LED_2 | | LED604 | LQM2HPN2R2MG0 | FLASH MODULE | LED_2 | | Q301 | 2-1L1B/SMD/SSM3K35MFV | PNM23T703E0-2 | MOSFET_N_2 | | Q302 | SOT-6 | PT236T30E2 | FDG6303_2 | | Q601 | VMT3 | DTC114TMT2L | TRANSISTOR-NPN-DTC114TMT2L | | REC+ | TP_6.0X2.5 | | TP_6.0X2.5 | | REC- | TP_6.0X2.5 | | TP_6.0X2.5 | | T301 | DTESDBLC5V0LED02 | ESD / TVS / 50pF / 0402 | DTESDBLC5V0LED02 | | TP45 | ANT/DIP/101266-1C | TP | ANTENNA_11 | | U101 | MT6572/TFBGA428/P0.4/B0.25/10.6X10.6 | MT6572T | MT6572/TFBGA428/P0.4/B0.25/10.6X10.6 | | U102 | BALUN_SAW/10P/G20 | RFBLN2012090BM5T25 | BALUN_SAW/10P/G20 | | U105 | MT6166/TMP/SMD | | MT6166/TMP/SMD | | U301 | MT6323/VFBGA145/P0.4/B0.25/5.8X5.8 | MT6323 | MT6323/VFBGA145/P0.4/B0.25/5.8X5.8 | | U402 | FBGA162/P0.5/B0.27/11.5X13/SAMSUNGAAAA | | FBGA162/P0.5/B0.27/11.5X13/SAMSUNG | | U404 | WCSP9 | AW8145 | AW8145 | | U501 | MT6627-NS/MQFN40/SMD/P0.4/5X5 | | MT6611_SMD_WLCSP-61_1 | | U503 | TCXO/SMD/2.5X2.0/IT2205BE | RAKON/IT2205BE/26MHz | TCXO_RAKON_SMD_4P | | U505 | BGA725L6 | XN223 | NJG1107HB3_0 | | U602 | MMA8452Q | AFA750 | MMA8452Q | | U685 | QFN30/SMD/MPU-3000 | MT6572 DRL Gyro | 74ALVC74PW_1 | | U701 | BCT3661 | | BCT3661 | | U702 | L/CHOKE/SMD/DLP0NS0806B | DLP0NSC280HL2 | EMIX21A390FNPE_1 | | U703 | OCH177 | OCH177AVAD | OCH177 | | U704 | L/CHOKE/SMD/DLP0NS0806B | DLP0NSC280HL2 | EMIX21A390FNPE_1 | | U705 | L/CHOKE/SMD/DLP0NS0806B | DLP0NSC280HL2 | EMIX21A390FNPE_1 | | U801 | SKY77590 | | PA_/_SKY77590_0 | | U803 | SAW/8P/SMD/SAYFP1G95AA0B00 | SAYFH836MCA0F00 | SAYRF1G95HQ0F0A | | U804 | SKY77186 | | SKY77701_2 | | U806 | SAW/8P/SMD/SAYFP1G95AA0B00 | SAYFH836MCA0F00 | SAYRF1G95HQ0F0A | | U808 | SKY77186 | | SKY77701_2 | | X301 | SSP-T7 | SSP-T7-F | SSP-T7 | | X600 | TCXO3225 | | TCXO3225 | | Z501 | SAW/SMD/1.05X1.35 | SAFEB1G57KE0F00 | SAFEB1G57KE0F00 |
重要提示:PCB作品文件展下载说明
