| Name | PCB Decal | Part Type | Value |
| 3G_C1 | C0603 | C_/_2200_/_NF_/_0603_/_X5R | C / 2200 / nF / 0603 / X5R |
| 3G_CON701 | MM8430-2610B | TST_PORT_1 | MM8430-2610B_RA1_RB3 |
| 3G_CP1 | C0603 | C0805 | 22uF/10V/X5R |
| 3G_CP6 | C0603 | C0805 | 22uF/10V/X5R |
| 3G_D900 | LED190 | LED_1 | LED_1 |
| 3G_D901 | LED190 | LED_1 | LED_1 |
| 3G_E702 | ANT/DIP/101266-1 | ANTENNA_15 | ANTENNA1PIN |
| 3G_E703 | ANT/DIP/101266-1 | ANTENNA_15 | ANTENNA1PIN |
| 3G_L207 | L/IND/SMD/CKP20164R7M | INDUCTOR | CKP25202R2M-T |
| 3G_L208 | L/IND/SMD/CKP20164R7M | INDUCTOR | CKP25202R2M-T |
| 3G_L217 | L0402 | EMIFILTER | 0R |
| 3G_L613 | L0402 | L_/_NC_/_0402 | L / NC / 0402 |
| 3G_Q202 | 2-1L1B/SMD/SSM3K35MFV | MOSFET_N_2 | SSM3K35MFV |
| 3G_U3 | MLPQ16/SMD/P0.5/SC187_____________________ | G5627_5 | Semtech_SC187 |
| 3G_U101 | MT6280NS/TFBGA288/P0.4/B0.25/8.8X8.8 | MT6280_69 | MT6280NS |
| 3G_U201 | MT6327/MQFN20/SMD/P0.4/3X3 | MT6280_64 | MT6327 |
| 3G_U401 | TFBGA130/P0.65/B0.3/8X9/TOSHIBA | K5D1257DCA-D090_0 | MT29C1G12MAADVAMD_5IT |
| 3G_U609 | QCS5F | SAW_1 | SAFEA1G84FA0F00R14 |
| 3G_U611 | SAW/8P/SMD/D2.0X1.6/SAY/MURATA | SAW-DPX-RX-BAL | SAYRF1G95HQ0F0A |
| 3G_U612 | SAW/8P/SMD/D2.0X1.6/SAY/MURATA | SAW-DPX-RX-BAL | SAYFH836MCA0F00 |
| 3G_U613 | SAW/8P/SMD/D2.0X1.6/SAY/MURATA | SAW-DPX-RX-BAL | B8078 |
| 3G_U614 | SAW/8P/SMD/D2.0X1.6/SAY/MURATA | SAW-DPX-RX-BAL | SAYFH897MHA0F00 |
| 3G_U705 | XM0860SH-DL0601 | XM0860SH-DL0601 | XM0860SH-DL0672 |
| 3G_U706 | SKY77186 | SKY77701_0 | RF7245 |
| 3G_U707 | SKY77186 | SKY77701_0_2 | RF7241 |
| 3G_U708 | SKY77186 | SKY77701_2 | RF7248 |
| 3G_U709 | SKY77186 | SKY77701_1 | RF7242 |
| 3G_U901 | RF3235 | RF3232DS_1 | RF3236 |
| 3G_X603 | CRYS/SMD/D3.2X2.5/7M26000010 | TCVCXO_0 | TXC 7M26000028 X'tal 26MHz |
| ANT1002 | GPS/ANT/CON1 | ANTENNA_0 | 101266-1 |
| BEAD414 | BEAD/SMD/0603 | BEAD | BLM18BD252SN1 |
| CON401 | PHONEJACK/SMD/PJ-S3142/MD0840 | CXJC-PJ2_0 | PJ-S3142 |
| CON402 | USB_NOKIA | MINI_10PIN_0 | Wisky USB connector |
| CON804 | FPC_24P-0.5M | OV7645FB_6 | Wisky camera connector |
| CON805 | FPC_24P-0.5M | OV7645FB_6 | Wisky camera connector |
| CON806 | FPC_6P-0.5M | OV7645FB_10 | Wisky sidekey connecotr |
| CON807 | H3/SMD/P1.27 | OV7645FB_9 | H3/SMD/P1.27 |
| CON1001 | MM8430-2600B | CAR_KIT_/_MM8430-2610B | MM8430-2610B |
| CON1404 | TF_CARD | MMC_CONN_6 | SD-47352-101 |
| CON1503 | SIM-CARD | SIM_SOCKET_0_2 | Wisky SIM-card |
| CON1711 | H40S/P0.5 | IPEX-20455-040E_1 | 40P-0.5PITCH, BOTTOM |
| CON1712 | CON20X2/SMD/M/AXT440124 | HEADER_1 | AXT440124 |
| CON1713 | 7-ITO-CON/S | CON8P_3.5P | Wisky CTP controller |
| CON1714 | H6S/P1.0 | CON8P_0.5P | FH12-6S-1SH |
| D1 | SOT23 | DIODE_DUAL_RS_AJK_3 | BAV-99 |
| D2 | SOT23 | DIODE_DUAL_RS_AJK_2 | BAV-99 |
| D3 | RB551V-30(UMD2) | DIODE_SCHOTTKY_6 | RB551V-30 |
| D4 | RB551V-30(UMD2) | DIODE_SCHOTTKY_6 | RB551V-30 |
| D6 | RCLAMP0524P/10P/SMD | RCLAMP0524P | Rclamp0524P |
| D7 | RCLAMP0524P/10P/SMD | RCLAMP0524P | Rclamp0524P |
| D8 | ESD0603/SMD | DIODE_DIAC | ESD0603/SMD/NC |
| D9 | ESD0603/SMD | DIODE_DIAC | ESD0603/SMD/NC |
| D10 | RB551V-30(UMD2) | DIODE_SCHOTTKY_6 | RB551V-30 |
| D11 | RCLAMP0524P/10P/SMD | RCLAMP0524P | Rclamp0524P/NC |
| D12 | RCLAMP0524P/10P/SMD | RCLAMP0524P | Rclamp0524P/NC |
| D13 | RCLAMP0524P/10P/SMD | RCLAMP0524P | Rclamp0524P/NC |
| D300 | RB551V-30(UMD2) | DIODE_SCHOTTKY_6 | RB551V-30 |
| D303 | DIODE/SMD/MMSZ5221B | DIODE/ZENER | MMSZ5231BT1G |
| D401 | SOD923/SMD | PG05BSESC_0 | ESD9L5.0ST5G |
| D402 | D/SMD/UMD2 | DIODE_SCHOTTKY_0 | UDZV 5.6B |
| EMI823 | FILTER/SMD/ICVE10184E150R101FR | EMIX21A390FNPE_0 | ICVE10184E070R100FR |
| GND1 | TP/SMD/D0.6 | TEST_POINT_DIP0.6 | TEST POINT |
| H5 | HOLE/NPTH/D2.2/WS1962 | SCREW_HOLE_3_0.5MM | HOLE/NPTH/D2.2/WS1962/NC |
| J300 | HDMI/SMD/CON/A | PORT_HDMI_TYPE-A | HDMI_TYPE-A/NC |
| J301 | MICROHDMI/19P/SMD/ATOMO10130010031 | PORT_HDMI_TYPE-A | HDMI_TYPE-D |
| J505 | DIP4/W/H/P2.0 | CONN_4_W/HOUSING_DIP_2.0 | Wafer_2.0_4 |
| L2 | L/IND/SMD/LVS252010-2R2 | INDUCTOR | VLS252010T-4R7M (4.7uH) |
| L4 | L/IND/SMD/LVS252010-2R2 | INDUCTOR | VLS252010T-4R7M (4.7uH) |
| L6 | L/IND/SMD/IHLP-2020AB-01 | INDUCTOR | Vishay IHLP2020ABER2R2M01 (2.2uH) |
| L212 | BEAD/SMD/0603 | INDUCTOR | BLM18PG221SH1 |
| L402 | BEAD/SMD/0603 | BEAD | LQM18NN82NM00 |
| L1001 | L/IND/SMD/LQM2HP-1008 | INDUCTOR | LQM2HPN2R2MG0 (2.2uH) |
| L1003 | L0603 | INDUCTOR_3 | LQW18ANR10G00 |
| L1004 | L0402 | L_/_39_/_NH_/_0402 | 39nH/NC |
| L1007 | L0402 | FERRITE_BEAD_SMD_0402 | 8.2nH/LQG15HS/Murata |
| L1008 | L0402 | INDUCTOR_3 | NC |
| L1009 | L0402 | INDUCTOR_3 | 27nH/LQG15HS/Murata |
| LED10 | LED/SMD/0603 | LED_DIP2.54 | Green/NC |
| LED301 | LED/6P/SMD/SMLP36 | DIODE_8 | ROHM SMLP36RGB1W |
| LED302 | LED/6P/SMD/SMLV36 | LED_0 | SMLV36WBFCW/NC |
| M5 | SCREW_HOLE/PTH/R6.5D3.3 | SCREW_HOLE_3_0.5MM | SCREW_1MM/NC |
| MIC403 | EAO-4015-PFA | AUDIO_JACK_0 | EAO-4015-PFA |
| NFC_ANT1201 | PAD/1P/2.2X3 | ANTENNA | ANT / R2.2 |
| NFC_ANT1202 | PAD/1P/2.2X3 | ANTENNA | ANT / R2.2 |
| NFC_C1201 | C0402 | C_/_2200_/_NF_/_0402_/_X5R | 2.2uF/6.3V/X5R |
| NFC_L1201 | L0603 | FERRITE_BEAD_SMD_0402 | 560nH/MLF1608DR56J |
| NFC_L1202 | L0603 | FERRITE_BEAD_SMD_0402 | 560nH/MLF1608DR56J |
| NFC_R1201 | R0402 | R_/_0_/_OHM_/_0402 | 0 |
| NFC_R1202 | R0402 | R_/_0_/_OHM_/_0402_3 | 0 |
| NFC_R1203 | R0402 | R_/_0_/_OHM_/_0402 | 0 |
| NFC_R1204 | R0402 | R0402 | 6K_1% |
| NFC_R1205 | R0402 | R0402 | NC |
| NFC_R1206 | R0402 | R_/_0_/_OHM_/_0402 | 10K/NC |
| NFC_R1207 | R0402 | R0402 | 0 |
| NFC_U1201 | MT6605/MQFN32/SMD/P0.4/4X4/S | MT3301-140_SMD_PBGA-140_0 | MT6605 QFN (32 Pins, 0.4mm pitch) |
| NFC_X1201 | CRYS/SMD/FA-128 | QUARTZ_IQX0_1 | QUARTZ 27.12 Mhz |
| RD4 | R0402 | R0603_8 | 56_1% |
| SW2 | SWITCH/SMD/STS-A85SNS | SW_PUSHBUTTON_FLAT_TYPE_0 | STS-A85SNS |
| U5 | FBGA96/SMD/P0.8/MICRON | IC_DDR3_X16_FBGA-96 | IC DDR3 x16 FBGA-96 |
| U6 | FBGA96/SMD/P0.8/MICRON | IC_DDR3_X16_FBGA-96 | IC DDR3 x16 FBGA-96 |
| U7 | MT8135/VFBGA398/P0.65/B0.3/15X15 | MT8130_14.9X14.9_0.65P_0904 | MT8135/VFBGA398/P0.65/B0.3/15X15 |
| U11 | QFN16/SMD/P0.5/HA5266 | 10109_0 | HA5266ADD |
| U12 | TSOT-23-6/SMD/P0.95/AT1316/S | APL5151_1 | TPS61165DBVT |
| U22 | TSOP48/SMD | AM29PL160C_3 | NAND08GW3B2CN6E/NC |
| U406 | SOT23-6/SMD | TEA1206T_0 | Onsemi CAT3200TDI-T3 |
| U407 | SW/10P/SMD/FSA3000/FAIRCHILD | SIM_SOCKET_0 | FSA3000 |
| U408 | SW/10P/SMD/FSA3000/FAIRCHILD | SIM_SOCKET_0 | FSA3000 |
| U502 | BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA | 169_BALL_EMMC | Samsung KLM2G1HE3F-B001 |
| U1001 | MODULE/MT6620/56P/SMD | S500_0 | S501 |
| U1002 | PCTCXO/SMD/2.5X2/IT2200MV/RAKON | TCXO_RAKON_SMD_4P_0 | RAKON/TX6217 |
| U1006 | DFN6/SMD/DALLAS/MAX2659 | NJG1107HB3_2 | MAXIM_2659 |
| U1007 | SAW/SMD/DGLT36M07/S | DGLT36M07_0 | TDK DPX252500DT-5217A1 |
| U1602 | WLCSP14/SMD/P0.4/B0.23/AK8963 | ADXL345_2 | AK8963C |
| U1604 | VDFN10/SMD/P0.5/MC3200 | ADXL345_1 | MC3210 |
| U1607 | OPLGA6/SMD/P0.6/CM3623 | CM3623_1 | STK2203 |
| U1609 | QFN30/SMD/MPU-3000 | 74ALVC74PW_1 | MPU-3050 |
| U1613 | NLSX3378/12P/P0.5/B0.27/2.02X1.54/ON | NLSX3378 | NLSX4378 |
| U1901 | DSBGA4/SMD/P0.4/B0.25/TMP103 | TMP103AYFFT | TMP103AYFFT |
| U1904 | VQFN24/SMD/P0.5/BQ24196 | BQ24196_0 | bq24196 |
| U1907 | MT6397/TFBGA211/P0.65/B0.3/11.7X11 | MT6397_17X18_FINAL | MT6397/TFBGA211/P0.65/B0.3/11.7X11 |
| VBAT_SUPPLY1 | TP/SMD/D0.6 | TEST_POINT_DIP0.6 | TEST POINT |
| VR1527 | R0402 | VR0402 | EZJZ0V500AA |
| X302 | CRYS/SMD/MS3V-T1R | CRYSTAL_1 | 32K (MS3V-T1R) |
| X601 | CRYS/SMD/D2.5X2.0/RXT2520AT/RAKON | TCVCXO_2 | XTAL / RAKON / RXT2520AT / SMD/11.5pF |
| X602 | PCTCXO/SMD/2.5X2/IT2200MV/RAKON | TCXO_RAKON_SMD_4P_0 | RAKON/TX6217 |
