| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BH5 | MOUNT_HOLE_PMC_MECH_HOLE_IC_0MM | MTG1 | PMC_MECH_HOLE |
| BH6 | MOUNT_HOLE_PMC_MECH_HOLE_IC_0MM | MTG1 | PMC_MECH_HOLE |
| BH7 | MOUNT_HOLE_PMC_MECH_HOLE_IC_0MM | MTG1 | PMC_MECH_HOLE |
| BH8 | MOUNT_HOLE_PMC_MECH_HOLE_IC_0MM | MTG1 | PMC_MECH_HOLE |
| BH9 | MOUNT_HOLE_MH_C256-165T_IC_0.12 | M.2MOUNTING HOLE | MH_C256-165T |
| BH10 | MOUNT_HOLE_MH_C256-165T_IC_0.12 | M.2MOUNTING HOLE | MH_C256-165T |
| BT3 | BATTERY_SKT_3V_SKT_BAT_225X886_ | CR2032+HOLDER | SKT_BAT_225X886_3V |
| D2 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | LED_0603 |
| D4 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
| D6 | ZDIODE_SOD123_IC_1.35MM_480-776 | MMSZ5245B | SOD123 |
| D508 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
| D509 | LED_QUAD_GRN_LED_QUAD_2P54_TH_I | 4_GRN_LED | LED_QUAD_2P54_TH |
| D510 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
| D511 | LED_LED_0603_IC_0.8MM_370-75077 | LED_GREEN | LED_0603 |
| F2 | FUSE_RST_FUSE_3P4X1P8_DISCRETE_ | 8A | FUSE_3P4X1P8 |
| FL2 | EMIFILTER_CC_CC_NFM41P_1806_DIS | 1.5uF | CC_NFM41P_1806 |
| FL30 | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | CC0603_NFM18PC |
| FL31 | EMIFILTER_CC_CC_NFM41P_1806_DIS | 1.5uF | CC_NFM41P_1806 |
| FL32 | EMIFILTER_CC_CC_NFM41P_1806_DIS | 1.5uF | CC_NFM41P_1806 |
| J1 | DC_POWER_JACK_063BH_CON_DCJACK_ | PJ-063AH | CON_DCJACK_063BH_TH_RA |
| J8 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J9 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J11 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J12 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J13 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J14 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J15 | CONN_HDR_5X2_HDR205_10M_50_SM_K | FTSH-105-01-L-DV-K | HDR205_10M_50_SM_K |
| J46 | CON_67_FEMALE_RA_CON_67_0P5_22X | M.2SKT | CON_67_0P5_22X7P75_RA |
| J52 | CON_67_FEMALE_RA_CON_67_0P5_22X | M.2SKT | CON_67_0P5_22X7P75_RA |
| J55 | CON8_SDCARD_DETECT_CON_SDCARD_9 | 95220030-14RRF | CON_SDCARD_95220 |
| J56 | CONN_HDR_8X1_CON_1X8_SKT_2P54_T | CON_1X8 | CON_1X8_SKT_2P54_TH |
| J57 | CONN_HDR_8X1_CON_1X8_SKT_2P54_T | CON_1X8 | CON_1X8_SKT_2P54_TH |
| J58 | ZX62RD-AB-5P8_USB_MICROAB_CON_U | CONSKT MICRO-B | CON_USB_5F_0P65_SM_RA_B |
| J60 | CONN_HDR_6X1_HDR106_TH_TSW_IO_8 | HDR1X6 | HDR106_TH_TSW |
| J63 | CONN_HDR_3X1_HDR103_IO_8.59MM_2 | HDR_1X3 | HDR103 |
| J64 | CONN_HDR_3X1_HDR103_IO_8.59MM_2 | HDR_1X3 | HDR103 |
| J65 | CONN_HDR_3X1_HDR103_IO_8.59MM_2 | HDR_1X3 | HDR103 |
| J66 | CONN_HDR_8X1_JUMP1X8-6040_IO_8. | HDR_1X8 | JUMP1X8-6040 |
| J67 | CONN_HDR_10X2_CON_TSM_20M_2P54_ | HDR2X10 | CON_TSM_20M_2P54_SM |
| J70 | GSB311231HR_USB18P_CON_18P_USB3 | GSB311231HR | CON_18P_USB3_RA_TH |
| J72 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J73 | HDR-1X4_JUMP1X4-6040_IO_8.6MM_2 | HDR1X4 | JUMP1X4-6040 |
| J74 | CONN_HDR_2X1_HDR1X2_50MIL_IO_4. | HDR_1X2 | HDR1X2_50MIL |
| J75 | CONN_HDR_2X1_HDR102_IO_8.59MM_2 | HDR1X2 | HDR102 |
| L2 | CHOKE_4P_IND4_7X13_SM_DISCRETE_ | 400OHM@10MHZ | IND4_7X13_SM |
| L9 | INDUCTOR_IND2_744308033_DISCRET | 0.33uH | IND2_744308033 |
| L11 | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | IND_NFE31P |
| L56 | INDUCTOR_FERRITE_IND_0402_DISCR | 220OHM | IND_0402 |
| L514 | NFE31P_IND_NFE31P_DISCRETE_1.75 | NFE31PT222Z1E9L | IND_NFE31P |
| L515 | INDUCTOR_IND2_4P3SQ_XFL4020_DIS | 2.2uH | IND2_4P3SQ_XFL4020 |
| L516 | INDUCTOR_IND2_XAL60XX_102_DISCR | 0.82uH | IND2_XAL60XX_102 |
| L531 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L532 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L533 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L535 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L536 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| L537 | INDUCTOR_IND2520_DISCRETE_1.2MM | 1uH | IND2520 |
| P1 | RJ45_MAG_2X1_LED_CON_RJ45_2X1_T | RJ4513X2PORTS | CON_RJ45_2X1_TH_RA |
| P2 | RJ45_MAG_2X1_LED_CON_RJ45_2X1_T | RJ4513X2PORTS | CON_RJ45_2X1_TH_RA |
| Q3 | MOSFET_N_SOT23-40X40_IC_1.12MM | IRLML6346TRPbF | SOT23-40X40 |
| Q4 | NMOSFET_3P_ESD_DIODE_SOT323_3_I | RYU002N05 | SOT323_3 |
| R964 | RES_RC0201_DISCRETE_0.26MM_470 | 100 | RC0201 |
| S1 | SW_DIP-10_SW_DIP20_10POS_SM_IC_ | SW_DIP-10/SM | SW_DIP20_10POS_SM |
| SW6 | SW2P_SPST_SW2_4P45_4X3_SM_IC_2. | SWSPST NO | SW2_4P45_4X3_SM |
| TP94 | TEST_POINT_TP_TH_063_IC_5.6MM_2 | 5006 | TP_TH_063 |
| TP95 | TEST_POINT_TP_TH_063_IC_5.6MM_2 | 5006 | TP_TH_063 |
| TP116 | TESTLOOP_TP_PTH_IO_0.1MM_210-7 | TP_PTH | TP_PTH |
| TP117 | TESTLOOP_TP_PTH_IO_0.1MM_210-7 | TP_PTH | TP_PTH |
| TP126 | TESTLOOP_TPAD_020_IO_0.1MM_211- | TPAD_020 | TPAD_020 |
| TP127 | TESTLOOP_TPAD_020_IO_0.1MM_211- | TPAD_020 | TPAD_020 |
| TP142 | TESTLOOP_TPAD_020_IO_0.1MM_211- | TPAD_020 | TPAD_020 |
| TVS1 | DIODE_TVS_BIDIR_DIODE_BIDIR_040 | SESD0402X1BN | DIODE_BIDIR_0402 |
| U1 | LT8609S_16P_EP_QFN16_0P5_3X3_EP | LT8609SEV | QFN16_0P5_3X3_EP_4MP |
| U14 | LS1043_1046_SS_BGA780_0P8_23X23 | LS1046ASE8T1A/LS1043XXXXX | BGA780_0P8_23X23MM |
| U15 | MT40A512M16JY_BGA96_BGA96_0P8_8 | MT40A512M16 | BGA96_0P8_8P1X14P1 |
| U16 | MT40A512M16JY_BGA96_BGA96_0P8_8 | MT40A512M16 | BGA96_0P8_8P1X14P1 |
| U17 | MT40A512M16JY_BGA96_BGA96_0P8_8 | MT40A512M16 | BGA96_0P8_8P1X14P1 |
| U18 | MT40A512M16JY_BGA96_BGA96_0P8_8 | MT40A512M16 | BGA96_0P8_8P1X14P1 |
| U24 | 74AUP2G07GW_SOT-363_0P65_SMT_IC | 74AUP2G07GW | SOT-363_0P65_SMT |
| U28 | SA56004ED_SO8_SO8_1P27_4X5_IC_1 | SA56004ED | SO8_1P27_4X5 |
| U35 | 74LVC2T45DC_8P_SSOP8_DCU_IC_1MM | 74LVC2T45DC | SSOP8_DCU |
| U36 | 74LVC2T45DC_8P_SSOP8_DCU_IC_1MM | 74LVC2T45DC | SSOP8_DCU |
| U37 | 74LVC2T45DC_8P_SSOP8_DCU_IC_1MM | 74LVC2T45DC | SSOP8_DCU |
| U38 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U39 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U40 | NX5P3090UK_WLCSP12_WLCSP12_0P4_ | NX5P3090UK | WLCSP12_0P4_1P38X1P68MM_SMDP |
| U42 | PRTR5V0U2AX_SOT143B_IC_1.1MM_48 | PRTR5V0U2AX | SOT143B |
| U44 | DIODE_ESD_4CH_PUSB3AB4_XSON10_0 | PUSB3AB4 | XSON10_0P5_1P1X2P6MM |
| U50 | SI5332FD10253-GM2_QFN40_QFN40_0 | Si5332FD10253-GM2 | QFN40_0P5_6X6_2P6EP |
| U54 | ADM8611_WLCSP_6P_WLCSP6_0P5_0P9 | ADM8611N293ACBZ-R7 | WLCSP6_0P5_0P98X1P48 |
| U55 | 74AUP1G11GW_SOT-363_0P65_SMT_IC | 74AUP1G11GW | SOT-363_0P65_SMT |
| U56 | 74AUP1G07GW_SC70-5_IC_1.1MM_31 | 74LVC1G07GW | SC70-5 |
| U58 | GATE_AND_SGL_SC70-5_IC_1.1MM_3 | 74AUP1G09GW | SC70-5 |
| U60 | GATE_AND_SGL_SC70-5_IC_1.1MM_3 | 74AUP1G09GW | SC70-5 |
| U62 | GATE_AND_SGL_SC70-5_IC_1.1MM_3 | 74AUP1G09GW | SC70-5 |
| U114 | 74AUP1G07GW_SC70-5_IC_1.1MM_31 | 74LVC1G07GW | SC70-5 |
| U123 | VSC8514_QFN_138P_A_AQFN138_0P65 | VSC8514_QFN | AQFN138_0P65_12X12_EP |
| U522 | S34MS04G200BH_BGA63P_VFBGA63_0P | S34MS04G200BHI000 | VFBGA63_0P8_9X11 |
| U523 | PCF2129AT_SO_20P_SO20_1P27_7P6X | PCF2129AT | SO20_1P27_7P6X12P95 |
| U524 | CAT24C04_SO8_SO8_1P27_4X5_IC_1. | CAT24C04WI-G | SO8_1P27_4X5 |
| U525 | PCA9546_16P_TSSOP16_IC_1.1MM_3 | PCA9546APW | TSSOP16 |
| U527 | 74AUP1G07GW_SC70-5_IC_1.1MM_31 | 74LVC1G07GW | SC70-5 |
| U530 | NC7SZ14_SC70-5_IC_1.1MM_315-810 | 74LVC1G04GW | SC70-5 |
| U532 | MT25QU512ABB8ESF_SO16W_SO16W_IC | MT25QU512ABB8ESF-0SIT | SO16W |
| U533 | 74AUP1G07GW_SC70-5_IC_1.1MM_31 | 74LVC1G07GW | SC70-5 |
| U534 | GATE_AND_SGL_SC70-5_IC_1.1MM_3 | 74AUP1G09GW | SC70-5 |
| U535 | NC7SZ14_SC70-5_IC_1.1MM_315-810 | 74LVC1G04GW | SC70-5 |
| U536 | CP2102N_QFN20_QFN20_3X3MM_B_IC_ | CP2102N | QFN20_3X3MM_B |
| U537 | PRTR5V0U2AX_SOT143B_IC_1.1MM_48 | PRTR5V0U2AX | SOT143B |
| U538 | PCA9510ADP_8P_TSSOP8_A_IC_1.1MM | PCA9510ADP | TSSOP8_A |
| U539 | 74LVC2T45DC_8P_SSOP8_DCU_IC_1MM | 74LVC2T45DC | SSOP8_DCU |
| U540 | 74LVC2T45DC_8P_SSOP8_DCU_IC_1MM | 74LVC2T45DC | SSOP8_DCU |
| U543 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U544 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U545 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U546 | GATE_AND_SGL_SC70-5_IC_1.1MM_3 | 74AUP1G09GW | SC70-5 |
| U547 | GATE_AND_SGL_SC70-5_IC_1.1MM_3 | 74AUP1G09GW | SC70-5 |
| U548 | NTB0102_8P_XSON_8P_IC_0.5MM_312 | NTB0102GT | XSON_8P |
| U549 | 74LVC2T45DC_8P_SSOP8_DCU_IC_1MM | 74LVC2T45DC | SSOP8_DCU |
| U550 | NX5P3090UK_WLCSP12_WLCSP12_0P4_ | NX5P3090UK | WLCSP12_0P4_1P38X1P68MM_SMDP |
| U551 | NC7SZ14_SC70-5_IC_1.1MM_315-810 | 74LVC1G04GW | SC70-5 |
| U552 | PRTR5V0U2AX_SOT143B_IC_1.1MM_48 | PRTR5V0U2AX | SOT143B |
| U553 | DIODE_ESD_4CH_PUSB3AB4_XSON10_0 | PUSB3AB4 | XSON10_0P5_1P1X2P6MM |
| U554 | NX3DV42GU_XQFN_10P_A_UQFN10_0P4 | NX3DV42GU | UQFN10_0P4_1P45X1P85 |
| U555 | 74LVC2T45DC_8P_SSOP8_DCU_IC_1MM | 74LVC2T45DC | SSOP8_DCU |
| U557 | LTC7150_BGA42_BGA42_0P8_5X6_IC_ | LTC7150S | BGA42_0P8_5X6 |
| U558 | INA220AIDGST_MSOP_10_0P5_3X3_IC | INA220AIDGST | MSOP_10_0P5_3X3 |
| U560 | LT8642SEV_LQFN24_QFN24_4X4MM_4E | LT8642SEV | QFN24_4X4MM_4EP |
| U561 | PC33PF8100A0ES_QFN56_QFN56_0P5_ | PF8100 | QFN56_0P5_8P1X8P1_EP5P1 |
| U562 | GATE_AND_SGL_SC70-5_IC_1.1MM_3 | 74AUP1G09GW | SC70-5 |
| U563 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U564 | PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0 | PUSB3AB6 | XSON7_0P5_2P2X1P2 |
| U565 | MT40A512M16JY_BGA96_BGA96_0P8_8 | MT40A512M16 | BGA96_0P8_8P1X14P1 |
| U566 | NC7SZ14_SC70-5_IC_1.1MM_315-810 | 74LVC1G04GW | SC70-5 |
