| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| ANT6100 | ANT_1P1G_WIFIANTA_ANT4411DR | ANT4411DR | WIFIANTA |
| ANT6101 | ANT_0_MM4829-2702B_ANT_JACK | ANT_JACK | MM4829-2702B |
| BT2100 | BATT3_BAT3_2R54_BAT3_2R54 | BAT3_2R54 | BAT3_2R54 |
| CON2405 | CON/ 10 / AXE510127_11_TDWC06P | NC/6pin_0.5 | TDWC06P-05 |
| CON5300 | CON/ 10 / AXE510127_3_TDWC06P- | DNP/6pin_0.5 | TDWC06P-05 |
| CON7001 | CON/ 10 / AXE510127_2_TDWC06P- | 6pin_0.5 | TDWC06P-05-L |
| CON9000 | CON/ 10 / AXE510127_3_STK3171- | DNP/STK3311-A | STK3171-018 |
| CON9001 | CON/ 10 / AXE510127_4_TDWC06P- | 6pin_0.5 | TDWC06P-05 |
| CON9101 | CON/ 10 / AXE510127_12_TDWC010 | DNP/6pin_0.5 | TDWC010P-05-L |
| CON9200 | CON/ 10 / AXE510127_0_TDWC06P- | 6pin_0.5 | TDWC06P-05 |
| D2500 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D2504 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D2513 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D2514 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D2515 | DIODEBI_DIR TRIG_E0603_PSUR161 | PSUR1610DNV07/RSD8535MA/BTRD06B800A | E0603 |
| D4200 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D4201 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D4202 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D4203 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D4204 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D4205 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D4206 | DIODEBI_DIR TRIG_ESD0402_ESD53 | ESD5341N | ESD0402 |
| D5000 | DIODE_SOD_323_B5819WS | B5819WS | SOD_323 |
| D5001 | DIODE_SOD_323_B5819WS | B5819WS | SOD_323 |
| D5002 | DIODE_SOD_123_B5819W | B5819W | SOD_123 |
| D5200 | DIODE_SOD_123_B5819W | B5819W | SOD_123 |
| D5201 | DIODEZENER1_SOD_123_BZT52B6V8 | BZT52B6V8 | SOD_123 |
| D5202 | DIODEDOUBLE F_SOT_23_BAT54S | BAT54S | SOT_23 |
| D5203 | DIODEZENER1_SOD_123_BZT52B18 | BZT52B18 | SOD_123 |
| D5204 | DIODEDOUBLE F_SOT_23_BAT54S | BAT54S | SOT_23 |
| D5205 | DIODE_SOD_123_B5819W | B5819W | SOD_123 |
| ED9108 | DIODEBI_DIR TRIG_E0402N_ST0561 | ST0561D4 | E0402N |
| FB2100 | BEAD_L0603_120R-100MHZ | 120R-100MHz | L0603 |
| FB7001 | BEAD_L0603_180R-100M | 180R-100M | L0603 |
| FB7002 | BEAD_L0603_180R-100M | 180R-100M | L0603 |
| J2501 | USB31_TYPE_C_1_USB16-3190016-CF | USB_TYPEC_115H0 | USB16-3190016-CF059-RA |
| J4200 | TFCARD_SOCKET_TF9_TFP09-2-12B_T | TFP09-2-12B | TF9_TFP09-2-12B |
| J4700 | FH26-25S-0_0.3SHW-05_CON39-06-1 | FH26-25S-0.3SHW(05) | CON39-06-1329-105 |
| J4701 | FH26-25S-0_1.3SHW-05_FLASH-LED_ | SPEAK1 | FLASH-LED |
| J5000 | HDMI_C_HDMI-MINI-19PIN-COR_HDMI | HDMI_C | HDMI-MINI-19PIN-COR |
| J5200 | CLAP070LF02CW_1_CON30PIN-0R5MM_ | 30PIN-DOWN | CON30PIN-0R5MM |
| J5300 | 33PIN_1_CON51_ZF0R6A_CON0.6/51P | CON0.6/51P | CON51_ZF0R6A |
| J5301 | BL509-06G31-TAH1_1_CON30-0R5-H1 | CON0.5/30P | CON30-0R5-H1R2A |
| J7001 | TOUCH-4PIN_7.25MM_CON2_0R8_2PIN | 2PIN_0.5mm | CON2_0R8 |
| J7002 | TOUCH-4PIN_5.25MM_CON2_0R8_2PIN | 2pin_0.5 | CON2_0R8 |
| J7003 | TOUCH-4PIN_5.25MM_CON2_0R8_2PIN | 2pin_0.5 | CON2_0R8 |
| JP7001 | LS_JAF00-05382-0304 | PJ301-6 | PJ18-05AB03-XX |
| L1700 | INDUCTORCOM_RP2_0405_NC/MCZ121 | NC/MCZ1210DH900L2TA0G | RP2_0405 |
| L2100 | INDUCTORSOF FERRITE_IND_252010 | 470nH | IND_252010 |
| L2101 | INDUCTORSOF FERRITE_IND_252010 | 470nH | IND_252010 |
| L2102 | INDUCTORSOF FERRITE_IND_252010 | 470nH | IND_252010 |
| L2103 | INDUCTORSOF FERRITE_IND_252010 | 470nH | IND_252010 |
| L2104 | INDUCTORSOF FERRITE_IND_252010 | 470nH | IND_252010 |
| L2200 | INDUCTORSOF FERRITE_IND_252012 | 0.24uH | IND_252012 |
| L2500 | INDUCTORCOM_RP2_0405_DNP | DNP | RP2_0405 |
| L2502 | INDUCTORCOM_RP2_0405_DNP | DNP | RP2_0405 |
| L4700 | BEAD_L0603_180R-100M | 180R-100M | L0603 |
| L5200 | INDUCTORSOF FERRITE_IND_404030 | 10uH | IND_404030 |
| L5201 | INDUCTORSOF FERRITE_IND_303015 | 2.2uH | IND_303015 |
| L6101 | INDUCTOR_L0402_DNP | DNP | L0402 |
| L6102 | INDUCTOR_L0402_DNP | DNP | L0402 |
| L6103 | INDUCTORSOF FERRITE_IND_303012 | 4.7uH | IND_303012 |
| L7002 | BEAD_L0603_180R-100M | 180R-100M | L0603 |
| L7003 | INDUCTOR_L0402_600R-100M | 600R-100M | L0402 |
| L7004 | INDUCTOR_L0402_600R-100M | 600R-100M | L0402 |
| M9900 | MARK_MARK_MARK | MARK | MARK |
| Q2204 | MOSFETP_SOT_23_DNP/WPM2341-3/T | DNP/WPM2341-3/TR | SOT_23 |
| Q4203 | MOSFETP_SOT_23_WPM3407-3/TR | WPM3407-3/TR | SOT_23 |
| Q4700 | MOSFETP_SOT23_TCS1401-C | TCS1401-C | SOT23 |
| Q5000 | MOSFETN_SOT_323_2SK3018 | 2SK3018 | SOT_323 |
| Q5001 | MOSFETN_SOT_323_2SK3018 | 2SK3018 | SOT_323 |
| Q5002 | MOSFETN_SOT_323_2SK3018 | 2SK3018 | SOT_323 |
| Q5200 | MOSFETP_SOT_23_WPM3407-3/TR | WPM3407-3/TR | SOT_23 |
| Q5201 | NPN_SOT_23_S8050 | S8050 | SOT_23 |
| Q5202 | NPN_SOT_23_S8050 | S8050 | SOT_23 |
| Q6102 | MOSFETP_SOT23_DNP/WPM2026 | DNP/WPM2026 | SOT23 |
| SHIELD10 | CON5_0_YZT24_CON5 | CON5 | YZT24 |
| TP1301 | TP_TP_0R70_GND | GND | TP_0R70 |
| TP1302 | TP_TP_0R70_EMMC_D0/FLASH_D0 | eMMC_D0/FLASH_D0 | TP_0R70 |
| TVS2501 | DIODE_TVS_BIDIR_ESD0402__B72590 | B72590D0050H160 | ESD0402 |
| U1000 | SOC_RK3566_BGA565_15R5X14R4X0R9 | RK3566 | BGA565_15R5X14R4X0R90 |
| U2100 | PMIC_RK817_5_QFN68_7R00X7R00X0R | PMIC_RK817_5 | QFN68_7R00X7R00X0R80_T |
| U2200 | DCDC_SY827_CSP20_1R96X1R56X0R66 | TCS4525 | CSP20_1R96X1R56X0R66 |
| U2300 | LDO_PT5108_SOT_23_5_RT9193-18GB | RT9193-18GB | SOT_23_5 |
| U3900 | LPDDR4_200P_0_BGA200_15R00X10R0 | LPDDR4_200p | BGA200_15R00X10R00X0R90 |
| U3901 | LDO_PT5108_SOT_23_5_DNP/PT5108E | DNP/PT5108E23E-18 | SOT_23_5 |
| U4000 | INAND_EMMC_153_2L_BGA153_13R00X | EMMC_B153_2L | BGA153_13R00X11R50X0R90_2L |
| U4100 | NANDFLASH_TSOP48_TSOP48_18R40X1 | NAND_FLASH | TSOP48_18R40X12R10X1R20 |
| U4700 | BCT642_QFN24_2R50X3R40X0R90_BCT | BCT642 | QFN24_2R50X3R40X0R90 |
| U4701 | LDO_PT5108_SOT_23_5_PT5108E23E- | PT5108E23E-12 | SOT_23_5 |
| U4702 | BCT642_QFN24_2R50X3R40X0R90_BCT | BCT642 | QFN24_2R50X3R40X0R90 |
| U5000 | ESD_ESD5304D_SON10_2R50X1R00X0R | ESD5304D | SON10_2R50X1R00X0R50 |
| U5001 | ESD_ESD5304D_SON10_2R50X1R00X0R | ESD5304D | SON10_2R50X1R00X0R50 |
| U5002 | SWITCH_SY6280_SOT_23_5_SY6280AA | SY6280AAC | SOT_23_5 |
| U5200 | DCDC_MP1488_SOT26_TCS5226 | TCS5226 | SOT26 |
| U5201 | RT9271_0_SOT26_TCS3256 | TCS3256 | SOT26 |
| U5202 | LDO_PT5108_SOT_23_5_PT5108E23_1 | PT5108E23E-18 | SOT_23_5 |
| U5300 | GT800_1_GSL3675_GSL3676 | GSL3676 | GSL3675 |
| U5301 | GT800_0_QFN5X5-40PINA_CST21680S | CST21680SE | QFN5X5-40PINA |
| U6100 | MODULE_AP6XXX_MD44_AP6XXX_AP625 | AP6255 | MD44_AP6XXX |
| U7005 | AMPLIFIER_PT1505_MSOP8_TT8642 | TT8642 | MSOP8 |
| U9001 | U/ AK09918C_AK09918_DNP/AK0991 | DNP/AK09918C | AK09918 |
| U9002 | U/ ITG-1010_0_LGA14-2R5X3_DNP/ | DNP/ICM-20600 | LGA14-2R5X3 |
| U9003 | MC3413-P-HF_0_MC3433_SC7A20 | SC7A20 | MC3433 |
| Y1200 | CRYSTAL_4P_CRY4_3R20X2R50X0R80_ | 24MHz | CRY4_3R20X2R50X0R80 |
| Y2100 | CRYSTAL_2P_1G_CRY2_6R90X1R40X1R | 32.768KHz | CRY2_6R90X1R40X1R30 |
| Y6100 | CRYSTAL_4P_CRY4_3R20X2R50X0R8_1 | 37.4MHz | CRY4_3R20X2R50X0R80 |
