查看: 51|回复: 2
[Allegro24.1以下] Synaptics SL1620 挂两个DDR4 DEMO 板PCB文件共享(LT9611+FXL6408UMX+GL3523)
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 3 天前 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    SL1620_DF950-C01096-01+RevA.7z (2.47 MB, 下载次数: 17, 售价: 5 枚金币)
    CM17CM  CHOKE 90 OHM 330MA 0805_TDK4_0P85MM_2X1P2MM_DLW21SN900HQ2LDLW21SN900HQ2LTDK4_0P85MM_2X1P2MM
    D1LED_LED0402_LED_GRNLED_GRNLED0402
    D695SQ015_ST-SOD-523_RB531SM-30T2RRB531SM-30T2RST-SOD-523
    D7LED_LED0402_LED_GRNLED_GRNLED0402
    D8LED_LED0402_LED_GRNLED_GRNLED0402
    D995SQ015_ST-SOD-523_RB531SM-30T2RRB531SM-30T2RST-SOD-523
    D1095SQ015_ST-SOD-523_RB531SM-30T2RRB531SM-30T2RST-SOD-523
    D1195SQ015_ST-SOD-523_RB531SM-30T2RRB531SM-30T2RST-SOD-523
    D1295SQ015_ST-SOD-523_RB531SM-30T2RRB531SM-30T2RST-SOD-523
    D13ESD7002_ONSEMI_SOT323-3_ESD7002WTT1GESD7002WTT1GONSEMI_SOT323-3
    D14TPD4S009_USON10_0P5MM_2P5X1P0MM_ESD8104MUTAGESD8104MUTAGUSON10_0P5MM_2P5X1P0MM
    D15TPD4S009_USON10_0P5MM_2P5X1P0MM_ESD8104MUTAGESD8104MUTAGUSON10_0P5MM_2P5X1P0MM
    D16ESD7002_ONSEMI_SOT323-3_ESD7002WTT1GESD7002WTT1GONSEMI_SOT323-3
    D17ESD7002_ONSEMI_SOT323-3_ESD7002WTT1GESD7002WTT1GONSEMI_SOT323-3
    D18TPD4S009_USON10_0P5MM_2P5X1P0MM_ESD8104MUTAGESD8104MUTAGUSON10_0P5MM_2P5X1P0MM
    D19TPD4S009_USON10_0P5MM_2P5X1P0MM_ESD8104MUTAGESD8104MUTAGUSON10_0P5MM_2P5X1P0MM
    D20ESD7002_ONSEMI_SOT323-3_ESD7002WTT1GESD7002WTT1GONSEMI_SOT323-3
    D21ESD7002_ONSEMI_SOT323-3_ESD7002WTT1GESD7002WTT1GONSEMI_SOT323-3
    D22TPD4S009_USON10_0P5MM_2P5X1P0MM_ESD8104MUTAGESD8104MUTAGUSON10_0P5MM_2P5X1P0MM
    D23TPD4S009_USON10_0P5MM_2P5X1P0MM_ESD8104MUTAGESD8104MUTAGUSON10_0P5MM_2P5X1P0MM
    D2495SQ015/TO_2_ST-SOD-523_BAT41KFILMBAT41KFILMST-SOD-523
    D25BZX84C47/SOT_0_DIODE-SOD-523_BZT52C5V6T-7BZT52C5V6T-7DIODE-SOD-523
    D45LED_LED0402_GREEN_0402GREEN_0402LED0402
    DR1BZX84C47/SOT_0_DIODE-SOD-123_MMSZ4678T1GMMSZ4678T1GDIODE-SOD-123
    J1HDR_QSPI_HIROSE_DF11-12DP-2DS-24_CONN_QSPI/RACONN_QSPI/RAHIROSE_DF11-12DP-2DS-24
    J2TRRS_JACK_0_54-00177_TRRS_JACKTRRS_JACK54-00177
    J3RJ118BA_0_RJ45-LED-PHY_HRK1-1B71PG5-36A1BB-1RHRK1-1B71PG5-36A1BB-1RRJ45-LED-PHY
    J4CONN4_2R_2R54_CONN4_2R_2R54_CONN4_2R_2R54CONN4_2R_2R54CONN4_2R_2R54
    J5CON-MSD-TFP09-2-12B_DNI_ATTEND-112J-TDAR-R01_112J-TDAR-R01112J-TDAR-R01ATTEND-112J-TDAR-R01
    J6FH27-54S-0P4SH_0512965494_0512965494_MOLEX0512965494_Molex512965494
    J7525592252_CON_525592253_MOL_CON_525592253CON_525592253CON_525592253_MOL
    J9CON-M2_KEYE_MST_TE-2199230-4_2230_CON-M2_KEYE-2230CON-M2_KeyE-2230TE-2199230-4_2230
    J10USB4105GFA_GCT_USB4105GFA_USB4105GFAUSB4105GFAGCT_USB4105GFA
    J11USB3_0_DOUBLE_1_USB3_18P4R-LOTES-SHORTBODY_1_USB-303WSD-BRYUSB-303WSD-BRYUSB3_18P4R-LOTES-SHORTBODY_1
    J12USB3_0_DOUBLE_1_USB3_18P4R-LOTES-SHORTBODY_1_USB-303WSD-BRYUSB-303WSD-BRYUSB3_18P4R-LOTES-SHORTBODY_1
    J13CONN40_2R_2R54_CONN-DIP2R-40P-2R54_CONN40_2R_2R54CONN40_2R_2R54CONN-DIP2R-40P-2R54
    J14HDMI_RA_CONN_MOLEX-47151-0001_HDMI/RA_W/OFLANGEHDMI/RA_w/oFlangeMOLEX-47151-0001
    J15USB4105GFA_GCT_USB4105GFA_USB4105GFAUSB4105GFAGCT_USB4105GFA
    J16HEADER_4_HEADER_4PIN_100_SINGLEROW_04_CN00200SingleRow_04HEADER_4PIN_100
    JP1THD  HEADER 2 A_HDR1X2_HDR 2X1HDR  2x1HDR1X2
    L1INDUCTOR  FERRITE_L0402_220OHM/700MA220ohm/700mAL0402
    L2INDUCTOR  FERRITE_L0402_220OHM/700MA220ohm/700mAL0402
    L19INDUCTOR  FERRITE_L0402_330OHM/1.2A330ohm/1.2AL0402
    L20FERRITE  BEAD_L0603_10UH/300MA10uH/300mAL0603
    L21INDUCTOR  IRON_0_L2520_1.0UH/3.1A1.0uH/3.1AL2520
    L22INDUCTOR  IRON_0_CHI_4343-3225_2.2UH/2.2A2.2uH/2.2ACHI_4343-3225
    L23INDUCTOR  IRON_0_CHI_252012_1.0UH/3.6A1.0uH/3.6ACHI_252012
    L24INDUCTOR  IRON_0_CHI_252012_1.0UH/3.6A1.0uH/3.6ACHI_252012
    L45INDUCTOR  IRON_0_CHI_5050-2520_220NH/9.5A220nH/9.5ACHI_5050-2520
    LD1LED_598-8170-107F_LED_0805_0-7_598-8170-107F598-8170-107FLED_0805_0-7
    LD9LED_598-8170-107F_LED_0805_0-7_598-8170-107F598-8170-107FLED_0805_0-7
    MH1HOLE_M_MH-C6D3MM_HOLE_MHole_MMH-C6D3MM
    MH2HOLE_M_MH-C6D3MM_HOLE_MHole_MMH-C6D3MM
    MH3HOLE_M_MH-C6D3MM_HOLE_MHole_MMH-C6D3MM
    MH4HOLE_M_MH-C6D3MM_HOLE_MHole_MMH-C6D3MM
    MH5HOLE_M_MH-C6D3MM_HOLE_MHole_MMH-C6D3MM
    MH6HOLE_M_MH-C6D3MM_HOLE_MHole_MMH-C6D3MM
    MH7HOLE_M_MH-C6D3MM_HOLE_MHole_MMH-C6D3MM
    MH8HOLE_M_MH-C6D3MM_HOLE_MHole_MMH-C6D3MM
    Q1MTD4P05_FAIRCHILD-SOT-23_DMG301NU-13DMG301NU-13FAIRCHILD-SOT-23
    Q2MTD4P05_FAIRCHILD-SOT-23_DMG301NU-13DMG301NU-13FAIRCHILD-SOT-23
    Q3MTD4P05_3_FAIRCHILD-SOT-23_AO3415AO3415FAIRCHILD-SOT-23
    Q4NPN  BCE_SOT-23_MMBT3904LT1GMMBT3904LT1GSOT-23
    Q5MTD4P05_FAIRCHILD-SOT-23_FDV301NFDV301NFAIRCHILD-SOT-23
    Q6MTD4P05_3_FAIRCHILD-SOT-23_AO3415AO3415FAIRCHILD-SOT-23
    Q7NPN  BCE_SOT-23_MMBT3904LT1GMMBT3904LT1GSOT-23
    Q8MMBT3906L_ONSEMI-SOT-23_MMBT3906LT1GMMBT3906LT1GONSEMI-SOT-23
    Q9MTD4P05_3_FAIRCHILD-SOT-23_DMP2066LSN-7DMP2066LSN-7FAIRCHILD-SOT-23
    Q10NPN  BCE_SOT-23_MMBT3904LT1GMMBT3904LT1GSOT-23
    Q11MTD4P05_14_NXP_SOIC8_FDS6679AZFDS6679AZNXP_SOIC8
    Q12MMBT3906L_FAIRCHILD-SOT-23_MMBT4403MMBT4403FAIRCHILD-SOT-23
    Q13NPN  BCE_SOT-23_MMBT3904LT1GMMBT3904LT1GSOT-23
    Q14BC807-40LT1_SOT23_BC807_TR00604BC807SOT23
    Q15MTD4P05_FAIRCHILD-SOT-23_DMG301NU-13DMG301NU-13FAIRCHILD-SOT-23
    Q16MTD4P05_FAIRCHILD-SOT-23_DMG301NU-13DMG301NU-13FAIRCHILD-SOT-23
    RV15VARISTOR_R0402_AVR-M1005C270MTABBAVR-M1005C270MTABBR0402
    STO1STANDOFF_M2_TPAD-18MIL_STANDOFFStandOffTPAD-18MIL
    SW1PB  SWITCH_4_MINGHUI-3X4X2H_3X4X2H3x4x2HMINGHUI-3X4X2H
    SW6PB  SWITCH_4_MINGHUI-3X4X2H_3X4X2H3x4x2HMINGHUI-3X4X2H
    U1SL1620_DDR4_BGA443_0P4MM_13X13MM_BM32X32_DVF120_SL1620_DDR4SL1620_DDR4BGA443_0P4MM_13X13MM_BM32X32_DVF120
    U2TMUX1574RSVR_1_RSV16_TEX_TMUX1574RSVRTMUX1574RSVRRSV16_TEX
    U3TMUX1574RSVR_1_RSV16_TEX_TMUX1574RSVRTMUX1574RSVRRSV16_TEX
    U4DDR4_4GB  X16 - FBGA96_BGA96_0P8MM_10P1X14P1MM_DDR34_DDR4_4GB X16 - FBGA96DDR4_4Gb  x16 - FBGA96BGA96_0P8MM_10P1X14P1MM_DDR34
    U5EMMC_5.0_MICRON-EMMC5_0P5_11P5X13X1MM_MTFC16GAPALBH-IT  TRMTFC16GAPALBH-IT  TRMICRON-EMMC5_0P5_11P5X13X1MM
    U6SKT_TSOP-48_5_SAMSUNG-TSOP48_S34MS04G204TFB010S34MS04G204TFB010SAMSUNG-TSOP48
    U7W25Q128JVSIQ-TR_8-SOIC_W25Q128JWSIQW25Q128JWSIQ8-SOIC
    U8RTL8211F_RTL-QFN40_RTL8211F-CGRTL8211F-CGRTL-QFN40
    U9FXL6408_UMLP16_0P4MM_1P8X2P6MM_ONSEMI_FXL6408UMXFXL6408UMXUMLP16_0P4MM_1P8X2P6MM_ONSEMI
    U10FXL6408_UMLP16_0P4MM_1P8X2P6MM_ONSEMI_FXL6408UMXFXL6408UMXUMLP16_0P4MM_1P8X2P6MM_ONSEMI
    U11FXL6408_UMLP16_0P4MM_1P8X2P6MM_ONSEMI_FXL6408UMXFXL6408UMXUMLP16_0P4MM_1P8X2P6MM_ONSEMI
    U13GL3520_QFN88_V094-1_41_I-QFN76-9X9X0_4A_GL3523-OTY3CGL3523-OTY3CI-QFN76-9X9X0_4A
    U14CAT25C128/256_SOIC8_1P27MM_5X4MM_W25X05CLSNIGW25X05CLSNIGSOIC8_1P27MM_5X4MM
    U15PCM5101AQPWRQ1_TSSOP-20P_PCM5101AQPWRQ1PCM5101AQPWRQ1TSSOP-20P
    U16IM69D130_5P_MIC_IM69D130_5P_4-0X3-0MM_69  DB(A)_1.62-3.6V69  dB(A)_1.62-3.6VMIC_IM69D130_5P_4-0X3-0MM
    U17IM69D130_5P_MIC_IM69D130_5P_4-0X3-0MM_69  DB(A)_1.62-3.6V69  dB(A)_1.62-3.6VMIC_IM69D130_5P_4-0X3-0MM
    U18AT24C02_0_UDFN8EP_0P5MM_2X3MM_CAT24C08HU4I-GT3CAT24C08HU4I-GT3UDFN8EP_0P5MM_2X3MM
    U19LT9611_QFN64_LONTIUM_LT9611LT9611QFN64_LONTIUM
    U20TPS53321_0_XQFN16_0P4MM_1P8X2P6MM_NVT4858HKZNVT4858HKZXQFN16_0P4MM_1P8X2P6MM
    U21TS5A3159_8_WLCSP6_0P5MM_1P46X0P96MM_FPF1320UCXFPF1320UCXWLCSP6_0P5MM_1P46X0P96MM
    U22SN74LVC4T245A_W_TI_TSSOP16_SN74AVC4T245PWRSN74AVC4T245PWRTI_TSSOP16
    U23OSCILLATOR  4-PIN_XTAL4_2P5X2P0MM_32.768K/1.6V~3.6V32.768K/1.6V~3.6VXTAL4_2P5X2P0MM
    U24TPS2069C_SOT23-5_0P95MM_3P1X3MM_TPS2051CDBVTPS2051CDBVSOT23-5_0P95MM_3P1X3MM
    U25SGM7220XUQT12G_IC_TUSB320IRWBR_TUSB320IRWBRTUSB320IRWBRIC_TUSB320IRWBR
    U26AP2162A_0_MSOP-8EP_AP2162AMPGAP2162AMPGMSOP-8EP
    U27AP2162A_0_MSOP-8EP_AP2162AMPGAP2162AMPGMSOP-8EP
    U28SN74LVC4T245A_W_TI_TSSOP16_SN74AVC4T245PWRSN74AVC4T245PWRTI_TSSOP16
    U29PCA9306_NXP_SOIC8_PCA9306DPCA9306DNXP_SOIC8
    U30PCA9306_NXP_SOIC8_PCA9306DPCA9306DNXP_SOIC8
    U31SN74LVC4T245A_W_TI_TSSOP16_SN74AVC4T245PWRSN74AVC4T245PWRTI_TSSOP16
    U32TXB0108DQSR_2_SON40P400X200X55-20N_TXB0108DQSRTXB0108DQSRSON40P400X200X55-20N
    U33TXB0108DQSR_2_SON40P400X200X55-20N_TXB0108DQSRTXB0108DQSRSON40P400X200X55-20N
    U34SY8113C1_1_TSOT23-6_0-95MM_SY8113C1SY8113C1TSOT23-6_0-95MM
    U35TLV73325_SOT23-5_0P95MM_3P1X3MM_TLV73325PDBVRTLV73325PDBVRSOT23-5_0P95MM_3P1X3MM
    U36SY8088_SOT23-5_0P95MM_3P1X3MM_SY8088IAACSY8088IAACSOT23-5_0P95MM_3P1X3MM
    U37SY8832_TSOT23-8_0P65MM_3X3P05MM_SY8832AICSY8832AICTSOT23-8_0P65MM_3X3P05MM
    U39DDR4_4GB  X16 - FBGA96_BGA96_0P8MM_10P1X14P1MM_DDR34_DDR4_4GB X16 - FBGA96DDR4_4Gb  x16 - FBGA96BGA96_0P8MM_10P1X14P1MM_DDR34
    U40TPS628660AYCG_0_WCSP15_0P35MM_1P05X1P78MM_TPS628660AYCGTPS628660AYCGWCSP15_0P35MM_1P05X1P78MM
    Y1CRYSTAL  CS325_XTAL4_2P0X1P6MM_25.0000MHZ/8PF25.0000MHz/8pFXTAL4_2P0X1P6MM
    Y3CRYSTAL  CS325_XTAL4_2P0X1P6MM_25.0000MHZ/8PF25.0000MHz/8pFXTAL4_2P0X1P6MM
    Y4CRYSTAL  CS325_XTAL4_2P0X1P6MM_27.0000MHZ/18PF27.0000MHz/18pFXTAL4_2P0X1P6MM
    Y5CRYSTAL  CS325_XTAL4_2P0X1P6MM_25.0000MHZ/8PF25.0000MHz/8pFXTAL4_2P0X1P6MM
    重要提示:PCB作品文件展下载说明
    前天 10:02
    1元学习Allegro(1期)
    社区居民终身成就奖特殊贡献奖
    发表于 前天 10:21 | 显示全部楼层
    昨天 22:10
  • 签到天数: 257 天
    发表于 昨天 22:11 | 显示全部楼层
