查看: 12586|回复: 59
[Allegro16.6以下] TI公司AM437X评估板PCB
终身成就奖社区居民
发表于 2015-3-11 14:14:09 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BT11P_BATTERYCR1632HOLDER_BH600SM_BH600SMBH600SM
D11F_LED_GREEN_SM_LED_0805_GREENGreen LEDSM_LED_0805
D21F_LED_GREEN_SM_LED_0805_GREENGreen LEDSM_LED_0805
D31E_DIODE_SMCJ15CA_SMCJ15CA_SMCJSMCJ15CASMCJ15CA
D41E_DIODE_5ARECT_B520C-13-F_B520B520C-13-FB520C-13-F
D51E_DIODE1A20V_SCHOTTKY_SM_DIO_CMBRM120LSM_DIO_CASE_457-04
D6DIODE200MA30V_SCHOTTKY_SM_SOT32BAT54SSM_SOT323-3
D7DIODE200MA250V_SOD-123_MMSD103TMMSD103T1SOD-123
D8DIODE200MA250V_SOD-123_MMSD103TMMSD103T1SOD-123
F11P_FUSE_4A_SMDFUSEBLK_FUSE4AFuse 4ASMDFUSEBLK
FB211L_FERRITEBEAD_600MA10OHM_HF70A600mAFB10ohmHF70ACB201209
FB221L_FERRITEBEAD_600MA10OHM_HF70A600mAFB10ohmHF70ACB201209
FB231L_FERRITEBEAD_300OHM500MA_SM-7300OHM500mASM-7351-IND-0603
FB241L_FERRITEBEAD_300OHM500MA_SM-7300OHM500mASM-7351-IND-0603
FB251L_FERRITEBEAD_600MA10OHM_HF70A600mAFB10ohmHF70ACB201209
J12H_HEADER8X2PIN_RA_HDR2X8RA-201Header 8x2 RAHDR2X8RA-201M
J22C_CONN_FPC_AXK_24PIN_SCKAXK7L2AXK7L24223GSCKAXK7L24
J32H_HEADER12X2_HDR2X12_HEADER12HEADER 12x2HDR2X12
J42C_CONN_DSUB9M_TH_NORCOMP_DB9M_Conn_DB9M_THNORCOMP_DB9M_TH
J52J_CONN_PWRJACK_RAPC712_RAPC712Power Jack RAPC712RAPC712
J62H_HEADER_5X1_HEADER_5X1_HEADERHEADER 5HEADER_5X1
J72C_CONN_MICROSD_8_SD-MICRO-SCHASCHA5B0200SD-MICRO-SCHA5B0300
J82H_HEADER10X2_ARMJTAG_HDR2X10-3ARM JTAGHDR2X10-330M
J92C_CONN_DSUB9M_TH_NORCOMP_DB9M_Conn_DB9M_THNORCOMP_DB9M_TH
J102H_HEADER_4X1_HDR1X4-330M_HEADEHEADER 4HDR1X4-330M
J112C_MICROUSBAB_ZX62-AB-5PA_USB_MUSB_MicroABZX62-AB-5PA
J122H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J132C_CONNECTOR_USB_A_USB_STD_A_THUSB AUSB_STD_A_TH
J142C_CONN_3.5MM_SJ3524SMT_SJ3524S3.5mm SJ3524SJ3524SMT4PIN
J152C_CONN_FPC_0.5MMPITCH_50POSBOTFH12S-50S-0.5SHCNFH12S-50S-05SH
J162C_CONN_3.5MM_SJ3524SMT_SJ3524S3.5mm SJ3524SJ3524SMT4PIN
J172C_CONN_FPC_527450897_CN527450-527450897CN527450-897
J182J_CONNECTORRJ45_GIGABIT_CNRJ45RJ-45 GigabitCNRJ45-1X1WLED-598M
J192C_CONN_HDMI_TYPEA_SMD_HDMIA_RAHDMIConnASMD_HDMIA_RA
J202C_CONN_SAMTECMEC6_150_MEC6-150MEC6_100pinMEC6-150-02-S-D-RA1
J212C_MICROUSBAB_ZX62-AB-5PA_USB_MUSB_MicroABZX62-AB-5PA
J222H_HEADER10X2_HDR2X10-330M_HEADHEADER 10x2HDR2X10-330M
J232H_HEADER3X2_HDR2X3-330M_HEADERHEADER 3x2HDR2X3-330M
J242H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J252H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J262H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J282H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J292H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J302H_HEADER20X2_HDR2X20-330M_HEADHeader 20x2HDR2X20-330M
J312H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J322H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J332H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J342H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J362H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
J372C_CONN_DSUB9M_TH_NORCOMP_DB9M_Conn_DB9M_THNORCOMP_DB9M_TH
J382H_HEADER_2X1_HEADER_2X1_HEADERHEADER 2HEADER_2X1
L11M_ACM2012_ACM2012H_ACM2012ACM2012ACM2012H
L21M_ACM2012_ACM2012H_ACM2012ACM2012ACM2012H
L31L_4.7UHINDUCTOR20%450MASMD_SM_4.7uHSM_IND_LQH32CN
L51L_1.5UHINDUCTOR20%2.8ASMD_IND_1.5uHIND_SPM3012T
L61L_10UHINDUCTOR20%110MASMD_IND-10uHIND-MLZ2012-57M
L71L_10UHINDUCTOR20%110MASMD_IND-10uHIND-MLZ2012-57M
L81L_1.5UHINDUCTOR20%2.8ASMD_IND_1.5uHIND_SPM3012T
L91L_1.5UHINDUCTOR20%2.8ASMD_IND_1.5uHIND_SPM3012T
L101L_1.5UHINDUCTOR20%2.8ASMD_IND_1.5uHIND_SPM3012T
L111L_4.7UHINDUCTOR30%3.1ASMD_SMD_4.7uHSMD_SLF7055T
L121L_4.7UHINDUCTOR30%1.7ASMD_VLCF4.7uHVLCF5020T
Q11Q_MOSFET_NCHAN_BSS138_SOT23-3_BSS138SOT23-3
Q21Q_MOSFET_NCHAN_BSS138_SOT23-3_BSS138SOT23-3
Q31Q_MOSFET_NCHAN_BSS138_SOT23-3_BSS138SOT23-3
Q41Q_MOSFET_NCHAN_BSS138_SOT23-3_BSS138SOT23-3
Q51Q_NPN_FMMT458_SM_SOT23_BCE_FMMFMMT458TASM_SOT23_BCE
Q61Q_MOSFET_PCHAN_FDT434P_SOT223-FDT434PSOT223-4
Q71Q_MOSFET_NCHAN_BSS138_SOT23-3_BSS138SOT23-3
SCKT1AM437X_ZDN_PROCESSOR_SOCKET_SCKAM437X ZDN SocketSCKBGA625
SPKR11G_AUDIOBUZZER_AI_1027_SPKR_AI_AudioBuzzer_AI_1027SPKR_AI_1027
SW12W_SWITCH_PUSHBUTTONSMD_SW_B3SLB3SLSW_B3SL-1022P
SW22W_SWITCH_SLIDERA_SPDT_TH_SW_T5Slide SwitchTH_SW_T551101
SW112W_SWITCHDIP5POS_SMD_SW291-5M_DDIP Switch 5PosSW291-5M
SW122W_SWITCHDIP5POS_SMD_SW291-5M_DDIP Switch 5PosSW291-5M
SW132W_SWITCH_PUSHBUTTONSMD_SW_B3SLB3SLSW_B3SL-1022P
U11A_TSL2550_SMD4X3-4-59M_TSL2550TSL2550SMD4X3-4-59M
U21A_PSM712_SM-SOT-23_PSM712PSM712SM-SOT-23
U31A_FT2232_2_LQFP64PIN_FT2232HLFT2232HLLQFP64PIN
U4TPS51200_DRCPSO_10PIN_TPS51200TPS51200DRCPSO_10PIN
U51A_INA226_MSOP3X3-10-43M_INA226INA226MSOP3X3-10-43M
U61A_SN74AVC2T244_SON2X1-8-16M_SNSN74AVC2T244SON2X1-8-16M
U71A_SN74AVC4T245_U_16_PW_SN74AVCSN74AVC4T245U_16_PW
U81A_SN74AVC4T245_U_16_PW_SN74AVCSN74AVC4T245U_16_PW
U91A_ISOREG5V_R1Z-3.305HP_SMD15X1R1Z-3.305HPSMD15X11-6-374M
U101A_ISO1050_SO9X6-8-191M_ISO1050ISO1050SO9X6-8-191M
U111A_SN74AVC2T244_SON2X1-8-16M_SNSN74AVC2T244SON2X1-8-16M
U121A_SN74LVC2G07_U_6_DCK_SN74LVC2SN74LVC2G07U_6_DCK
U131A_SN74LVC1G00DCK_SC70-5-43M_SNSN74LVC1G00DCKSC70-5-43M
U141A_93C56EEPROM2KBIT_SOIC8_MC_9393LC56BSOIC8_MC
U151A_SN74AVC8T245_TSSOP8X4-24-47MSN74AVC8T245TSSOP8X4-24-47M
U171A_SN74LVC1G04_SC70-5-43M_SN74LSN74LVC1G04SC70-5-43M
U181A_INA226_MSOP3X3-10-43M_INA226INA226MSOP3X3-10-43M
U191A_MAX3232E_U_16_D_MAX3232EMAX3232EU_16_D
U201A_TMP275_MSOP_DGK_TMP275TMP275MSOP_DGK
U211A_TPS2051BD_U_8_D_TPS2051BDTPS2051BDU_8_D
U221A_SN74LVC1G07_SC70-5-43M_SN74LSN74LVC1G07SC70-5-43M
U231A_SN74AVC8T245_TSSOP8X4-24-47MSN74AVC8T245TSSOP8X4-24-47M
U241A_SN74LVC1G125_SC70-5-43M_74LV74LVC1G125SC70-5-43M
U251A_TXS0108_U_20_PW_TXS0108ETXS0108EU_20_PW
U261A_SN74LVC32244_BGA13X5-96_SN74SN74LVC32244ZKEBGA13X5-96
U271A_SN74AVC8T245_TSSOP8X4-24-47MSN74AVC8T245TSSOP8X4-24-47M
U281A_SN74LVC244A_BGA3X4-20-39M_SNSN74LVC244ABGA3X4-20-39M
U291A_SN74AVC8T245_TSSOP8X4-24-47MSN74AVC8T245TSSOP8X4-24-47M
U301A_SN74LVC1G04_SC70-5-43M_SN74LSN74LVC1G04SC70-5-43M
U311A_ISO1050_SO9X6-8-191M_ISO1050ISO1050SO9X6-8-191M
U321A_LIS331DLH_LGA16PIN_3X3_LIS33LIS331DLHLGA16PIN_3X3
U331A_SN74AVC4T245_U_16_PW_SN74AVCSN74AVC4T245U_16_PW
U341A_SN74AVC1T45_SMDSC70-6_SN74AVSN74AVC1T45SMDSC70-6
U351A_SN74LVC1G04_SC70-5-43M_SN74LSN74LVC1G04SC70-5-43M
U361A_PSM712_SM-SOT-23_PSM712PSM712SM-SOT-23
U371A_SN74AVC4T245_U_16_PW_SN74AVCSN74AVC4T245U_16_PW
U381A_TPS65105PWP_U_24_PW_TPS65105TPS65105U_24_PW
U391G_HAPTICS_PICO_304-100_PICO_30PicoHaptics 304-100PICO_304-100
U401A_SIL9022A_QFN_72_SIL9022ASIL9022AQFN_72
U411A_KSZ9031RNX_QFN7X7-48_KSZ9031KSZ9031RNQFN7X7-48
U421A_SN74LVC1G07_SC70-5-43M_SN74LSN74LVC1G07SC70-5-43M
U431A_TPD12S016_PW_24PIN_TSSOP_TPDTPD12S016PW_24PIN_TSSOP
U441A_TPD2E001DRL_U_5_DRL_TPD2E001TPD2E001U_5_DRL
U461A_TPS79333_U_5_DBV_TPS79333TPS79333U_5_DBV
U471A_TXS0102_DCT8_TXS0102TXS0102DCT8
U481A_TPS79301_U_6_DBV_TPS79301TPS79301U_6_DBV
U501A_SN74AVC1T45_SMDSC70-6_SN74AVSN74AVC1T45SMDSC70-6
U511A_TPD2E001DRL_U_5_DRL_TPD2E001TPD2E001U_5_DRL
U521A_CAT24C256W_SOIC_8_CAT24C256WCAT24C256WSOIC_8
U531A_TPD6E001RSE_U_10_RSE_TPD6E00TPD6E001U_10_RSE
U541A_TPS79301_U_6_DBV_TPS79301TPS79301U_6_DBV
U551A_MT41K512M8RH_BGA11X9-78_MT41MT41K512M8RHBGA11X9-78
U561A_TPS65218_QFN6X6-48-39M_TPS65TPS65218QFN6X6-48-39M
U571A_MT41K512M8RH_BGA11X9-78_MT41MT41K512M8RHBGA11X9-78
U581A_MT41K512M8RH_BGA11X9-78_MT41MT41K512M8RHBGA11X9-78
U59AM437X_ZDN_GPEVM_AM437X_ZDN_AM4AM437X_ZDNAM437X_ZDN
U601A_MT41K512M8RH_BGA11X9-78_MT41MT41K512M8RHBGA11X9-78
U611A_TPD4S012_U_6_DRY_TPD4S012TPD4S012U_6_DRY
U621A_TPS63010YFF_U_20_DSBGA_TPS63TPS63010U_20_DSBGA
U631A_MT29F4G08ABAE_SKT-TSOP48SM_MMT29F4G08ABSKT-TSOP48SM
U641A_TPD4S012_U_6_DRY_TPD4S012TPD4S012U_6_DRY
U651A_MTFC4GLDDQ-4M_BGA18X14-100-MTFC4GLDDQ-4M ITBGA18X14-100-55M
U661A_TPS2051BD_U_8_D_TPS2051BDTPS2051BDU_8_D
U671A_SN74AVC4T245_U_16_PW_SN74AVCSN74AVC4T245U_16_PW
U681A_TLV320AIC3106_VQFN48_RGZ_TLVTLV320AIC3106VQFN48_RGZ
U691A_TPS61081DRC_U_10_DRC_TPS6108TPS61081DRCU_10_DRC
U701A_ISOREG5V_R1Z-3.305HP_SMD15X1R1Z-3.305HPSMD15X11-6-374M
U711A_TPS79501_SOT223_6PIN_TPS7950TPS79501SOT223_6PIN
U72TPS71712_SMDSC70-5_TPS71712TPS71712SMDSC70-5
U731A_SN74LVC1G08DCKT_SC70_SM-SO-SSN74LVC1G08SM-SO-SC70-5
U741A_SN74LVC1G07_SC70-5-43M_SN74LSN74LVC1G07SC70-5-43M
U751A_SN74LVC1G07_SC70-5-43M_SN74LSN74LVC1G07SC70-5-43M
U761A_TPS78101_SOT23-5-43M_TPS7810TPS78101SOT23-5-43M
Y11Y_CRYSTAL12MHZABM3_SM_OSC_ABM312MHzSM_OSC_ABM3
Y21Y_CRYSTAL_SMD32_768KHZ_MC-306_32.768KHz MC-306MC-306
Y31Y_CRYSTAL_SMD32_768KHZ_MC-306_32.768KHz MC-306MC-306
Y41Y_CRYSTAL24MHZSCM_XTAL2X3-30M_24MHzXTAL2X3-30M
Y51Y_OSCILLATOR_12MHZ_ECS_SMD3_2X12MHzECS_SMD3_2X5MM
Y61Y_CRYSTAL25MHZABM3_SM_OSC_ABM325MHzSM_OSC_ABM3
重要提示:PCB作品文件展下载说明
终身成就奖社区居民
 楼主| 发表于 2015-3-11 14:17:59 | 显示全部楼层
游客,如果您要查看本帖隐藏内容请回复
社区居民社区明星最爱沙发宣传大使奖终身成就奖
发表于 2015-3-11 14:22:23 | 显示全部楼层
    社区居民终身成就奖社区明星宣传大使奖
    发表于 2015-3-11 14:27:39 | 显示全部楼层
    社区居民
    发表于 2015-3-11 15:00:53 | 显示全部楼层
  • 签到天数: 49 天
    PADS-180606高级班
    终身成就奖社区居民忠实会员社区劳模最爱沙发优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2015-3-11 16:17:04 | 显示全部楼层
  • 签到天数: 49 天
    PADS-180606高级班
    发表于 2015-3-11 16:18:24 | 显示全部楼层
    需要提供一下图纸的截图!
    终身成就奖社区居民忠实会员社区劳模最爱沙发原创达人优秀斑竹奖
    发表于 2015-3-11 16:25:48 | 显示全部楼层
    终身成就奖社区居民忠实会员
    发表于 2015-3-11 16:40:14 | 显示全部楼层
    社区居民原创达人终身成就奖
    发表于 2015-3-11 16:47:19 | 显示全部楼层
