查看: 707|回复: 0
[其他器件] SKB360 Bluetooth 4.0 datasheet
发表于 2016-7-6 08:52:32 | 显示全部楼层 |阅读模式
SKB360 Bluetooth 4.0 Low Energy Module
The SKB360 is a highly integrated Bluetooth 4.0 BLE module, designed for high data
rate, short-range wireless communication in the 2.4GHz ISM band. The module is
designed base on Nordic nRF51822 radio Transceiver IC, has a 32 bit ARM Cortex-M0
CPU, flash memory and analog and digital peripherals. The SKB360 provides a low
power and ultra-low cost BLE solution for wireless transmission applications.
SKB360 Bluetooth 4.0 datasheet.pdf (516 KB, 下载次数: 0)
