查看: 2542|回复: 2
RK3288平台USB摄像头驱动 有二种模式  今天发下ONEFRAM
社区居民社区明星忠实会员宣传大使奖终身成就奖特殊贡献奖
发表于 2016-10-26 16:46:01 | 显示全部楼层 |阅读模式
fine  CIF_CIF_FRM1_ADDR_Y                0x1c
#define  CIF_CIF_FRM1_ADDR_UV               0x20
#define  CIF_CIF_VIR_LINE_WIDTH             0x24
#define  CIF_CIF_SET_SIZE                   0x28
#define  CIF_CIF_SCM_ADDR_Y                 0x2c
#define  CIF_CIF_SCM_ADDR_U                 0x30
#define  CIF_CIF_SCM_ADDR_V                 0x34
#define  CIF_CIF_WB_UP_FILTER               0x38
#define  CIF_CIF_WB_LOW_FILTER              0x3c
#define  CIF_CIF_WBC_CNT                    0x40
#define  CIF_CIF_CROP                       0x44
#define  CIF_CIF_SCL_CTRL                   0x48
#define     CIF_CIF_SCL_DST                    0x4c
#define     CIF_CIF_SCL_FCT                    0x50
#define     CIF_CIF_SCL_VALID_NUM              0x54
#define     CIF_CIF_LINE_LOOP_CTR              0x58
#define     CIF_CIF_FRAME_STATUS               0x60
#define     CIF_CIF_CUR_DST                    0x64
#define     CIF_CIF_LAST_LINE                  0x68
#define     CIF_CIF_LAST_PIX                   0x6c
/*The key register bit descrition*/
/* CIF_CTRL Reg , ignore SCM,WBC,ISP,*/
#define  DISABLE_CAPTURE              (0x00<<0)
#define  ENABLE_CAPTURE               (0x01<<0)
#define  MODE_ONEFRAME                (0x00<<1)
#define  MODE_PINGPONG                (0x01<<1)
#define  MODE_LINELOOP                (0x02<<1)
#define  AXI_BURST_16                 (0x0F << 12)
/*CIF_CIF_INTEN*/
#define  FRAME_END_EN            (0x01<<1)
#define  BUS_ERR_EN                (0x01<<6)
#define  SCL_ERR_EN                (0x01<<7)
/*CIF_CIF_FOR*/
#define  VSY_HIGH_ACTIVE                   (0x01<<0)
#define  VSY_LOW_ACTIVE                    (0x00<<0)
#define  HSY_LOW_ACTIVE                    (0x01<<1)
#define  HSY_HIGH_ACTIVE                   (0x00<<1)
#define  INPUT_MODE_YUV                    (0x00<<2)
#define  INPUT_MODE_PAL                    (0x02<<2)
#define  INPUT_MODE_NTSC                    (0x03<<2)
#define  INPUT_MODE_RAW                    (0x04<<2)
#define  INPUT_MODE_JPEG                    (0x05<<2)
#define  INPUT_MODE_MIPI                   (0x06<<2)
#define  YUV_INPUT_ORDER_UYVY(ori)           (ori & (~(0x03<<5)))
#define  YUV_INPUT_ORDER_YVYU(ori)           ((ori & (~(0x01<<6)))|(0x01<<5))
#define  YUV_INPUT_ORDER_VYUY(ori)           ((ori & (~(0x01<<5))) | (0x1<<6))
#define  YUV_INPUT_ORDER_YUYV(ori)           (ori|(0x03<<5))
#define  YUV_INPUT_422                       (0x00<<7)
#define  YUV_INPUT_420                       (0x01<<7)
#define  INPUT_420_ORDER_EVEN               (0x00<<8)
#define  INPUT_420_ORDER_ODD               (0x01<<8)
#define  CCIR_INPUT_ORDER_ODD               (0x00<<9)
#define  CCIR_INPUT_ORDER_EVEN             (0x01<<9)
#define  RAW_DATA_WIDTH_8                  (0x00<<11)
#define  RAW_DATA_WIDTH_10                 (0x01<<11)
#define  RAW_DATA_WIDTH_12                 (0x02<<11)
#define  YUV_OUTPUT_422                    (0x00<<16)
#define  YUV_OUTPUT_420                    (0x01<<16)
#define  OUTPUT_420_ORDER_EVEN             (0x00<<17)
#define  OUTPUT_420_ORDER_ODD              (0x01<<17)
#define  RAWD_DATA_LITTLE_ENDIAN           (0x00<<18)
#define  RAWD_DATA_BIG_ENDIAN              (0x01<<18)
#define  UV_STORAGE_ORDER_UVUV             (0x00<<19)
#define  UV_STORAGE_ORDER_VUVU             (0x01<<19)
/*CIF_CIF_SCL_CTRL*/
#define ENABLE_SCL_DOWN                    (0x01<<0)
#define DISABLE_SCL_DOWN                   (0x00<<0)
#define ENABLE_SCL_UP                      (0x01<<1)
#define DISABLE_SCL_UP                     (0x00<<1)
#define ENABLE_YUV_16BIT_BYPASS            (0x01<<4)
#define DISABLE_YUV_16BIT_BYPASS           (0x00<<4)
#define ENABLE_RAW_16BIT_BYPASS            (0x01<<5)
#define DISABLE_RAW_16BIT_BYPASS           (0x00<<5)
#define ENABLE_32BIT_BYPASS                (0x01<<6)
#define DISABLE_32BIT_BYPASS               (0x00<<6)
extern unsigned long rk_cif_grf_base;
extern unsigned long rk_cif_cru_base;
#define MIN(x,y)   ((x<y) ? x: y)
#define MAX(x,y)    ((x>y) ? x: y)
#define RK_SENSOR_24MHZ      24*1000*1000          /* MHz */
#define RK_SENSOR_48MHZ      48
#define __raw_readl(p)          (*(unsigned int *)(p))
#define __raw_writel(v,p)     (*(unsigned int *)(p) = (v))
#define write_cif_reg(base,addr, val)  __raw_writel(val, addr+(base))
#define read_cif_reg(base,addr) __raw_readl(addr+(base))
#define mask_cif_reg(addr, msk, val)    write_cif_reg(addr, (val)|((~(msk))&read_cif_reg(addr)))
static u32 CRU_PCLK_REG30;
static u32 CRU_CLK_OUT;
static u32 clk_cif_out_src_gate_en;
static u32 CRU_CLKSEL29_CON;
static u32 cif0_clk_sel;
static u32 ENANABLE_INVERT_PCLK_CIF0;
static u32 DISABLE_INVERT_PCLK_CIF0;
static u32 ENANABLE_INVERT_PCLK_CIF1;
static u32 DISABLE_INVERT_PCLK_CIF1;
static u32 CHIP_NAME;
#define write_cru_reg(addr, val)            __raw_writel(val, addr+RK_CRU_VIRT)
#define read_cru_reg(addr)                  __raw_readl(addr+RK_CRU_VIRT)
#define mask_cru_reg(addr, msk, val)        write_cru_reg(addr,(val)|((~(msk))&read_cru_reg(addr)))
#define rk3368_write_cru_reg(addr, val)            __raw_writel(val, addr+rk_cif_cru_base)
#define rk3368_read_cru_reg(addr)                  __raw_readl(addr+rk_cif_cru_base)
#define rk3368_mask_cru_reg(addr, msk, val)        rk3368_write_cru_reg(addr,(val)|((~(msk))&rk3368_read_cru_reg(addr)))
#define CAM_WORKQUEUE_IS_EN()   (true)
#define CAM_IPPWORK_IS_EN()     (false)/*((pcdev->zoominfo.a.c.width != pcdev->icd->user_width) || (pcdev->zoominfo.a.c.height != pcdev->icd->user_height))*/
#define IS_CIF0()        (true)/*(pcdev->hostid == RK_CAM_PLATFORM_DEV_ID_0)*/
#if (CONFIG_CAMERA_SCALE_CROP_MACHINE == RK_CAM_SCALE_CROP_IPP)
#define CROP_ALIGN_BYTES (0x03)
#define CIF_DO_CROP 0
#elif (CONFIG_CAMERA_SCALE_CROP_MACHINE == RK_CAM_SCALE_CROP_ARM)
#define CROP_ALIGN_BYTES (0x0f)
#elif (CONFIG_CAMERA_SCALE_CROP_MACHINE == RK_CAM_SCALE_CROP_RGA)
#elif(CONFIG_CAMERA_SCALE_CROP_MACHINE == RK_CAM_SCALE_CROP_PP)
#define CROP_ALIGN_BYTES (0x0F)
#define CIF_DO_CROP 1
#endif
*v0.1.0 : this driver is 3.10 kernel driver;
        copy and updata from v0.3.0x19;
        support rk312x;
*v0.1.1:
         1. spin lock in struct rk_cif_clk is not neccessary,and scheduled func clk_get called in this spin lock scope
            cause warning, so remove this spin lock .
*v0.1.2:
         1. rk3126 and rk3128 use different dts file.
*v0.1.3:
         1. i2c 1 and wifi use the common io in rk3128,so just enable i2c1 in rk3126 dts file
*v0.1.4:
         1. When cif was at work, the aclk is closed ,may cause bus abnormal ,so sleep 100ms before close aclk
*v0.1.5:
           1. Improve the code to support all configuration.reset,af,flash...
*v0.1.6:
         1. Delete SOCAM_DATAWIDTH_8 in SENSOR_BUS_PARAM parameters,it conflict with V4L2_MBUS_PCLK_SAMPLE_FALLING.
*v0.1.7:
         1. Add  power and powerdown controled by PMU.
*v0.1.8:
         1. Support front and rear camera support are the same.
*v0.1.9:
         1. Support pingpong mode.
         2. Fix cif_clk_out cannot close which base on XIN24M and cannot turn to 0
         3. Move Camera Sensor Macro from rk_camera.h to rk_camera_sensor_info.h
         4. Support flash control when preview size == picture size
*v0.1.a:
         1. Support rk3288 cif driver
         2. Query and upload iommu info
*v0.1.b:
         1. Vpu_service compatible has change ,fix it.
*v0.1.c:
         1. setting cif capture en bit can't stop cif really,reset cif instead.
*v0.1.d:
         1. use of_find_node_by_name to get vpu node instead of of_find_compatible_node
*v0.1.e:
         1. support focus mode.
*v0.1.f:
         1. focus mode have some bug,fix it.
*v0.2.0:
        1. support rk3368.
#define RK_CAM_VERSION_CODE KERNEL_VERSION(0, 2, 0)
static int version = RK_CAM_VERSION_CODE;
module_param(version, int, S_IRUGO);
/* limit to rk29 hardware capabilities */
#define RK_CAM_BUS_PARAM   (V4L2_MBUS_MASTER |\
                V4L2_MBUS_HSYNC_ACTIVE_HIGH |\
                V4L2_MBUS_HSYNC_ACTIVE_LOW |\
                V4L2_MBUS_VSYNC_ACTIVE_HIGH |\
                V4L2_MBUS_VSYNC_ACTIVE_LOW |\
                V4L2_MBUS_PCLK_SAMPLE_RISING |\
                V4L2_MBUS_PCLK_SAMPLE_FALLING|\
                V4L2_MBUS_DATA_ACTIVE_HIGH |\
                V4L2_MBUS_DATA_ACTIVE_LOW|\
                SOCAM_DATAWIDTH_8|SOCAM_DATAWIDTH_10|\
                SOCAM_MCLK_24MHZ |SOCAM_MCLK_48MHZ)
#define RK_CAM_W_MIN        48
#define RK_CAM_H_MIN        32
#define RK_CAM_W_MAX        3856                /* ddl@rock-chips.com : 10M Pixel */
#define RK_CAM_H_MAX        2764
#define RK_CAM_FRAME_INVAL_INIT      0
#define RK_CAM_FRAME_INVAL_DC        0          /* ddl@rock-chips.com :  */
#define RK30_CAM_FRAME_MEASURE       5
extern void videobuf_dma_contig_free(struct videobuf_queue *q, struct videobuf_buffer *buf);
extern dma_addr_t videobuf_to_dma_contig(struct videobuf_buffer *buf);
/* buffer for one video frame */
struct rk_camera_buffer
    /* common v4l buffer stuff -- must be first */
    struct videobuf_buffer vb;
    enum v4l2_mbus_pixelcode    code;
    int            inwork;
enum rk_camera_reg_state
    Reg_Invalidate,
    Reg_Validate
struct rk_camera_reg
    unsigned int cifCtrl;
    unsigned int cifCrop;
    unsigned int cifFs;
    unsigned int cifIntEn;
    unsigned int cifFmt;
    unsigned int cifVirWidth;
    unsigned int cifScale;
/*    unsigned int VipCrm;*/
    enum rk_camera_reg_state Inval;
struct rk_camera_work
    struct videobuf_buffer *vb;
    struct rk_camera_dev *pcdev;
    struct work_struct work;
    struct list_head queue;
    unsigned int index;
struct rk_camera_frmivalenum
    struct v4l2_frmivalenum fival;
    struct rk_camera_frmivalenum *nxt;
struct rk_camera_frmivalinfo
    struct soc_camera_device *icd;
    struct rk_camera_frmivalenum *fival_list;
struct rk_camera_zoominfo
    struct semaphore sem;
    struct v4l2_crop a;
    int vir_width;
    int vir_height;
    int zoom_rate;
#if CAMERA_VIDEOBUF_ARM_ACCESS
struct rk29_camera_vbinfo
    unsigned long phy_addr;
    void __iomem *vir_addr;
    unsigned int size;
#endif
struct rk_camera_timer{
    struct hrtimer timer;
    bool istarted;
struct rk_cif_clk
    /************must modify start************/
    struct clk *pd_cif;
    struct clk *aclk_cif;
    struct clk *hclk_cif;
    struct clk *cif_clk_in;
    struct clk *cif_clk_out;
    /************must modify end************/
   // spinlock_t lock;
    bool on;
struct rk_cif_crop
    spinlock_t lock;
游客
社区居民忠实会员社区劳模最爱沙发终身成就奖优秀斑竹奖
发表于 2016-10-27 09:01:49 | 显示全部楼层
发表于 2016-11-29 21:28:45 | 显示全部楼层
无私的你很好啊,好人
