查看: 7594|回复: 38
[Allegro16.6以下] 比亚迪手机,Intel Atom+X_GOLD7160G+PMB5742 win10手机 PCB和原理图
    12万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2017-9-24 11:03:43 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    之前已经发过一个版本了。 和这个文件区别非常小。 http://bbs.ntpcb.com/read.php?tid=90388
    如果之前有下载了。就不要下载这个了。
    ANT2401ANT_3_ANT-3_2MM_H2U14W1H1A0100H2U14W1H1A0100ANT-3_2MM
    ANT_J1401J0_P-JS-TSB25_P-JS-TSB25_P-JS-TSB25P-JS-TSB25
    ANT_J1402J0_P-JS-TSB25_P-JS-TSB25_P-JS-TSB25P-JS-TSB25
    ANT_J2001J0_P-JS-TS-14_P-JS-TS-14_P-JS-TS-14P-JS-TS-14
    ANT_J2002J0_P-JS-TS-14_P-JS-TS-14_P-JS-TS-14P-JS-TS-14
    ANT_J2003J0_P-JS-TS-14_P-JS-TS-14_P-JS-TS-14P-JS-TS-14
    ANT_J2004ANT_3+1_ARAF0009-P002A_ARAF0009ARAF0009-P002AARAF0009-P002A
    ANT_J2005ANT_3+1_ARAF0009-P002A_ARAF0009ARAF0009-P002AARAF0009-P002A
    ANT_J2006J0_P-JS-TS-08_P-JS-TS-08_P-JS-TS-08P-JS-TS-08
    ANT_J2007J0_P-JS-TS-08_P-JS-TS-08_P-JS-TS-08P-JS-TS-08
    ANT_J2008J0_P-JS-TS-08_P-JS-TS-08_P-JS-TS-08P-JS-TS-08
    ANT_J2301ANT_2_RF-2_6X3-1N_8519A0000A008519A0000A00RF-2_6X3-1N
    CN1904SIM_8+4_SF56S006V4A_SIM-16X14_4SF56S006V4ASIM-16X14_4-6N
    CON2601TP_3_TP-60P13_8X3_2-41N_TP_5051TP_50515-041TP-60P13_8X3_2-41N
    CON2701TP_1_TP-60P13_8X3_2-41N_TP_5051TP_50515-041TP-60P13_8X3_2-41N
    CON2702TP_2_TP-60P13_8X3_2-41N_TP_5051TP_50515-041TP-60P13_8X3_2-41N
    CON2901BAT_0_SP-7_65X6_7-2N_SPKSPKSP-7_65X6_7-2N
    CON3001AXT524124_YT2_CON40P7_3X3-24N_MAXT524124CON40P7_3X3-24N_M_MAIN
    CON3101CN_24+4_AXT52124_F_1_CON40P7_3XAXT524124CON40P7_3X3-24N_M_SUB
    CON3301CN_5+4_YUSB0005-K001_0_USB_5N_U3DF005S-7L300CR001USB_5N_UB120
    CON3402TF_9+10_CH1S-111-H-N_TF-13_8X15CH1S-111-H-NTF-13_8X15_35-10N
    D2601DIODESCHOTTKY_SC79-SS2030FL_SSSS2030FL_30V_2ASC79-SS2030FL
    ED1201DIOD,ESD,0402,LXES15AAA1-100_ESLXES15AAA1-100ESD-AIES12U020R2
    ED1202DIOD,ESD,0402,LXES15AAA1-100_ESLXES15AAA1-100ESD-AIES12U020R2
    ED1203DIOD,ESD,0402,LXES15AAA1-100_ESLXES15AAA1-100ESD-AIES12U020R2
    ED1901DIOD,ESD,SM,ESDAVLC8,0201,8.5V_LXES15AAA1-100ESD-AIES12U020R2
    ED1902DIOD,ESD,SM,ESDAVLC8,0201,8.5V_LXES15AAA1-100ESD-AIES12U020R2
    ED1903DIOD,ESD,SM,ESDAVLC8,0201,8.5V_LXES15AAA1-100ESD-AIES12U020R2
    ED1904DIOD,ESD,SM,ESDAVLC8,0201,8.5V_LXES15AAA1-100ESD-AIES12U020R2
    ED1905DIOD,ESD,SM,ESDAVLC8,0201,8.5V_LXES15AAA1-100ESD-AIES12U020R2
    ED1906DIOD,ESD,SM,ESDAVLC8,0201,8.5V_LXES15AAA1-100ESD-AIES12U020R2
    ED2001DIOD,ESD,0402,LXES15AAA1-100__1DNPESD-AIES12U020R2
    ED2002DIOD,ESD,0402,LXES15AAA1-100__1DNPESD-AIES12U020R2
    ED2101DIODE BI-DIRTRIG_ESD_AEM_MURATDNPESD_AEM_MURATA
    ED2501DIOD,ESD,0402,LXES15AAA1-100__1DNPESD-AIES12U020R2
    ED2502DIOD,ESD,0402,LXES15AAA1-100__1DNPESD-AIES12U020R2
    ED3505DIOD,ESD,SM,ESDAVLC8,0201,8.5V_LXES15AAA1-100ESD-AIES12U020R2
    EU1601IC,74AUP1G07GF,LOG,LCC6,1G_BUFF74AUP1G07GFSON35P1X1-6N
    FB1901FERBD,0402,120OHM_100MHZ,1.3A_F120 Ohm@100MHzFB0402
    FB1902FERBD,0402,120OHM_100MHZ,1.3A_1DNPFB0402
    FB1903FERBD,0402,120OHM_100MHZ,1.3A_F120 Ohm@100MHzFB0402
    FB2001FERBD,0402,120OHM_100MHZ,1.3A_2120 Ohm@100MHzFB0402
    FB2002FERBD,0603,120OHM_100MHZ,2.0A_F120ohm@100MHzFB0603
    FB2201FERBD,0402,600OHM_100MHZ,300MA_600Ohm@100MHzFB0402
    FB2202FERBD,0402,600OHM_100MHZ,300MA_600Ohm@100MHzFB0402
    FB2303FERBD,0402,600OHM_100MHZ,300M_110ohm@100MHzFB0402
    FB2401FERBD,0402,600OHM_100MHZ,300MA_600Ohm@100MHzFB0402
    FB2402FERBD,0402,120OHM_100MHZ,1.3A_F120 Ohm@100MHzFB0402
    FB2403FERBD,0402,600OHM_100MHZ,300MA_600Ohm@100MHzFB0402
    FB2404FERBD,0402,120OHM_100MHZ,1.3A_F120 Ohm@100MHzFB0402
    FB2405FERBD,0402,120OHM_100MHZ,1.3A_F120 Ohm@100MHzFB0402
    FB2701FB0402L_FB0402L_600R600RFB0402L
    FB2702FB0402L_FB0402L_600R600RFB0402L
    FB2801FB0402L_FB0402L_600R600RFB0402L
    FB2802FERBD,0402,120OHM_100MHZ,1.3A_3BLM15AG121SN1DFB0402
    FB2803FERBD,0402,120OHM_100MHZ,1.3A_3BLM15AG121SN1DFB0402
    FB2804FERBD,0402,120OHM_100MHZ,1.3A_3BLM15AG121SN1DFB0402
    FB2805FERBD,0402,120OHM_100MHZ,1.3A_3BLM15AG121SN1DFB0402
    FB2806FB0402L_FB0402L_600R600RFB0402L
    FB2807FB0402L_FB0402L_600R600RFB0402L
    FB2901FERBD,0402,120OHM_100MHZ,1.3A_4PZ1608D601-R50TFFB0603
    FB2902FERBD,0402,120OHM_100MHZ,1.3A_4PZ1608D601-R50TFFB0603
    FB3001FERBD,0402,120OHM_100MHZ,1.3A_3BLM15AG121SN1DFB0402
    FB3002FERBD,0402,120OHM_100MHZ,1.3A_3BLM15AG121SN1DFB0402
    FB3102FERBD,0402,120OHM_100MHZ,1.3A_3BLM15AG121SN1DFB0402
    FB3103FERBD,0402,120OHM_100MHZ,1.3A_3BLM15AG121SN1DFB0402
    FB3301COMCHOKE_1_CHOKE_4P_DNP_DNPCHOKE_4P
    FB3302FERBD,0402,120OHM_100MHZ,1.3A_F120 Ohm@100MHzFB0402
    FB3401FERBD,0402,120OHM_100MHZ,1.3A_3BLM15AG121SN1DFB0402
    H1TP_0_H3_1X5_2MM-PTH_H3_1X5_2MM-H3_1x5_2MM-PTHH3_1X5_2MM-PTH
    H2TP_0_H3_1X5_2MM-PTH_H3_1X5_2MM-H3_1x5_2MM-PTHH3_1X5_2MM-PTH
    H3TP_0_H3_1X5_2MM-PTH_H3_1X5_2MM-H3_1x5_2MM-PTHH3_1X5_2MM-PTH
    H4TP_0_H3_1X5_2MM-PTH_H3_1X5_2MM-H3_1x5_2MM-PTHH3_1X5_2MM-PTH
    H5TP_0_H3_1X5_2MM-PTH_H3_1X5_2MM-H3_1x5_2MM-PTHH3_1X5_2MM-PTH
    H6TP_0_H3_1X5_2MM-PTH_H3_1X5_2MM-H3_1x5_2MM-PTHH3_1X5_2MM-PTH
    H7TP_0_H3_1X5_2MM-PTH-1_H3_1X5_2MH3_1x5_2MM-PTH-1H3_1X5_2MM-PTH-1
    J1201BAT_6+2_CON100P6_4X4_3-6N_ACES-ACES-88231-0600CON100P6_4X4_3-6N
    J2006MM8030-2610B/RJ3/RK0_3_MM8030-2MM8030-2610B/RJ3/RK0MM8030-2610RK0
    J2007MM8030-2610B/RJ3/RK0_3_MM8030-2MM8030-2610B/RJ3/RK0MM8030-2610RK0
    J2101J0_P-JS-TSB25_P-JS-TSB25_P-JS-TSB25P-JS-TSB25
    J2301MM8030-2610B/RJ3/RK0_1_MM8030-2MM8030-2610B/RJ3/RK0MM8030-2610RK0
    J2401MM8030-2610B/RJ3/RK0_2_MM8030-2MM8030-2610B/RJ3/RK0MM8030-2610RK0
    J2501J0_P-JS-TSB25_P-JS-TSB25_P-JS-TSB25P-JS-TSB25
    J2502J0_P-JS-TSB25_P-JS-TSB25_P-JS-TSB25P-JS-TSB25
    J2903AUDIOJACK_DA300-K2-01A_AUDIO-1DA300-K2-01AAUDIO-12_5X6_4-5N
    J3501CON40,BTB,SM,.4MM,AXT440164,HDR2x20 BTBheader,AXT440164CON40P1_75X11_4_40N_P
    Q1402G39961-001SSM6J501NULCC6_DIE_ODD_2X2
    Q1403Q UPA650NEC_0_SOT23-6-LP6205_PP4402FAGSOT23-6-LP6205
    Q1404Q UPA650NEC_0_SOT23-6-LP6205_PP4402FAGSOT23-6-LP6205
    Q2501SSM3K36MFV_2_SOT_31X47_DNPDNPSOT_31X47
    Q2502SSM3K36MFV_1_SOT_31X47_SSM3K36MSSM3K36MFVSOT_31X47
    Q2601NCHMOSFET_RUE003N02_1_MOS-0_8XRUE003N02MOS-0_8X1_6-3N
    Q3301Q UPA650NEC_0_SOT23-6-LP6205_PP4402FAGSOT23-6-LP6205
    Q3401EM6K31_MOS-1_6X1_2-6N_EM6K31EM6K31MOS-1_6X1_2-6N
    Q3402NCHMOSFET_RUE003N02_1_MOS-0_8XRUE003N02MOS-0_8X1_6-3N
    Q3403NCHMOSFET_RUE003N02_1_MOS-0_8XRUE003N02MOS-0_8X1_6-3N
    RNT1801THERMISTOR,0201,1%,NTC,10K_R02010K 1%R0201
    RNT2001THERMISTOR,0201,1%,NTC,10K_R0_110KR0201
    RNT2002THERMISTOR,0201,3%,NTC,22K_R020DNPR0201
    RNT2003THERMISTOR,0201,1%,NTC,10K_R0_110KR0201
    RT1201THERMISTOR,0201,1%,NTC,10K_R0_110KR0201
    RT1202THERMISTOR,0201,1%,NTC,10K_R0_110KR0201
    RT1203THERMISTOR,0201,1%,NTC,10K_R0_110KR0201
    RT2001RESD,0201,5%,1/20W,0_R0201_DNP_DNPR0201
    SW3401SW_4_SW_NTC325_NTC325-EA1J-A160NTC325-EA1J-A160TSW_NTC325
    SW3402SW_4_SW_NTC325_NTC325-EA1J-A160NTC325-EA1J-A160TSW_NTC325
    SW3403SW_4_SW_NTC325_NTC325-EA1J-A160NTC325-EA1J-A160TSW_NTC325
    U301TNG_2.00_EXT_CUST_1P02_BGA796_PIntel Atom processorZ34xx Rev 1.02BGA796_P200
    U601IC,74AUP1G04,LOG,LCC6,1G_BUFF_S74AUP1G04GFSON35P1X1-6N
    U1001IC,BASINCOVE,TI,1.0_BGA168_P4MMBASIN COVE 1.0BGA168_P4MM_5P12X6P75
    U1101IC,TS3A24159,BGA10,DUALSPDT_0_BTS3A24159YZPRBGA50P1_89X1_39-10N
    U1301BQ27441DRZR-G1A_3_SO40P2_5X4-12BQ27441DRZR-G1ASO40P2_5X4-12N
    U1401BQ51013BYFPR_2_BGA40P1_88X3-28NBQ51010BYFPRBGA40P1_88X3-28N
    U1402BQ24261_QFN50P4X4-24N_BQ24261RGBQ24261RGERQFN50P4X4-24N
    U1501IC,EMMC,THGBM5G8A4JBAIM,BGA169_THGBM5G8A4JBAIMBGA169_12X16_H1P0
    U1601IC,X-GOLD716G_E100,BGA330,BSBNDX_GOLD7160G_E100BGA330_P4MM_9X9P5
    U2001IC,SM4G_E250,LCC153,TRNCVR_LCC1PMB5742LCC153_11P15X10P7
    U2002SWITCH,RF1604,LCC12,BRDBND_LCC1DNPLCC12_2P5SQ_NS
    U2003SWITCH,RF1604,LCC12,BRDBND_LCC1DNPLCC12_2P5SQ_NS
    U2004IC,RF8085E4.1,LCC36,PWR_AMP_LCCRF8085E4.1LCC36_NONC_6X8MM
    U2005IC,RF8007IE2.2,LCC10,PWR_AMP_LCRF8007I_E2.2LCC10_P505MM_NONC_2P1X2P6
    U2006IC,LP3983,BGA5,CMOS_REG_2P5V_BGLP3983ITLX-2.5BGA-LP3983-5N
    U2007IC,RF8081TR7X,BGA28,PWR_AMP_BGARF8081TR7XBGA-RF8081-28N
    U2101IQS128_1_TSOT23_6-95P300X170_IQIQS128TSOT23_6-95P300X170
    U2201IC,BC4339,BGA145,HARDY_BGA40P4_BCM4339XKUBGBGA40P4_87X5_413-145N
    U2301TDP-2012-205-WA_1_TDP-2_05X1_3-TDP-2012-205-WATDP-2_05X1_3-8N
    U2302SKY13317-373LF_0_SKY13317-373LFSKY13317-373LFSKY13317-373LF
    U2303SKY13351-378LF_0_SKY13351-378LFSKY13351-378LFSKY13351-378LF
    U2304FILTER_ACPF-7124_ACPF-7124_ACPFACPF-7124ACPF-7124
    U2402IC,BCM4752,BGA30,GNSS_RECEIVER_BCM4752IUB2GBGA0_4P2_07X2_47MM-30P
    U2403IC,SAFFB1G58KA0F0,LCC5,SAW_FLTRSAFFB1G58KA0F0ASAW-1_1X0_9-5N
    U2404IC,SAFFB1G58KA0F0,LCC5,SAW_FLTRSAFFB1G58KA0F0ASAW-1_1X0_9-5N
    U2405BGU7005_1_SON50P1X1_45-6N_BGU70BGU7005SON50P1X1_45-6N
    U2501G81541-003PN5472A2EV/C20803BGA49_P5MM_4X4P3
    U2502G81447-002STG_SELCC8_1MM_4X4P2
    U2601ECMF02-2BF3_BGA40P1_23X0_83-5N_ECMF02-2BF3BGA40P1_23X0_83-5N
    U2602ECMF02-2BF3_BGA40P1_23X0_83-5N_ECMF02-2BF3BGA40P1_23X0_83-5N
    U2603ECMF02-2BF3_BGA40P1_23X0_83-5N_ECMF02-2BF3BGA40P1_23X0_83-5N
    U2604ECMF02-2BF3_BGA40P1_23X0_83-5N_ECMF02-2BF3BGA40P1_23X0_83-5N
    U2605ECMF02-2BF3_BGA40P1_23X0_83-5N_ECMF02-2BF3BGA40P1_23X0_83-5N
    U2606TPS22908YZTR_1_BGA50P0_918X0_91TPS22907YZTRBGA50P0_918X0_918-4N
    U2608TPS61165DRVR_1_QFN2X2_6PIN_TPS6TPS61165DRVRQFN2X2_6PIN_TPS61165DRVR
    U2701S7508_BGA138_1_BGA0_5P5X8_5MM-1S7508_BGA138BGA0_5P5X8_5MM-138N
    U2801IC,WM8958E,BGA72,AUDIO_CODEC_BGWM8958E- AUDIO CODECBGA72_P5MM_4P541X4P283_P738H
    U2901MIC,DMO-D100R26-K1_0_MIC_5P_3P1MIC,DMO-D100R26-K1_0MIC_5P_3P1X4P1
    U2902EMIF02-MIC03F2_CSP5_P5MM_EMIF02EMIF02-MIC03F2CSP5_P5MM
    U3001ACFT4A2G900E_0_F0_85X0_65-4N_ACACFT4A2G900EF0_85X0_65-4N
    U3002ACFT4A2G900E_0_F0_85X0_65-4N_ACACFT4A2G900EF0_85X0_65-4N
    U3003ACFT4A2G900E_0_F0_85X0_65-4N_ACACFT4A2G900EF0_85X0_65-4N
    U3004TLV71128518DDSER_6_SON50P150X15TLV71128518DDSER_6SON50P150X150-6N
    U3101TLV71128518DDSER_SON50P150X150-TLV71128518DDSERSON50P150X150-6N
    U3103ACFT4A2G900E_F0_85X0_65-4N_ACFTACFT4A2G900EF0_85X0_65-4N
    U3104ACFT4A2G900E_F0_85X0_65-4N_ACFTACFT4A2G900EF0_85X0_65-4N
    U3201LIS3DH_0_LGA50P300X300_16N_LSM3LSM303DLGA50P300X300_16N
    U3202BH1721FVC_SOT-5P-WSOF5_BH1721FVBH1721FVCSOT-5P-WSOF5
    U3203L3GD20_0_QFN65P400X400_16N_L3GDL3GD20QFN65P400X400_16N
    U3301IC,TUSB1211,BGA36,USB_XCVR_BGA3TUSB1211BGA36_0P5_40H
    U3302MAX809SD_1_SOT-23_RT9818C-27GVRT9818C-27GVSOT-23
    U3401IP4855CX25_0_BGA40P2_04X2_04-25IP4855CX25BGA40P2_04X2_04-25N
    Y401XTAL,2X2P5,19.20MHZ,4PIN_Y-3_2X19.2MHzY-3_2X2_5-4N
    Y1201XTAL,FC-12M,32.7680KHZ,2PIN,SM_CC7V-T1A_32.768kHz_9.0pFCC7V-T1A
    Y1701XTAL,FC-12M,32.7680KHZ,2PIN,S_1DNPCC7V-T1A
    Y2001OSC,TCXO,26MHZ,4P,7Z26021001_0_26MHz,10pF,10K,+/-1.5PPMY2_5X2-4N
    Y2301XTAL,1P2X1P6,37_0.400MHZ,TXC_Y-37.4MHzY-2_5X2-4N
    Y2401OSC,TCXO,26MHZ,4P,1612A_0_Y2_5X1XXB26000CAAY2_5X2-4N
    重要提示:PCB作品文件展下载说明
    12万
    管理员
     楼主| 发表于 2017-9-24 11:07:52 | 显示全部楼层
    金币下载
    GOLD7160G_brd.7z (4.62 MB, 下载次数: 26)
    GOLD7160G_dsn.7z (1.66 MB, 下载次数: 33)
    前天 08:13
  • 签到天数: 233 天
    你必须非常努力才能显
    发表于 2017-9-24 11:24:57 | 显示全部楼层
    比亚迪不是做汽车的吗,还生产手机?
    发表于 2017-9-24 12:10:46 | 显示全部楼层
    比亚迪都有手机了?见识下
    发表于 2017-9-24 12:18:24 | 显示全部楼层
    社区居民终身成就奖特殊贡献奖忠实会员社区明星宣传大使奖
    发表于 2017-9-24 12:22:05 | 显示全部楼层
    又来精品了!Intel Atom方案做的手机应该很少
    活着就是一种挑战!
  • 签到天数: 258 天
    发表于 2017-9-24 14:09:00 | 显示全部楼层
  • 签到天数: 167 天
    发表于 2017-9-24 15:00:44 | 显示全部楼层
    发表于 2017-9-24 15:28:10 | 显示全部楼层
    第一次听说比亚迪做手机了,牛逼
    终身成就奖社区居民
    发表于 2017-9-24 16:16:20 | 显示全部楼层
