查看: 17568|回复: 93
[AD格式] Arria10_mini PC原理图与PCB文件共享下载
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
发表于 2018-11-4 00:43:32 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
主板16层设计,八个DDR4对贴8层设计
主板:
DDR4:
WIFI:
CommentDescriptionDesignatorFootprintLibRefQuantity
FA-12825.0000MB-CRange Crystal Unit,25 MHz, -40 to 85 degC, 4-Pin SMD, RoHS, Tape and ReelY1, Y2, Y3, Y4EPSON-FA-128_VCMP-1695-00001-34
ASE2-33.000MHZ-ETCMOS Compatible SMDCrystal Oscillator, 33 MHz, 2.5 V, -20 to 70 degC, 4-Pin SMD, RoHS, Tape andReelX1, Y5ABRA-ASE2_VCMP-1688-00001-12
FT601Q32 Bit USB 3.0 toFIFO Bridge, 5 Gbps, 3 to 3.6 V, -40 to 85 degC, 76-Pin QFN, Pb-FreeU33FTDI-QFN-76_MCMP-1723-00001-11
516FHA000132AAGDual FrequencyVoltage-Controlled Crystal Oscillator (VCXO), LVDS, 2.5 V, 100 KHz to 250MHz, -40 to 85 degC, 6-Pin DFN, RoHS, TrayU32SLAB-DFN-6-5000X7000DE_A_VCMP-1706-00001-11
ICS83054AGILFSingle-EndedMultiplexer, 2.375 to 3.465 V, -40 to 85 degC, 16-Pin TSSOP, RoHS, TubeU31IDT-TSSOP-16_MCMP-1699-00001-11
Si5338C-B03798-GMI2C-ProgrammableAny-Frequency, Any-Output Quad Clock Generator, 1.8 / 2.5 / 3.3 V, 0.16 to200 MHz Output, -40 to 85 degC, 24-Pin QFN, RoHSU30SLAB-QFN-24-2550x2550TP_VCMP-1706-00005-11
Si52112-A1-GM2PCI-Express Gen 1Dual Output Clock Generator, 3.13 to 3.46 V, -40 to 85 degC, 10-Pin TDFN,RoHS, TubeU29SLAB-TDFN-10_LCMP-1706-00007-11
Si5338B-B03799-GMI2C-ProgrammableAny-Frequency, Any-Output Quad Clock Generator, 1.8 / 2.5 / 3.3 V, 0.16 to350 MHz Output, -40 to 85 degC, 24-Pin QFN, RoHSU27, U28SLAB-QFN-24-2550x2550TP_VCMP-1706-00002-12
EPCQL1024F24INEPCQ-L SerialConfiguration Device, 1.8 V, -40 to 85 degC, 24-Pin FBGA, RoHS, TrayU26ALTR-FBGA24_A-130CMP-1689-00001-11
LTC3026EDD-1#PBF1.5 A Low InputVoltage VLDO Linear Regulator, Boost Converter Disabled, Require 5 V ExternalSupply, 1.14 to 5.5 V Vin, Adjustable Vout, 10-pin SON (DD-10), -40 to 125degC, Pb-FreeU25LT-DD-10_VCMP-0476-00185-21
LTM4676IY#PBFDual 13 A or Single26 A uModule Regulator with Digital Power System Management, 4.5 to 26.5 VInput, 0.5 to 5.4 V Output, -40 to 125 degC, 144-Ball BGA, RoHS, TrayU23LT-BGA-144-05-08-1920_VCMP-1701-00002-31
LTC3025EDC-1#PBF500 mA MicropowerVLDO Linear Regulator, 0.9 to 5.5 V Vin, Adjustable Vout, 6-pin SON (DC6-6),-40 to 125 degC, Pb-FreeU19, U22LT-DC6-6_VCMP-0476-00124-42
SG-310SDF25.0000M-B3Crystal Oscillator(SPXO), 2.5 V, 25 MHz, -20 to 70 degC, 4-Pin SMD, RoHS, Tape and ReelU18, U21, U24EPSON-SG-310-4_VCMP-1695-00002-33
88E1111-B2-NDC2C000Integrated10/100/1000 Ultra Gigabit Ethernet Transceiver, Commercial Grade, 96-Pin QFN,RoHSU17, U20MARV-NDC96CMP-1702-00002-32
MAX14523AATA+AdjustableCurrent-Limit Switch, 1.7 to 5.5 V, -40 to 125 degC, 8-Pin TDFN (T833+2),RoHSU16MAXM-T833+2_VCMP-0247-00012-31
MT40A512M16LY-107E8 Gb DDR4 SDRAM, 512Meg x 16, 1.2 V, 0 to 95 degC, 96-Ball FBGA (LY), RoHSU14, U15MICT-LY-96_ACMP-1718-00002-12
LT1389ACS8-1.25Nanopower PrecisionShunt Voltage Reference, 1.25 V, 0.05%, 10 ppm/degC, 0 to 70 degC, 8-Pin S8,TubeU13LT-S8-8_MCMP-1701-00004-21
EN2342QIPowerSoC Voltage ModeSynchronous PWM Buck with Integrated Inductor, 4 A, 4.5 to 14 V Input, 0.75to 5 V Output, -40 to 85 degC, 68-Pin QFN, RoHS, Tape and ReelU12ALTR-QFN-68_A-305_D1-210_VCMP-1689-00003-31
KSZ9031RNXCAGigabit EthernetTransceiver with RGMII Support, 1.14 to 1.26 V, 0 to 70 degC, 48-Pin QFN,RoHSU11MICL-QFN-48_VCMP-1337-00004-21
LTM4677IY#PBFDual 18 A or Single36 A uModule Regulator with Digital Power System Management, 4.5 to 16 VInput, 0.5 to 1.8 V Output, -40 to 125 degC, 144-Ball BGA, RoHS, TrayU10LT-BGA-144-05-08-1920_VCMP-1701-00001-11
TPS3700DDCRWindow Comparatorwith Internal Reference for Overvoltage and Undervoltage Detection, 1.8 to 18V, -40 to 125 degC, 6-Pin SOT (DDC), Green (RoHS & no Sb/Br), Tape andReelU9DDC0006A_MCMP-1708-00001-41
EN6337QIPowerSoC Voltage ModeSynchronous PWM Buck with Integrated Inductor, 2.5 to 6.6 V Input, -40 to 85degC, 38-Pin QFN, RoHS, Tape and ReelU6, U8ALTR-QFN-38_A-190_D1-193_VCMP-1689-00002-32
EN63A0QIPowerSoC HighlyIntegrated Synchronous Buck with Integrated Inductor, 2.5 to 6.6 V Input, -40to 85 degC, 76-Pin QFN, RoHS, Tape and ReelU3, U7ALTR-QFN-76_A-305_VCMP-1689-00005-32
EN6360QIPowerSoC HighlyIntegrated Synchronous DC-DC Buck with Integrated Inductor, 2.5 to 6.6 VInput, -40 to 85 degC, 68-Pin QFN, RoHS, Tape and ReelU2, U4, U5ALTR-QFN-68_A-305_VCMP-1689-00004-33
10AS066N3F40E2SGE2Arria 10 SX Family,588 I/O Pins, 16 Fractional PLLs, 1517-Pin FBGA, Speed Grade 2, ExtendedGrade, RoHSU1ALTR-FBGA1517_A-350CMP-1689-00006-31
416131160804WS-DISV 1.27 mm smallcompact SMD Dip Switch with top tapeSW2416131160804CMP-1433-00004-11
EG2207Slide Switch DPDT, 30V, -20 to 70 degC, 6-Pin THD, RoHS, BulkSW1ESWI-EG2207_VCMP-1696-00001-31
CRCW040212K1FKEDChip Resistor, 12.1KOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR299RESC1005X40X25LL05T05CMP-2002-08179-31
ERJ-2GEJ221XChip Resistor, 220Ohm, +/- 5%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR297, R298RESC1005X40X25LL05T05CMP-2002-00487-32
ERJ-2RKF4991XChip Resistor, 4.99KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR265, R289RESC1005X40X25NL05T05CMP-2002-00966-32
ERJ-2RKF4701XChip Resistor, 4.7KOhm, +/- 1%, 0.1 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR259, R261, R263,R264, R283, R285, R287, R288, R302, R303, R304, R305, R306, R307, R308, R309,R310, R312, R313, R332, R333, R334RESC1005X40X25LL05T05CMP-1665-00031-322
ERJ-2RKF2803XChip Resistor, 280KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Cut TapeR243RESC1005X40X25LL05T05CMP-2002-00835-31
RC0402JR-0739RLChip Resistor, 39Ohm, +/- 5%, 0.063 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR211, R212, R213,R214, R215, R216, R217, R218, R219, R220, R222, R224, R225, R226, R227, R228,R229, R230, R231, R236, R237, R238, R239, R240, R241RESC1005X40X25NL5T10CMP-2002-07994-225
ERJ-2RKF2001XChip Resistor, 2KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR210, R314RESC1005X40X25NL05T05CMP-2002-00758-32
ERJ-2RKF2400XChip Resistor, 240Ohm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR208, R209, R221,R223, R266, R267, R268, R269, R271, R290, R291, R292, R294, R296RESC1005X40X25NL05T05CMP-1665-00034-114
ERJ-2GEJ241xChip Resistor, 240Ohm, +/- 5%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR184, R185, R186,R187, R188, R189, R190, R191, R192, R193, R194, R195, R196, R197, R198, R199,R200, R201, R202, R203, R204, R205, R206RESC1005X40X25ML05T05CMP-2002-00493-323
ERJ-6RQF4R7VChip Resistor, 4.7Ohm, +/- 1%, 125 mW, -55 to 125 degC, 0805 (2012 Metric), RoHS, Tape and ReelR183RESC2013X70X40LL20T20CMP-1665-00033-11
ERJ-2RKF6812XChip Resistor, 68.1KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR182RESC1005X40X25LL05T05CMP-2002-01039-31
CRCW040230K1FKEDChip Resistor, 30.1KOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR181RESC1005X40X25LL05T05CMP-2002-08506-31
ERJ-2GEJ561xChip Resistor, 560Ohm, +/- 5%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR178RESC1005X40X25ML05T05CMP-2002-00557-31
ERJ-2RKF1432XChip Resistor, 14.3KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR177RESC1005X40X25LL05T05CMP-2002-00683-31
ERJ-2RKF4751XChip Resistor, 4.75KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR169, R172RESC1005X40X25ML05T05CMP-2002-00956-32
CRCW040222K6FKEDChip Resistor, 22.6KOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR167, R170, R171RESC1005X40X25LL05T05CMP-2002-08381-23
ERJ-2RKF1782XChip Resistor, 17.8KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR152RESC1005X40X25LL05T05CMP-2002-00732-31
ERJ-2RKF1651XChip Resistor, 1.65KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR150, R153, R154,R342RESC1005X40X25LL05T05CMP-2002-00716-34
ERJ-2RKF2552xChip Resistor, 25.5KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR113RESC1005X40X25NL05T05CMP-2002-00813-31
CMP-2002-00967Chip Resistor, 49.9KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR112RESC1005X40X25ML05T05CMP-2002-00967-21
ERJ-2RKF8662XChip Resistor, 86.6KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR110RESC1005X40X25ML05T05CMP-2002-01090-31
ERJ-2RKF8062XChip Resistor, 80.6KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR90, R174RESC1005X40X25ML05T05CMP-2002-01074-32
ERJ-2RKF1004XChip Resistor, 1MOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR88, R246, R247, R248RESC1005X40X25LL05T05CMP-2002-00609-34
ERJ-2RKF2003XChip Resistor, 200KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR86, R108RESC1005X40X25NL05T05CMP-2002-00760-32
CRCW0402137KFKEDChip Resistor, 137KOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR81RESC1005X40X25LL05T05CMP-2002-08193-31
ERJ-2RKF2403XChip Resistor, 240KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR80RESC1005X40X25NL05T05CMP-2002-00799-31
CRCW0402390KFKEDChip Resistor, 390KOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR78RESC1005X40X25LL05T05CMP-2002-08563-31
CRCW0402649KFKEDChip Resistor, 649KOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR76RESC1005X40X25LL05T05CMP-2002-00156-31
CRCW0402976KFKEDChip Resistor, 976KOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR73RESC1005X40X25ML05T05CMP-2002-00281-31
ERJ-2RKF5491XChip Resistor, 5.49KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR62, R79, R103RESC1005X40X25NL05T05CMP-2002-00990-33
CRCW0402191KFKEDChip Resistor, 191KOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR49, R63RESC1005X40X25LL05T05CMP-2002-08268-32
CSS2725FTL250Chip Resistor, 0.25mOhm, +/- 1%, 4 W, -55 to 225 degC, 2725 (6865 Metric), RoHS, Tape and ReelR42, R96STAC-CSS2725-099H_VCMP-1719-00001-22
ERJ-2RKF1202XChip Resistor, 12KOhm, +/- 1%, 0.1 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR37RESC1005X40X25ML05T05CMP-1665-00028-31
ERJ-2RKF2263XChip Resistor, 226KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR36RESC1005X40X25NL05T05CMP-2002-00784-31
CRCW04023K57FKEDChip Resistor, 3.57KOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR35, R48RESC1005X40X25NL05T05CMP-2002-08586-22
CRCW04021M78FKEDChip Resistor, 1.78MOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR32RESC1005X40X25ML05T05CMP-2002-08335-31
NRC04F49R9TRFChip Resistor, 49.9Ohm, +/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReel, Chip Resistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005Metric), RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to155 degC, 0402 (1005 Metric), RoHS, Tape and Reel, Chip Resistor, 39 Ohm, +/-5%, 0.063 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and Reel, ChipResistor, 39 Ohm, +/- 5%, 0.063 W, -55 to 155 degC, 0402 (1005 Metric), RoHS,Tape and Reel, Chip Resistor, 39 Ohm, +/- 5%, 0.063 W, -55 to 155 degC, 0402(1005 Metric), RoHS, Tape and Reel, Chip Resistor, 39 Ohm, +/- 5%, 0.063 W,-55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and Reel, Chip Resistor, 49.9Ohm, +/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReel, Chip Resistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005Metric), RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to155 degC, 0402 (1005 Metric), RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm,+/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and Reel,Chip Resistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric),RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155degC, 0402 (1005 Metric), RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/-1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and Reel, ChipResistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric),RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155degC, 0402 (1005 Metric), RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/-1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and Reel, ChipResistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric),RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155degC, 0402 (1005 Metric), RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/-1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and Reel, ChipResistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric),RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155degC, 0402 (1005 Metric), RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/-1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and Reel, ChipResistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric),RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155degC, 0402 (1005 Metric), RoHS, Tape and Reel, Chip Resistor, 49.9 Ohm, +/-1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and Reel, ChipResistor, 49.9 Ohm, +/- 1%, 0.06 W, -55 to 155 degC, 0402 (1005 Metric),RoHS, Tape and ReelR31, R87, R120, R232,R233, R234, R235, R249, R250, R251, R252, R253, R254, R255, R256, R260, R273,R274, R275, R276, R277, R278, R279, R280, R284, R300, R301RESC1005X35X25NL8T10CMP-1599-00001-2,CMP-1599-00001-2, CMP-1599-00001-2, CMP-2002-07994-2, CMP-2002-07994-2,CMP-2002-07994-2, CMP-2002-07994-2, CMP-1599-00001-2, CMP-1599-00001-2,CMP-1599-00001-2, CMP-1599-00001-2, CMP-1599-00001-2, CMP-1599-00001-2,CMP-1599-00001-2, CMP-1599-00001-2, CMP-1599-00001-2, CMP-1599-00001-2,CMP-1599-00001-2, CMP-1599-00001-2, CMP-1599-00001-2, CMP-1599-00001-2,CMP-1599-00001-2, CMP-1599-00001-2, CMP-1599-00001-2, CMP-1599-00001-2,CMP-1599-00001-2, CMP-1599-00001-227
ERJ-2RKF1000XChip Resistor, 100Ohm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR28, R30, R38, R40,R56, R58, R70, R72, R92, R94RESC1005X40X25LL05T05CMP-2002-00605-310
WSLP12061L000FEAChip Resistor, 0.001Ohm, +/- 1%, 1 W, -65 to 170 degC, 1206 (3216 Metric), RoHS, Tape and ReelR27, R55, R69, R83,R105RESC3216X89X104LL25T25CMP-1666-00018-25
ERJ-2GE0R00XChip Resistor, 0mOhm, +/- 5%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR26, R29, R41, R43,R54, R57, R59, R68, R71, R74, R85, R95, R97, R100, R107, R109, R141, R142,R143, R149, R155, R156, R157, R163, R166, R173, R245, R257, R258, R281, R282,R323, R326, R327, R335, R336, R337, R338RESC1005X40X25ML05T05CMP-2002-00429-338
CRCW0402160KFKEDChip Resistor, 160KOhm, +/- 1%, 63 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR24, R39, R52, R66,R93RESC1005X40X25ML05T05CMP-2002-08227-35
ERJ-2RKF1502XChip Resistor, 15KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR22, R50, R64, R91,R270, R293RESC1005X40X25ML05T05CMP-2002-00694-36
ERJ-2RKF3243XChip Resistor, 324KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR21RESC1005X40X25ML05T05CMP-2002-00868-21
ERJ-2RKF1002XChip Resistor, 10KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR7, R9, R23, R25,R33, R44, R45, R46, R51, R53, R60, R65, R67, R75, R82, R84, R98, R99, R101,R104, R106, R118, R119, R122, R123, R127, R140, R147, R148, R151, R158, R159,R160, R161, R162, R164, R165, R168, R175, R180, R262, R272, R286, R295, R311,R316, R320, R321, R322, R324, R325, R343RESC1005X40X25NL05T05CMP-2002-00607-352
ERJ-2RKF1001XChip Resistor, 1KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR6, R11, R117, R121,R138, R139, R315, R317, R318, R319, R328, R329, R330, R331, R339, R340, R341RESC1005X40X25LL05T05CMP-2002-00606-317
ERJ-2RKF1003XChip Resistor, 100KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR4, R5, R8, R10, R16,R17, R18, R20, R34, R47, R61, R77, R89, R102, R111, R115, R116, R124, R125,R131, R137, R176, R207, R242, R244RESC1005X40X25LL05T05CMP-2002-00608-325
ERJ-2RKF4992XChip Resistor, 49.9KOhm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape andReelR3, R129, R132, R133,R134, R179RESC1005X40X25LL05T05CMP-2002-00967-36
ERJ-2RKF10R0XChip Resistor, 10Ohm, +/- 1%, 100 mW, -55 to 155 degC, 0402 (1005 Metric), RoHS, Tape and ReelR1, R2, R12, R13,R14, R15, R19, R114, R128, R130, R135, R136RESC1005X40X25LL05T05CMP-2002-00622-312
DMP3098L-7P-Channel EnhancementMode MOSFET, -30 V VDS, -55 to 155 degC, 3-Pin SOT23, RoHS, Tape and ReelQ22DIOD-SOT23-3_VCMP-0697-00001-21
Si7635DP-T1-GE3P-Channel MOSFET, 20V, -55 to 150 degC, 8-Pin SMD (PPAKSO-8), RoHS, Tape and ReelQ13, Q20, Q21VISH-PPAKSO-8_VCMP-1709-00003-33
MMBT2222A-7-FNPN Small SignalTransistor, 40 V, -55 to 150 degC, 3-Pin SOT23, RoHS, Tape and ReelQ5, Q6, Q7, Q15, Q16,Q19, Q23, Q24DIOD-SOT23-3_VCMP-1693-00003-18
SiRA00DP-T1-GE3N-Channe MOSFET, 30V, -55 to 150 degC, 8-Pin SMD (PPAKSO-8), RoHS, Tape and ReelQ3, Q4, Q14, Q17VISH-PPAKSO-8_VCMP-1709-00004-34
DMG2305UX-7P-Channel EnhancementMode MOSFET, 20 V, -55 to 150 degC, 3-Pin SOT23, RoHS, Tape and ReelQ2, Q10, Q11DIOD-SOT23-3_A_VCMP-1693-00002-13
SiSS23DN-T1-GE3P-Channel MOSFET, 20V, -50 to 150 degC, 8-Pin SMD (PPAK1212-8S), RoHS, Tape and ReelQ1, Q8, Q9, Q12VISH-PPAK1212-8S_VCMP-1709-00001-34
1008CS-102XFLCChip Inductor, 1000nH, +/- 1%, -40 to 125 degC, 2-Pin SMD, RoHS, Tape and ReelL23, L24, L25, L26COIL-1008CS_VCMP-1716-00001-24
742792780SMD EMI SuppressionFerrite Bead WE-CBF, Z = 220 OhmL19, L20, L21SMD-0402CMP-0220-00137-13
BLM15AG221SN1xChip Bead, 220 Ohm,+/- 25 %, 100 MHz, 300 mA, -55 to 125 degC, 0402 (1005 Metric), RoHSL18, L22MURA-BLM15AG221SN1x_VCMP-1662-00018-32
BLM15AG221SN1JChip Ferrite Bead forGeneral Use, 220 Ohm, 450 mA, -55 to 125 degC, 1 x 0.5 x 0.55 mm SMD, Tapeand ReelL17MURA-BLM15-CHIP-2_VCMP-0686-00186-21
742792609SMD EMI SuppressionFerrite Bead WE-CBF, Z = 30 OhmL1, L2, L3, L4, L5,L6, L7, L8, L9, L10, L11, L12, L13, L14, L15, L16SMD-0603CMP-0220-00193-116
10117835USB 3.0 Standard-AReceptacle Right Angle Type Soldering to Board Termination, 30 V, -55 to 85degC, 9-Pin THD, RoHS, TrayJ22FCI-10117835_VCMP-1698-00002-11
AS0A823-H4SB-7HSurface MountHorizontal Type DDR4 DIMM Socket Connector, 260 Position, Pitch 0.5 mm, -55to 85 degC, Halogen/Lead Free, Tape and ReelJ20FOXC-AS0A823-H4SB-7H_VCMP-1735-00001-21
LTI-SASF54GTSMA Connector, Pitch2.54 mm, 1 Position, Height 9.5 mm, Tail Length 4 mm, RoHSJ15, J16, J17LHT-LTI-SASF54GT_VCMP-1713-00001-13
PCIE-098-02-F-D-THFemale Header, Pitch1 mm, 98 Positions, 4 Rows, Height 11 mm, Tail Length 2.31 mm, -55 to 125degC, RoHSJ14SMTC-PCIE-098-02-F-D-TH_VCMP-1707-00002-11
292443-1Board-to-BoardConnector, SMT, Right Angle, Pitch 0.8mm, 52-Position, FemaleJ13BTB-SM0-8-2H52FCMP-0001-00120-21
L829-1J1T-43Gigabit MagJack(R)Ultra Low Profile, 10/100/1000 Base-T, 19-Pin THD, RoHS, TrayJ11BELS-L829-1J1T-43_VCMP-1715-00001-11
7499111001ARJ45 LAN Transformer,Modular JACK, 0 to 70 degC, 10-Pin THD, RoHS, TubeJ9, J10WE-7499111001A_VCMP-1710-00001-32
AS0A823-H8SB-7HSurface MountHorizontal Type DDR4 DIMM Socket Connector, 260 Position, Pitch 0.5 mm, -55to 85 degC, Halogen/Lead Free, Tape and ReelJ8FOXC-AS0A823-H8SB-7H_VCMP-1735-00002-11
MECT-110-01-M-D-RA1Female TransceiverInterface, Pitch 0.8 mm, 2 x 10 Position, Height 5.2 mm, -55 to 125 degC,RoHS, TubeJ7, J21SMTC-MECT-110-01-M-D-RA1_VCMP-1707-00001-12
472720024DisplayPortConnector, Pitch 0.5 mm, 1 x 20 Position, Height 6.65 mm, -20 to 85 degC,RoHS, Tape and ReelJ6MOLX-472720024_VCMP-1704-00002-11
16PJ032DC Power Jack,Female, -10 to 70 degC, 3-Pin THD, RoHSJ4KOBI-16PJ032_VCMP-1737-00001-11
TSM-105-01-T-DV-TRMale Header, Pitch2.54 mm, 2 x 5 Position, Height 9.65 mm, -55 to 105 degC, RoHS, Tape and ReelJ2, J12SMTC-TSM-105-01-T-DV_VCMP-1707-00003-1,CMP-1707-00003-32
613 002 111 21Male Header, Pitch2.54 mm, 1 x 2 Position, Height 8.54 mm, Tail Length 3 mm, -40 to 105 degC,RoHS, BulkJ1, J3, J5, J18, J19WE-61300211121_VCMP-1712-00002-15
154001154 SeriesOMNI-BLOK(R) Fuse and Holder Assembly, 125 VAC, 125 VDC, 1 A, -55 to 125degC, 2-Pin SMD, RoHSF1LFUS-0154001.DR_VCMP-1700-00001-31
150060VS75000SMD mono-color ChipLED, WL-SMCW, Bright GreenD5, D6, D7, D8, D9,D10, D11, D12, D13, D140603_ACMP-1426-00006-110
82401646TVS Diode WE-TVS-SS,VRWM=5VD3, D4MSOP-8LCMP-1482-00002-12
B530C-13-FSurface MountSchottky Barrier Rectifier, 5 A, 0.55 V, -55 to 150 degC, 2-Pin SMD, RoHS,Tape and ReelD1DIOD-SMC-2_VCMP-1693-00001-11
GRM155R60J475ME87DChip Capacitor, 4.7uF, +/- 20%, 6.3 V, -55 to 85 degC, 0402 (1005 Metric), RoHS, Tape and ReelC407, C408, C409,C410, C411, C412, C413, C414, C415, C416, C417, C418, C419, C420, C421, C422CAPC1005X55X25LL05T10CMP-2008-04550-416
T520B337M2R5ATE045Tantalum Capacitor,330 uF, +/- 20%, 2.5 V, -55 to 105 degC, 2-Pin Molded, RoHS, Tape and ReelC390KEMT-520-B-2_MCMP-1664-00002-21
C2012X5R1C106K085ACChip Capacitor, 10uF, +/- 10%, 16 V, -55 to 85 degC, 0805 (2012 Metric), RoHS, Tape and ReelC330, C356, C370,C376, C377, C549, C552, C554, C557, C559CAPC2013X100X20NL20CMP-1663-00007-110
GRM155R71H472KA01DChip Capacitor, 4.7nF, +/- 10%, 50 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC308CAPC1005X55X25NL05T10CMP-2008-04663-41
GRM188R61A225KE34xChip Capacitor, 2.2uF, +/- 10%, 10 V, -55 to 85 degC, 0603 (1608 Metric), RoHS, Tape and ReelC297, C329, C355,C368, C372, C375, C379, C382, C386, C542CAPC1608X90X35ML10T15CMP-1662-00016-210
GRM033R60J104KE19DChip Capacitor, 100nF, +/- 10%, 6.3 V, -55 to 85 degC, 0201 (0603 Metric), RoHS, Tape and ReelC118, C119, C120,C121, C122, C123, C124, C125, C126, C127, C128, C129, C130, C143, C144, C145,C146, C153, C154, C155, C156, C157, C158, C159, C160, C162, C163, C164, C165,C166, C167, C168, C169, C170, C171, C172, C173, C174, C175, C176, C177, C178,C179, C180, C181, C182, C183, C184, C185, C186, C187, C188, C189, C190, C191,C192, C193, C194, C195, C196, C197, C198, C199, C200, C201, C202, C203, C204,C205, C206, C207, C208, C209, C210, C211, C212, C213, C214, C215, C216, C217,C218, C219, C220, C221, C222, C223, C224, C225, C226, C227, C228, C229, C230,C231, C232, C233, C234, C235, C236, C237, C238, C239, C240, C241, C242, C243,C244, C245, C246, C247, C248, C249, C250, C251, C252, C253, C254, C255, C256,C257, C258, C259, C260, C261, C262, C263, C264, C265, C266, C267, C268, C269,C270, C271, C272, C273, C274, C275, C276, C277, C278, C279, C280, C281, C282,C391, C392, C393, C394, C395, C396, C397, C398, C399, C400, C401, C402, C403,C404, C405, C406, C424, C425, C426, C427, C428, C429, C430, C431, C432, C433,C434, C435, C436, C437, C438, C439, C440, C441, C442, C443, C444, C445, C446,C447, C448, C449, C450, C451, C452, C453, C454, C455, C456, C457, C458, C459,C460, C461, C462, C463, C464, C465, C466, C467, C468, C469, C470, C471, C472,C473, C474, C475, C476, C477, C478, C479, C480, C560, C561, C562, C563, C564,C565, C569CAPC0603X33X15LL03T05CMP-2010-01652-4226
GRM155R71H681KA01DChip Capacitor, 680pF, +/- 10%, 50 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC117CAPC1005X55X25ML05T10CMP-2008-04665-41
GRM155R71E223KA61DChip Capacitor, 22nF, +/- 10%, 25 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC111CAPC1005X55X25ML05T10CMP-2008-04622-41
GRM155R71E473KA88DChip Capacitor, 47nF, +/- 10%, 25 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC110CAPC1005X55X25NL05T10CMP-2008-04630-41
GRM1535C1H560JDD5DChip Capacitor, 56pF, +/- 5%, 50 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC108CAPC1005X33X20ML05T10CMP-2008-04685-41
CGJ2B2X7R1E222K050BAChip Capacitor, 2.2nF, +/- 10%, 25 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC107CAPC1005X55X10ML05CMP-1663-00010-21
ECJ-0EC1H680JChip Capacitor, 68pF, +/- 5%, 50 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC106CAPC1005X55X20ML5T10CMP-1665-00023-11
VJ0402Y182JXJCW1BCChip Capacitor, 1.8nF, +/- 5%, 16 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC94CAPC1005X55X23NL05T8CMP-1666-00016-31
GRM31CR60J107ME39LChip Capacitor, 100uF, +/- 20%, 6.3 V, -55 to 85 degC, 1206 (3216 Metric), RoHS, Tape and ReelC82, C83, C84, C89,C90, C91, C92, C93, C96, C97, C98, C102, C103, C104, C105, C132, C133, C134,C135, C136, C137, C138, C139, C140, C141, C142, C147, C148, C149, C150, C151,C152, C161, C423, C509CAPC3216X190X55ML30T25CMP-1662-00011-235
6TPF330M9LTantalum Capacitor,330 uF, +/- 20%, 6.3 V, -55 to 105 degC, 2-Pin Molded, RoHS, Tape and ReelC80, C81, C87, C88,C95, C101PNSC-TPF-D3L_VCMP-1665-00019-26
EEH-ZA1E331PAluminum ElectrolyticCapacitor, 330 uF, +/- 20%, 25 V, -55 to 105 degC, 2-Pin CAPAE, RoHS, Tapeand ReelC74, C75, C76, C77PNSC-EEH-ZA1E331P_MCMP-1665-00032-14
C1005X7R1E104MChip Capacitor, 0.1uF, +/- 20%, 25 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC68, C69, C79, C131,C283, C284, C285, C286, C287, C288, C289, C290, C291, C292, C293, C294, C295,C296, C298, C299, C300, C301, C302, C303, C304, C305, C306, C307, C309, C313,C315, C316, C317, C319, C320, C321, C322, C323, C324, C325, C326, C331, C332,C333, C334, C335, C339, C341, C342, C343, C345, C346, C347, C348, C349, C350,C351, C352, C357, C358, C359, C360, C361, C369, C373, C380, C383, C387, C388,C389, C481, C482, C483, C501, C502, C503, C504, C505, C506, C507, C508, C510,C511, C512, C513, C514, C515, C516, C517, C518, C519, C520, C521, C522, C523,C524, C525, C526, C527, C528, C529, C530, C531, C532, C533, C534, C535, C536,C537, C538, C539, C540, C541, C544, C545, C546, C547, C548, C550, C551, C553,C555, C556, C558, C566, C567, C568, C570, C571, C572, C573, C574CAPC1005X55X10LL05CMP-1663-00009-2132
ECJ-0EC1H150JChip Capacitor,15 pF,+/- 5%, 50 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC48, C64CAPC1005X55X20ML5T10CMP-1665-00025-12
ECJ-0EC1H270JChip Capacitor, 27pF, +/- 5%, 50 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC17, C51CAPC1005X55X20ML5T10CMP-1665-00021-12
VJ0402Y153JXQPW1BCChip Capacitor, 15nF, +/- 5%, 10 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC14, C24, C33, C42,C49, C58, C65CAPC1005X55X23ML05T8CMP-1666-00015-37
GRM155R61A224KE19DChip Capacitor, 220nF, +/- 10%, 10 V, -55 to 85 degC, 0402 (1005 Metric), RoHS, Tape and ReelC13, C15, C16, C25,C32, C34, C41, C43, C50, C59, C115, C484, C485, C486, C487, C488, C489, C490,C491, C492, C493, C494, C495, C496, C497, C498, C499CAPC1005X55X25NL05T10CMP-2008-04561-427
C3216X5R1A476M160ABChip Capacitor, 47uF, +/- 20%, 10 V, -55 to 85 degC, 1206 (3216 Metric), RoHS, Tape and ReelC11, C12, C18, C19,C20, C21, C22, C30, C31, C39, C40, C46, C47, C52, C53, C54, C55, C56, C62,C63, C71, C72, C112, C113CAPC3216X180X20ML20CMP-1663-00005-124
GRM31CR61E226KE15LChip Capacitor, 22uF, +/- 10%, 25 V, -55 to 85 degC, 1206 (3216 Metric), RoHS, Tape and ReelC9, C10, C28, C29,C37, C38, C45, C61, C85, C86, C99, C100, C116, C328, C354, C367, C371, C374,C378, C381, C385, C500CAPC3216X180X55ML20T25CMP-1662-00010-222
C1005C0G1H220J050BAChip Capacitor, 22pF, +/- 5%, 50 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC8, C27, C36CAPC1005X55X10LL05CMP-1663-00008-23
GRM155R71H103KA88DChip Capacitor, 10nF, +/- 10%, 50 V, -55 to 125 degC, 0402 (1005 Metric), RoHS, Tape and ReelC2, C3, C67, C70,C310, C311, C312, C314, C318, C336, C337, C338, C340, C344, C362, C363, C364,C365, C366, C543CAPC1005X55X25ML05T10CMP-2008-04637-420
CGB2A1X5R1E105K033BCChip Capacitor, 1 uF,+/- 10%, 25 V, -55 to 85 degC, 0402 (1005 Metric), RoHS, Tape and ReelC1, C4, C5, C6, C7,C23, C26, C35, C44, C57, C60, C66, C73, C78, C109, C114, C327, C353, C384CAPC1005X33X10LL5CMP-1663-00006-219
74754-0101SFP+ Cage, SinglePort, Height 10.85 mm, Tail Height 3.05 mm, -40 to 85 degC, RoHS, TrayB1, B2MOLX-74754-0101_VCMP-1704-00003-12
评分
参与人数 1威望 +10 收起 理由
老吴 + 10 这个好东西,额外奖励10RMB
查看全部评分
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
 楼主| 发表于 2018-11-4 00:59:06 | 显示全部楼层
原理图与PCB文件共享
游客,如果您要查看本帖隐藏内容请回复
PADS-180606高级班
社区居民终身成就奖特殊贡献奖优秀斑竹奖
 楼主| 发表于 2018-11-4 01:14:27 | 显示全部楼层
  • 签到天数: 9 天
    发表于 2018-11-4 07:26:38 | 显示全部楼层
    7 天前
  • 签到天数: 111 天
    发表于 2018-11-4 08:26:02 | 显示全部楼层
    老吴20万,一下有这么多好作品
  • 签到天数: 61 天
    社区居民终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-11-4 08:31:44 | 显示全部楼层
    1元学习Allegro(1期)
    发表于 2018-11-4 08:41:23 | 显示全部楼层
    发表于 2018-11-4 08:57:45 | 显示全部楼层
  • 签到天数: 6 天
    承接PCB设计
    发表于 2018-11-4 08:58:27 | 显示全部楼层
    郁闷
    2024-12-1 17:54
    发表于 2018-11-4 08:59:40 | 显示全部楼层
