查看: 1931|回复: 1
[PADS9.5以下] LAY-28118_C  PCB文件
1元学习Allegro(1期)
发表于 2018-11-5 13:53:23 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
QQ截图20181105114537.png LAY-28118_C_pads.pcb (2.45 MB, 下载次数: 0)
NamePart TypePCB Decal
@FPAD_1FPAD_1
@_2FPAD_1FPAD_1
@_3FPAD_2FPAD_2
@_4FPAD_2FPAD_2
@_5FPAD_3FPAD_3
@_6FPAD_3FPAD_3
@_7FPAD_4FPAD_4
@_8FPAD_4FPAD_4
BAR1SHORTBAR1206_SHORTBAR_1206_IC_0SHORTBAR_1206
BH1MOUNT_HOLE_PLATED_HOLE_3_5MM_ICPLATED_HOLE_3_5MM
C1CC0805_OV/12CC0805_OV/12
C2CAP_NP_CC0805_OV_DISCRETE_1.35/6CC0805_OV/42
C3CAP_NP_CC0805_OV_DISCRETE_1.35/5CC0805_OV/41
C4CC0805_OV/13CC0805_OV/13
C5CAP_NP_CC0805_OV_DISCRETE_1.3_1/4CC0805_OV/40
C6CAP_NP_CC0805_DISCRETE_1.27MM_1CC0805
C7CAP_NP_CC0805_OV_DISCRETE_1.4_2CC0805_OV/15
C8CAP_NP_CC0805_OV_DISCRETE_1.35/13CC0805_OV/53
C9CAP_NP_CC0805_DISCRETE_1.27MM_1/2CC0805/2
C10CAP_NP_CC0805_OV_DISCRETE_1.35/7CC0805_OV/43
C11CAP_NP_CC0805_OV_DISCRETE_1.35/4CC0805_OV/34
C12CAP_NP_CC0805_OV_DISCRETE_1.45M/3CC0805_OV/39
C13CAP_NP_CC0805_OV_DISCRETE_1.35/11CC0805_OV/51
C14CC0805_OV/20CC0805_OV/20
C15CC0805_OV/21CC0805_OV/21
C16CAP_NP_CC0805_OV_DISCRETE_0.88M/2CC0805_OV/49
C17CAP_NP_CAP_METPLY_15MM_18P2X6P9CAP_METPLY_15MM_18P2X6P9
C18CC0805_OV/22CC0805_OV/22
C19CAP_NP_C402_520_154_35_DISCRETEC402_520_154_35
C20CAP_NP_C402_520_154_35_DISCRETE/2C402_520_154_35/2
C21CAP_NP_CC0805_OV_DISCRETE_1.35/15CC0805_OV/55
C22CAP_NP_CC0805_OV_DISCRETE_1.35/10CC0805_OV/50
C23CAP_POL_CCE50X54_DISCRETE_5.4MMCCE50X54/4
C24CAP_POL_CCE50X54_DISCRETE_5.5MMCCE50X54/5
C25CAP_NP_CC0805_OV_DISCRETE_1.35/12CC0805_OV/52
C26CAP_NP_CC0805_OV_DISCRETE_1.4MM/6CC0805_OV/26
C27CAP_NP_CC0805_OV_DISCRETE_1.45MCC0805_OV/31
C28CAP_NP_CC0805_OV_DISCRETE_1.35/9CC0805_OV/48
C29CAP_POL_CR1653_1220_POL_DISCRET/2CR1653_1220_POL/2
C30CAP_NP_CC0805_OV_DISCRETE_1.4MM/7CC0805_OV/27
C31CAP_NP_CC0805_OV_DISCRETE_1.35/21CC0805_OV/61
C32CAP_POL_CCE50X54_DISCRETE_5.5MM/2CCE50X54/6
C33CAP_NP_CC0805_OV_DISCRETE_1.4MM/5CC0805_OV/24
C34CAP_NP_CC0805_OV_DISCRETE_1.35/8CC0805_OV/45
C35CAP_NP_CC0805_OV_DISCRETE_1.35/20CC0805_OV/60
C36CAP_NP_CC0805_OV_DISCRETE_1.4MM/8CC0805_OV/28
C37CAP_NP_CC0805_OV_DISCRETE_1.4MM/11CC0805_OV/33
C38CAP_NP_CC0805_OV_DISCRETE_1.4MMCC0805_OV/9
C39CAP_NP_CC0805_OV_DISCRETE_1.4MM/4CC0805_OV/23
C40CAP_NP_CC0805_OV_DISCRETE_1.45M/2CC0805_OV/32
C41CAP_NP_CC0805_OV_DISCRETE_1.35/19CC0805_OV/59
C42CAP_NP_CC0805_OV_DISCRETE_1.35/18CC0805_OV/58
C43CAP_NP_CC0805_OV_DISCRETE_1.35/17CC0805_OV/57
C44CAP_NP_CC0805_OV_DISCRETE_1.4MM/9CC0805_OV/29
C45CAP_POL_CAP_10P5_RAD_DISCRETE_2CAP_10P5_RAD
C46CAP_NP_CAP_MET_PLY_18X6MM_DISCRCAP_MET_PLY_18X6MM
C47CAP_NP_CC0805_OV_DISCRETE_1.35/14CC0805_OV/54
C48CAP_NP_CC0805_OV_DISCRETE_1.4_1/2CC0805_OV/35
C49CAP_NP_CC0805_OV_DISCRETE_1.4MM/3CC0805_OV/17
C50CAP_NP_CC0805_OV_DISCRETE_1.4MM/10CC0805_OV/30
C51CAP_NP_CC0805_OV_DISCRETE_1.4MM/2CC0805_OV/16
C52CAP_NP_CC0805_OV_DISCRETE_1.35/16CC0805_OV/56
C53CAP_NP_CC0805_OV_DISCRETE_1.4_1CC0805_OV/25
C54CCE50X54CCE50X54
C55CCE50X54/2CCE50X54/2
C56CCE50X54/3CCE50X54/3
C57CAP_POL_CCE8P3X8P3_DISCRETE_10.CCE8P3X8P3
C58CC0805_OV/19CC0805_OV/19
C59CC1812/2CC1812/2
C60CCE50X54/7CCE50X54/7
C61CC0805_OV/18CC0805_OV/18
C62CAP_NP_CC0805_OV_DISCRETE_1.3_1/6CC0805_OV/46
C63CAP_POL_CR1653_1220_POL_DISCRETCR1653_1220_POL
C64CAP_POL_CCE10_3X10_3_DISCRETE_1CCE10_3X10_3
C65CC0805_OV/14CC0805_OV/14
C66CAP_NP_CC0805_OV_DISCRETE_1.3_1/2CC0805_OV/36
C67CAP_NP_CC0805_OV_DISCRETE_1.3_1/5CC0805_OV/44
C68CAP_NP_CC0805_OV_DISCRETE_1.35/3CC0805_OV/10
C69CAP_NP_CC0805_OV_DISCRETE_1.35/2CC0805_OV/8
C70CAP_NP_CC0805_OV_DISCRETE_1.35/23CC0805_OV/63
C71CAP_NP_CC0805_OV_DISCRETE_1.35/22CC0805_OV/62
C72CAP_NP_CC0805_OV_DISCRETE_1.3_1/3CC0805_OV/38
C73CAP_NP_CC0805_OV_DISCRETE_1.4_1/3CC0805_OV/37
C74CCE50X54/8CCE50X54/8
C75CC0805_OV/11CC0805_OV/11
C76CAP_NP_CC0805_OV_DISCRETE_1.3_1/7CC0805_OV/47
C77CC0805_OV/7CC0805_OV/7
C78CAP_NP_CC0805_OV_DISCRETE_1.473/2CC0805_OV/5
C79CAP_NP_CC0805_OV_DISCRETE_1.3_1CC0805_OV/2
C80CAP_NP_CC0805_OV_DISCRETE_1.473/3CC0805_OV/6
C81CAP_NP_CC0805_OV_DISCRETE_0.88MCC0805_OV/3
C82CAP_NP_CC0805_OV_DISCRETE_1.35CC0805_OV/4
C83CC1812CC1812
C84CAP_NP_CC0805_OV_DISCRETE_1.473CC0805_OV
D1HSMX-C170/3HSMX-C170/3
D2LED_HSMX-C170_IC_0.8MM_370-7578HSMX-C170
D3DIODE_SCHTKY_TO-220AC_VERT_2P_ITO-220AC_VERT_2P
D4DIODE_SCHTKY_TO-220AC_VERT_2P_I/2TO-220AC_VERT_2P/2
D5TO-220AC_VERTTO-220AC_VERT
D6BRIDGE_RECTIFIER_BRIDGE_DFB20_TBRIDGE_DFB20_TH
D7ZDIODE_SOD123_IC_1.35MM_480-780SOD123/6
D8DIODE_DO214AC_4P06_IC_2.64MM_48/2DO214AC_4P06/2
D9DIODE_DO214AC_4P06_IC_2.64MM_48DO214AC_4P06
D10ZDIODE_SOD123_IC_1.35MM_480-780/2SOD123/7
D11DIODE_SOD-123_IC_1.35MM_480-760SOD-123
D12DIODE_SOD-123_IC_1.35MM_480-760/3SOD-123/3
D13DIODE_SOD-123_IC_1.35MM_480-760/2SOD-123/2
D14DIODE_SCHTKY_SOD123_IC_1.45MM_4/5SOD123/5
D15DIODE_SCHTKY_SOD123_IC_1.45MM_4/4SOD123/4
D16ZDIODE_SMA_IC_2.41MM_480-77778_SMA
D17DIODE_CASE403D_02_IC_2.41MM_480/3CASE403D_02/3
D18DIODE_CASE403D_02_IC_2.41MM_480CASE403D_02
D19LED_LED_2P_0805_IC_0.9MM_370-76LED_2P_0805
D20HSMX-C170/2HSMX-C170/2
D21DIODE_SMC_CASE403_IC_2.616MM_48SMC_CASE403
D22LED_LED0805_IC_1.2MM_370-76452_LED0805
D23DIODE_CASE403D_02_IC_2.41MM_480/2CASE403D_02/2
D24DUALDIODE_CC_SOT23_SOT23-3_IC_1SOT23-3
D25LM4041_SOT23-3_IC_1.12MM_315-78SOT23-3/2
D26DIODE_SCHTKY_SOD123_IC_1.45MM_4/3SOD123/3
D27DIODE_SCHTKY_SOD123_IC_1.45MM_4/2SOD123/2
D28DIODE_SCHTKY_SOD123_IC_1.45MM_4SOD123
D29DUALDIODE_SERIES_SOT23_SOT-23_I/2SOT-23/2
D30DUALDIODE_SERIES_SOT23_SOT-23_ISOT-23
J1CONN_HDR_4X1_JUMP1X4-6040_IO_8./2JUMP1X4-6040/2
J2CONN_HDR_4X1_JUMP1X4-6040_IO_8.JUMP1X4-6040
J3CONN_HDR_4X1_JUMP1X4-6040_IO_8./3JUMP1X4-6040/3
J4USB_B_RCPT_CON_USB_RA_IO_11.50MCON_USB_RA
J5CONN_HDR_2X1_HDR102_IO_8.6MM_21HDR102
J8CONN_HDR_3X1_CON3_TB_5P08_TH_IO/2CON3_TB_5P08_TH/2
J9CONN_HDR_5X1_CON_5M_100_TH_IO_1CON_5M_100_TH
J10JUMP1X8-6040JUMP1X8-6040
J11CONN_PCIEXP_64P_CUST_CONN_2X32_CONN_2X32_THRUHOLE
J12CONN_HDR_2X1_CON_2_TB_5P08_TH_ICON_2_TB_5P08_TH
J13CONN_HDR_3X1_CON3_TB_5P08_TH_IOCON3_TB_5P08_TH
K1G5LA-1A4-DC12_RELAY_4P_19P8X15PRELAY_4P_19P8X15P8
L1INDUCTOR_IND_2012_DISCRETE_0.85IND_2012
L2GA3199_12P_IND_12P_45P5X42P4_DI/2IND_12P_45P5X42P4/2
L3GA3199_12P_IND_12P_45P5X42P4_DIIND_12P_45P5X42P4
L4INDUCTOR_IND12X12_DISCRETE_8.0MIND12X12
L20IND_PFC3125ER_IND_PFC_26X33MM_DIND_PFC_26X33MM
L30IND_PFC3125ER_IND_PFC_26X33MM_D/2IND_PFC_26X33MM/2
Q1MOSFET_N3_TO-220AB_NSP_IC_19.62/2TO-220AB_NSP/2
Q2MOSFET_N3_TO-220AB_NSP_IC_19.62TO-220AB_NSP
Q3SOT-23/3SOT-23/3
Q4D2PAK_BD2PAK_B
R1RES_RC0805_OV_DISCRETE_470-7546/4RC0805_OV/24
R2RES_RC0805_OV_DISCRETE_0.55MM_4/6RC0805_OV/35
R3RES_RC0805_OV_DISCRETE_0.6MM_47/4RC0805_OV/52
R4RES_RC0805_OV_DISCRETE_470-7557/4RC0805_OV/78
R5RES_RC0805_OV_DISCRETE_470-7557/3RC0805_OV/77
R6RES_RC2512_B_DISCRETE_470-80263/3RC2512_B/3
R7RES_RC0805_OV_DISCRETE_0.6MM_47/3RC0805_OV/51
R8RES_RC0805_OV_DISCRETE_0.55MM_4/5RC0805_OV/34
R9RES_RC0805_OV_DISCRETE_470-7842/3RC0805_OV/27
R10RES_RC0805_OV_DISCRETE_470-7842/4RC0805_OV/28
R11RES_RC0805_OV_DISCRETE_470-7842/2RC0805_OV/26
R12RES_RC0805_OV_DISCRETE_0.55MM_4/4RC0805_OV/33
R13RES_RC0805_OV_DISCRETE_0.6MM_47/2RC0805_OV/50
R14RC0805_OV/30RC0805_OV/30
R15RES_RC0805_OV_DISCRETE_470-75_1/6RC0805_OV/60
R16RES_RC0805_OV_DISCRETE_0.55MM_4/2RC0805_OV/31
R17RES_RC0805_OV_DISCRETE_0.6MM_47RC0805_OV/49
R18RES_RC0805_OV_DISCRETE_470-7590/6RC0805_OV/81
R19RES_RC2512_B_DISCRETE_470-80263/4RC2512_B/4
R20RES_RC0805_OV_DISCRETE_470-7546/3RC0805_OV/23
R21RES_RC0805_OV_DISCRETE_470-75_2RC0805_OV/25
R22RES_RC0805_OV_DISCRETE_470-7590/5RC0805_OV/80
R23RES_RC0805_OV_DISCRETE_470-7590/10RC0805_OV/87
R24RC0805_OV/29RC0805_OV/29
R25RES_RC0805_OV_DISCRETE_470-7590/7RC0805_OV/82
R26RES_RC0805_OV_DISCRETE_0.55MM_4/12RC0805_OV/41
R27RES_RC0805_OV_DISCRETE_0.55MM_4/11RC0805_OV/40
R28RES_RC0805_OV_DISCRETE_470-75_3RC0805_OV/76
R29RES_RC0805_OV_DISCRETE_0.55MM_4/10RC0805_OV/39
R30RES_RC0805_OV_DISCRETE_0.55MM_4/9RC0805_OV/38
R31RES_RC1206_OV_DISCRETE_470-8065/6RC1206_OV/12
R32RES_RC1206_OV_DISCRETE_470-8065/7RC1206_OV/13
R33RES_RC1206_OV_DISCRETE_470-8065/8RC1206_OV/14
R34RES_RC0805_OV_DISCRETE_0.55MM_4/8RC0805_OV/37
R35RES_RC0805_OV_DISCRETE_0.55MM_4/7RC0805_OV/36
R36RES_RC0805_OV_DISCRETE_470-7881/6RC0805_OV/68
R37RES_RC0805_OV_DISCRETE_470-7544RC0805_OV/58
R38RES_RC0805_OV_DISCRETE_470-7590/13RC0805_OV/90
R39RES_RC0805_OV_DISCRETE_470-7881/3RC0805_OV/65
R40RES_RC0805_OV_DISCRETE_470-7881/7RC0805_OV/69
R41RES_RC0805_OV_DISCRETE_470-7544/2RC0805_OV/59
R42RES_RC0805_OV_DISCRETE_470-7590/14RC0805_OV/91
R43RES_RC0805_OV_DISCRETE_470-7881/4RC0805_OV/66
R44RES_RC0805_OV_DISCRETE_470-7881/11RC0805_OV/73
R45RES_RC0805_OV_DISCRETE_470-7590/12RC0805_OV/89
R46RES_RC0805_OV_DISCRETE_470-7881/8RC0805_OV/70
R47RES_RC0805_OV_DISCRETE_470-7590/15RC0805_OV/92
R48RES_RC0805_OV_DISCRETE_470-7881/5RC0805_OV/67
R49RES_RC0805_OV_DISCRETE_470-7877/2RC0805_OV/75
R50RES_RC1206_OV_DISCRETE_470-8065/2RC1206_OV/3
R51RES_RC2512_B_DISCRETE_470-80263/5RC2512_B/5
R52RES_RC0805_OV_DISCRETE_470-75_3/2RC0805_OV/79
R53RES_RC1206_OV_DISCRETE_470-8065/3RC1206_OV/4
R54RES_RC1206_OV_DISCRETE_470-7868RC1206_OV/8
R55RES_RC1206_OV_DISCRETE_470-8065RC1206_OV/2
R56RES_RC1206_OV_DISCRETE_470-8065/11RC1206_OV/17
R57RES_RC1206_OV_DISCRETE_470-8065/12RC1206_OV/18
R58RES_RC1206_OV_DISCRETE_470-8065/13RC1206_OV/19
R59RES_RC1206_OV_DISCRETE_470-3006/3RC1206_OV/7
R60RES_RC2512_B_DISCRETE_470-80263/6RC2512_B/6
R61RES_RC2512_B_DISCRETE_470-80263RC2512_B
R62RES_RC2512_B_DISCRETE_470-80263/2RC2512_B/2
R63RES_RC1206_OV_DISCRETE_470-3006/2RC1206_OV/6
R64RC0805_OV/22RC0805_OV/22
R65RES_RC0805_OV_DISCRETE_0.55MM_1RC0805_OV/93
R66RES_RC0805_OV_DISCRETE_0.55MM_4/14RC0805_OV/43
R67RES_RC0805_OV_DISCRETE_0.6MM_47/6RC0805_OV/54
R68RES_RC0805_OV_DISCRETE_0.55MM_4/13RC0805_OV/42
R69RES_RC0805_OV_DISCRETE_0.6MM_47/6RC0805_OV/54
R70RES_RC0805_OV_DISCRETE_470-7634/4RC0805_OV/84
R71RES_RC0805_OV_DISCRETE_470-7634/3RC0805_OV/83
R72RES_RC0805_OV_DISCRETE_0.55MM_4/16RC0805_OV/45
R73RES_RC0805_OV_DISCRETE_0.6MM_47/6RC0805_OV/54
R74RES_RC0805_OV_DISCRETE_470-7877RC0805_OV/74
R75RES_RC0805_OV_DISCRETE_0.55MM_4/15RC0805_OV/44
R76RES_RC0805_OV_DISCRETE_0.6MM_47/6RC0805_OV/54
R77RES_RC0805_OV_DISCRETE_0.55MM_1/8RC0805_OV/99
R78RES_RC0805_OV_DISCRETE_470-7595RC0805_OV/64
R79RES_RC0805_OV_DISCRETE_470-7590/11RC0805_OV/88
R80RES_RC0805_OV_DISCRETE_470-75_1/7RC0805_OV/61
R81RES_RC0805_OV_DISCRETE_470-7968/3RC0805_OV/62
R82RES_RC0805_OV_DISCRETE_0.55MM_1/2RC0805_OV/94
R83RES_RC0805_OV_DISCRETE_0.55MM_1/4RC0805_OV/95
R84RES_RC0805_OV_DISCRETE_470-7881/9RC0805_OV/71
R85RES_RC0805_OV_DISCRETE_0.55MM_1/3RC0805_OV/54
R86RES_RC0805_OV_DISCRETE_470-7590/9RC0805_OV/86
R87RES_RC0805_OV_DISCRETE_470-7590/8RC0805_OV/85
R88RES_RC0805_OV_DISCRETE_470-7634/2RC0805_OV/63
R89RES_RC0805_OV_DISCRETE_0.55MM_1/5RC0805_OV/96
R90RES_RC1206_OV_DISCRETE_470-8065/14RC1206_OV/20
R91RES_RC1206_OV_DISCRETE_470-8065/4RC1206_OV/5
R92RES_RC1206_OV_DISCRETE_470-8065/9RC1206_OV/15
R93RES_RC0805_OV_DISCRETE_0.55MM_1/6RC0805_OV/97
R95RES_RC0805_OV_DISCRETE_0.55MM_1/7RC0805_OV/98
R96RES_RC1206_OV_DISCRETE_470-7868/2RC1206_OV/9
R97RES_RC0805_OV_DISCRETE_0.55MM_4/19RC0805_OV/48
R98RES_RC0805_OV_DISCRETE_0.6MM_47/9RC0805_OV/57
R99RES_RC1206_OV_DISCRETE_470-8065/15RC1206_OV/21
R100RES_RC1206_OV_DISCRETE_470-8065/17RC1206_OV/23
R101RES_RC1206_OV_DISCRETE_470-8065/10RC1206_OV/16
R102RES_RC0805_OV_DISCRETE_470-7881/10RC0805_OV/72
R103RES_RC0805_OV_DISCRETE_0.55MM_4/18RC0805_OV/47
R104RES_RC0805_OV_DISCRETE_0.6MM_47/8RC0805_OV/56
R105RES_RC1206_OV_DISCRETE_470-7868/2RC1206_OV/9
R106RES_RC1206_OV_DISCRETE_470-8065/16RC1206_OV/22
R107RES_RC1206_OV_DISCRETE_470-8065/5RC1206_OV/11
R108RES_RC1206_OV_DISCRETE_470-8065/10RC1206_OV/16
R109RES_RC0805_OV_DISCRETE_0.55MM_4/17RC0805_OV/46
R110RES_RC0805_OV_DISCRETE_0.6MM_47/7RC0805_OV/55
R111RES_RC1206_OV_DISCRETE_470-7868/3RC1206_OV/10
R112RES_RC0805_OV_DISCRETE_0.55MM_4/3RC0805_OV/32
R113RES_RC0805_OV_DISCRETE_0.6MM_47/5RC0805_OV/53
R114RES_RC0805_OV_DISCRETE_0.55MM_1/9RC0805_OV/100
R115RES_RC0805_OV_DISCRETE_470-7590/4RC0805_OV/18
R116RES_RC1206_OV_DISCRETE_470-3006RC1206_OV
R117RES_RC0805_OV_DISCRETE_470-7546RC0805_OV/2
R118RES_RC0805_OV_DISCRETE_470-7546/2RC0805_OV/20
R119RES_RC0805_OV_DISCRETE_470-7842RC0805_OV/3
R121RES_RC0805_OV_DISCRETE_470-75_1/5RC0805_OV/9
R122RES_RC0805_OV_DISCRETE_0.55MM_4RC0805_OV/19
R123RES_RC0805_OV_DISCRETE_470-7634RC0805_OV/12
R124RES_RC0805_OV_DISCRETE_470-7881/2RC0805_OV/14
R125RC0805_OV/4RC0805_OV/4
R126RES_RC0805_OV_DISCRETE_470-7557/2RC0805_OV/21
R127RES_RC0805_OV_DISCRETE_470-7590/3RC0805_OV/17
R128RES_RC0805_OV_DISCRETE_470-7881RC0805_OV/13
R129RES_RC0805_OV_DISCRETE_470-75_1/4RC0805_OV/8
R130RES_RC0805_OV_DISCRETE_470-75_1/3RC0805_OV/7
R131RES_RC0805_OV_DISCRETE_470-75_1/2RC0805_OV/6
R132RES_RC0805_OV_DISCRETE_470-75_1RC0805_OV/5
R133RES_RC0805_OV_DISCRETE_470-7590/2RC0805_OV/16
R134RES_RC0805_OV_DISCRETE_470-7590RC0805_OV/15
R135RES_RC0805_OV_DISCRETE_470-7968/2RC0805_OV/11
R136RES_RC0805_OV_DISCRETE_470-7968RC0805_OV/10
R137RES_RC0805_OV_DISCRETE_470-7557RC0805_OV
RT1THERMISTOR_THERMISTOR_328_770X2THERMISTOR_328_770X220_TH
RV1VARISTOR_VARISTOR_7P5_17X5P6_THVARISTOR_7P5_17X5P6_TH
TP1TESTPOINT_060_039MIL/36TESTPOINT_060_039MIL/36
TP2TESTPOINT_060_039MIL/29TESTPOINT_060_039MIL/29
TP3TESTPOINT_060_039MIL/30TESTPOINT_060_039MIL/30
TP4TESTPOINT_060_039MIL/15TESTPOINT_060_039MIL/15
TP5TESTPOINT_060_039MIL/40TESTPOINT_060_039MIL/40
TP6TESTPOINT_060_039MIL/37TESTPOINT_060_039MIL/37
TP7TESTPOINT_060_039MIL/32TESTPOINT_060_039MIL/32
TP8TESTPOINT_060_039MIL/42TESTPOINT_060_039MIL/42
TP9TESTPOINT_060_039MIL/41TESTPOINT_060_039MIL/41
TP10TESTPOINT_060_039MIL/31TESTPOINT_060_039MIL/31
TP11TESTPOINT_060_039MIL/18TESTPOINT_060_039MIL/18
TP12TESTPOINT_060_039MIL/34TESTPOINT_060_039MIL/34
TP13TESTPOINT_060_039MIL/9TESTPOINT_060_039MIL/9
TP14TESTPOINT_060_039MIL/39TESTPOINT_060_039MIL/39
TP15TESTPOINT_060_039MIL/35TESTPOINT_060_039MIL/35
TP16TESTPOINT_060_039MIL/46TESTPOINT_060_039MIL/46
TP17TESTPOINT_060_039MIL/45TESTPOINT_060_039MIL/45
TP18TESTPOINT_060_039MIL/38TESTPOINT_060_039MIL/38
TP19TESTPOINT_060_039MIL/43TESTPOINT_060_039MIL/43
TP20TESTPOINT_060_039MIL/20TESTPOINT_060_039MIL/20
TP21TESTPOINT_060_039MIL/21TESTPOINT_060_039MIL/21
TP22TESTPOINT_060_039MIL/7TESTPOINT_060_039MIL/7
TP23TESTPOINT_060_039MIL/19TESTPOINT_060_039MIL/19
TP24TESTPOINT_060_039MIL/6TESTPOINT_060_039MIL/6
TP25TESTPOINT_060_039MIL/23TESTPOINT_060_039MIL/23
TP26TESTPOINT_060_039MIL/5TESTPOINT_060_039MIL/5
TP27TESTPOINT_060_039MIL/4TESTPOINT_060_039MIL/4
TP28TESTPOINT_060_039MIL/25TESTPOINT_060_039MIL/25
TP29TESTPOINT_060_039MIL/3TESTPOINT_060_039MIL/3
TP30TESTPOINT_060_039MIL/27TESTPOINT_060_039MIL/27
TP31TESTPOINT_060_039MIL/11TESTPOINT_060_039MIL/11
TP32TESTPOINT_060_039MIL/13TESTPOINT_060_039MIL/13
TP33TESTPOINT_060_039MIL/10TESTPOINT_060_039MIL/10
TP34TESTPOINT_060_039MIL/2TESTPOINT_060_039MIL/2
TP35TESTPOINT_060_039MIL/8TESTPOINT_060_039MIL/8
TP36TESTPOINT_060_039MIL/28TESTPOINT_060_039MIL/28
TP37TESTPOINT_060_039MIL/12TESTPOINT_060_039MIL/12
TP38TESTPOINT_060_039MIL/26TESTPOINT_060_039MIL/26
TP39TESTPOINT_060_039MIL/16TESTPOINT_060_039MIL/16
TP40TESTPOINT_060_039MIL/44TESTPOINT_060_039MIL/44
TP41TESTPOINT_060_039MIL/14TESTPOINT_060_039MIL/14
TP42TESTPOINT_060_039MIL/24TESTPOINT_060_039MIL/24
TP43TESTPOINT_060_039MIL/22TESTPOINT_060_039MIL/22
TP44TESTPOINT_060_039MIL/33TESTPOINT_060_039MIL/33
TP45TESTPOINT_060_039MILTESTPOINT_060_039MIL
TP46TESTPOINT_060_039MIL/17TESTPOINT_060_039MIL/17
U1SI8622BD_16P_SO16W_IC_2.65MM_31SO16W
U2MC33502D_SO8_1P27_4X5_IC_1.75MM/2SO8_1P27_4X5/3
U3CP2102_QFN28_5X5MM_3P3_EP_IC_1MQFN28_5X5MM_3P3_EP
U5MC33269_DPAK_DPAK_MC33269_IC_2.DPAK_MC33269
U6MC78XXCT_SIP3_2P54_12X8P6_TH_ICSIP3_2P54_12X8P6_TH
U7LNK306G_SMD-8B_IC_3.98MM_312-79SMD-8B
U8MC33502D_SO8_1P27_4X5_IC_1.75MM/3SO8_1P27_4X5/4
U9MC33152D_S08_1P27_4X5_IC_1.75MMS08_1P27_4X5
U10LMV7271MF_SOT-23-5_IC_1.22MM_31/2SOT-23-5/2
U11MC33502D_SO8_1P27_4X5_IC_1.75MMSO8_1P27_4X5/2
U12FNB41560_26P_DIP_26P_39P5X23P5_DIP_26P_39P5X23P5_SPMAA-C26_TH
U13LMV7271MF_SOT-23-5_IC_1.22MM_31SOT-23-5
U14FAN3224_SO_8P_SO8_1P27_4X5_IC_1SO8_1P27_4X5
重要提示:PCB作品文件展下载说明
    郁闷
    4 天前
  • 签到天数: 6 天
    社区居民忠实会员社区劳模最爱沙发原创达人终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-11-5 14:33:34 | 显示全部楼层
