原理图功能最终 量产, PCB文件后续由修改过。 ^GyGh{@,f T%opkyP>= FL,av>mV y[pU8QSt S7I8BS[*v 附件出售:修改_2.zip :~%
zX* hj8S".A_ kOQq+_Y
Comment | Description | Designator | Footprint | LibRef | Quantity | 104_P | | 1 | 1210_C | 104_P | 1 | R-SMD | | 1K, R8, R9, R35, R38 | 0805_R | R-SMD | 5 | 106 | | C1 | 0805_C | 104_P | 1 | 104_P | | C2, C3, C4, C5, C6, C7, C8, C13 | 0603_C | 104_P | 8 | 104 | | C9, C10, C11 | 0603_C | 104_P | 3 | 100uf | | C12 | RB0.1X0.8 | 电解电容_直插 | 1 | 104_P | | C14, C15, C16, C17, C27, C28 | 0805_C | 104_P | 6 | 10uf | | C18, C20, C30, C31, C33, C37, C40, C48 | 0805_C | 104_P, 104_P, 104_P, 104_P, 104_P, 104_P, 104, 104 | 8 | 22uf | | C19 | 0805_C | 104_P | 1 | 104 | | C21, C29, C35, C38 | 0805_C | 104_P, 104_P, 104_P, 104 | 4 | 22uf | | C22, C23, C46, C47 | 1210_C | 104_P, 104_P, 104, 104 | 4 | 102 | | C24 | 1206_C | 104_P | 1 | 470pf | | C25 | 0805_C | 104_P | 1 | 222 | | C26 | 0805_C | 104_P | 1 | 4.7uf | | C32, C34, C36 | 0805_C | 104_P | 3 | 100nF | | C39, C43, C44, C45, C49 | 0805_C | 104 | 5 | 4148 | | D1, D2 | SOD-80Q | 1N4007-P | 2 | 1N4007-P | | D3, D4, D5 | SOD-80Q | 1N4007-P | 3 | 1N4007-P | | D6 | SMB | 1N4007-P | 1 | 1N4007-P | | D7 | DO-214 | 1N4007-P | 1 | T8 | | D8 | SOD-80Q | 1N4007-P | 1 | SS24 | | D9, D11, D18 | SMB | 1N4007-P, 1N4007, 1N4007 | 3 | T4 | | D10 | SOD-80Q | 1N4007-P | 1 | SS14 | | D12, D13, D14, D15, D16, D17 | SOD-80Q | 1N4007 | 6 | LED | | D19 | 0805LED_GREEN | LED | 1 | 蜂鸣器 | | HXD1 | FMQ | 蜂鸣器 | 1 | J5 | | J1 | SIP5_2.54XH | J5 | 1 | J1 | | J2, J3 | J1_ | J1 | 2 | USB_A | | J4 | USBR-A_DIP | USB_A | 1 | J2 | | J5, J8 | SIP2_2.54XH | J2 | 2 | J12 | | J6, J7, J14, J15 | PH12 | J12 | 4 | 接线柱 | | J9 | 接线柱 | 接线柱 | 1 | DC_6MM | | J10 | DC-6mm | DC_6MM | 1 | DC_6MM | | J11 | DC3.5*1.5 | DC_6MM | 1 | J4 | | J12 | SIP2.54XH_4 | J4 | 1 | J5 | | J13 | HDR1X5 | J5 | 1 | 按钮开关 | | KEY1 | SW-SMD1 | 按钮开关 | 1 | 按钮开关 | | KEY2, KEY3, KEY4 | 点动按钮_P | 按钮开关 | 3 | 电感 | | L1 | Inductor_0.2 | 电感 | 1 | 电感 | | L2 | INDP7850X23N | 电感 | 1 | 29uH | | L3, L4 | Inductor_0.2 | 电感 | 2 | 米字型_共阳 | | LED1, LED2 | 数码管米字 | 米字型_共阳 | 2 | MOS_N沟道 | | Q1, Q2, Q3, Q7, Q8, Q9, Q12, Q17, Q18 | SOT_23_MOS | MOS_N沟道 | 9 | MOS_P沟道 | | Q4, Q6, Q16 | TO-252 | MOS_P沟道 | 3 | 4403 | | Q5, Q11 | SOT23 | 8550 | 2 | MDP3015LS | | Q10 | SOP8 | MOS_P沟道 | 1 | 4450 | | Q13 | SOP_8_MOS | MOS_N沟道 | 1 | 2X | | Q14 | SOT23 | 8050 | 1 | 8050 | | Q15, Q19, Q20, Q21 | SOT23 | 8050 | 4 | 8550 | | Q22 | SOT23 | 8550 | 1 | 100 | | R1 | 0805_R | R-SMD | 1 | 1K | | R2, R3, R4, R10, R11, R13, R28, R34, R36, R37, R39, R40, R41 | 0603_R | R-SMD | 13 | 3M | | R5, R6, R14, R17, R31, R32 | 0603_R | R-SMD | 6 | 1K | | R7, R26, R58, R60, R71, R75, R76, R79, R94, R103, R111, R113 | 0805_R | R-SMD | 12 | 310 | | R12 | 0805_R | R-SMD | 1 | 510 | | R15 | 0805_R | R-SMD | 1 | 10K | | R16, R46, R48, R102 | 0603_R | R-SMD | 4 | 510K | | R18 | 0805_R | R-SMD | 1 | 0.01 | | R19 | 2512R | R-SMD | 1 | 加粗线/1.2 | | R20 | R_AXIAL-0.7 | R-AXIAL | 1 | 5.1K | | R21, R101, R115, R116 | 0805_R | R-SMD | 4 | 47.8k | | R22 | 0805_R | R-SMD | 1 | 475K | | R23, R24, R29, R33, R61, R63, R84 | 0805_R | R-SMD | 7 | 7.15k | | R25 | 0805_R | R-SMD | 1 | 475K | | R27 | 0603_R | R-SMD | 1 | 47K | | R30, R62 | 0805_R | R-SMD | 2 | 42.2k | | R42 | 0603_R | R-SMD | 1 | 51K/1% | | R43, R44 | 0805_R | R-SMD | 2 | 470R | | R45 | 0805_R | R-SMD | 1 | 11 | | R47 | 0805_R | R-SMD | 1 | 1K/1% | | R49 | 0603_R | R-SMD | 1 | 0.1/1% | | R50, R56 | 1210_R | R-SMD | 2 | 75K1% | | R51 | 0805_R | R-SMD | 1 | 43K/1% | | R52 | 0805_R | R-SMD | 1 | 20R/1% | | R53 | 0805_R | R-SMD | 1 | 13k | | R54 | 0603_R | R-SMD | 1 | 0.33 | | R55 | 1206_R | R-SMD | 1 | 19.6K/1% | | R57, R89 | 0805_R | R-SMD | 2 | 10K | | R59, R68, R95, R98, R99, R100, R104, R107, R110 | 0805_R | R-SMD | 9 | 10 | | R64 | 1210_R | R-SMD | 1 | 4.7 | | R65 | 1210_R | R-SMD | 1 | 2K | | R66, R70 | 0805_R | R-SMD | 2 | 10 | | R67 | 0805_R | R-SMD | 1 | 150K | | R69 | 0805_R | R-SMD | 1 | 6.8K | | R72, R74 | 0805_R | R-SMD | 2 | 0.1 | | R73, R77 | 1210_R | R-SMD | 2 | 365 | | R78 | 0805_R | R-SMD | 1 | 20K | | R80, R109, R112 | 0805_R | R-SMD | 3 | R-AXIAL | | R81 | R_AXIAL-0.7 | R-AXIAL | 1 | 3.3K | | R82 | 0805_R | R-SMD | 1 | 1k/1% | | R83 | 0805_R | R-SMD | 1 | 0.005R/3W | | R85, R86, R87 | 2512R | R-SMD | 3 | 0.005R | | R88 | 2512R | R-SMD | 1 | 4.7k | | R90 | 0805_R | R-SMD | 1 | 470K | | R91, R93 | 0805_R | R-SMD | 2 | 3K | | R92 | 0805_R | R-SMD | 1 | R-SMD | | R96, R114 | 0603_R | R-SMD | 2 | 300k | | R97 | 0805_R | R-SMD | 1 | 1R | | R105, R106, R108 | 1206_R | R-SMD | 3 | 继电器 | | T1 | 继电器80A | 继电器 | 1 | SH367004 | | U1 | TSOP24 | SH367004 | 1 | XRP7665 | | U2 | SO8 | XRP7665 | 1 | LM358P | | U3, U6 | SO8 | LM358P | 2 | PT4115 | | U4 | PT4115 | PT4115 | 1 | uc3843 | | U5 | SO8 | uc3843 | 1 | MKE02Z16 | | U7 | LQFP_32 | MKE02Z16 | 1 | TM1629C | | U8 | TSOP_32 | TM1629C | 1 | TL431 | | U9 | SOT23 | TL431 | 1 | `akbzHOM /.Fvl;!J; }gfs [ 此帖被544316200在2018-11-07 16:45重新编辑 ]
