查看: 2251|回复: 1
[Pads_VX.2x] 新塘NUC951开发板原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-8 13:32:27 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
下面有DSN文件,PCB导的器件表不全,给个PDF原理图自己看 nuc951_evb_v11_2013-7-5.pdf (336 KB, 下载次数: 0)
NamePart TypePCB DecalValue
BT1BATTERY_ELEM_0BAT\CR2032\ACR2032
CB29CAP-B_0C06031uF
CON1DIN_96_ABC-RDIN96SDIN 32PX3
CON2RJ45_SHLD_0RJ45RJ-45L
CON3MICROPHONEMICMICROPHONE
CON4MICROPHONEMICMICROPHONE
CON5PHONEJACK_STEREO_SW_PJK-634_4PHONE-PJK-631PJK-634
CON6JTAGHEADER10X2/BOX10PX2
CON7JAE_IL-FHJ-39S-HF-A1_1A035QN02V4FPC Connector 0.5mm 54PIN
CON8CON-PWRJACKPOWERJACK\3PPower Jack
CON9PS2DN-608S-6PS2 CONNECTOR
CON10LCM_0SIP4\2.54MMI2C Header
CON11CONNECTOR_DB9DB9_FEMALE
CON12CONNECTOR_DB9DB9_MALEDB9_MALE
CON13CONNECTOR_DB9DB9_MALEDB9_MALE
CON14USB_TYPE_B_MINI_CONNECTORUSB_MINI_BUSB MINI-B RECEP.
CON15USB_TYPE_A_CONNECTORUSB4PUSB TYPE-A RECAP.
D1ZENAR_0SOD-523RB521S-40
D2DIODE1N41481N4148
D3DIODE1N41481N4148
J1CON32A_1HEADER20X2HEADER20X2/FEMALE
JP1HEADER_3SIP3\2.54MM3PX1, 2.54mm
JP2HEADER_3SIP3\2.54MM3PX1, 2.54mm
JP3HEADER_3SIP3\2.54MM3PX1, 2.54mm
JP4HEADER_3SIP3\2.54MM3PX1, 2.54mm
JP7CON2SIP/2PSIP/2P
JP8HEADER6X2_2HEADER5X2HEADER5X2_NOP
JP9HEADER_4X2_0HEADER3X2HEADER 3X2 / 2.54mm_M
JP10HEADER_4X2_0HEADER3X2HEADER 3X2 / 2.54mm_M_NOP
JP11HEADER6X2_0HEADER4X2HEADER4X2_NOP
JP12CON2SIP/2PSIP/2P
JP13HEADER6X2_0HEADER4X2HEADER4X2_NOP
JP14HEADER6X2_0HEADER4X2HEADER4X2_NOP
JP15JUMPER2HEADER2X2HEADER2X2_NOP
JP16HEADER_3SIP3\2.54MM3PX1, 2.54mm
JP17HEADER6X2_1HEADER8X2HEADER8X2_NOP
LED1LEDLED0603GREEN LED
LED2LEDLED0603YELLOW LED
LED3LEDLED0603RED LED
LED4LEDLED0603GREEN LED
LED5LED_DIPLED0603GREEN_LED
LED6LED_DIPLED0603GREEN_LED
LED7LED_DIPLED0603RED_LED MORE LIGHT
Q1MOSFET_P_1SOT-23SI2301DS
SW1SW_PUSHBUTTONSWSW PUSHBUTTON
SW2SW_DPDT_0SW6PXPTS-020S
U1SDRAM_TSOP50_0TSOP54/463W9825G6EH-6
U2SDRAM_TSOP50_0TSOP54/463W9825G6EH-6
U3SDRAM_TSOP50_0TSOP54/463W9825G6EH-6
U4SDRAM_TSOP50_0TSOP54/463W9825G6EH-6
U5AM29F400T_TSOPTQFP48\0.5MX29LV320EBTI-70G
U6IP101A_0P48LQFPIP101A
U7TS6121C_0ST6200TTS6121C
U8WAU8822_032-QFNWAU8822
U9W83971_0LQFP48\0.5ALC203
U10MIC811SOT-143MIC811TU
U1174VHC1G08SOT-23-574VHC1G08
U12TPS61042/3_0QFN-8TPS61042
U13TSC2003_0TSSOP16TSC2007
U14K9F5608U0DTQFP48\0.5K9F1G08U0B
U15NUC951_1LQFP216LNUC951
U17ELM9818SOT-23ELM9818
U19SD/MMC_0SD-14P_F23RSD/MMC SOCKET
U20SPI_FLASH_0SO8_300_208_150W25Q16BV
U21ADM232_0SOP16/150SP3232EEN
U22ADM232_0SOP16/150SP3232EEN
U23AIC1528-1SOP8AIC1526-1
U24MP1492SOIC8\1.27MP1492
U25RT9013SOT-23-5RT9013-18PB
X1CRYSTAL25MHz
X2CRYSTALXTAL324.576MHz
X3CRYSTALXTAL315MHz
X4CRYSTALXTAL/32.768KHZ32.768KHz
X5CRYSTALXTAL348MHz
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-8 13:38:15 | 显示全部楼层
NUC951_EVB_V11_2013-7-5.DSN.rar (186 KB, 下载次数: 1) NUC951_EVB_2013-07-12_V1.2.pcb.rar (1022 KB, 下载次数: 0)
