查看: 4911|回复: 16
[AD格式] STM32L475VGT6 物联网开发板硬件设计原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-8 15:13:11 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
CommentDescriptionDesignatorFootprintLibRefQuantity
SW-PUSH-CMS_BLACKPush-button SMDB1SWI_WEALTHMETAL_TD-0341_4P - BACKSW-PB_21
SW-PUSH-CMS_BLUEPush-button SMDB2SWI_WEALTHMETAL_TD-0341_4P- BLUESW-PB_21
100nFCapacitor_notpolarizedC1, C3, C5, C7, C9,C10, C11, C12, C13, C17, C19, C20, C22, C23, C25, C26, C28, C29, C31, C32,C33, C34, C36, C42, C43, C44, C45, C47, C48, C54, C55, C57, C60, C61, C62,C63, C65, C73, C740402_CAP_NPOLCAP_NPOL39
Not Fitted(8.2pF)Capacitor_notpolarizedC2, C40402_CAP_NPOLCAP_NPOL2
1uFCapacitor_notpolarizedC6, C8, C24, C56,C59, C64, C680402_CAP_NPOLCAP_NPOL7
5.1pFCapacitor_notpolarizedC14, C150402_CAP_NPOLCAP_NPOL2
10uFCapacitor_notpolarizedC16, C38, C39, C40,C41, C46, C49, C500603_CAP_NPOLCAP_NPOL8
4.7uFCapacitor_notpolarizedC18, C21, C30, C660603_CAP_NPOLCAP_NPOL4
2.2uFCapacitor_notpolarizedC27, C75, C760603_CAP_NPOLCAP_NPOL3
10pFCapacitor_notpolarizedC35, C37, C51, C52,C53, C710402_CAP_NPOLCAP_NPOL6
10nFCapacitor_notpolarizedC580402_CAP_NPOLCAP_NPOL1
100pFCapacitor_notpolarizedC670402_CAP_NPOLCAP_NPOL1
Not FittedCapacitor_notpolarizedC69, C70, C720402_CAP_NPOLCAP_NPOL3
Header10X1_Female_SMDHeader, 10-Pin, SMD,Single row,femaleCN1F-V50XC-1X10R-LFHeader10X1_Female_SMD1
Header8X1_Female_SMDHeader, 8-Pin, SMD,Single row,femaleCN2, CN3F-V50XC-1X08R-LFHeader 8X1_Female_SMD2
Header6X1_Female_SMDHeader, 6-Pin, SMD,Single row,femaleCN4F-V50XC-1X06R-LFHeader 6X1_Female_SMD1
TC2050-IDC-NLTag_Connector Header,10-Pin, Dual row No legsCN5CON_TAG-C_TC2050-IDC-NLTag-10-C1
header 2 pins2.54mmHeader 2 pinsCN6CON_SAMTEC_TSW-102-07-G-SHeader 2 pins1
1050170001USB-MICRO-B,1050170001, SMT, MOLEXCN7CON_USBMICROB_MOLEX_105017-0001_H2P9010501700011
Header 4 pinsHeader, 4-PinCN8CON_SAMTEC_TSW-104-07-G-SHeader 41
475900001USB-MICRO-AB,47590-0001, SMT, MOLEXCN9CON_USBMICROAB_MOLEX_47590-0001_H34759000011
HEADER_2X6_PMODPMOD ConnectorWarning Specific PinoutCN10Header F 2x6x2.54 THH PMODHEADER_2X6_PMOD1
BAT60JFILMBAT60JFILMD2, D3, D4, D5DIO_SOD323BAT60JFILM4
SHUNT_BKSHUNT 2.54mm BLACKHW1, HW2, HW3, HW4 Shunt 2.54mm4
HEADER_2X5 JP4Header M 2x5x2.54 THVHEADER_2X51
Jumper_2.54mmConnector jumper 1positionJP5, JP6, JP7, JP8CON_SAMTEC_TSW-102-07-G-STSW-102-07-x-S4
FCM1608KF-601T03InductorL10603LInductor1
742792042InductorL20603LInductor1
LEDLight-Emitting DiodeLD1, LD2, LD5, LD90603_LED_GREENLED4
LEDLight-Emitting DiodeLD30603_LED_YellowLED1
LEDLight-Emitting DiodeLD40603_LED_BlueLED1
LD_BICOLOR_CMSBicolor LedLD6LED_BI-GR_HSMF-A201-A00J1LD_BICOLOR_CMS1
LEDLight-Emitting DiodeLD7, LD80603_LED_REDLED2
BT ModuleSPBTLE-RFM1SPBTLE-RFSPBTLE-RF1
ISM43362-M3G-L44ISM43362-M3G-L44 WifiModule 802.11 bgnM2ISM43362-M3G-L44ISM43362-M3G-L441
SPSGRFSPSGRF-915orSPSGRF-868M3SPSGRFSPSGRF1
BSR14BSR14 NPN switchingtransistor SOT23 (Marking U8)Q1, Q2SOT23-3BSR142
30KResistorR10402_RESRES1
0RResistorR2, R6, R12, R13,R42, R430402_RESRES6
1kResistorR3, R18, R19, R21,R24, R52, R560402_RESRES7
20KResistorR40402_RESRES1
Not Fitted(0R)ResistorR5, R7, R300402_RESRES3
2K2ResistorR8, R9, R10, R11, R530402_RESRES5
10KResistorR14, R15, R16, R31,R48, R51, R670402_RESRES7
330RResistorR20, R25, R44, R47,R550402_RESRES5
680RResistorR220402_RESRES1
100KResistorR23, R29, R49, R54,R590402_RESRES5
47KResistorR26, R57, R58, R620402_RESRES4
4K7ResistorR27, R40, R410402_RESRES3
2K7ResistorR280402_RESRES1
22RResistorR32, R33, R34, R350402_RESRES4
Not Fitted(10K)ResistorR36, R64, R65, R660402_RESRES4
200KResistorR380402_RESRES1
100RResistorR39, R450402_RESRES2
36KResistorR460402_RESRES1
1K5ResistorR500402_RESRES1
0RResistorR610603_RESRES1
CloseSolder JumperSB1, SB2, SB3, SB4,SB5, SB6, SB7, SB8, SB10, SB13, SB14, SB15, SB17, SB18, SB21SBStrap215
OpenSolder JumperSB9, SB11, SB12,SB16, SB19, SB20SBStrap26
PTPoint de testTP1, TP2, TP3, TP4,TP5, TP6PTBPT6
STM32L475VGTxSTM32L475VGTxU1LQFP100 14x14x1.6STM32L475VGTx1
MP34DT01-MMEMS audio microphoneU2, U10HCLGA-4LD 3x4x1MP34DT012
LSM6DSLAccelero + Gyro MEMS(6 Axis)U3LGA14L-2.5X3X0.86p0.5LSM6DSL1
VL53L0XProximity sensor MEMSU4LGA12-opticalVL53L0X1
LIS3MDLIC,SensorU5VFLGA12-2x2x1LIS3MDL1
HTS221Humidity + Temp MEMSU6HLGA6L-2x2x0.9HTS2211
LPS22HBIC,SensorU7HLGA10L-2X2X0.76LPS22HB1
M24SR64-YM24SR64-Y  64K_EEPROM NFC/RFIDU8SOP8M24SR64-Y1
STSAFE-A100(Not Fitted)STSAFE-A100U9SOP8STSAFE-A1001
MX25R6435FMX25R6435F SerialFlash Memory 64MU11SOP8LMX25R6435F1
LT1963EST-3.3LT1963EST-3.3 LDO LowNoise 1.5A fast Transient ResponseU12SOT223_SC73LT1963EST-3.31
LD1117S50TRIC REG LDO 5V 0.8ASOT223U13REG_SOT223-TABLD1117S50TR1
LD1117S33TRLOW DROP FIXED ANDADJUSTABLE POSITIVE VOLTAGE REGULATORS (3.3 Volts)U14REG_SOT223-TABLD1117S33TR1
STM32F103CBT6Medium-densityperformance line ARM-based 32-bit MCU with 128KB FlashU15ICC_LQFP48_7X7_P050STM32F103CBT61
LD3985M33RUltra low drop-lownoise BiCMOS voltage, regulators low ESR capacitors compatibleU16REG_SOT23-5LLD3985M33R1
ST890CDR1.2 A current limitedhigh-side power switch with thermal shutdownU17ICC_SO8_5X4_P127ST890CDR1
EMIF02-USB03F22-line IPAD, EMIfilter including ESD protectionU18, U20ESD_FLIP-CHIP-BGA11_1P44X1P94_P050EMIF02-USB03F22
STMPS2141STREnhanced singlechannel power switchesU19MOS_SOT23-5LSTMPS2141STR1
TSV631AILTTSV631AILT  Rail-to-rail input/output, 60 礎, 880 kHz, 5V CMOS  operational amplifiersU21SOT23-5TSV631AILT1
Not Fitted(NX3225GD-8.00M)Crystal 8Mhz, 8pF,-+50PPM, SMDX1CRY_NX3225GD_2PXTAL_8M_NX3225GD1
NX3215SA-32.768KCrystal 32.768kHz,6pF, -+20PPM, R=50K, SMDX2CRY_NX3215SA_2PXTAL_32K_NX3215SA1
NX3225GD-8.00MCrystal 8Mhz, 8pF,-+50PPM, SMDX3CRY_NX3225GD_2PXTAL_8M_NX3225GD1
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-8 15:14:32 | 显示全部楼层
[hide=1,money] MB1297 revD.PcbDoc.rar (2.09 MB, 下载次数: 13) SCH1.rar (249 KB, 下载次数: 11) SCH2.rar (238 KB, 下载次数: 11)
[/hide]
发表于 2019-6-25 17:10:23 | 显示全部楼层
发表于 2019-9-16 09:11:29 | 显示全部楼层
发表于 2019-9-16 09:12:51 | 显示全部楼层
社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
发表于 2019-9-16 09:13:42 | 显示全部楼层
发表于 2019-9-16 09:37:00 | 显示全部楼层
    半小时前
  • 签到天数: 210 天
    社区居民终身成就奖特殊贡献奖
    发表于 2019-9-16 10:09:19 | 显示全部楼层
    VERY GOOD!
    1 小时前
  • 签到天数: 216 天
    发表于 2019-9-18 19:49:31 | 显示全部楼层
    头像被屏蔽
    禁止发言
    发表于 2019-11-16 21:06:40 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
