重要提示:PCB作品文件展下载说明
Comment | Description | Designator | Footprint | LibRef | RB751V-40-TP | DIODE SCHTKY 30MA 30VSOD-323 | D1 | SOD323 | RB751V-40-TP | Green | LED SMARTLED GREEN570NM 0603 | D2 | LED_0603 | LG L29K-G2J1-24-Z | Orange | LED SMARTLED ORANGE606NM 0603 | D3 | LED_0603 | LO L29K-H2K1-24-Z | 220R, 2.5A | FERRITE CHIP 220 OHM2500MA 0603 | FB1, FB2, FB8 | C0603 | BLM18SG221TN1D | BLM18KG101TN1D | FERRITE CHIP 100 OHMBEAD 0603 3A | FB3, FB4, FB6, FB7 | C0603 | BLM18KG101TN1D | BLM15AX601SN1D | FERRITE CHIP 600 OHM0402 420mA | FB5 | C0402 | BLM15AX601SN1D | QSH-030-01-L-D-A | CONN RCPT HI-SPD .5MM60POS DL | J1, J2 | QSH-030-01-L-D-A | QSH-030-01-L-D-A | 4μ7 | INDUCTOR POWER 4.7UH5.5A SMD | L1 | IHLP_255MILX270MIL | IHLP2525CZER4R7M01 | 3u3 | INDUCTOR POWER 3.3UH6A SMD | L2, L4, L5 | IHLP_255MILX270MIL | IHLP2525CZER3R3M01 | VLCF4020T-100MR85 | INDUCTOR POWER 10UH.85A SMD | L3 | VLCF4020 | VLCF4020T-100MR85 | 2N7002BKW,115 | MOSFET N-CH 60V 310MASOT323 | Q1, Q2, Q5, Q8, Q9 | SC70_SOT323 | 2N7002BKW,115 | SI4816BDY-T1-GE3 | MOSFET DL N-CH 30V6.8A 8-SOIC | Q3, Q4, Q6, Q7 | 8_SOIC_3.9MM | SI4816BDY-T1-GE3 | 27k | RES 27.0K OHM 1/16W1% 0402 SMD | R147 | R0402 | RC0402FR-0727KL | MCIMX6Q5EYM10AC | IC MCU 32BIT ARM QUAD624FCBGA | U1 | PBGA624 | MCIMX6Q5EYM10AC | MT41J128M16HA-15E TR | IC DDR3 SDRAM 2GBIT667MHZ 96BGA | U2, U3, U4, U5 | 96_FPGA_DD3 | MT41J128M16HA-15E TR | TPS3808G09DBVRG4 | IC VOLT SUPERVISOR0.9V SOT23-6 | U6 | DBV_SOT_23_6 | TPS3808G09DBVR | SN74AHC1G09DBVR | IC GATE AND SGL 2INPSOT23-5 | U7 | DBV_SOT_23_5 | SN74AHC1G09DBVR | KSZ9021RN | IC TXRX 10/100/1000SGL 48QFN | U8 | QFN48_7MMX7MM | KSZ9021RN | MIC33050-4YHLTR | IC PWM REG 600mA 1.2V12-MLF | U9 | MLF_3X3_12PINS | MIC33050-4YHL TR | SST25VF016B-75-4I-QAF-ND | IC FLASH 16MBIT 75MHZ8WSON | U10 | WSON8_6X5MM | SST25VF016B-75-4I-QAF | ISL6236AIRZ | IC MAIN PWR CTRLRQUAD 32-QFN | U11, U13 | 32_VFQFN_EXPOSED_PAD | ISL6236AIRZ | TPS62175DQCT | IC REG BUCK SYNC ADJ0.5A 10WSON | U12 | DQC_PWSON-N10 | TPS62175DQCT | 24MHz | CRYSTAL 24.0000MHZ18PF SMD | Y1 | ABM7_V1_1 | ABM7-24.000MHZ-D-2-Y-T | 32.768kHz | CRYSTAL 32.768 KHZ9.0 PF SMD | Y2 | ABS06 | ABS06-32.768KHZ-9-1-T | 25MHz | CRYSTAL 25.0000 MHZ18PF SMD | Y3 | ABM7_V1_1 | ABM7-25.000MHZ-D-2-Y-TV1.1 |
重要提示:PCB作品文件展下载说明
