17128| 52
[PADS9.5以下] 新唐NUC972DF62Y 原理图及PCB |
![]() ![]() {Item} {Quantity} {Reference} {Value} {pcb footprint} {Quantity} ______________________________________________ 1 63 CB1,CB2,CB3,CB4,CB5,CB6, 0.1uF C0603 63 CB7,CB8,CB9,CB10,CB11, CB12,CB13,CB14,CB15,CB16, CB17,CB18,CB19,CB20,CB21, CB22,CB23,CB24,CB25,CB26, CB27,CB28,CB29,CB30,CB31, CB32,CB33,CB34,CB35,CB36, CB37,CB38,CB39,CB40,CB41, CB42,CB43,CB44,CB45,CB46, CB47,CB48,CB49,CB50,CB51, CB52,CB55,CB57,CB58,CB59, CB60,CB61,CB62,CB63,CB64, CB65,CB66 2 5 CB53,CB54,C69,C70,C71 N.C. C0603 5 3 1 CON1 HEADER10/2.54mm_M 1 4 1 CON2 SD Card AXA2R63021 1 5 2 CON3,CON7 USB miniAB RECEP. mini_5P_B_TYPE 2 6 2 CON5,CON6 DB9_FEMALE DB9_FMALE 2 7 1 CON8 USB TYPE-A RECAP. USB4P 1 8 2 CON9,CON10 RJ-45 8P8C_LED R/A RJ45\8P\JA\LED 2 9 7 C1,C2,C4,C6,C10,C11,C67 1uF C0603 7 10 28 C3,C17,C18,C19,C20,C21, 10uF C0603 28 C22,C23,C24,C25,C45,C46, C47,C48,C49,C50,C51,C52, C53,C54,C55,C56,C57,C58, C59,C60,C61,C66 11 2 C5,C7 4.7uF C0603 2 12 6 C8,C9,C26,C27,C28,C29 15pF C0603 6 13 1 C12 470pF C0603 1 14 2 C13,C16 102pF C0603 2 15 6 C15,C33,C34,C40,C41,C68 0.01uF C0603 6 16 2 C30,C37 NC C0603 2 17 4 C31,C32,C38,C39 30pF C0603 4 18 4 C35,C36,C42,C43 0.01uF/2KV CK05 4 19 2 D1,D2 RB521S-30 SOD-523 2 20 2 D3,D4 SS24A 403A-03 2 21 7 D5,D6,D7,D8,D9,D10,D11 ESD5311N-21TR DFN1006-2L 7 22 1 JP1 HEADER2/2.54mm 1 23 2 JP4,JP5 HEADER3/2.54mm_M 2 24 1 J1 HEADER17X2/2.54mm_F 1 25 1 J2 HEADER13X2/2.54mm_M 1 26 1 J6 HEADER5/2.54mm_M CONS/5X1/2.54 1 27 3 J7,J10,J11 HEADER2/2.54mm_M 3 28 2 J8,J9 HEADER2/2.54mm_RS485 2 29 1 K1 Exit STS-B5 1 30 1 K2 Right STS-B5 1 31 1 K3 Left STS-B5 1 32 1 K4 Enter STS-B5 1 33 1 K5 Dwn STS-B5 1 34 1 K6 Up STS-B5 1 35 1 LED1 LED_YELLOW/2.54mm DIP/2.54mm 1 36 1 LED2 LED_GREEN/2.54mm DIP/2.54mm 1 37 1 LED3 LED_RED/2.54mm DIP/2.54mm 1 38 1 LED4 SD_Ind LED_0603 1 39 1 LED5 P_Fault LED_0603 1 40 1 LED6 3V3 LED_0603 1 41 7 L1,L6,L7,L9,L10,L13,L14 FB 0603 7 42 3 L3,L4,L5 4.7uH SMTDR43 3 43 2 L11,L12 FB L0603 2 44 2 Q1,Q2 2N3904 SOT-23BEC 2 45 2 Q4,Q6 IS2303 SOT23-GSD 2 46 2 Q5,Q7 IS2304 SOT23-GSD 2 47 1 RP1 47K-8P4R 8P4RA 1 48 2 RP2,RP3 47K-8P4R R8P4R\A 2 49 11 R1,R43,R44,R49,R53,R64, 5.1K R0603 11 R66,R67,R72,R76,R87 50 14 R2,R9,R10,R11,R13,R28, 10K R0603 14 R32,R55,R61,R78,R84,R101, R103,R104 51 7 R3,R4,R5,R50,R54,R73,R77 330 R0603 7 52 4 R6,R8,R25,R38 100K R0603 4 53 11 R7,R12,R14,R45,R68,R102, 0 R0603 11 R106,R107,R108,R109,R110 54 3 R15,R33,R36 1K R0603 3 55 2 R19,R20 27 R0603 2 56 2 R21,R22 12.1K R0603 2 57 2 R23,R24 47K R0603 2 58 1 R26 470K R0603 1 59 1 R27 2.7K R0603 1 60 2 R29,R95 20K R0603 2 61 1 R30 680K R0603 1 62 1 R31 150K R0603 1 63 2 R34,R35 120K R0603 2 64 1 R37 200K R0603 1 65 3 R39,R46,R69 1M R0603 3 66 2 R42,R65 6.19K/1% R0603 2 67 6 R56,R62,R63,R79,R85,R86 NC R0603 6 68 8 R57,R58,R59,R60,R80,R81, 75 R0603 8 R82,R83 69 2 R88,R89 N.C. R0603 2 70 4 R93,R94,R97,R99 4.7 R0603 4 71 2 R96,R98 51K R0603 2 72 1 R100 39K R0603 1 73 1 SW1 Reset STS-B5 1 74 1 SW2 VDD33 2P-1.2mm 1 75 1 SW3 VDD12 2P-1.2mm 1 76 1 SW4 VDD18 2P-1.2mm 1 77 1 U1 W55X16 SOIC8_208 1 78 1 U2 EN25QH256 SOIC16_300 1 79 1 U3 NUC123ZD4AN0 QFN33_5X5 1 80 1 U4 NUC972DF62Y LQFP-216 1 81 1 U5 APL3211A TDFN2x2-8 1 82 3 U6,U7,U8 ZT7103T TSOT-25 3 83 2 U9,U10 IP101GR QFN32 2 84 2 U11,U13 TRS3232EC SOP16/150 2 85 2 U12,U14 SN65HVD10D SOP8/6.0/1.27 2 86 2 U17,U18 TS8121C ST6200T 2 87 2 X1,X3 12MHz TXC7m-3.2x2.5mm 2 88 1 X2 TXC-9H T9 SMD 32.768KHz 30ppm XTAL_2P/1.5mm 1 89 2 X4,X5 25MHz TXC7V-3.2x2.5mm 2
购买主题
本主题需向作者支付 2 枚金币 才能浏览
重要提示:PCB作品文件展下载说明
下载板块默认-5金币,如果会员有销售附件需要扣销售金币+板块5金币,最少要保证你的积分>=100+5+附件销售金额,否则下载不了。 《《《 点击这里展开全文 》》》 | |
请保证积分充足再下载,本板块最少需要105积分以上才能下载,如果附件有销售的需要105+销售积分,否则下载不了。 | |
