查看: 4843|回复: 19
[Pads_VX.2x] 24 位、4 通道模拟数据采集系统的信号调理电路原理图PCB
终身成就奖原创先锋奖特殊贡献奖优秀斑竹奖金点子奖
发表于 2018-11-9 21:50:30 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
项目数量参考编号元件名称制造商说明
11U7AD7192Analog Devices4.8 kHz Ultra-Low Noise 24-BitSigma-Delta ADC with PGA
21U2AD8226Analog DevicesWide Supply Range, Rail-to-RailOutput Instrumentation Amplifier
31U3AD8475Analog DevicesPrecision, Selectable Gain, FullyDifferential Funnel Amp
41U1ADG1409Analog Devices4 Ohm Ron, 4 - /8 - Channel ±15V/+12 V/±5 V iCMOS Multiplexer
51U6ADP1720ARMZ-5Analog Devices50 mA, High Voltage, MicropowerLinear 5V Regulator
61U4ADP3336ARMZAnalog DevicesIC ADP3336 ADJ 500mA LDO ADI
71U5ADR444ARMZAnalog DevicesUltralow Noise, LDO XFET VoltageReference with Current Sink and Source
84B1-4B0805_330_BLM21PG331SN1D_MURATAMURATAB0805 300ohm@100MHz 2ABLM21PG331SN1D MURATA
911C1-2 C6-7 C9 C14-16 C23 C30-31C0603_0.1UF25V_GRM188R71E104KA01D_MURATAMurataC0603 0.1uF 25V GRM188R71E104KA01DMurata
103C5 C11 C13C0603_10N16V_0603YC103KAT2A_AVXAVXC0603 10nF 16V 0603YC103KAT2A AVX
112C3-4C0603_1NF50V_X7R0603HTTD102J_KOAKOAC0603 1nF 50V X7R0603HTTD102J KOA
121C12C0603_1UF16V_C1608X7R1C105K_TDKTDKC0603 1.0uF 16V C1608X7R1C105K TDK
131C26C0603_470P50V_06033A471JAT2A_AVXAVXC0603 470pF 50V 06033A471JAT2A AVX
143C8 C28-29C0805_10UF_10V_GRM21BR61A106KE19L_MURATAMURATAC0805 10uF 10VGRM21BR61A106KE19L  MURATA
155C10 C19-20 C25 C27C0805_1UF25V_ECJ-2VB1E104K_PANASONICPANASONICC0805 1uF 25V ECJ-2VB1E104KPANASONIC
165C17-18 C21-22 C24C1206_10UF_25V_CC1206ZKY5V8BB106_YAGEOYAGEOC1206 10uF 25V YAGEO
173F1-3C3T_CKD510JB1A105ST_TDKTDKCAP 3T C-Type Chip EMIFILCKD510JB1A105ST 10V TDK
181J1CONRA-8P-200CAMDEN8 Way, 5mm Pitch
191J5CON_SDPHiroseSDP Connector
208D4-11DIODE_BAT54S_200MA_30V_DIODESDIODES INCSchottky Diode BAT54S 200mA 30VDIODES INC
211U9IC_24LC32A-I/SN_32KEEPROM_I2C_MICROCHIPMICROCHIPIC EEPROM I2C Bus 32K 24LC32A-I/SNMICROCHIP
221U8IC_74HC1G125GW_NXPNXPIC 74HC1G125GW NXP
234JP1-4JUMPER-3PINMOLEX3Pin 2.54mm 22-03-2031 MOLEX
243PS1-3POLYSW_NANOSMDC035F_TYCOTycoPolyswitch NANOSMDC035F 350mA 30VTYCO
257R16 R19 R21 R23 R25 R27 R34R0603_100K_5%_CRCW0603100KJNEA_VASHAYVASHAYR0603 100K 5% 1/10W  100ppm CRCW0603100KJNEA VASHAY
262R14-15R0603_100_1%_MC0.063_MULITCOMPMULTICOMPR0603 100 1% 0.063W 200ppm  MC 0.063W 0603 MULTICOMP
271R17R0603_210K_1%_ERJ-3EKF2103V_PANASONICPANASONICR0603 210K 1% 1/10W  100ppm ERJ-3EKF2103V PANASONIC
2812R22 R24 R26 R28-33 R35-37R0603_33_1%_CRCW060333R0FKEA_VASHAYVISHAYR0603 33 1% 1/10W  100ppm CRCW060333R0FKEA VISHAY
291R18R0603_64.9K_1%_ERJ-3EKF6492V_PANASONICPANASONICR0603 64.9K 1% 63mW  100ppm ERJ-3EKF6492V  PANASONIC
308R1-8R0805_1.5K_1%_CRCW08051K50FKEA_VISHAYVIshayR0805 1.5K 1% 100mW  100ppm CRCW08051K50FKEA VIshay
312R9-10R0805_4.02K_1%_ERJ-6ENF4021V_PANASONICPANASONICR0805 4.02K 1% 125mW  100ppm ERJ-6ENF4021V PANASONIC
323R12-13 R20RES0603IPC SM-782 STD.SURFACE MOUNT RESISTOR 0.031 X 0.061INCHES, 1/10W
331R11RES0805IPC SM-782 STD.SURFACE MOUNT RESISTOR 0.048 X 0.079INCHES
343D1-3SCHOTTKY_SBR2U30P1-7_2A_DIODESDIODES INCDiode SBR2U30P1-7 Vf:0.5V@2A If:2ADIODES INC
351J3TERMINAL_MC24356_2PIN_5.08_MULTICOMPMULTICOMPTerminal, 5.08mm, 2 Way
361J4TERMINAL_MC24357_3PIN_5.08_MULTICOMPMulticompScrew Terminal MC24357 5.08mm 180(D)Multicomp
3722+15VA +5VA -15VA /SYNC A4V096 AGND D3V3 D5V D6V DGND DIN MISO MUX_A0-1MUX_EN SCL SCLK SDA SPI_SEL VN VOCM VPTP_1Test Point Hole 60*40(mil)
381TVS3TVS_SMBJ10CA_600W_FAIRCHILDFAIRCHILDTVS SMBJ10CA 600W FAIRCHILD
3910TVS1-2 TVS4-11TVS_SMBJ30CA_600W_BOURNSBOURNSTVS SMBJ30CA 600W FAIRCHILD
重要提示:PCB作品文件展下载说明
 楼主| 发表于 2018-11-9 21:52:25 | 显示全部楼层
EVAL-CN0251-SDPZ-PADSSchematics-REVA.sch.rar (43 KB, 下载次数: 9) EVAL-CN0251-SDPZ-PADSLayout-RevA.pcb.rar (257 KB, 下载次数: 5)
发表于 2018-11-9 22:05:42 | 显示全部楼层
 楼主| 发表于 2018-11-10 00:22:28 | 显示全部楼层
  • 签到天数: 6 天
    承接PCB设计
    发表于 2018-11-10 08:23:59 | 显示全部楼层
    2 小时前
  • 签到天数: 269 天
    发表于 2018-11-10 08:54:50 | 显示全部楼层
    5 天前
    发表于 2018-11-10 08:55:15 | 显示全部楼层
    前天 09:48
  • 签到天数: 216 天
    终身成就奖社区居民特殊贡献奖优秀斑竹奖
    发表于 2018-11-10 09:29:54 | 显示全部楼层
    发表于 2018-11-10 10:19:55 | 显示全部楼层
    发表于 2018-11-10 11:17:39 | 显示全部楼层
