重要提示:PCB作品文件展下载说明
Comment | Description | Designator | Footprint | LibRef | Quantity | 0.1uF | | C1, C3, C4, C10, C11, C13, C16, C17,C18, C19, C20, C21, C22, C23, C26, C27, C28, C29, C30, C31, C34 | 0603 | CAP_603 | 21 | 10uF | Multilayer Ceramic | C2, C5 | 1206 | CAP_1206 | 2 | 10pF | | C6, C7 | 0603 | CAP_603 | 2 | 0.01uF | | C8, C9, C15 | 0603 | CAP_603 | 3 | 1uF | Multilayer Ceramic -0805 Size | C12, C14, C33, C36 | 0603 | CAP_603, CAP_805 | 4 | 22pF | | C24, C25 | 0603 | CAP_603 | 2 | 1000pF | | C32, C35 | 0603 | CAP_603 | 2 | SMF6V5A | | D1 | SMAJ6.5A | TVSDIODE | 1 | 5V | Lumex SM LED | D2 | LED_0603 | SM_LED_1206 | 1 | 3.3V | Lumex SM LED | D3 | LED_0603 | SM_LED_1206 | 1 | XMIT | Lumex SM LED | D4 | LED_0603 | SM_LED_1206 | 1 | JTAG | 20 Pin Header | J1 | 10X2X.1 | 20PIN_HEADER | 1 | PJ-102 | CUI STACK barrel-typeDC power jack | J2 | CUI_PJ-102 | CUI_PJ-102 | 1 | DB9M | | J3, J4 | DB9RAM-SPECIAL | DB9 | 2 | DB9F | | J5 | DB9RAF-SPECIAL | DB9 | 1 | CON_3TERM_SCREW | 3 Terminal ScrewConnector | J6 | OST_ED1515 | CON_3TERM_SCREW | 1 | USB-B | USB connector, type B | J7 | USB SOCKET-B | USB-B | 1 | 3POS_JUMPER | 3 Position Jumper _.1" spacing | JP1, JP2 | 3pos_jump | 3POS_JUMPER | 2 | 27.4 | 1/16W 0603 ChipResistor | R1, R2, R3, R4 | 0603 | .0625W_0603 | 4 | 4.7k | 1/16W 0603 ChipResistor | R5 | 0603 | .0625W_0603 | 1 | 9.10k | 1/16W 0603 ChipResistor | R6 | 0603 | .0625W_0603 | 1 | 330 | 1/16W 0603 ChipResistor | R7, R9 | 0603 | .0625W_0603 | 2 | 499 | 1/16W 0603 ChipResistor | R8 | 0603 | .0625W_0603 | 1 | 2K | 1/16W 0603 ChipResistor | R10, R11, R12, R13,R19, R21 | 0603 | .0625W_0603 | 6 | 20 | 1/16W 0603 ChipResistor | R14, R15, R16, R17 | 0603 | .0625W_0603 | 4 | 5.1K | 1/16W 0603 ChipResistor | R18, R20 | 0603 | .0625W_0603 | 2 | 10k | 1/16W 0603 ChipResistor | R22 | 0603 | .0625W_0603 | 1 | PAN_EVQP2 | Panasonic EVQ-PH SMTtact switch | S1 | PAN_EVQP2 | PAN_EVQPH | 1 | | Test Point - Single.025" Pin | TP1, TP2, TP3, TP4,TP5, TP6, TP7, TP8 | test_point2 | TP_.025 | 8 | LM3S3748 | | U1 | LQFP100 | LM3S3748 | 1 | REG104GA-3.3 | LDO voltage regulator | U2 | TXI_DCQ-5 | REG103GA | 1 | REG104GA-5 | LDO voltage regulator | U3 | TXI_DCQ-5 | REG103GA | 1 | TPD2E001DRL | | U4 | 5-SOT(DRL) | TPD2E001DRL | 1 | AMC1210 | Quad Digital Filterfor 2nd Order Delta-Sigma Modulator | U5 | QFN-40(RHA) | AMC1210 | 1 | OPA353 | High-Speed SingleSupply Rail-to-Rail Op Amp | U6 | 5-SOT(DBV) | OPA353 | 1 | ADS1205 | 2-1 Bit Delta-SigmaModulator | U7 | 24-QFN(RGE) | ADS1205 | 1 | OPA1632 | DifferentialAmplifier | U8 | 8-SOP(D) | THS4520 | 1 | 8.00MHz | Crystal | Y1 | NX8045GB | CRYSTAL | 1 | CWX823-032.0M | | Y2 | SG-636OSCILLATOR | OSCILLATOR | 1 |
重要提示:PCB作品文件展下载说明
